Results 1 to 10 of 20
Thread: VW Transporter 2016 - remote retrofit for factory webasto?
    Sep 2015
    My friend recently upgraded his van, bought this 2016 Transporter. It has factory installed auxiliary heater with options for timed pre-heating, but no remote control.
    What would we need in order to retrofit remote control? Some hardware should be installed, I presume? Or is it possible that there already is remote control, only that remote is missing...?
    Below is auto-scan with some errors too, but he tells me that everything is working as intended so we didn't go digging those...
    Friday,23,November,2018,15:33:23:26429
    VCDS Version: 18.9.0.1  HEX-V2 CB: 0.4436.4
    VIN: WV1ZZZ7HZGH144338   License Plate:
    Mileage: 57050km-35449mi   Repair Order:
    Chassis Type: 7H-VN75 (7E0)
    Scan: 01 03 04 08 09 15 17 18 19 25 5F 61 69 6E 0B
    VIN: WV1ZZZ7HZGH144338   Mileage: 57050km-35449miles
    6E-Ctrl Head Roof -- Status: Malfunction 0010
    Address 01: Engine (2D2D2-CXGB)       Labels:. 04L-907-309-V2.clb
       Part No SW: 04L 906 056 KA    HW: 04L 907 445
       Component: R4 2.0l TDI   H02 4047
       Revision: 23002001
       Coding: 0011401C433401090000
       Shop #: WSC 00000 790 50316
       ASAM Dataset: EV_ECM20TDI03004L906056KA 004003
       ROD: EV_ECM20TDI03004L906056KA.rod
       VCID: 76B51B1A48414E67B4A-8022
    33262 - Reductant System Performance Bank 1
              P204F 00 [100] - Malfunction
                        Mileage: 57002 km
                        Date: 2028.01.16
                        Time: 08:28:48
                        Engine speed: 2420.25 /min
                        Normed load value: 57.3 %
                        Vehicle speed: 102 km/h
                        Coolant temperature: 91 C
                        Intake air temperature: -1 C
                        Voltage terminal 30: 14.726 V
                        Simulated particle filter surface temperature: 283.5 C
                        Reducing agent fill level sensor: act. value: 73 mm
                        Sensor for reducing agent tank temperature: temperature: 3.3 C
                        Calculated NOx concentration behind turbocharger: 0 ppm
                        NOx sens.dwnstrm.SCR cat conv: NOx conc.: 206 ppm
                        Reducing agent quality sensor: urea concentration: 0.00 %
    31103 - SCR NOx Catalyst Bank 1
              P20EE 00 [100] - Efficiency too Low
                        Mileage: 56999 km
                        Date: 2028.01.16
                        Time: 08:26:41
                        Engine speed: 2424.25 /min
                        Normed load value: 51.0 %
                        Vehicle speed: 103 km/h
                        Voltage terminal 30: 14.742 V
                        Air mass at air mass meter 1: 205.2 kg/h
                        Extern.temp.sens.1 bank 1: raw value: -1.5 C
                        Mass airflow sensor 1 bank 1 airflow: raw value: 706.5 mg/stroke
                        Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
                        NOx sensor before SCR cat conv: offset correction factor: 0 ppm
                        NOx sensor after SCR cat conv: offset correction factor: 203 ppm
                        Reducing agent quality sensor: raw temperature value: 0.0 C
    16230 - Control Module for Instrument Cluster
              U1019 00 [032] - Missing Signal for Oil Level/Temperature
              [Instrument cluster control moduleMissing signal oil level/temperature]
    Readiness: N/A
    Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
       Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
       Component: ESC           H05 0132
       Revision: 00000000    Serial number: 41226000000341
       Coding: 557E409825668482AA780279A48A21E6780000
       Shop #: WSC 02739 790 50316
       VCID: 3FDBBE3E27FBCF2FA7C-806A
       Part No SW: 6R0 959 654     HW: 6R0 959 654
       Component: LENKW.SENSOR  H07 0070
       Serial number: 10031613471249
       Coding: 01
       ROD: EV_LWSKLOVW25X.rod
       VCID: 7EA5033A60710627ECA-802A
       Part No SW: 7E0 907 047 AF    HW: 7E0 907 047 AF
       Component: Climatic-T5   H22 0708
       Revision: 00001002
       Coding: 0000000003
       Shop #: WSC 02737 790 50316
       ROD: EV_ClimaT5Basis.rod
       VCID: 6E85337A301176A77CA-803A
       Part No SW: 7E0 937 090     HW: 7E0 937 090
       Component: BCM PQ25 Max4 H80 0736
       Revision: B9080001    Serial number: 0771 127160658
       Coding: 62A0303A0A212032002009742C2B8CD40F90708F60444D60320000220800
       Shop #: WSC 02737 022 1974138
       VCID: 688945621275A897366-803C
       Subsystem 1 - Part No SW: 7E0 959 801 M    HW: 7E0 959 801 M
       Component: J386__TSG_FT  003 0653
       Serial number: KU0KU009051661306101
       Coding: 0400A0
       Subsystem 2 - Part No SW: 7E0 959 802 M    HW: 7E0 959 802 M
       Component: J387__TSG_BT  003 0653
       Serial number: KU0KU009051661303377
       Coding: 1400A0
       Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
       Component: VW10Airbag01L H08 0018
       Revision: --------    Serial number: 003V3000RZMZ
       Coding: 00000000000000000000000000000000314C
       Shop #: WSC 02734 790 50316
       VCID: 3A2DCF2A3CD9EA07902-806E
       Part No SW: 7E0 920 860 L    HW: 7E0 920 860 L
       Component: KOMBI         H05 1007
