Enable TPMS on Vw Fox 2018
Nico_dl
Argentina
C?ID=332831
Hello to everyone! I have a Volkswagen Fox Highline 2018. I want to enable TPMS function. I have enabled "TYRE PREASSURE WARNING, YES" byte on instrument cluster long coding helper with no luck.
I know I have to enable some byte on ABS BRAKES long coding helper, but the probem is that ABS lng coding helper does not shows the description of each byte so I dont know what byte I have to enable. The ABS BRAKES part number is 5U0 907 379 D and component is ESP9.0i front H03 0005
The ABS BRAKES current coding is: F1DC908D212403C68F1B09708452C0400D03
If someone can help me, I will be very thankful.
Nicolas.
Hi and welcome to our forum.
Please post an Auto-Scan so people can see how this car is equipped and configured.
iichel
Netherlands, eastern part
C?ID=284912
Without having seen the full scan, a wild guess, F1DC908D212403C68F1B09708452C0400D04
But it would be good to install TPMS button as well to reset the warning.
Nico_dl
Argentina
C?ID=332831
Hi! I will make a full autoscan so you can see. This model resets the TPMS warning from the instrument cluster options. Does not have any reset button. I ill upload the full autoscan in next minutes!
Nico_dl
Argentina
C?ID=332831
Hi again! I will send you right now the auto full scan: please let me know what you think about it as soon as you can!
Thursday,06,December,2018,13:04:37:45631
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
Workshop Code: 993 01321 000001
VIN: 9BWAB45Z1J4016771   License Plate:
Chassis Type: 5Z-VW21 (5Z - VW Fox (2004 >))
Scan: 01 03 08 09 15 17 19 44 46 56
VIN: 9BWAB45Z1J4016771   Mileage: 1950km-1211miles
Address 01: Engine (J623-CWSA)       Labels: None
   Part No SW: 04E 906 032 AH    HW: 04E 907 425
   Component: 1.6l R4 MPI   H07 3818
   Revision: --H07---
   Coding: 00190012022400000000
   Shop #: WSC 01530 935 00200
   ASAM Dataset: EV_ECM16MPI02104E906032AH 001003
   ROD: EV_ECM16MPI02104E906032AH.rod
   VCID: 669441BD18ECEEC7049-8032
   Part No SW: 5U0 907 379 D    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0005
   Serial number: --------------
   Coding: F1DC908D212403C68F1B09708452C0400D03
   Shop #: WSC 01321 993 00001
   ASAM Dataset: EV_Brake1ESP90iBOSCH 004035
   ROD: EV_Brake1ESP90iBOSCH_004.rod
   VCID: 41DEB2215102E9FFD1B-8014
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 089 A    HW: 7E0 937 089
   Component: BCM PQ25 MMI4 H81 0744
   Revision: BB081001    Serial number: 95007151170291
   Coding: 3AA98BBE4C3BC600113A06C07CCA9E81B180629D60842000240580020800
   VCID: 313EE2E1E122797F21B-8064
   Component: RLS 190117 05  54  0403
   Coding: 06302D
   Subsystem 2 - Part No SW: 5Z0 959 800 D    HW: 5Z0 959 800 D
   Component: ZFH_4T  H09 0022
   Serial number: 3982FL00001707280661
   Coding: 00EB54
   Subsystem 3 - Part No SW: 5Z0 959 800 D    HW: 5Z0 959 800 D
   Coding: 00EB54
   Subsystem 4 - Part No: 5Z0 951 171 E
   Component: DWA-Sensor 00  004 0008
   Subsystem 5 - Part No SW: 18D 959 442     HW: 18D 959 442
   Component: E221__MFL-YLG  H01 0110
   Serial number: 000000000A0232220417
   Coding: 200000
   Subsystem 6 - Part No SW: 5Z0 959 800 D    HW: 5Z0 959 800 D
   Coding: 00EB54
   Subsystem 7 - Part No SW: 5Z0 959 800 D    HW: 5Z0 959 800 D
   Coding: 00EB54
   Part No SW: 5Z0 959 655 C    HW: 5Z0 959 655 C
   Component: VW10AirbagZYH H02 0218
   Revision: --------    Serial number: 003UH300B3C-
   Coding: 000000000000000000000000000000005948
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
   VCID: 49CEAA01693221BF09B-801C
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI1
   Part No SW: 5Z0 920 865 D    HW: 5Z0 920 865 D
