- Joined
- Jan 12, 2015
- Messages
- 185
- Reaction score
- 15
- Location
- Singapore
- VCDS Serial number
- C?ID=232348
Hi guys,
I'm having another issue s with My GTD Mk5 Golf. The car wont turn on at first key turn , feels like low battery start (full charge).
Second crank last bit longer but it turns on after 5 seconds. This behavior is constant regardless weather or not car is hot or cold.
Car has power and drives with no loss of mpg. I have replaced starter motor and G28 sensor. Both new.
Below from my scan you can see the G28 sensor error keeps repeating and it can not be cleared. After replacing G28, does timing on V belt have to be adjusted or something similar on VCDS.?
Can someone please advise on what it possibly could be . I really don;t want to replace this again on BMN engine as its extremely difficult exercise for the 3rd time.
Also could someone explain priority and frequency of this.
Thanks in advance, help greatly appreciated.
Al
Al
Tuesday,04,December,2018,21:10:54:41771
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VMWare)
VCDS Version 18.9.0.2
Chassis Type: 1K (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: WVWZZZ1KZ8U002011 Mileage: 187480km-116494miles
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 FC HW: 03G 906 018 FC
Component: R4 2.0l PPD1.2 G 1155
Revision: --H42--- Serial number: VWX7Z0G43NO1FZ
Coding: 0000078
Shop #: WSC 00046 412 00000
VCID: 6BD5F48C4A26DB1210-803F
000801 - Engine Speed Sensor (G28)
P0321 - 006 - Implausible Signal - Intermittent
Fault Frequency: 61
Reset counter: 39
Mileage: 187434 km
Time: 13:55:26
RPM: 64 /min
Torque: 0.0 Nm
Time: 0.02 s
Angle: 0.0 °
Bin. Bits: 00000000
Bin. Bits: 00000001
Readiness: N/A
Part No SW: 02E 300 044 L HW: 02E 927 770 AE
Component: GSG DSG 081 1403
Revision: 04608010 Serial number: 00000704301340
Shop #: WSC 44551 111 44551
VCID: 1E33ED58C914FEBAC7-804B
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0023170
VCID: 73E5ECEC121603D2D8-8027
Part No SW: 1K0 907 044 BR HW: 1K0 907 044 BR
Component: ClimatronicPQ35 120 1111
Revision: 00120021 Serial number: 00000000000000
VCID: 78FFDBC00B70608AED-802D
Revision: 00H54000 Serial number: 00000007980938
Coding: E5890F2700041500471400001400000000087F075C000100000000000000
VCID: 71E9E6E4680A31C22A-8025
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 140707 020 0501
Coding: 00049109
Shop #: WSC 00046
Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
Component: RLS 310806 020 0105
Coding: 00208933
Shop #: WSC 00046
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 1P AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD19R1ST
Coding: 0012624
VCID: 3D710AD464D285A2FE-8069
Subsystem 1 - Serial number: 6332MSME173C6109A
Subsystem 2 - Serial number: 6342MSME1A251E29G
Subsystem 3 - Serial number: 6352QSME265C3269M
Subsystem 4 - Serial number: 6362QSME274E403BN
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 636 0070
Coding: 0012122
VCID: 0109B62458AA2142DA-8055
Component: E0221 002 0010
Part No SW: 1K0 920 874 B HW: 1K0 920 874 B
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0G43NO1FZ
Coding: 0003103
VCID: 2C5737908FA81C2A59-8079
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 240314F1005704
Coding: 350003
VCID: 356112F49CE25DE236-8061
Component: IMMO VDD 1216
Part No SW: 1K0 959 701 N HW: 1K0 959 701 N
Component: Tuer-SG 006 120B
Coding: 0000692
VCID: 39791EC470FAB982D2-806D
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
VCID: 366315F841E456FA3F-8063
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 809002005103087F2D0484056008DF0380FC00
VCID: 0305BC2C42B63352C8-8057
Part No SW: 1K0 959 702 N HW: 1K0 959 702 N
Component: Tuer-SG 005 090B
Coding: 0000948
VCID: 3A7B01C875FCB29ADB-806F
Part No SW: 56D 035 190 A HW: 56D 035 190 A
Component: RCD510USBRVC 001 0003
Revision: -----001 Serial number: VWZ4Z3M8175927
Coding: 01000424040000
Shop #: WSC 00078 790 00230
VCID: 224BD9A83D6CDA5AE3-8077
Reset counter: 131
Mileage: 182346 km
Time: 00:20:00
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1201
Coding: 0000144
Shop #: WSC 00046 412 1012544
VCID: 387F1BC04BF0A08A2D-806D
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 22 Einparkhilfe 0101
VCID: 2D513A94B4B215224E-8079
End-------------------------(Elapsed Time: 02:51)--------------------------
