Results 1 to 10 of 19
Thread: 2018 Audi A3: Turn Off Parking Brake Engage When Door Open
    Nov 2018
    Canada
    I saw this tweak for a different Audi, but doesn't work for the '18 A3. Basically when I'm parking I like to look at the curb and my rear tire sometimes to make sure it doesn't hit as I roll slowly into the spot...or backing up and the collision avoidance doesn't see the low curb. The A3 immediately engages the parking brake which is super-annoying. How to turn that off?
    Also, I assume this one is impossible as it involves CarPlay, but is there a way to have the map button bring up Waze instead of the non-installed Audi navigation?
    Hi and welcome to our forum.
    It might be helpful to post an Auto-Scan so that people can see exactly how your car is equipped and configured.
    Nov 2018
    Canada
    Sunday,25,November,2018,11:58:03:28469
    VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
    Chassis Type: FF-AU37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 3C 42 44 52 5F 6C
              BB BC CF
    Mileage: 1270km-789miles
    Address 01: Engine (J623-CNTC)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 L    HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0002
       Revision: --H13---
       Coding: 0A1D00124426010F3000
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
       ROD: EV_ECM20TFS0205G0906259L_AU37.rod
       VCID: 372B29CCDFCB77EF6FF-8062
       Part No SW: 0D9 300 018 A    HW: 02E 927 770 AS
       Component: DQ250-6A MQB  H54 5201
       Revision: 06454104    Serial number: TFK01709271113
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021.rod
       VCID: 1A6DD0784C194A87701-804E
              P1734 00 [002] - -
       Part No SW: 5Q0 614 517 CG    HW: 5Q0 614 517 AG
       Component: ESC           H62 0643
       Revision: 00000000    Serial number: 63017000000126
       Coding: 13FF6A9234232274897F0B09A0CC29C8562C4491D0059476124150548288420000000012121212B835351919323200
       ROD: EV_Brake1UDSContiMK100IPB_036_VW41.rod
       VCID: 78A9EAF09255B897A65-802C
    16401 - Tire Pressure Warning
              C102D 00 [008] -  -
                        Reset counter: 114
                        Mileage: 1007 km
                        Date: 2018.11.20
                        Time: 16:31:40
       Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
       Component: VWKESSYMQB    021 0803
       Revision: 00021000    Serial number: 0460595285
       Coding: 030C0C
       ASAM Dataset: EV_KessyHellaMQBAB 002020
       VCID: 3C2136E0E6ED54B782D-8068
       Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
       Component: AC Automat    H03 0130
       Revision: 20002000    Serial number: 00000001403586
       Coding: 03000014010000001000000000001400
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
       VCID: 40D942108A053057DE5-8014
       Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: FD7097D800PAG0MUFU03
       Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
       Component: BCM MQBAB MNA H36 0253
       Serial number: 01001731901138
       ROD: EV_BCMBOSCH_018.rod
       VCID: 06559408E8A1DE67A49-8052
       Component: WWS371 171018  043 0585
       Serial number:         171028220216
       Coding: 0A47F7
       Serial number: 21036734X81A955547A0
       Coding: 00006C
       Component: E1 - LDS MQB  H06 0032
       Serial number: 12 06 2017  00000038
       Serial number: 00000000000039742522
       Sun Roof:
       Component: J245 PS73.404  H04 0005
       Serial number: 0000FST001VEFAZ00000
       Coding: 101F00
       Part No SW: 5QA 919 294 B    HW: 5QA 919 294
       Serial number: 000308418617311
       Coding: 0470155011
       VCID: 4BC3653CB343E30F3B7-801E
       Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
       Component: ACC BOSCH MQB H10 0571
       Coding: B500008111F78428949C8055000024
       ASAM Dataset: EV_ACCBOSCHVW416 001005
       ROD: EV_ACCBOSCHVW416_001_VW37.rod
       VCID: 3B2335FCE3E3538F8B7-806E
       Serial number: 003GCR09L77G
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47CB590CAF2B076F1FF-8012
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34230167A08111740990
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34230168A09111740031
       Coding: 333135
       Occupant Detection:
       Serial number: 694000000000001NNMUW
       Coding: 303334
       Subsystem 4 - Part No SW: -----------    HW: 480 001 311 17
       Serial number: 357000000003A850C92L
       Subsystem 5 - Part No SW: -----------    HW: 480 001 311 17
       Serial number: 358000000007988C692Y
       Subsystem 6 - Part No SW: -----------    HW: 480 402 710 17
       Serial number: 3510001C527CABF3D2FV
       Subsystem 7 - Part No SW: -----------    HW: 480 402 710 17
