Results 1 to 4 of 4
Thread: 6R Polo Cross service ESI not reset
    Apr 2015
    South Africa
    Managed to reset oil service but no functions available for inspection service reset.
    Wednesday,05,December,2018,07:36:15:48706
    VCDS Version: 18.9.0.2 (x64)  HEX-NET CB: 0.4436.4
    Dealer/Shop Name: RyMar Auto
    Workshop Code: 000 00000 001753
    VIN: AAVZZZ6RZFU061750   License Plate: DN54YPGP
    Mileage: 62567km   Repair Order:
    Chassis Type: 6R-VW25 (6C0)
    Scan: 01 03 08 09 15 17 19 44 5F
    Address 01: Engine (J623-CJZD)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 027 BC    HW: 04E 907 309 AF
       Component: 1.2l R4 TSI   H21 8229
       Revision: R4H21---
       Coding: 01190012230418010000
       Shop #: WSC 31414 790 50316
       ASAM Dataset: EV_ECM12TFS01104E906027BC 001006
       ROD: EV_ECM12TFS01104E906027BC.rod
       VCID: 6680537599D98F7A4F-8032
       CAN Converter 01:
    5453 - Starter Relay
              P3088 00 [096] - Electrical Malfunction
    14633 - ROD - Unknown Error Code
              - 00 [032]
                        Mileage: 62468 km
                        Date: 2018.11.30
                        Time: 08:20:15
                        Coolant temperature: 78 °C
                        Intake air temperature: 41 °C
                        Ambient air pressure: 940 mbar
                        Voltage terminal 30: 11.426 V
                        Mass flow through throttle valve: 0.0 kg/h
    14643 - Coolant Pump for Intercooler
              P16BA 00 [032] - Running Dry
    Readiness: 0000 0001
       Part No SW: 6C0 907 379 G    HW: 6R0 907 379 BA
       Component: ESP9.0i       H03 0003
       Serial number: 08500933141209
       Coding: 23DD48854A2933C1091B006E0051C41252CC90000005C9098700
       ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
       VCID: 3326FA219A8B2AD218-8066
    Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
       Part No SW: 6C0 820 045 A    HW: 6C0 820 045 A
       Component: AC Manuell    H02 0108
       Serial number:  1412041B-0138
       Coding: 200000010000100000
       ROD: EV_ACManueKMMValeoPQ26.rod
       VCID: 1D723C990C0F8CA2DE-8048
    Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
       Part No SW: 6C0 937 089 B    HW: 6C0 937 089
       Component: BCM PQ26 Hi4R H07 0065
       Serial number: 001098019551
       Coding: 0300084040530A7B4B844080A12703800000580053010000000000000000
       ASAM Dataset: EV_BCMA0 004008
       ROD: EV_MQBA0.rod
       VCID: 2F2EF65176A30E327C-807A
       Subsystem 1 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
       Component: RLS  037 0059
       Serial number: S2Y14M11D26H23M11S27
       Coding: 0178DD
       Drivers Door Control Module:
       Subsystem 2 - Part No SW: 6R0 959 802 AT    HW: 6R0 959 802 AT  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  003 8612
       Serial number: KU0KU019111443238971
       Coding: 1000A0
       Subsystem 3 - Part No SW: 6R0 959 801 BB    HW: 6R0 959 801 BB  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  003 8612
       Serial number: KU0KU020111443243291
       Coding: 0000A0
       Subsystem 4 - Part No SW: 6C0 951 171     HW: 5Q0 951 171
       Serial number: 000000000ZY143140888
       Subsystem 5 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
       Component: J389__TSG_HR  003 8611
       Serial number: KU0KU012111443168780
       Coding: 1000A0
       Subsystem 6 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
       Component: J388__TSG_HL  003 8611
       Serial number: KU0KU017111443214647
       Coding: 0000A0
    6 Faults Found:
    131330 - Supply voltage
              [Versorgungsspannung - unterer Grenzwert unterschritten >]
                        Reset counter: 209
                        Mileage: 59467 km
                        Date: 2018.08.19
                        Time: 20:04:55
    131586 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
              [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten >]
                        Fault Frequency: 19
                        Reset counter: 209
                        Mileage: 60762 km
                        Date: 2018.09.30
                        Time: 19:14:02
    206604 - Locking Unit for Central Locking; Passenger Side
              B1680 29 [009] - Signal Implausible
                        Reset counter: 37
                        Mileage: 31194 km
                        Date: 2017.01.03
                        Time: 19:42:05
    227080 - Turn Signal Switch
              B1144 29 [008] - Signal Implausible
                        Mileage: 53844 km
                        Date: 2018.04.18
                        Time: 18:17:55
    791048 - Limit Switch for Windshield Wiper
              B12D6 29 [009] - Signal Implausible
                        Mileage: 41258 km
                        Date: 2017.08.11
                        Time: 23:52:13
    934148 - No Communications with Rain/Light Sensor
              U10F6 00 [008] - -
              [Sensor für Regen- und Lichterkennung->kein Signal/ Kommunikation]
