Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 49
Thread: New Beetle 2003 ECU No communication. All other modules OK
  1. #31
    Verified VCDS User LucaDN's Avatar
    Dec 2018
    If the J363 relay has a bad diode it could.............or harness corrosion bridge/backfeed!
    Thank you Jack, I was beginning to think I checked the wrong relay! Must be something like that
  2. #32
    Still.........I want to know the status of terminal 30 at the J363 from J59 X?
  3. #33
    Dec 2018
    I will do that as well, no problem!
  4. #34
  5. Likes LucaDN liked this post
  6. #35
    Dec 2018
    Hold your popcorn, I could not find the time to run all the tests today
    I will complete them tomorrow morning.
    I was able to test the T121 harness (ECU disconnected) and partially the J363 relay:
    Readings on T121 harness all pins have been probed.
    • With ignition OFF, ECU disconnected: 0V on all pins
    • With ignition ON, ECU disconnected: (0V if not listed)
    PIN# Voltage Connection
    3 0 87 of J363 relay
    9 12 Speed signal from dash panel
    17 12 K-Line
    23 12 86A of J363 relay
    29 1.8 T10/4 connector in plenum chamber (and then?)
    39 2.7 CAN-H
    40 2.4 CAN-L
    62 12 Positive in engine compartment
    63 12 Cruise / Brake pedal
    65 12 Clutch pedal
    80 11 491 (Fuel shut off)
    J363 Relay seems OK. Coil 150 Ohm, Diode OK, Click test OK.
    Continuity check for wire connecting Relay J363/87 to T121/3 is OK (which makes me think the relay is faulty after all, as I see 0V on the harness. We'll see)
    I am puzzled, honestly. I need to think it over, but I'll do that after I complete all tests tomorrow.
  7. #36
    Just remember the J59 terminal X relay feeds the J363 and provides that terminal 30 to terminal 87 & that you state is currently DEAD!............
    Do you have power to terminal 30 at J363?
    NostraJackASS Has Spoken!
  8. Likes Uwe, LucaDN, rhinopower liked this post
  9. #37
    Dec 2018
    I know, Jack, I know. I just couldn't get to do that!
  10. #38
    Takes a minute!
  11. Likes LucaDN liked this post
  12. #39
    Dec 2018
    I checked right now. Ignition ON, no power at terminal 30.
    But you knew that already, Jack, didn't you?
    Sorry it took so long.
    Now I need to find where the problem is, from terminal 30 to Fuse 10 (which I tested and has 12V).
    Thanks thanks thanks, we are getting close
    P.S.
    It doesn't help to be on a UK model, where some components are on the opposite side with respect to the factory manual. ECU is on the left, as usual, but Fuse box is on the right. Chasing down T6 connector (Pin4 connects terminal 30 to Fuse10) first thing.
  13. Likes Uwe liked this post
  14. #40
    Dec 2018
    And before you yell at me, Jack ....
    X contact, I know!!!!
