VW Transporter 2016 - remote retrofit for factory webasto?
Mika_M
C?ID=183725
My friend recently upgraded his van, bought this 2016 Transporter. It has factory installed auxiliary heater with options for timed pre-heating, but no remote control.
What would we need in order to retrofit remote control? Some hardware should be installed, I presume? Or is it possible that there already is remote control, only that remote is missing...?
Below is auto-scan with some errors too, but he tells me that everything is working as intended so we didn't go digging those...
Friday,23,November,2018,15:33:23:26429
VCDS Version: 18.9.0.1  HEX-V2 CB: 0.4436.4
VIN: WV1ZZZ7HZGH144338   License Plate:
Mileage: 57050km-35449mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 15 17 18 19 25 5F 61 69 6E 0B
VIN: WV1ZZZ7HZGH144338   Mileage: 57050km-35449miles
6E-Ctrl Head Roof -- Status: Malfunction 0010
Address 01: Engine (2D2D2-CXGB)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KA    HW: 04L 907 445
   Component: R4 2.0l TDI   H02 4047
   Revision: 23002001
   Coding: 0011401C433401090000
   Shop #: WSC 00000 790 50316
   ASAM Dataset: EV_ECM20TDI03004L906056KA 004003
   ROD: EV_ECM20TDI03004L906056KA.rod
   VCID: 76B51B1A48414E67B4A-8022
33262 - Reductant System Performance Bank 1
          P204F 00 [100] - Malfunction
                    Mileage: 57002 km
                    Date: 2028.01.16
                    Time: 08:28:48
                    Engine speed: 2420.25 /min
                    Normed load value: 57.3 %
                    Vehicle speed: 102 km/h
                    Coolant temperature: 91 °C
                    Intake air temperature: -1 °C
                    Voltage terminal 30: 14.726 V
                    Simulated particle filter surface temperature: 283.5 °C
                    Reducing agent fill level sensor: act. value: 73 mm
                    Sensor for reducing agent tank temperature: temperature: 3.3 °C
                    Calculated NOx concentration behind turbocharger: 0 ppm
                    NOx sens.dwnstrm.SCR cat conv: NOx conc.: 206 ppm
                    Reducing agent quality sensor: urea concentration: 0.00 %
31103 - SCR NOx Catalyst Bank 1
          P20EE 00 [100] - Efficiency too Low
                    Mileage: 56999 km
                    Date: 2028.01.16
                    Time: 08:26:41
                    Engine speed: 2424.25 /min
                    Normed load value: 51.0 %
                    Vehicle speed: 103 km/h
                    Voltage terminal 30: 14.742 V
                    Air mass at air mass meter 1: 205.2 kg/h
                    Extern.temp.sens.1 bank 1: raw value: -1.5 °C
                    Mass airflow sensor 1 bank 1 airflow: raw value: 706.5 mg/stroke
                    Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
                    NOx sensor before SCR cat conv: offset correction factor: 0 ppm
                    NOx sensor after SCR cat conv: offset correction factor: 203 ppm
                    Reducing agent quality sensor: raw temperature value: 0.0 °C
16230 - Control Module for Instrument Cluster
          U1019 00 [032] - Missing Signal for Oil Level/Temperature
          [Instrument cluster control moduleMissing signal oil level/temperature]
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
   Component: ESC           H05 0132
   Revision: 00000000    Serial number: 41226000000341
   Coding: 557E409825668482AA780279A48A21E6780000
   Shop #: WSC 02739 790 50316
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: 3FDBBE3E27FBCF2FA7C-806A
   Component: LENKW.SENSOR  H07 0070
   Serial number: 10031613471249
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5033A60710627ECA-802A
Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
   Part No SW: 7E0 907 047 AF    HW: 7E0 907 047 AF
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   Shop #: WSC 02737 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 6E85337A301176A77CA-803A
