- Apr 17, 2015
- 275
- 86
- South Africa
- C?ID=133909
Managed to reset oil service but no functions available for inspection service reset.
Wednesday,05,December,2018,07:36:15:48706
VCDS Version: 18.9.0.2 (x64) HEX-NET CB: 0.4436.4
Dealer/Shop Name: RyMar Auto
Workshop Code: 000 00000 001753
VIN: AAVZZZ6RZFU061750 License Plate: DN54YPGP
Mileage: 62567km Repair Order:
Chassis Type: 6R-VW25 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
Address 01: Engine (J623-CJZD) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 BC HW: 04E 907 309 AF
Component: 1.2l R4 TSI H21 8229
Revision: R4H21---
Coding: 01190012230418010000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12TFS01104E906027BC 001006
ROD: EV_ECM12TFS01104E906027BC.rod
VCID: 6680537599D98F7A4F-8032
CAN Converter 01:
5453 - Starter Relay
P3088 00 [096] - Electrical Malfunction
14633 - ROD - Unknown Error Code
- 00 [032]
Mileage: 62468 km
Date: 2018.11.30
Time: 08:20:15
Coolant temperature: 78 °C
Intake air temperature: 41 °C
Ambient air pressure: 940 mbar
Voltage terminal 30: 11.426 V
Unlearning counter according OBD: 35
Mass flow through throttle valve: 0.0 kg/h
Median injection timing: 0.000 ms
14643 - Coolant Pump for Intercooler
P16BA 00 [032] - Running Dry
Readiness: 0000 0001
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 G HW: 6R0 907 379 BA
Component: ESP9.0i H03 0003
Serial number: 08500933141209
Coding: 23DD48854A2933C1091B006E0051C41252CC90000005C9098700
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
VCID: 3326FA219A8B2AD218-8066
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 A HW: 6C0 820 045 A
Component: AC Manuell H02 0108
Serial number: 1412041B-0138
Coding: 200000010000100000
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 1D723C990C0F8CA2DE-8048
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 B HW: 6C0 937 089
Component: BCM PQ26 Hi4R H07 0065
Serial number: 001098019551
Coding: 0300084040530A7B4B844080A12703800000580053010000000000000000
ASAM Dataset: EV_BCMA0 004008
ROD: EV_MQBA0.rod
VCID: 2F2EF65176A30E327C-807A
Subsystem 1 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S2Y14M11D26H23M11S27
Coding: 0178DD
Drivers Door Control Module:
Subsystem 2 - Part No SW: 6R0 959 802 AT HW: 6R0 959 802 AT Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU019111443238971
Coding: 1000A0
Subsystem 3 - Part No SW: 6R0 959 801 BB HW: 6R0 959 801 BB Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU020111443243291
Coding: 0000A0
Subsystem 4 - Part No SW: 6C0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY143140888
Subsystem 5 - Part No SW: 6R0 959 812 N HW: 6R0 959 812 N
Component: J389__TSG_HR 003 8611
Serial number: KU0KU012111443168780
Coding: 1000A0
Subsystem 6 - Part No SW: 6R0 959 811 N HW: 6R0 959 811 N
Component: J388__TSG_HL 003 8611
Serial number: KU0KU017111443214647
Coding: 0000A0
131330 - Supply voltage
[Versorgungsspannung - unterer Grenzwert unterschritten >]
Fault Frequency: 8
Reset counter: 209
Mileage: 59467 km
Date: 2018.08.19
Time: 20:04:55
131586 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten >]
Fault Frequency: 19
Reset counter: 209
Mileage: 60762 km
Date: 2018.09.30
Time: 19:14:02
206604 - Locking Unit for Central Locking; Passenger Side
B1680 29 [009] - Signal Implausible
Reset counter: 37
Mileage: 31194 km
Date: 2017.01.03
Time: 19:42:05
227080 - Turn Signal Switch
B1144 29 [008] - Signal Implausible
Mileage: 53844 km
Date: 2018.04.18
