My friend recently upgraded his van, bought this 2016 Transporter. It has factory installed auxiliary heater with options for timed pre-heating, but no remote control.
What would we need in order to retrofit remote control? Some hardware should be installed, I presume? Or is it possible that there already is remote control, only that remote is missing...?
Below is auto-scan with some errors too, but he tells me that everything is working as intended so we didn't go digging those...
Friday,23,November,2018,15:33:23:26429
VCDS Version: 18.9.0.1 HEX-V2 CB: 0.4436.4
VIN: WV1ZZZ7HZGH144338 License Plate:
Mileage: 57050km-35449mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 15 17 18 19 25 5F 61 69 6E 0B
VIN: WV1ZZZ7HZGH144338 Mileage: 57050km-35449miles
6E-Ctrl Head Roof -- Status: Malfunction 0010
Address 01: Engine (2D2D2-CXGB) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KA HW: 04L 907 445
Component: R4 2.0l TDI H02 4047
Revision: 23002001
Coding: 0011401C433401090000
Shop #: WSC 00000 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KA 004003
ROD: EV_ECM20TDI03004L906056KA.rod
VCID: 76B51B1A48414E67B4A-8022
33262 - Reductant System Performance Bank 1
P204F 00 [100] - Malfunction
Mileage: 57002 km
Date: 2028.01.16
Time: 08:28:48
Engine speed: 2420.25 /min
Normed load value: 57.3 %
Vehicle speed: 102 km/h
Coolant temperature: 91 °C
Intake air temperature: -1 °C
Voltage terminal 30: 14.726 V
Simulated particle filter surface temperature: 283.5 °C
Reducing agent fill level sensor: act. value: 73 mm
Sensor for reducing agent tank temperature: temperature: 3.3 °C
Calculated NOx concentration behind turbocharger: 0 ppm
NOx sens.dwnstrm.SCR cat conv: NOx conc.: 206 ppm
Reducing agent quality sensor: urea concentration: 0.00 %
31103 - SCR NOx Catalyst Bank 1
P20EE 00 [100] - Efficiency too Low
Mileage: 56999 km
Date: 2028.01.16
Time: 08:26:41
Engine speed: 2424.25 /min
Normed load value: 51.0 %
Vehicle speed: 103 km/h
Voltage terminal 30: 14.742 V
Air mass at air mass meter 1: 205.2 kg/h
Extern.temp.sens.1 bank 1: raw value: -1.5 °C
Mass airflow sensor 1 bank 1 airflow: raw value: 706.5 mg/stroke
Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
NOx sensor before SCR cat conv: offset correction factor: 0 ppm
NOx sensor after SCR cat conv: offset correction factor: 203 ppm
Reducing agent quality sensor: raw temperature value: 0.0 °C
16230 - Control Module for Instrument Cluster
U1019 00 [032] - Missing Signal for Oil Level/Temperature
[Instrument cluster control moduleMissing signal oil level/temperature]
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H05 0132
Revision: 00000000 Serial number: 41226000000341
Coding: 557E409825668482AA780279A48A21E6780000
Shop #: WSC 02739 790 50316
VCID: 3FDBBE3E27FBCF2FA7C-806A
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 10031613471249
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5033A60710627ECA-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AF HW: 7E0 907 047 AF
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
Shop #: WSC 02737 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: 6E85337A301176A77CA-803A
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0736
Revision: B9080001 Serial number: 0771 127160658
Coding: 62A0303A0A212032002009742C2B8CD40F90708F60444D60320000220800
Shop #: WSC 02737 022 1974138
VCID: 688945621275A897366-803C
Subsystem 1 - Part No SW: 7E0 959 801 M HW: 7E0 959 801 M
Component: J386__TSG_FT 003 0653
Serial number: KU0KU009051661306101
Coding: 0400A0
Subsystem 2 - Part No SW: 7E0 959 802 M HW: 7E0 959 802 M
Component: J387__TSG_BT 003 0653
Serial number: KU0KU009051661303377
Coding: 1400A0
Part No SW: 7E0 959 655 G HW: 7E0 959 655 G
Component: VW10Airbag01L H08 0018
Revision: -------- Serial number: 003V3000RZMZ
Coding: 00000000000000000000000000000000314C
Shop #: WSC 02734 790 50316
VCID: 3A2DCF2A3CD9EA07902-806E
Part No SW: 7E0 920 860 L HW: 7E0 920 860 L
Component: KOMBI H05 1007
Coding: 1603010300
VCID: 313FE806E1AF295F218-8064
Address 18: Aux. Heat (J364) Labels:| 7E0-963-27X-18.clb
Part No SW: 7E0 963 272 B HW: 7E0 963 272 B
Component: STH-T5GP2 003 0009
Coding: 4C01
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
ROD: EV_AuxilParkiHeateWOST5G2.rod
VCID: 2B03FA6EC383438F1B4-807E
0004 - System Voltage
P0563 00 [009] - Too High
Reset counter: 0
Operating condition of parking heater: System malfunction
71
Coolant temperature of parking heater: 0 °C
Coolant temperature: 0 °C
Engine running status: not recognized
Fuel level: 0 l
Heater output: 0 W
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0736
Revision: B9080001
Coding: 042201
Component: IMMO H05 1007
VCID: 6A8D3F6A0CF99A87202-803E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 1K8 035 150 D HW: 1K8 035 150 D
Component: MU-E--ER 857 6495
Serial number: 17051600011418
Coding: 065700003C00000041110001000000001F0000840000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001025
VCID: 26150B5AD8617EE7C4A-8072
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H80 0736
Coding: 330B1A73
Shop #: WSC 02739 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 G HW: 7E0 915 181 G
Component: J367-BDM H08 0223
Serial number: 53116202481261973574
02256 - Quiescent Current
Fault Status: 00100001
Fault Frequency: 16
Reset counter: 107
Mileage: 55494 km
Date: 2018.11.08
Time: 01:09:52
Part No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revision: 3B001001 Serial number: 00000402363523
Coding: 410D000103000000
VCID: 323DE70AE4291247582-8066
Address 6E: Ctrl Head Roof (J702) Labels:. 7E5-919-037-W2.clb
Part No SW: 7E5 919 037 G HW: 7E5 919 037 G
Component: Dachdisplay H15 0185
Revision: 10100011 Serial number: 429322
Coding: 000102
Shop #: WSC 02759 790 00000
VCID: 3537DC161547057F7D0-8060
Fault Status: 00111000
Reset counter: 107
Mileage: 56856 km
Date: 2018.11.21
Time: 21:23:42
End----------(Elapsed Time: 02:02, VBatt start/end: 12.0V/12.1V)-----------