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090     HW: 7E0 937 090
   Component: BCM PQ25 Max4 H80 0736
   Revision: B9080001    Serial number: 0771 127160658
   Coding: 62A0303A0A212032002009742C2B8CD40F90708F60444D60320000220800
   Shop #: WSC 02737 022 1974138
   VCID: 688945621275A897366-803C
   Subsystem 1 - Part No SW: 7E0 959 801 M    HW: 7E0 959 801 M
   Component: J386__TSG_FT  003 0653
   Serial number: KU0KU009051661306101
   Coding: 0400A0
   Subsystem 2 - Part No SW: 7E0 959 802 M    HW: 7E0 959 802 M
   Component: J387__TSG_BT  003 0653
   Serial number: KU0KU009051661303377
   Coding: 1400A0
   Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
   Component: VW10Airbag01L H08 0018
   Revision: --------    Serial number: 003V3000RZMZ
   Coding: 00000000000000000000000000000000314C
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   VCID: 3A2DCF2A3CD9EA07902-806E
   Part No SW: 7E0 920 860 L    HW: 7E0 920 860 L
   Component: KOMBI         H05 1007
   Coding: 1603010300
   VCID: 313FE806E1AF295F218-8064
Address 18: Aux. Heat (J364)       Labels:| 7E0-963-27X-18.clb
   Part No SW: 7E0 963 272 B    HW: 7E0 963 272 B
   Component: STH-T5GP2     003 0009
   Coding: 4C01
   ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
   ROD: EV_AuxilParkiHeateWOST5G2.rod
   VCID: 2B03FA6EC383438F1B4-807E
0004 - System Voltage
          P0563 00 [009] - Too High
                    Reset counter: 0
                    Operating condition of parking heater: System malfunction
                    71
                    Coolant temperature of parking heater: 0 °C
                    Coolant temperature: 0 °C
                    Engine running status: not recognized
                    Fuel level: 0 l
                    Heater output: 0 W
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H80 0736
   Revision: B9080001
   Coding: 042201
   Component: IMMO          H05 1007
   VCID: 6A8D3F6A0CF99A87202-803E
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 1K8 035 150 D    HW: 1K8 035 150 D
   Component: MU-E--ER      857 6495
   Serial number: 17051600011418
   Coding: 065700003C00000041110001000000001F0000840000010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001025
   ROD: EV_MUEnt4CGen2LGE_VW12.rod
   VCID: 26150B5AD8617EE7C4A-8072
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0736
   Coding: 330B1A73
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 G    HW: 7E0 915 181 G
   Component: J367-BDM  H08 0223
   Serial number: 53116202481261973574
02256 - Quiescent Current
                    Fault Status: 00100001
                    Fault Frequency: 16
                    Reset counter: 107
                    Mileage: 55494 km
                    Date: 2018.11.08
                    Time: 01:09:52
   Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Component: Anhaenger     H12 0130
   Revision: 3B001001    Serial number: 00000402363523
   Coding: 410D000103000000
   VCID: 323DE70AE4291247582-8066
Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-W2.clb
   Part No SW: 7E5 919 037 G    HW: 7E5 919 037 G
   Component: Dachdisplay   H15 0185
   Revision: 10100011    Serial number: 429322
   Coding: 000102
   Shop #: WSC 02759 790 00000
   VCID: 3537DC161547057F7D0-8060
01207 - Control Module for Auxiliary Heater (J364)
                    Fault Status: 00111000
                    Reset counter: 107
                    Mileage: 56856 km
                    Date: 2018.11.21
                    Time: 21:23:42
End----------(Elapsed Time: 02:02, VBatt start/end: 12.0V/12.1V)-----------
darkchina811
ITALY
C?ID=333184
in order to transform a factory Aux heater into a Parking heater the control module needs to be replaced, usually. it is located on the Webasto itself.
then there might be wiring and probably coding. and of course the receiver for the remote.
