Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: VW Transporter 2016 - remote retrofit for factory webasto?
    Jun 2014
  2. #12
    Sep 2015
    If You wait few days I can check both wiring diagram and part numbers based on VIN and some creative thinking.
    Any news about this...?
    I think that we would need receiver 3Q0 963 513, remote 3G0 963 511, wiring harness for receiver (for LIN, +12VDC, ground) and antenna for receiver. Am I forgetting something...?
  3. #13
    Apr 2018
    ITALY
    before May/2016 part numbers are different but I am not sure, that's why I suggested you to check with an online, updated ETKA.
    anyway yes, that is the shop list.
  4. #14
    Sep 2015
    Yes, I get that double-check would be necessary, that's why I was hoping that golfi_vend would have enough spare time to maybe help me out...
    As I was checking from one online source, I found that 7N0963513B would be the receiver for 2016 7H Transporter.
    EDIT: Maybe that was wrong, at least https://www.oemvwshop.com/ lists the 3Q receiver for 2016- models. 7N is for -2015 models.
  5. #15
    Apr 2018
    ITALY
    the official ETKA says the parts changed from May2016. my best bet is both pre and post 05-2016 sets would work as long as you match the set.
    I mean, do not buy the pre-may remote and the post-may receiver cause they would not talk to each other.
    I have an extra remote that I could sell, let me check the part number, I'll let you know.
  6. #16
    Tartu, Estonia
    Promise is a Promise.
    Remote:
    You would need matching receiver and remote.
    Receiver: 5Q0963513A and Remote: 5Q0963511
    or
    Reveiver: 3Q0963513 and Remote: 3G0963511 or 3G0963511A or 3G0963511B
    Wiring(Connector for telestart: 6Q0972706 and wires: 000979009E)
    1- Power from fuse SC54, same fuse as for time
    2- LIN to Webasto pin T6au/2, Wire for webasto connector would be 000979009E and seal 3B0972742B
    6- GND
    The world is my oyster...
  7. Likes Mika_M, Uwe liked this post
  8. #17
    Sep 2015
    Much appreciated!
  9. #18
    Apr 2018
    ITALY
    my extra remote is 7N0 963 511, so I guess it will stay on the shelf. damn
  10. #19
    Jan 2017
    Mika_M, slightly off topic but I think the Webasto in your friends van currently does not preheat the engine (before starting) with that coding. It works only as cabin heater. To preheat also the engine using the timer (and in the future remote) you need to change coding from 4C01 to 4801 (or with remote 5801).
    More details in https://www.t6forum.com/threads/weba...ith-vcds.6824/
  11. Likes darkchina811, Mika_M liked this post
  12. #20
    Sep 2015
    Thanks, that's a good tip! Didn't go in to digging coding, when I did the auto-scan. But will definitely change this to pre-heat engine also.
  13. Likes VWT6 liked this post
