DEE DEE
New Member
- Joined
- Nov 28, 2018
- Messages
- 3
- Reaction score
- 0
- Location
- USA
- VCDS Serial number
- HC483374 (2nd hand?)
I have a 2009 GTI and the ABS control module failed. replaced with a salvage unit 1K0-907-379-AP. I could not retrieve the code from old unit. Can you generate a long code ? Here is the latest auto scan
Wednesday,28,November,2018,18:16:12:34514
VCDS Version: 18.9.0.2 (x64)
VIN: WVWHV71K79W123172 License Plate: 2
Mileage: 191750km-119147mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 47 52 55 56 62
65 72
VIN: WVWHV71K79W123172 Mileage: 191750km-119147miles
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AE HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH03--- Serial number: VWX7Z0H83NH82W
Coding: 0403010A1C070160
Shop #: WSC 01269 785 00200
VCID: 69D25E8940FF300262-803C
000051 - Turbocharger Bypass Valve Control Circuit
P0033 - 000 - Malfunction / Open Circuit
Date: 2047.15.31
Time: 31:63:63
RPM: 582 /min
Load: 53.3 %
Temperature: 54.0°C
Temperature: 35.0°C
Absolute Pres.: 990.0 mbar
Voltage: 11.049 V
000769 - Cylinder 1
P0301 - 000 - Misfire Detected - Intermittent
Mileage: 190135 km
Time: 08:54:58
RPM: 840 /min
Load: 25.1 %
Temperature: 14.0°C
Temperature: 8.0°C
Voltage: 14.224 V
000770 - Cylinder 2
P0302 - 000 - Misfire Detected - Intermittent
Mileage: 191037 km
Time: 10:05:17
RPM: 2438 /min
Load: 27.0 %
Temperature: 7.0°C
Temperature: 12.0°C
Voltage: 14.478 V
Part No SW: 02E 300 051 R HW: 02E 927 770 AM
Component: GSG DSG AG6 511 1966
Revision: 05351112 Serial number: 00001102251555
Shop #: WSC 04940 001 00001
VCID: 224009A5FD49235AE3-8076
Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Shop #: WSC 48605 001 1048576
VCID: 0004632D9385D14AD5-8054
03306 - Coding Not Valid
Reset counter: 80
Mileage: 191757 km
Count: 3
Count: 14
Count: 12288
Count: 4161
Count: 42496
Fault Status: 01100101
Reset counter: 0
Mileage: 191351 km
Count: 3
Count: 14
Count: 12288
Count: 279
Count: 41472
Count: 64768
Reset counter: 0
Mileage: 191351 km
Count: 3
Count: 14
Count: 12288
Count: 295
Count: 41472
Count: 64768
Reset counter: 0
Mileage: 191351 km
Count: 3
Count: 14
Count: 12288
Count: 270
Count: 41472
Count: 64768
Reset counter: 71
Mileage: 191351 km
Count: 7
Count: 14
Count: 12288
Count: 195
Count: 41472
Count: 64768
Part No SW: 1K0 820 047 HS HW: 1K0 820 047 HS
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 7CFC17DD3F6DB5AA89-8028
Revision: 00H54000 Serial number: 00000008742796
Coding: 178D8F214004150047140000001400000028770B5C000100000000000000
Shop #: WSC 00000 785 00200
VCID: 336EFCE152B3BAD218-8066
Component: Wischer 100908 021 0501
Coding: 00038805
Address 0F: Digital Radio Labels: None
Part No SW: 8E0 035 593 Q HW: 8E0 035 593 Q
Component: SDAR SIRIUS H08 0160
Revision: 00000000 Serial number: AUZ4Z7J0562339
Coding: 0000000
VCID: 3776C8F146CB56F224-8062
Reset counter: 71
Mileage: 191351 km
Time: 11:40:21
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6K AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0BYWK1
Coding: 0013899
VCID: 6CDC279D4F0D252A19-8038
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME40243706/
Subsystem 3 - Serial number: 6342MSME4023551C4
Subsystem 4 - Serial number: 6352QSME030C060CA
Subsystem 5 - Serial number: 6362QSME4B0D3D1CZ
Subsystem 6 - Serial number: 63727SME177D34757
Subsystem 7 - Serial number: 63827SME177D082CB
Part No SW: 1K0 953 549 BG HW: 1K0 953 549 BG
Component: J0527 051 0101
Coding: 0012122
VCID: 78F40BCD0B55998AED-802C
Component: E0221 002 0010
Part No SW: 1K6 920 974 H HW: 1K6 920 974 H
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0003000 Serial number: VWX7Z0H83NH82W
Coding: 0007203
VCID: 3972CEC970DF4082D2-806C
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 140908F2001645
Coding: ED817F071013020002
VCID: 356AC2F95CC7A4E236-8060
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T3ZVW03
VCID: 7DFA1AD92477BCA2BE-8028
Component: IMMO VDD 2416
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1219
Coding: 0001205
VCID: 3874CBCD4BD5598A2D-806C
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
Shop #: WSC 00000 028 00001
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 139006885103281B0904058FB0080F0488DC00
VCID: 040C6F3D479DCD6AF1-8050
Address 47: Sound System Labels: 3C0-035-456.clb
Part No SW: 1K6 035 456 B HW: 1K6 035 456 B
Component: 08K Audioverst. 0006
Revision: 00004000 Serial number: 00000008155397
VCID: 2B5EE4818A83E21250-807E
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0001204
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74EC3FFD173DFDEAC1-8020
Part No SW: 1K0 035 180 L HW: 1K0 035 180 L
Component: Radio PM6 125 0037
Revision: 00125000 Serial number: VWZ5Z7H2260485
Coding: 0010011
VCID: 29521E89807FF002A2-807C
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1302
Coding: 0001168
Shop #: WSC 01269 785 1012552
Component: RDK 0450
Coding: 0100101
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0001168
End-------------------------(Elapsed Time: 02:15)--------------------------