       Coding: 1603010300
       VCID: 313FE806E1AF295F218-8064
    Address 18: Aux. Heat (J364)       Labels:| 7E0-963-27X-18.clb
       Part No SW: 7E0 963 272 B    HW: 7E0 963 272 B
       Component: STH-T5GP2     003 0009
       Coding: 4C01
       ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
       ROD: EV_AuxilParkiHeateWOST5G2.rod
       VCID: 2B03FA6EC383438F1B4-807E
    0004 - System Voltage
              P0563 00 [009] - Too High
                        Reset counter: 0
                        Operating condition of parking heater: System malfunction
                        71
                        Coolant temperature of parking heater: 0 C
                        Coolant temperature: 0 C
                        Engine running status: not recognized
                        Fuel level: 0 l
                        Heater output: 0 W
       Part No SW: 7E0 909 901     HW: 7E0 937 090
       Component: GW-K-CAN TP20 H80 0736
       Revision: B9080001
       Coding: 042201
       Component: IMMO          H05 1007
       VCID: 6A8D3F6A0CF99A87202-803E
       Part No SW: 1K8 035 150 D    HW: 1K8 035 150 D
       Component: MU-E--ER      857 6495
       Serial number: 17051600011418
       Coding: 065700003C00000041110001000000001F0000840000010001
       ASAM Dataset: EV_MUEnt4CGen2LGE 001025
       VCID: 26150B5AD8617EE7C4A-8072
       Part No SW: 7E0 907 534     HW: 7E0 937 090
       Component: Batt.regelung H80 0736
       Coding: 330B1A73
       Shop #: WSC 02739 790 00000
       Subsystem 1 - Part No SW: 7E0 915 181 G    HW: 7E0 915 181 G
       Component: J367-BDM  H08 0223
       Serial number: 53116202481261973574
    02256 - Quiescent Current
                        Fault Status: 00100001
                        Fault Frequency: 16
                        Reset counter: 107
                        Mileage: 55494 km
                        Date: 2018.11.08
                        Time: 01:09:52
       Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
       Component: Anhaenger     H12 0130
       Revision: 3B001001    Serial number: 00000402363523
       Coding: 410D000103000000
       VCID: 323DE70AE4291247582-8066
    Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-W2.clb
       Part No SW: 7E5 919 037 G    HW: 7E5 919 037 G
       Component: Dachdisplay   H15 0185
       Revision: 10100011    Serial number: 429322
       Coding: 000102
       Shop #: WSC 02759 790 00000
       VCID: 3537DC161547057F7D0-8060
                        Fault Status: 00111000
                        Reset counter: 107
                        Mileage: 56856 km
                        Date: 2018.11.21
                        Time: 21:23:42
    End----------(Elapsed Time: 02:02, VBatt start/end: 12.0V/12.1V)-----------
    Apr 2018
    ITALY
    in order to transform a factory Aux heater into a Parking heater the control module needs to be replaced, usually. it is located on the Webasto itself.
    then there might be wiring and probably coding. and of course the receiver for the remote.
    Sep 2015
    Maybe I was unclear, this is already a parking heater, not aux heater. It just does not have a remote to start pre-heating, so you have to either use timer or walk to car and press button to start it.
    Apr 2018
    ITALY
    just a little bit
    I checked ETKA but mine does not allow VIN search so please double check with a dealer before buying parts.
    the remote is 3G0 963 511
    the receiver is 3Q0 963 513
    the receiver has 3 wires, +12V, GND and LIN bus that goes to the Webasto. buy one hour on erWin and download the necessary wiring diagram.
  5. Likes Mika_M liked this post
    Sep 2015
    Thanks!
    Additionally, is there any way to check that car doesn't already have this receiver installed...? With VCDS or by VIN? Or is it only possible by checking from car, if this receiver is physically installed or not?
    Just wondering, there's always possibility that the remote fob has gone missing by some previous owner...
    Jul 2014
    Tallinn, Estonia
    At least on MQB cars, the receiver is a slave module to the 0x18. Your module looks like a MQB one but no slave module most probably means no physical receiver module present.
    Apr 2018
    ITALY
    +1, I bet my ass you don't have it.
  9. #8
    Sep 2015
    Yes, so it seems. Found this as a reference scan: https://forums.ross-tech.com/showthr...daptation-FAIL
       Coding: 5901
       Shop #: WSC 28624 002 1048576
       VCID: 2B000D1DD38C4EBFF7A-807E
       Component: R64 D208L  004 0402
       Serial number: 00000000000000399683
    So it seems, that receiver should be 3Q0 963 513 as stated earlier.
    Next step, to buy this receiver (and remote fob). Then to erwin and learning how and where this module is actually installed at factory.
    Thank you for your help so far!
  10. Likes jyoung8607 liked this post
  11. #9
    Apr 2018
    ITALY
    it's somewhere in the dash under the steering wheel area... but you can put it anywhere...
    in my Golf it should be in the trunk but I put it behind the light switch
  12. #10
    Tartu, Estonia
    If You wait few days I can check both wiring diagram and part numbers based on VIN and some creative thinking.
    I am a VW Freak - Le WV Freaks OR Come visit me at my work with ODIS concerns - FORSS ODIS GeKo/FaZit access for VW/AUDI/koda
    The world is my oyster...
  13. Likes Uwe, Mika_M liked this post
