Results 1 to 8 of 8
Thread: No TPMS module response on VCDS
    Mar 2015
    2013 Audi Q5 Hybrid, 45 K miles, VCDS 18.9.0
    I'm getting an intermittent TPMS fault on the instrument cluster (not a low-tire pressure message). When I try scanning the vehicle, I've discovered that neither of the tire pressure modules (64 or 4C) show up as active.
    So how can I diagnose the TPMS fault? Where is the TPMS fault coming from?
    Thanks!
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Post a complete Auto Scan please.
    The trend in newer vehicles has been toward indirect TPMS in 03-ABS, particularly now that the tech exists to detect simultaneous deflation of all four tires. If you do have direct TPMS, that would most commonly be at address 65 but possibly others I think. Either way, an Auto Scan will tell us.
    Silence gives consent.
    Mar 2015
    Here is an autoscan from yesterday while the TPMS error was being displayed on the instrument cluster:
    Thursday,29,November,2018,18:21:11:47760
    VCDS Version: 18.9.0.2 (x64)
    VIN: WA1C8AFP7DA079130   License Plate: AFTER FIXING WOOD PLUG
    Mileage: 73170km-45465mi   Repair Order:
    Chassis Type: FP-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 40 42 44 46 47 51 52 53
              56 5F 62 6C 6D 72 8C
    VIN: WA1C8AFP7DA079130   Mileage: 73170km-45465miles
    40-AC Compressor -- Status: OK 0000
    Address 01: Engine (0-MA--CHJA)       Labels: None
       Part No SW: 8R1 907 115 D    HW: 8R0 907 115 G
       Component: 2.0l R4/4V TF H57 0003
       Revision: NDH57---
       Coding: 6A2A0013442600062000
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM20TFS0118R1907115D 002005
       ROD: EV_ECM20TFS_AU48.rod
       VCID: 3663CAFD89FDEDFA3F-8062
              U1113 00 [036] - -
                        Mileage: 73173 km
                        Date: 2018.11.29
                        Time: 18:12:22
                        Engine speed: 840.00 /min
                        Normed load value: 13.7 %
                        Coolant temperature: 69 ∞C
                        Intake air temperature: 17 ∞C
                        Voltage terminal 30: 14.677 V
                        Median injection timing: 0.874 ms
                        Engine operating condition-Channel 87: Idling
                        Relative load value: 17.02 %
                        Engine torque: 38.2 Nm
              U1113 00 [036] - -
                        Mileage: 73173 km
                        Date: 2018.11.29
                        Time: 18:12:22
                        Engine speed: 827.50 /min
                        Normed load value: 9.8 %
                        Voltage terminal 30: 14.701 V
                        Median injection timing: 0.498 ms
                        Relative load value: 12.73 %
                        Engine torque: 27.6 Nm
    Readiness: 1110 1101
       Part No SW: 8R1 927 158 K    HW: 0BW 927 156 P
       Component: 0BW 20TFSIUSA H16 1001
       Revision: --H16---
       Coding: 000001
       ASAM Dataset: EV_TCMAL551111 002022
       ROD: EV_TCMAL551111_002.rod
       VCID: 4683BA3DF91D7D7AAF-8012
       Part No SW: 8R0 907 379 T    HW: 8R0 907 379 T
       Component: ESP8 quattro  H09 0060
       Coding: 2D1D1C
       Shop #: WSC 48607 001 1048576
       VCID: 51A999610853AAC20A-8004
       Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
       Component: BCM2 2.0      H12 0633
       Coding: 0DC54040000000000000
       Shop #: WSC 06335 000 00000
       VCID: 0407603587A18F6AF1-8050
       Serial number: 2313000040689010
       Part No SW: 8K1 820 043 AL    HW: 8K1 820 043 AL
       Revision: C3000000    Serial number: 01080320130871
       Coding: 64C120C200
       VCID: 72EB36EDAD15B1DAD3-8026
       Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
       Revision: 09016001    Serial number: 00000566263501
       Coding: 26000091863CAFC00000480000003D0D0F1C4608E0090225000008004000010200040034000000
       Shop #: WSC 55826 001 1048576
       VCID: 7AFB1ECDF565C99A9B-802E
       Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 130225  H11 0050
       Serial number: 90243014130220165816
       Coding: 01DD13
       Serial number: 21062804
       Coding: 03005C
       Component: E1 - LDS  H03 0031
       Serial number: 00000000002802131292
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R55JW02
       Subsystem 5 - Part No SW: 8K0 959 772 E    HW: 8K0 959 772
       Component: SLR-B8  H06 0007
       Serial number:           0054053656
       Coding: 0F0000
       Subsystem 6 - Part No SW: 3D0 941 329     HW: 3D0 941 329
    H05 0012
       Subsystem 7 - Part No SW: 3D0 941 329     HW: 3D0 941 329
    H05 0012
       Serial number: CD08C696000000000001
    Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
       Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
       Serial number: 003GPD91CK1E
       Coding: 303634313432303030304A55304C38523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 479DB739FE17647254-8012
       Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
       Serial number: 5810000R130000C63C
       Serial number: 6334MSME78661A6CT
       Serial number: 6344MSME76235861C
       Serial number: 6352QSME5E2C3550N