       Serial number: 3520001C527CABF1C32H
       Subsystem 8 - Part No SW: -----------    HW: 480 402 709 17
       Serial number: 35500029F25629A501C5
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 402 709 17
       Serial number: 35600029F25629A3E0EJ
       Part No SW: 8V0 953 521 KK    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 14111704401505
       Coding: 2018
       VCID: 0D47AB248DD7AD3FE53-8058
       Part No SW: 8V0 920 961 C    HW: 8V0 920 961 C
       Component: KOMBI         H01 0311
       Coding: 0BE418192388CF050280A8001800000000000000
       Part No SW: 3Q0 907 530 L    HW: 3Q0 907 530 C
       Component: GW MQB High   518 5323
       Serial number: 09101710522906
       Coding: 030100043F085A005B00004C180B00000001010000000000000000000000
       ROD: EV_GatewNF_VW37.rod
       VCID: 38292AF0D2D57897665-806C
       Subsystem 2 - Part No SW: 81A 951 523 A    HW: 81A 951 523 A
       Component: J453 MFL  H04 0003
       Serial number: 20171108080516 20933
       Serial number: 75886000001711080A9E
       Part No SW: 0CQ 907 554 J    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7084
       Serial number: HA1-00007.09.17
       Coding: 0001
       VCID: 4CC16620B64DE43732D-8018
       Revision: 00000000    Serial number: 17000323090005
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 34311EC0CEBD9CF74AD-8060
       Part No SW: 3Q0 907 566 F    HW: 3Q0 907 566
       Component: MRR1Rear      H21 0610
       Revision: --------
       Coding: 040002
       Serial number: 011117EJV12615
       Coding: 001C1B204000048000000002
       VCID: 43D34D1C9B132B4FC37-8016
    65588 - Motor for Window Regulator
              B1487 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 103
                        Mileage: 600 km
                        Date: 2018.11.16
                        Time: 10:40:28
       Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
       Component: EPS_MQB_ZFLS  131 1081
       Coding: 811F0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 73B3DDDC8B33DBCF937-8026
       Serial number: 281017EJS08517
       Coding: 001C13204000048000000002
       VCID: 42DD481884092247C81-8016
    Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
       Part No SW: 8V1 035 652 E    HW: 8V1 035 652
       Component: MU-HS-S-US    050 0160
       Coding: 01730100FF0A000011220001061A00002F002DC401F001040A
       ASAM Dataset: EV_MUHigScl6C3DELP 001011
       ROD: EV_MUHigScl6C3DELP_AU37.rod
       VCID: 392F2FF4E9DF619F99B-806C
       Subsystem 1 - Part No SW: 8V0 919 604 C    HW: 8V0 919 604 C
       Component: DU High  H49 0014
       Serial number: AUZ8Z9H1Y07590
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614 BF    HW: 8V0 919 614 BF
       Component: ControlUnit_B  H50 0103
       Serial number: ALJAL107031700010284
       Coding: 0273010102002001400040
       Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
       Serial number: 241017EJO15091
       Coding: 000C13204000048000000002
       Serial number: 241017EJO1559B
       Part No SW: 3Q0 907 590 F    HW: 3Q0 907 590
       Revision: --------
       Coding: 040002
       ASAM Dataset: EV_RearRadarS2BoschVW48X 001007
    End----------(Elapsed Time: 01:38, VBatt start/end: 12.0V/12.1V)-----------
  4. Likes Uwe liked this post
    Hmm.. There's an Adaption Channel in your ABS module:
    IDE03493 Driver door status (not activated / activated)
    What's that set to?
    Nov 2018
    Canada
    Tog get in to that module it asks for a code and no code pops up like they do in other modules. Thanks
    Dec 2016
    DE
    You mean changing this adaption channel requires a login code? Because I‘m not sure if there is any such thing as requiring a login code upon entering a control module.
    However you can try the following: 40168, 20103, 24990, 37202, 31857, 28183, 44595, 24435, 15081, 18573, 10505, 11966 (some might not even be accepted).
  8. Likes Uwe, joe9, Dana liked this post
    When trying multiple Security Access codes, check this Measuring Value after each one:
    IDE00323 -- Security Access: Number of invalid keys
    If it goes too high, no Security Access will be accepted, not even a valid one. What's too high? 3 definitely is, but in some cases it can be lower. The only way to get it to decrease is to wait -- with the ignition on. A good battery charger is helpful.
  10. Likes TBAx, joe9, Dana liked this post
  11. #8
    Nov 2018
    Canada
    What's that set to?
    Workshop code 6385
    Importer 790
    Equipt 16
    ACTIVATED
    Thanks for the help!
  12. #9
    Try changing it to Not Activated.
  13. #10
    Nov 2018
    Canada
    OK, I'll try it out this weekend. Will that impact other things I wonder?
