VW Polo AW AID Retro Fit Question
golfman
C?ID=103115
for suitable model - yes
Hi Spacewalker can you please point me in the right direction to have this done or any info that can help?
regards
scott
golfman
C?ID=103115
If i were to buy a new Virtual Dash do you think that the dealers would be able to code this for me and adapt the keys with me also supplying the MOST cable to show the nav in the Virtual Dash?
can anyone help?
scott
golfi_vend
Tartu, Estonia
C?ID=195131
can anyone help?
scott
Adapt immobiliser and keys - Yes
Make coding and adaption work - If dealer tech isn't VW enthusiast, HARDLY.
You must also verify that Your MIB supports AID.
vastechnics
C?ID=143747
MIB must support MOST connection. Need to wire the most.
golfman
C?ID=103115
MOST installed?
It’s all in and working apart from the map screen it’s a mess and I don’t know what’s wrong.both cables connected at the back of cluster so I don’t know what’s wrong.
When I activate MOST in the long coding I get that fault in the 5F.
golfi_vend
Tartu, Estonia
C?ID=195131
And the fault is? As i told You in PM, I belive Your MIB doesn't support aid.
golfman
C?ID=103115
Can anyone tell me how to find the correct Adaption Channel to have Staging please?
I have it coded in the long coding but its not doing anything!!!
In the adaptions there is an option for staging but it says its Not Available and with the older clusters there was another option for Staging but its not the same on this one.
Can anyone help?
scott