   Component: KOMBI         H09 0018
   Coding: 830A03
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04726
   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
   Part No SW: 7E0 909 901     HW: 7E0 937 089
   Component: GW-K-CAN TP20 H81 0744
   Revision: BB081001
   Coding: 002200
   VCID: 68884F851278F8B7365-803C
   Part No SW: 180 909 144 G    HW: 180 909 144
   Component: EPS_ECU       413 4140
   Coding: 004F
   ASAM Dataset: EV_SteerAssisNSKGen2 006110
   ROD: EV_SteerAssisNSKGen2_006_VW21.rod
   VCID: 1B622049932EE32F6B7-804E
Address 56: Radio (J503)       Labels: None
   Part No SW: 6RF 035 187 C    HW: 6RF 035 187 C
   Component: Radio         556 5514
   Revision: --------    Serial number: VWZ7Z2T6125419
   Coding: 0E00045002000E
   VCID: 49CEAA0169B221BF09B-801C
End----(Elapsed Time: 01:45, VBatt start/end: 12.3V/12.3V. VIgn 0.0V)------
Nico_dl
Argentina
C?ID=332831
Hi iichel! Thank you for your answer. Jus to know, i have any risk to try the 04 coding? I Will be waiting for your reply. Thank you!!
Dana
Western PA, USA
You won't know if the ABS module even accepts the coding until you try.
  • If it accepts the coding you do want to make sure there aren't any new fault codes and I would compare both blockmap and the Adp map from before the coding to another set of maps after the experimental coding to see what changed. Maps are explained here: http://www.ross-tech.com/vcds/tour/controller-channels-map.php
For example, if you were to able to confirm Adv measuring value [*IDE04939-IDE02955*] Tire pressure monitoring display - System status changed from Not available due to specific system -to-Available I'd call that a success. However, if that group, in addition to any other groups related to TPMS, do not change I'd make sure to restore the coding to the factory value before driving it.
  • If it rejects the coding entirely any number of things are possible. This ABS module may not support TPMS, the coding may be incorrect or the coding may require additional bits or channels to be enabled simultaneously.
Nico_dl
Argentina
C?ID=332831
Thank you. I will try to enable bit 2 on byte 17 or 16??
If the byte is 16, the bits 0 and 1 are checked. Should I leave them checked?
Nico_dl
Argentina
C?ID=332831
I enabled bit 2 on byte 17 with bit 0 and 1 checked and coding was rejected. Do I have to leave bit 2 checked and the other two unchecked?
Nico_dl
Argentina
C?ID=332831
I have done both things: change coding to 07 and to 04, both coding rejected. Any ideas?
I’m from Argentina, and know that this exact model in brazil has this función enabled.
Can you find a scan from one that has it enabled?
Nico_dl
Argentina
C?ID=332831
Hi! Here in Argentina there is no one who has the scan. I also thought: to enable bit on ABS long coding, do o have to enable some long coding no the CAN GATEWAY?
Oski
Poland
C?ID=266615
Try to activate bit 1 and 2 in byte 16, and then bit 2 in byte 17. It should work. Bit 1 is not desribed but it takes a part in tpms.
Nico_dl
Argentina
C?ID=332831
So, my car has checked
bit 0 and bit 2 on byte 16
bit 0 and bit 1 on byte 17
So, what I have to do is to leave them checked, and also check bit 1 on byte 16 and bit 2 on byte 17??
Oski
Poland
C?ID=266615
What's the hex value of bytr 16?
Nico_dl
Argentina
C?ID=332831
Hex value for byte 16 is 0D, it has bit 0, 2 and 3 Checked. What do you think??
Oski
Poland
C?ID=266615
Ive no idea what is bit 3 for, but just ad h02 value to the byte, so it should be 0F.
Nico_dl
Argentina
C?ID=332831
So byte 16 should be 0F and also check bit 2?? Please confirm me this!
Oski
Poland
C?ID=266615
Don't tick anything, just type 0F and all boxes will change accordingly