       Serial number: 6362QSME5E2C1E78+
       Serial number: 63732SME4D2D264CC
       Serial number: 63832SME462B007A/
       Part No SW: 8K0 953 568 L    HW: 8K0 953 568 L
       Revision: --------    Serial number: 90372MC1001PT
       Coding: 000037
       VCID: 4385A329C22F485288-8016
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 981 D    HW: 8R0 920 981 D
       Component: KOMBIINSTR.   H35 0556
       Revision: 00200000    Serial number: UWU381U2E
       Coding: 8BBF23000B01D705020000
       VCID: 3B75DBC9BADF3092C0-806E
       Part No SW: 8R0 907 468 K    HW: 8R0 907 468 E
       Component: GW-BEM 5CAN-M H11 0055
       Revision: 2A120022    Serial number: 2242A132200029
       Coding: 80D00AFF00
       VCID: 479DB739F617647254-8012
       Subsystem 1 - Part No SW: 8R0 915 181 A    HW: 8R0 915 181 A
       Component: J367-BDM  H07 0180
       Serial number: 00000000001580143173
       Subsystem 2 - Part No SW: 8R0 915 181 B    HW: 8R0 915 181 B
       Component: J367-BDMLear2  H07 5040
       Serial number: 00000000001770349767
       Part No SW: 8R0 959 760 E    HW: 8R0 959 760 C
       Component: MEM-FS        H07 0076
       Revision: AA000000    Serial number: 00000049483487
       Coding: C0581B000F0000000000
       Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
       Component: SWA Master    H04 0060
       Serial number: 0192517036
       Coding: 010211
       Shop #: WSC 06334 000 00000
       VCID: 3F8DAFD9A6C72CB2EC-806A
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
       Component: SWA Slave  H04 0060
       Serial number: 0192496252
       Coding: 000102
    Address 40: AC Compressor (J842)       Labels: 8R0-260-797.clb
       Part No SW: 8R0 260 797 C    HW: 8R0 260 797 C
       Component: ES34          H01 0001
       ASAM Dataset: EV_AirCondiCompr_ES34 S03001
       ROD: EV_AirCondiCompr_ES34.rod
       VCID: 3C77D8D5B7D137AAC9-8068
       Component: TSG FA        H02 0508
       Revision:             Serial number: 0000053762085
       Coding: 011D13205E00440004
       VCID: 4FAD9F191E67BC321C-801A
       Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
       Revision: 00001000    Serial number: 0021290518
       Coding: 000000000100
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3B75DBC9B2DF3092C0-806E
       Revision: 00002001    Serial number: 0301732617
       Coding: 0126023A20FA709584B005321004000D
       Component: GTO BF  H01 0080
       Serial number: 00000000000000646281
       Component: J245EE20SKB13  H05 0220
       Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
       Component: J394EE20SKB13  H05 0220
       Revision: 00005001    Serial number: 94813011839502
       VCID: 2D51E59174ABAE224E-8078
    Address 51: Electric Drive (J841)       Labels: 06F-907-080.clb
       Part No SW: 06F 907 080 H    HW: 06F 907 080 H
       Component: MLB HYBRID    H19 0001
       Revision: --------
       ASAM Dataset: EV_DMCM030202106F907080H 001003
       ROD: EV_DMCM030202106F907080H.rod
       VCID: 2C57E89547B1A72A59-8078
       Component: TSG BF        H02 0508
       Revision:             Serial number: 0000054093461
       VCID: 4E93821D196DB53A17-801A
       Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
       Component: EPB-4         H01 0003
       Revision: --------    Serial number: 00000001272350
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 387FC4C583E91B8A2D-806C
       Part No SW: 4G0 035 082 H    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0138
       Revision: AB001007    Serial number: 156C$0D7702883
       Coding: 020007010000000001
       VCID: 25411DB12C5B966286-8070
       Part No SW: 8R1 035 746 K    HW: 8R1 035 746 B
       Component: H-BNT-NA      H44 1040
       Revision: --------    Serial number: 204C+0D7566667
       Coding: 170200060005A1EF51038B4E00000403140000000000000002
       VCID: 3F8DAFD9AEC72CB2EC-806A
       Subsystem 1 - Part No: 8R0 060 884 EN
       Component: NAR 2017/2018  1602
       Component: DU7 High  H42 0104
       Serial number: A130CJ0D2675021
       Serial number: 00000001436879
       Component: CD-Database  4949
       Revision:             Serial number: 0000054061364
       Coding: 010C13204000240004
       VCID: 4683BA3DF11D7D7AAF-8012
       Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
       Revision: --H07---    Serial number: 525PA8-J2ZA5M1
       Coding: 1020010
       VCID: 3467F0F55781FFEA01-8060
       Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
       Revision: --------    Serial number: 8R0827851B
       Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
       Serial number: 8R0827852B
       Revision:             Serial number: 0000054061609
    Address 8C: Hybrid Battery (J840)       Labels: None
       Part No SW: 8R0 915 591     HW: 8R0 915 591
       Component: BMS           H08 0543
       Coding: 0A0200
       Shop #: WSC 47336 001 1048576
       ASAM Dataset: EV_BECM0722011 004016
       ROD: EV_BECM0722011_004_AU48.rod
       VCID: 78FF04C5C369DB8AED-802C
    End-------------------------(Elapsed Time: 04:41)--------------------------
    Cincinnati, OH
    Quote Originally Posted by Treborg View Post
    Thank you for the Auto-Scan.
    No sign of a TPMS related fault anywhere, but sometimes there isn't when the system is functioning as designed and just reporting low pressure. There's no sign of a separate physical or BCM-integrated virtual TPMS controller, nor any complaints from other modules that an expected TPMS controller is MIA.
    Based on a PL24 FI inquiry on your VIN, it was factory equippped with PR-7K6 "Tire pressure monitor system (wheel rev. dependant)", a.k.a. indirect TPMS. So, you have no TPMS controllers or sensors, it's all software in 03-ABS. So, I would expect no address 65 in your GVL or Auto Scan.
    Without something showing up in the scan, we're going to need to know exactly what you saw in the instrument cluster. In particular, what makes you say it wasn't a low pressure issue?
  5. Likes Uwe liked this post
    Mar 2015
    In the center display between the gauges, the word “TPMS” appears at the top of the display with a red background. This is usually where major system fault messages appear, like “HYBRID”. An alarm sounds. This is different from the display for low tire pressure.
    And, I will confess that I forgot that this vehicle doesn’t use TPMS sensors in the wheels. So it goes.
    Mar 2015
    This is what the 2013 Audi Q5 Hybrid service manual says:
    System fault in Tyre Pressure Loss Indicator (TPLI+):
    If the warning lamp flashes for about 1 minute after switching on the ignition and then remains steadily lit, there is a system fault. TPMS also appears in the instrument cluster.
    System faults are stored in the event memory for the ABS/ESP control unit and indicated by the yellow TPLI+ lamp in the instrument cluster flashing for 1 minute after the ignition is switched on. The TPLI+ warning lamp cannot be switched off by pressing the button on the multimedia system operating unit - E380- . Proceed as follows if a fault is stored in the event memory:
    – Connect up the vehicle diagnosis, testing and information system - VAS 5051 B- and select Guided Fault Finding ⇒ Vehicle diagnostic tester.
    – Select the relevant program in Guided Functions.
    – Follow the instructions on the screen.
    What's described above are the fault symptoms I observed on the instrument cluster.
    So, since VCDS isn't seeing anything wrong in the ABS module, is it possible that VCDS isn't recognizing/decoding the TPMS fault in the ABS module?
    Right now, the TPMS fault has disappeared, but it has been reoccurring within a few days. I'm going to try resetting the tire pressures in the vehicle car menu tomorrow and see if the TPMS fault goes away. I'll report back if I see this fault again in the next week or so.
    Your scan shows the ABS properly recognized. When VCDS says "No fault code found" it means it. If there are any issues reading fault codes, it will add "... or fault codes not supported, or a communications error occurred" (not sure I have that text exactly verbatim, but it's close). In other words, when you see what you've got there currently, VCDS successfully queried the module for faults and the module responded, "Nope, I haven't got any."
    Check (and if appropriate, adjust) tire pressures first.
  9. Likes PetrolDave, jyoung8607 liked this post
  10. #8
    Cincinnati, OH
    Difficult to say, then. Sometimes faults in other systems/modules can effectively disable other systems. One example would be what your ECU is complaining about, the function restriction faults. Speaking of, I see no other faults in other modules that your ECU should be upset about. However, your ECU emissions Readiness state indicates fault codes have been cleared VERY recently:
    If you have been clearing faults in the ECU or in any other module, we may be missing part of the diagnostic picture here. There may be other faults you'd think are unrelated that can have an impact. Anything you'd like to share on this front?
    Just to add to what Uwe said, even if there was a fault that VCDS couldn't decode, it would still give the numeric fault ID and just label it Unknown. In this case, there is currently no fault, although someone may have cleared faults as stated above.
  11. Likes Uwe, Eric liked this post
