Tuesday,04,December,2018,12:31:07:49058
VCDS Version: 18.2.1.5 (x64)
VIN: WVWZZZAUZGW171796 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F A9
VIN: WVWZZZAUZGW171796 Mileage: 30883km-19189miles
13-Auto Dist. Reg -- Status: Not registered 0011
Address 01: Engine (J623-CHHB) Labels:. 06K-907-425-V1.clb
Part No SW: 5G0 906 259 C HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091900322444050B3000
ROD: EV_ECM20TFS0205G0906259C_VW37.rod
VCID: 2E59383E71A8E73486-807A
17176 - Databus
U1123 00 [039] - Received Error Message
Mileage: 30883 km
Date: 2018.12.04
Time: 11:48:22
Engine speed: 794.75 /min
Normed load value: 6.3 %
Coolant temperature: 95 °C
Intake air temperature: 63 °C
Voltage terminal 30: 14.472 V
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Readiness: 1010 0001
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 62865000002305
Coding: 01FA93A13427296D077E0609C1C9A980C92C94E0608395F71440507AC009
ROD: EV_Brake1UDSContiMK100IPB_034.rod
VCID: 79F3DB62F866F08C63-802C
Revision: 00021000 Serial number: 0384339393
Coding: 030C0C
VCID: 3A71046EBDE03B942A-806E
1052939 - Touch Sensor on Exterior Door Grip; Driver Side
B116B 13 [008] - Open Circuit
Reset counter: 153
Mileage: 30883 km
Date: 2018.12.04
Time: 11:59:01
1057035 - Antenna for Keyless Entry System; Drivers Side
B116F 13 [009] - Open Circuit
Reset counter: 113
Mileage: 30883 km
Date: 2018.12.04
Time: 11:53:34
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00120004200100011005000000101002
VCID: 6AD1F42E8DC04B149A-803E
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061529301293
Coding: 03050A46424122FB0BA44080B11C07281800000000000000000000000000
Shop #: WSC 26194 002 104857
ROD: EV_BCMBOSCH_015.rod
VCID: 0913ABA2A886E00C73-805C
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150909 042 0551
Serial number: 151015030105
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S3Y15M11D04H06M47S03
Coding: 90A8DD
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY152572LEG
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0312
Serial number: 00000000000033714923
18698 - Left LED Module for DRL and Parking Lights
B12EC F2 [009] - Voltage Supply Open or Short to Plus
Reset counter: 113
Mileage: 30883 km
Date: 2018.12.04
Time: 11:48:30
19210 - Right LED Module for DRL and Parking Lights
B12ED F2 [009] - Voltage Supply Open or Short to Plus
Reset counter: 113
Mileage: 30883 km
Date: 2018.12.04
Time: 11:48:30
534549 - Databus
Reset counter: 153
Mileage: 30883 km
Date: 2018.12.04
Time: 11:58:39
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5Q0 919 298 K HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0054
Revision: -------- Serial number: 39431527900356
Coding: 0131161041
ASAM Dataset: EV_EPHVA2CAU3700000 003021
ROD: EV_EPHVA2CAU3700000_003_VW37.rod
VCID: 47976D9AFE12567CA5-8012
1111572 - Side Front Left Parking Aid Sensor
B10F6 14 [009] - Open or Short to Ground
Reset counter: 113
Mileage: 30883 km
Date: 2018.12.04
Time: 11:48:30
1112852 - Side Front Right Parking Aid Sensor
B10FB 14 [009] - Open or Short to Ground
Reset counter: 113
Mileage: 30883 km
Date: 2018.12.04
Time: 11:48:30
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 2B00608159FFC728949C810560400600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
VCID: 3E79087EA1C817B416-806A
0267 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [009] - -
Reset counter: 113
Mileage: 30883 km
Date: 2018.12.04
Time: 11:48:29
Control Module temperature: 61 °C
Voltage terminal 15: 14.3 V
Status_ACC_System: ACC_irreversible error
U1101 00 [009] - Active
Reset counter: 113
Mileage: 30883 km
Date: 2018.12.04
Time: 11:48:29
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 015 0388
Serial number: 003MLR16WRFP
VCID: 7F07357AE642DEBC5D-802A
Belt Pretensioner left:
Component: BeltPretRevFL H37 0350
Serial number: 34169677E11121750984
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H37 0350
Serial number: 34169676E12121750244
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 012 17
Serial number: 35767000000C54D4D823
Subsystem 4 - Part No SW: ----------- HW: 480 002 110 15
Serial number: 358670000001D330171F
Subsystem 5 - Part No SW: ----------- HW: 480 402 310 15
Serial number: 3516502AD1CF1D23A29R
Subsystem 6 - Part No SW: ----------- HW: 480 402 310 15
Serial number: 35265029F1CF1D21928P
Subsystem 7 - Part No SW: ----------- HW: 480 402 310 15
Serial number: 3556502BF1CF1D23D37-
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 15101504220575
Coding: 0400
ASAM Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 0717AD9ABE92967C65-8052
Part No SW: 5G1 920 956 A HW: 5G1 920 956 A
Component: KOMBI 302 6420
Coding: 27AD09102F90260001886A011400000000000000
VCID: 2D5B3F327CAE9C2CBF-8078
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 21101510801740
Coding: 030100043F085900FB00027E080F00010001050000000000000000000000
ROD: EV_GatewConti_013_VW37.rod
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29170002775480027491
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 5897878203
66304 - Databus
U1124 00 [009] - Additional Installations Detected
Reset counter: 113
Mileage: 30883 km
Date: 2018.12.04
Time: 12:25:16
Terminal 15: On
Reset counter: 113
Mileage: 30883 km
Date: 2018.12.04
Time: 11:48:29
Supply voltage: Terminal 30: 14.3 V
Terminal 15: On
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000232735004
Coding: 5500000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 346D2A569F84CDE4F0-8060
Component: TSG FS 020 0041
Serial number: 261117EKO0318A
Coding: 003F0220D001048000001000
VCID: 438F798ACA2A7A5C79-8016
Subsystem 1 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000018070195
Coding: 0D0000
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8303
VCID: 39731B62B8E6308C23-806C
Component: TSG BFS 020 0041
Serial number: 300715BGT18977
Coding: 003F1020DE01048000801000
VCID: 42817C8ED530735472-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000007907197
Coding: 150000
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 029E010009000000
VCID: 40857686DB3C614464-8014
5275220 - Headlight
Reset counter: 113
Mileage: 30883 km
Date: 2018.12.04
Time: 12:20:45
13679104 - Local Data Bus
U10BA 00 [137] - No Communication
Reset counter: 113
Mileage: 30883 km
Date: 2018.12.04
Time: 12:20:45
Part No SW: 3Q0 035 874 A HW: 3Q0 035 874 A
Component: MU-S-ND-ER 820 0627
Coding: 02730001FF00000051111101008808001F0203D601200100CF
ROD: EV_MUStd4CDELP_VW27.rod
VCID: 306526466B9CF1C494-8064
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H43 4064
Serial number: VWZ6Z9R2920964
Subsystem 2 - Part No SW: 3G0 919 866 H HW: -----------
Component: ECE 2015/16 --- 0430
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 150918201707
VCID: 6BDFF12A823A521CE1-803E
End-------------------------(Elapsed Time: 04:39)--------------------------
