Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 36 3C 42 44 47 4B 52
5F A5 D6 D7
VIN: WVWZZZAUZJW285135 Mileage: 515km-320miles
Address 01: Engine (J623-DCYA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 RJ HW: 04L 907 309 R
Component: R4 2.0l TDI H24 4381
Revision: B5H24---
Coding: 01250032046405083000
ASAM Dataset: EV_ECM20TDI01104L906026RJ 004001
ROD: EV_ECM20TDI01104L906026RH.rod
VCID: 035373D86B9E9ECF837-8056
Part No SW: 0GC 300 042 G HW: 0GC 927 711 G
Component: GSG DQ381 H06 1404
Revision: 00H06V07
ROD: EV_TCMDQ381061.rod
VCID: 2A0DFE7CAC74AF87E01-807E
Part No SW: 5Q0 614 517 CR HW: 5Q0 614 517 AD
Component: ESC H25 0523
Revision: 00000000 Serial number: 61598000001649
Coding: 01FA8AA1242809714778060360C82980512490E26006947338625038C2A2430B00000012121212B835351919323200
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0482371069
Coding: 032C0C
ASAM Dataset: EV_KessyHellaMQBAB 002020
VCID: 3C21C82456E0213782D-8068
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 0012011420010000110500001210142A
VCID: 6D8735605D1A78BF453-8038
Air quality sensor:
Part No SW: 5Q0 937 084 CP HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H36 0253
Serial number: 8114012401ÿÿÿÿ
ROD: EV_BCMBOSCH_018.rod
VCID: 084964F452B8BD97D65-805C
Component: WWS 180306 042 0551
Serial number: 180312055033
Component: RLHS 052 0107
Serial number: SBY18M06D11H17M12S14
Coding: 00A8DD
Sun Roof:
Subsystem 3 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H04 0005
Serial number: 0000FST0022YL5S00000
Coding: 181901
Part No SW: 5QA 919 298 F HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0453
Serial number: 000308417618151
Coding: 0371167851
VCID: 53F38398DB7ECE4F737-8006
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 330067C15DFFC728949C810580400600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
VCID: 3E25C22C40FC3327AC9-806A
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 006 0339
Serial number: 003VWR48VE2N
Coding: 98CCC000000000005C000000008800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 094F61F049B2C49FC9B-805C
Belt Pretensioner left:
Serial number: 34169677E06061820794
Coding: 333135
Belt Pretensioner right:
Serial number: 34169676E06061830889
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 000 706 18
Serial number: 35700000000A61A07E2M
Subsystem 4 - Part No SW: ----------- HW: 480 000 706 18
Serial number: 35800000000E609C0E2U
Subsystem 5 - Part No SW: ----------- HW: 480 400 406 18
Component: SideSensor_Dr 003 6149
Serial number: 3510001A929F25E2E31A
Subsystem 6 - Part No SW: ----------- HW: 480 401 206 18
Component: SideSensor_Pr 003 6149
Serial number: 3520001AB29F25E4A72G
Subsystem 7 - Part No SW: ----------- HW: 480 400 506 18
Component: FrontSensor_D 004 6149
Serial number: 3550001162AEB0E2C58D
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Revision: -------- Serial number: 01061804400952
Coding: 0C10
ROD: EV_SMLSKLOMQB_VW37.rod
Part No SW: 5G1 920 791 A HW: 5G1 920 791 A
Component: KOMBI 409 3197
Coding: 27A401186F88000801886B0B5401000080000000
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 436 4326
Revision: -------- Serial number: 0008050927
Coding: 030100345F086800FB00025C1C0F00010001070000000000000000000000
ASAM Dataset: EV_GatewNF 013044
ROD: EV_GatewNF_VW37.rod
VCID: 3829D43462D80D17665-806C
Serial number: 39180000897230038206
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 6684538004
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 18000185865009
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3431E0047EB0E9774AD-8060
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 C HW: 5Q0 959 760 C
Component: Sitzmemory H09 0024
Serial number: Y0006RF524740
Coding: 0014000000000500018280808080000000008181000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002022
VCID: 3D27C5204DFA283FB53-8068
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0482545805
Coding: 02011203
ROD: EV_HREntryHella_VW37.rod
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0482812418
Coding: 020112
Component: TSG FS 020 0041
Serial number: 250518EEO19061
Coding: 003B1320D201048000001000
VCID: 43D3B3D82B1E5ECFC37-8016
Subsystem 1 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000021931014
Coding: 0D0000
Part No SW: 5Q0 909 144 AA HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 131 1081
Coding: 93170000
ROD: EV_SteerAssisMQB_015.rod
VCID: 73B323183B3EAE4F937-8026
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1JMD02FQ9X
Coding: 12000000008AAA8A000000000000
ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
ROD: EV_AMPMst11CGen2ALPI.rod
VCID: 2E05F26C909CC3A73C9-807A
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 28051810520665
Coding: 000000070100164E00000101020000000000000000000000000000000000
VCID: 72BD261C4424A747981-8026
Component: TSG BFS 020 0041
Serial number: 230418EDM08014
Coding: 003B1120DE01048000801000
VCID: 42DDB6DC340457C7C81-8016
Subsystem 1 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000021903930
Coding: 150000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 5NA 035 045 B HW: 5NA 035 045
Component: MU-H-N-RW H54 1161
Serial number: A849F0JS026848
Coding: 027310080000000051510002000808001F0100F601200402DF
VCID: 372BD7086FC6026F6FF-8062
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H52 9130
Serial number: VWZ6ZJV1625672
Subsystem 2 - Part No SW: V03 959 801 ED HW: -----------
Component: ROW 2017/2018 --- 0065
Component: Gracenote2 --- 4012
1637 - Interface for External Media
U11B8 00 [008] - No Communications
[USB - communication error]
Reset counter: 45
Mileage: 119 km
Date: 2018.12.01
Time: 11:37:57
Voltage terminal 30: 15.0 V
Interface for external media: status-Status: Open circuit
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H09 0272
Serial number: 02051812K11430
Coding: 000307000000010100022354C150A90088000E200020
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AD HW: 7P5 941 591 A
Component: LED1L H06 0005
ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
VCID: 7EA5022C007CF327EC9-802A
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H06 0005
ROD: EV_LED_PLUS_R_KEBODAVW416_VW37.rod
End----------(Elapsed Time: 01:53, VBatt start/end: 12.2V/12.2V)-----------
