Results 1 to 10 of 11
Thread: IMMO versions
    Verified VCDS User victor35ma's Avatar
    Nov 2014
    Los Angeles CA.
    IMMO versions
    hello Ross Tech:
    i have a question related to Immobilizer. I got this vehicle: 2010 audi A4 2.0T is there a way using the scanner to id the immo version on this car? whether using VCDS or other scan tool.
    Thursday,29,November,2018,11:53:47:23194
    VIN: WAUAFAFL9AN068793   License Plate: 7ECM136
    Mileage: 144090km-89533mi   Repair Order: 41247
    Chassis Type: FL-AU48 (8T0)
    Scan: 01 02 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 72 77
    VIN: WAUAFAFL9AN068793   Mileage: 144090km-89533miles
    Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
       Component: 2.0l R4/4V TF H17 0001
       Revision: E1H17---
       Coding: 0104010A02070160
       Shop #: WSC 22145 444 85933
       VCID: 79BA0A4AF883C88292-802C
    4201 - Fuel Level too Low
              P1250 00 [096] - -
    7666 - EVAP System
       Part No SW: 8K1 927 155 J    HW: 0AW 927 156 H
       Component: 0AW 20TAVSUSA H05 0003
       Revision: --H05---    Serial number: 0000000876
       Shop #: WSC 02149 785 00200
       ASAM Dataset: EV_TCMVL381 A02017
       ROD: EV_TCMVL381.rod
       VCID: 3B36D042B23F3A92C0-806E
       Part No SW: 8K0 907 379 BT    HW: 8K0 907 379 BT
       Component: ESP8 front    H04 0030
       Coding: 080D10
       Shop #: WSC 02391 823 56573
       VCID: 0C54439EAF11CD2AB9-8058
       Part No SW: 8K0 907 064 DF    HW: 8K0 907 064 DF
       Component: BCM2 1.1      H02 0328
       Coding: 090100
       Shop #: WSC 02399 823 56573
       VCID: 77BE0C72C697DEF2E4-8022
       Component: FBSAUDIB8 IDG  H50 0070
       Serial number: 0510000025642006
       Serial number: 0210000058716007
       Part No SW: 8T1 820 043 AM    HW: 8T1 820 043 AM
       Component: KLIMA 1 ZONE  H08 0180
       Revision: A0000000    Serial number: 01030520101883
       Coding: 64002000
       VCID: 7CB4135EFFB1FDAA89-8028
       Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
       Component: BCM1 1.0      H29 0380
       Revision: 09029001    Serial number: 00000000658611
       Coding: 690000B1063C00010000080000007F5F0F14520802000021000000
       VCID: 3A38D546B505039ADB-806E
       Component: WWS 050510  H06 0070
       Serial number: SWF10050055690
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8K0 941 531 AK    HW: 8K0 941 531 AK
       Component: E1 - LDS  H08 0090
       Serial number: 00000000002104100502
       Subsystem 3 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
       Component: HOMELINK  H01 0010
       Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
       Component: AirbagVW-AU10 H41 0610
       Serial number: 003GLD0G031U
       Coding: 303837354230303030304A55304C384B3053
       Shop #: WSC 02135 785 00200
       VCID: 45C2B6BAC4FB7C62A6-8010
       Serial number: 5810000R1000006U1R
       Serial number: 6334MSME53204C69E
       Serial number: 6344MSME53262D70C
       Serial number: 6352QSME2C5C3236M
       Serial number: 6362QSME145E3234E
       Serial number: 63732SME2F5E25245
       Serial number: 63832SME1259171A-
       Component: Lenks.Modul   H16 0014
       Revision: --------    Serial number: 90315JE6000JP
       Coding: 000014
       VCID: 3D32DE5AA42B34A2FE-8068
       Component: E221 - MFL  H02 0010
       Part No SW: 8K0 920 950 E    HW: 8K0 920 950 E
       Component: KOMBIINSTR.   H20 0255
       Revision: 00300000    Serial number: CIM31RP4A
       Coding: 8B1209000300D705020000
       VCID: 312AF26A6873C0C26A-8064
       Part No SW: 8T0 907 468 AB    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0117
       Revision: GB800053    Serial number: 5300G1042682A0
       Coding: 00C303
       VCID: 014A62AA98539042DA-8054
       Component: J367-BDM  H07 0170
       Serial number: 10016B7B220410
       Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
       Component: TSG FA        H11 0306
       Revision:             Serial number: 0000010590273
       Coding: 011C03204000410001
       VCID: 45C2B6BACCFB7C62A6-8010
       Revision: 00002001    Serial number: 0129792353
       Coding: 0106023A007A400400B0013200000000
       Component: GTO BF  H06 0050
       Serial number: 00000000000000254379
       Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J245 PS037  H06 0041
       Part No SW: 8T0 035 223 AH    HW: 8T0 035 223
       Component: DSP STD       H07 0230
       Revision: S2200000
       Coding: 0203010102
       VCID: 74A43B7ED7E1B5EAC1-8020
       Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
       Component: TSG BF        H11 0306
       Revision:             Serial number: 0000010594358
       VCID: 44C4ABBEC7C1456AB1-8010
       Revision: 00000003    Serial number: 10000000501680