Mika_M
C?ID=183725
Maybe I was unclear, this is already a parking heater, not aux heater. It just does not have a remote to start pre-heating, so you have to either use timer or walk to car and press button to start it.
darkchina811
ITALY
C?ID=333184
just a little bit :)
I checked ETKA but mine does not allow VIN search so please double check with a dealer before buying parts.
the remote is 3G0 963 511
the receiver is 3Q0 963 513
the receiver has 3 wires, +12V, GND and LIN bus that goes to the Webasto. buy one hour on erWin and download the necessary wiring diagram.
Mika_M
C?ID=183725
Thanks!
Additionally, is there any way to check that car doesn't already have this receiver installed...? With VCDS or by VIN? Or is it only possible by checking from car, if this receiver is physically installed or not?
Just wondering, there's always possibility that the remote fob has gone missing by some previous owner...
siLc
Tallinn, Estonia
C?ID=330192
At least on MQB cars, the receiver is a slave module to the 0x18. Your module looks like a MQB one but no slave module most probably means no physical receiver module present.
darkchina811
ITALY
C?ID=333184
+1, I bet my ass you don't have it.
Mika_M
C?ID=183725
Yes, so it seems. Found this as a reference scan: https://forums.ross-tech.com/showth...porter-T6-Address-18-Aux-Heat-Adaptation-FAIL
   Coding: 5901
   Shop #: WSC 28624 002 1048576
   VCID: 2B000D1DD38C4EBFF7A-807E
   Component: R64 D208L  004 0402
   Serial number: 00000000000000399683
So it seems, that receiver should be 3Q0 963 513 as stated earlier.
Next step, to buy this receiver (and remote fob). Then to erwin and learning how and where this module is actually installed at factory.
Thank you for your help so far!
darkchina811
ITALY
C?ID=333184
it's somewhere in the dash under the steering wheel area... but you can put it anywhere...
in my Golf it should be in the trunk but I put it behind the light switch;)
Mika_M
C?ID=183725
If You wait few days I can check both wiring diagram and part numbers based on VIN and some creative thinking.
Any news about this...?
I think that we would need receiver 3Q0 963 513, remote 3G0 963 511, wiring harness for receiver (for LIN, +12VDC, ground) and antenna for receiver. Am I forgetting something...?
darkchina811
ITALY
C?ID=333184
before May/2016 part numbers are different but I am not sure, that's why I suggested you to check with an online, updated ETKA.
anyway yes, that is the shop list.
Mika_M
C?ID=183725
Yes, I get that double-check would be necessary, that's why I was hoping that golfi_vend would have enough spare time to maybe help me out... :)
As I was checking from one online source, I found that 7N0963513B would be the receiver for 2016 7H Transporter. :confused:
EDIT: Maybe that was wrong, at least https://www.oemvwshop.com/ lists the 3Q receiver for 2016- models. 7N is for -2015 models.
darkchina811
ITALY
C?ID=333184
the official ETKA says the parts changed from May2016. my best bet is both pre and post 05-2016 sets would work as long as you match the set.
I mean, do not buy the pre-may remote and the post-may receiver cause they would not talk to each other.
I have an extra remote that I could sell, let me check the part number, I'll let you know.
golfi_vend
Tartu, Estonia
C?ID=195131
Promise is a Promise.
Remote:
You would need matching receiver and remote.
Receiver: 5Q0963513A and Remote: 5Q0963511
or
Reveiver: 3Q0963513 and Remote: 3G0963511 or 3G0963511A or 3G0963511B
Wiring(Connector for telestart: 6Q0972706 and wires: 000979009E)
1- Power from fuse SC54, same fuse as for time
2- LIN to Webasto pin T6au/2, Wire for webasto connector would be 000979009E and seal 3B0972742B
6- GND
Mika_M
C?ID=183725
Much appreciated! :thumbs:
darkchina811
ITALY
C?ID=333184
my extra remote is 7N0 963 511, so I guess it will stay on the shelf. damn :)
VWT6
C?ID=295527
Mika_M
C?ID=183725
Thanks, that's a good tip! Didn't go in to digging coding, when I did the auto-scan. But will definitely change this to pre-heat engine also. :thumbs:
