Results 1 to 10 of 13
Thread: VW Polo AW AID Retro Fit Question
    Oct 2014
    Does anyone know if its even possible to retro fit Active Info Display???????
    Scans are here......
    https://forums.ross-tech.com/showthr...SI-115-SEL-DSG
    Any info would be fantastic.
    cheers
    Scott
    Jun 2014
    Quote Originally Posted by golfman View Post
    cheers
    Scott
    for suitable model - yes
    Oct 2014
    Hi Spacewalker can you please point me in the right direction to have this done or any info that can help?
    regards
    scott
    Oct 2014
    If i were to buy a new Virtual Dash do you think that the dealers would be able to code this for me and adapt the keys with me also supplying the MOST cable to show the nav in the Virtual Dash?
    can anyone help?
    scott
    Võru, Estonia
    can anyone help?
    scott
    Adapt immobiliser and keys - Yes
    Make coding and adaption work - If dealer tech isn't VW enthusiast, HARDLY.
    You must also verify that Your MIB supports AID.
    The world is my oyster...
  6. Likes Spacewalker, Uwe liked this post
    May 2016
    MIB must support MOST connection. Need to wire the most.
    Võru, Estonia
    MOST installed?
  9. #8
    Oct 2014
    MOST installed?
    It’s all in and working apart from the map screen it’s a mess and I don’t know what’s wrong.both cables connected at the back of cluster so I don’t know what’s wrong.
    When I activate MOST in the long coding I get that fault in the 5F.
  10. #9
    Võru, Estonia
    And the fault is? As i told You in PM, I belive Your MIB doesn't support aid.
  11. #10
    AFAIK in most cases MIB2.5 is needed to support AID.