       VCID: 3424FB7E9761F5EA01-8060
       Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
       Component: Con3 Sirius   H06 0351
       Revision: 00000009    Serial number: AUZ5Z6J1399786
       Coding: 05020002010185004119070000
       VCID: 46C0B1B6F1FD777AAF-8012
       Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
       Component: Display
                000 -  -
                        Reset counter: 151
                        Mileage: 133865 km
                        Date: 2018.06.27
                        Time: 17:12:38
       Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
       Component: TSG HL        H10 0306
       Revision:             Serial number: 0000103970772
       Coding: 010C03204000210001
       VCID: 42C8ADA6DDD54B5A83-8016
       Component: TSG HR        H10 0306
       Revision:             Serial number: 0000103970737
       Part No SW: 8T0 862 336 D    HW: 8T0 862 336 D
       Component: FSE_256x BT     H39 0600
       Revision: 00000000    Serial number: 00000005078111
       Coding: 0010370
       Shop #: WSC 02335 785 00200
       VCID: 3C34D35E7F313DAAC9-8068
    End----------(Elapsed Time: 01:36, VBatt start/end: 12.0V/12.0V)-----------
                    Address 01: Engine  (8K2 907 115 AL)
    12:10:05
      IDE00151   Oil fill level 63.416 mm
      IDE00152   Oil warning threshold 56.232 mm
    I am new to VCDS but... I will master it.
    We haven't really kept track of Immo "versions" since 4C, where the whole on-line challenge/response thing became necessary. This car has at least that level.
    You should be able to see the Immo Challenge code if you go to Advanced ID in 05: Acc/Start Auth. You'll also see that this code changes every time the ignition is cycled.
  3. Likes Dana, victor35ma liked this post
    Nov 2014
    Los Angeles CA.
    oh ok then how does ODIS create/make a new key ? there is a bunch of handheal that are able to make the key amount then XTools, AVDI VVDI lonsdors... but i need to be able to id the system.
    also another questions that might be related to my post: why independant auto shop can't get ODIS loaded with all the immo features? or why is so hard to get a LSID from NASFT ? they are already changing the application process (monopolizing it)
    thanks again Mr. Uwe.
    Nov 2014
    Los Angeles CA.
    Oh... I forgot to ask you. you said since 4C. what is 4C? is it the chip / transponder in the key? no??
  6. Likes Fredrick Awuor liked this post
    Jul 2017
    Kenya
    4C is immo generation....like there was immo 1,2,3....etc
  8. Likes victor35ma liked this post
  9. #6
    Jun 2014
    this is Immo 5 BCM
  10. Likes Jack@European_Parts, victor35ma, Uwe liked this post
  11. #7
    Quote Originally Posted by victor35ma View Post
    On current cars, it alone does not. I believe you have order a key that is somehow pre-coded to the VIN of the car. Once the key arrives, you still have to match it to the car. ODIS does that by sending the current immo challenge code to the VW/Audi corporate server. The server generates the corresponding response, which unlocks the matching function.
    Don't the people who make those systems provide a reference chart?
    It is possible if you want to jump through all the hoops and spend the requisite amounts of money.
    That process wasn't particularly hard in the past.
    Yes, I understand they are changing it. I gather this is due to some serious abuse that they've experienced; cars that were stolen using codes obtained with a LSID.
  12. #8
    Tartu, Estonia
    When You order key, Component Security Data is pre-written to key, also known as Dealer Key.
    A Key Tool has to write this data, obtained from some module from car, into key.
    Depending on immo version, adaption is carried out different way. Immo5 procedure is to check all immobilizer related modules if immo fault is active and then correct it. Then it asks if You want to add key. Then You have to hold key next to coil for it to be read.
    I'm not familiar with Immo5 procedure with 3rd party tools, but for Immo4, key data was written manually to immobilizer module so when starting with that key, it would be recognized.
    Accessing the module would deploy series of exploits to get access.
    The world is my oyster...
  13. Likes Uwe liked this post
  14. #9
    Nov 2014
    Los Angeles CA.
    thank you so much. i just finished adding a new key to car thanks.
    https://drive.google.com/drive/folde...Ft?usp=sharing
  15. Likes Uwe liked this post
  16. #10
    Nov 2014
    Los Angeles CA.
    this is Immo 5 BCM
    thank you, so much. I just finished adding a new key to the car... it was actually super simple, compared to ODIS key making "enchilada" process.