Time: 18:17:55
791048 - Limit Switch for Windshield Wiper
B12D6 29 [009] - Signal Implausible
Mileage: 41258 km
Date: 2017.08.11
Time: 23:52:13
934148 - No Communications with Rain/Light Sensor
U10F6 00 [008] - -
[Sensor für Regen- und Lichterkennung->kein Signal/ Kommunikation]
Reset counter: 107
Mileage: 59467 km
Date: 2018.08.19
Time: 20:07:29
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 A HW: 6C0 959 655 A
Component: VW20Airbag015 001 0330
Revision: -------- Serial number: 003LM006XET%
Coding: 88C0C00000000000000000CA008800000000
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 312AF029609718C26A-8064
Subsystem 1 - Part No SW: ----------- HW: 410 820 911 14
Component: SideSensor_Df 151 0800
Serial number: 3575H009F16CCCB2A277
Subsystem 2 - Part No SW: ----------- HW: 410 821 011 14
Component: SideSensor_Pf 151 0800
Serial number: 3585H009F16CCCB210A0
Subsystem 3 - Part No SW: ----------- HW: 442 151 711 14
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A001A283FF69E6E0
Subsystem 4 - Part No SW: ----------- HW: 442 153 010 14
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00BB1751121A360
Address 17: Instruments (J285) Labels:. 5G0-920-XXX-17.clb
Part No SW: 6C0 920 740 A HW: 6C0 920 740 A
Component: KOMBI 211 0290
Coding: 232409002180000800082A001000000000000000
ROD: N/A
VCID: 200C056D3B7DA14AF5-8074
No ASAM data for: "EV_DashBoardVDDMQBAB" (VW25)
Address 19: CAN Gateway (J533) Labels:. 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 HW: 6C0 937 089
Component: GW MQB A0 H07 0065
Revision: -------- Serial number: 001098019551
Coding: 01010008300A560071000000000000000001010000000000000000000000
ASAM Dataset: EV_GatewA0Lear 001001
ROD: N/A
VCID: 6582547964DF846246-8030
Subsystem 1 - Part No SW: 6C0 959 442 HW: 6C0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H03 0015
Serial number: 1411416201201369AB1B
Coding: 240000
No ASAM data for: "EV_GatewA0Lear" (VW25)
131702 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 209
Mileage: 60762 km
Date: 2018.10.03
Time: 16:01:44
197175 - ROD - Unknown Error Code
- 00 [009]
Reset counter: 207
Mileage: 8818 km
Date: 2015.09.17
Time: 20:00:30
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C2 909 144 M HW: 6C2 909 144 D
Component: EPS_TRW_ALow 322 3211
Serial number: CEBI0049
Coding: 0007
ASAM Dataset: EV_SteerAssisUDSTRW 011021
ROD: EV_SteerAssisUDSTRW_011.rod
Part No SW: 3Q0 035 819 HW: 3Q0 035 819
Component: MU-S--ER H11 0135
Serial number: VWZAZ2P4638582
Coding: 02620000BE00000011110001000918001F0100860120010001
ASAM Dataset: EV_MUStd4CTSAT 001018
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: 6E902B55B129473A37-803A
Subsystem 1 - Part No SW: 6C0 919 603 HW: 6C0 919 603
Component: ABTm_Std2 H43 1017
Serial number: VWZ8Z9PH001KL7
1537 - Supply voltage
[Supply voltage - lower limit value not reached]
Reset counter: 120
Mileage: 59467 km
Date: 2018.08.19
Time: 20:05:16
Voltage terminal 30: 9.1 V
0002 - Antenna 1 for Radio
B1119 11 [008] - Short to Ground
Fault Frequency: 32
Reset counter: 95
Mileage: 62168 km
Date: 2018.11.20
Time: 13:18:44
Voltage terminal 30: 13.5 V
Status of antenna 1 for radio-Antenna current: 0 mA
Status of antenna 1 for radio-Connection between radio and antenna amplifier: Electrical OK
Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Electrical OK
Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
End----(Elapsed Time: 00:58, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