                        Reset counter: 107
                        Mileage: 59467 km
                        Date: 2018.08.19
                        Time: 20:07:29
    Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
       Part No SW: 6C0 959 655 A    HW: 6C0 959 655 A
       Component: VW20Airbag015 001 0330
       Revision: --------    Serial number: 003LM006XET%
       Coding: 88C0C00000000000000000CA008800000000
       ROD: EV_AirbaVW20BPAVW26X.rod
       VCID: 312AF029609718C26A-8064
       Subsystem 1 - Part No SW: -----------    HW: 410 820 911 14
       Component: SideSensor_Df  151 0800
       Serial number: 3575H009F16CCCB2A277
       Subsystem 2 - Part No SW: -----------    HW: 410 821 011 14
       Component: SideSensor_Pf  151 0800
       Serial number: 3585H009F16CCCB210A0
       Subsystem 3 - Part No SW: -----------    HW: 442 151 711 14
       Component: SideSensor_Dr  1CA 0148
       Serial number: 3517A001A283FF69E6E0
       Subsystem 4 - Part No SW: -----------    HW: 442 153 010 14
       Component: SideSensor_Pr  1CA 0148
       Serial number: 3527A00BB1751121A360
    Address 17: Instruments (J285)       Labels:. 5G0-920-XXX-17.clb
       Part No SW: 6C0 920 740 A    HW: 6C0 920 740 A
       Component: KOMBI         211 0290
       Coding: 232409002180000800082A001000000000000000
       ROD: N/A
       VCID: 200C056D3B7DA14AF5-8074
    No ASAM data for: "EV_DashBoardVDDMQBAB" (VW25)
    Address 19: CAN Gateway (J533)       Labels:. 6C0-909-901-V1.clb
       Part No SW: 6C0 909 901     HW: 6C0 937 089
       Component: GW MQB A0     H07 0065
       Revision: --------    Serial number: 001098019551
       Coding: 01010008300A560071000000000000000001010000000000000000000000
       ASAM Dataset: EV_GatewA0Lear 001001
       ROD: N/A
       VCID: 6582547964DF846246-8030
       Subsystem 1 - Part No SW: 6C0 959 442     HW: 6C0 959 442   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAT  H03 0015
       Serial number: 1411416201201369AB1B
       Coding: 240000
    No ASAM data for: "EV_GatewA0Lear" (VW25)
    131702 - ROD - Unknown Error Code
              - 00 [008]
                        Reset counter: 209
                        Mileage: 60762 km
                        Date: 2018.10.03
                        Time: 16:01:44
    197175 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 207
                        Mileage: 8818 km
                        Date: 2015.09.17
                        Time: 20:00:30
       Part No SW: 6C2 909 144 M    HW: 6C2 909 144 D
       Component: EPS_TRW_ALow  322 3211
       Serial number: CEBI0049
       Coding: 0007
       ASAM Dataset: EV_SteerAssisUDSTRW 011021
       ROD: EV_SteerAssisUDSTRW_011.rod
       Part No SW: 3Q0 035 819     HW: 3Q0 035 819
       Component: MU-S--ER      H11 0135
       Serial number: VWZAZ2P4638582
       Coding: 02620000BE00000011110001000918001F0100860120010001
       ASAM Dataset: EV_MUStd4CTSAT 001018
       ROD: EV_MUStd4CTSAT_VW36.rod
       VCID: 6E902B55B129473A37-803A
       Subsystem 1 - Part No SW: 6C0 919 603     HW: 6C0 919 603
       Component: ABTm_Std2  H43 1017
       Serial number: VWZ8Z9PH001KL7
    1537 - Supply voltage
              [Supply voltage - lower limit value not reached]
                        Reset counter: 120
                        Mileage: 59467 km
                        Date: 2018.08.19
                        Time: 20:05:16
                        Voltage terminal 30: 9.1 V
    0002 - Antenna 1 for Radio
              B1119 11 [008] - Short to Ground
                        Fault Frequency: 32
                        Reset counter: 95
                        Mileage: 62168 km
                        Date: 2018.11.20
                        Time: 13:18:44
                        Voltage terminal 30: 13.5 V
                        Status of antenna 1 for radio-Antenna current: 0 mA
                        Status of antenna 1 for radio-Connection between radio and antenna amplifier: Electrical OK
                        Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Electrical OK
                        Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
    End----(Elapsed Time: 00:58, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
    Aug 2016
    The Hague, NL
    Could you post an adapmap of 17? (see below)
    Are you on longlife/extended service interval for 30.000km?
    Apr 2015
    South Africa
    Oil Service intervals every 15000km or yearly. Service intervals 30 000km or yearly. (Fixed).
    Does not want to download! 09 Central Electrics it downloads (140kb data) for example, not for 17 (1kb data). When it downloads it converts it directly to Excell, When I save my normal log files they are automatically captured as Text message.
    Text message I copy & paste but the Excell log does not want to do it.
    See if 18.9.0.4 (now available from our download page) will solve your chassis identification issue. I'm not surprised you can't reset the SRI with no UDS data for the cluster (known issue with 18.9.0.2 and ZA Polotariat)
  5. Likes Uwe liked this post
