Results 1 to 2 of 2
Thread: 2011 Golf TDI Auxiliary heater won't start when it should
    New User
    Nov 2018
    Lithuania
    Hello everyone,
    I drive 2011 Golf 2.0 TDI (CFHC), which have auxiliary heater (z35) installed as standard. The problem is it won't turn on naturally, never. I can get it work only by using bidirectional control (output test) for low and high heat output relays. Just to be sure, I checked the heater element, wiring integrity, no fault codes - everything is fine, except ECU won't commanding it on when it should.
    According to ELSA, Z35 test condition are:
    Intake air temperature less than 16C
    Coolant temperature less than 80C
    Passenger compartment temperature about 20C
    Battery voltage greater than 11V
    Alternator load not greater than 50%
    Engine speed greater than 450 RPM.
    Turn rotary knob for interior temperature to end position for maximum temperature.
    And I'm sure that every single condition in that list is met, all the sensors are working fine.
    I made an observation and took some measuring values samples from my and known good car, with exactly the same aux. heater system:
    As you can see, in my car there is a "1" at he begging of the row in "Electric auxiliary heater: shut-off conditions Bit-0" parameter, which prevents auxiliary heater from turning on, despite that every single condition is met. I'm out of ideas how to solve this. What is the condition, which cause that "1" to appear?
    The design of this system is super simple: two relays turning that heater element on and off. When necessary conditions are met, ECU provides ground to high or low heat relay control side and turns heater element on.
    You can also find wiring diagrams below:
    https://i.imgur.com/zNlmFOU.png
    https://i.imgur.com/x3FbxAM.png
    Autoscan:
    Wednesday,28,November,2018,20:21:01:34902
    VCDS Version: 18.9.0.1 (x64)  HEX-NET CB: 0.4436.4
    VIN: WVWZZZ1KZBM653841   License Plate: GOLF6
    Mileage: 235660km-146432mi   Repair Order:
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 52 56 62 72 77
    VIN: WVWZZZ1KZBM653841   Mileage: 235660km-146432miles
    Address 01: Engine (J623-CFHC)       Labels:. 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 AN    HW: 03L 907 309 R
       Component: R4 2,0L EDC   H22 9015
       Revision: 42H22---    Serial number: 00000000000000
       Coding: 00190012042400080000
       Shop #: WSC 78387 152 12345
       ASAM Dataset: EV_ECM20TDI01103L906018AN 003008
       ROD: EV_ECM20TDI01103L906018AM_003_VW36.rod
       VCID: F6A09F40494FEBFA7C-80A2
    Address 03: ABS Brakes (J104)       Labels:. User\1K0-907-379-60EC1F.lbl
       Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
       Component: ESP MK60EC1   H31 0108
       Revision: 00H31001
       Coding: 143B600D092700FD281306E8901A0042350000
       Shop #: WSC 00066 123 12345
       VCID: F6A09F40414FEBFA7C-80A2
       Part No SW: 5K0 907 044 DT    HW: 5K0 907 044 DT
       Component: Climatronic   H17 1010
       Revision: 00003001
       Coding: 0000000002
       Shop #: WSC 00066 000 00149
       VCID: 804CF9981B8BD54A56-80D4
       Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
       Component: BCM PQ35 M    011 0045
       Revision: BC011001
       Coding: 00180E3A882D02C040080080340081E447790088537D8140648000200040
       VCID: BB364E743AED769243-80EE
       Component: Wischer 23111  26  0512
       Coding: 009795
       Component: RLS 081010 05  54  0403
       Coding: 03302D
       Part No SW: 1K9 919 475 A    HW: 5K0 919 475 E
       Component: PARKHILFE 8K  H01 0004
       Revision: --------    Serial number: 12591032319252
       Coding: 108003
       VCID: B93A547C30D1448251-80EC
       Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
       Component: AirbagVW10    012 0612
       Serial number: 003G6D0395NZ
       Coding: 00003536
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: B2286350E5A7B7DA90-80E6
       Subsystem 1 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Serial number: 3572MSME75604558ZZZX
       Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
       Serial number: 3582MSME1A460258ZZZU
       Serial number: 3511HSME194B6324ZZZL
       Serial number: 3521HSME3C423C24ZZZO
       Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
       Component: Lenks.Modul   007 0080
       Revision: --------    Serial number:  90422JJJ000C4
       Coding: 1082140000
       Shop #: WSC 00066 000 00158
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: F2A8A3502527F7DA50-80A6
       Component: E221__MFL-TAS  H07 0013
       Serial number: 0132234
       Coding: 820000
       Part No SW: 5K0 920 871 AX    HW: 5K0 920 871 AX
       Component: KOMBI         H20 0420
       Coding: 171B01
       Shop #: WSC 06494 995 29333
       VCID: 8444F5880F93C96A72-80D0
    Address 19: CAN Gateway (J533)       Labels:. User\7N0-907-530-V2.lbl
       Part No SW: 7N0 907 530 C    HW: 1K0 907 951
       Component: J533  Gateway H37 0614
       Revision:   H37       Serial number: 18111001210777
       Coding: 352002
       VCID: B02C6958E3AB85CAE6-80E4
       Component: IMMO          H20 0420
       VCID: EA98BB300DF73F1AE8-80BE
       Revision: A1001003    Serial number: 7668721145
       Coding: 020000
       VCID: A71E8204D665C27237-80F2
    Address 37: Navigation (J794)       Labels:| 3C0-035-270.clb
       Part No SW: 3C0 035 270 B    HW: 3C0 035 270
       Component: RNS310        H18 0357
       Revision: 10000000    Serial number: VWZ1Z2K6328197
       Coding: 040004010400000000000000
       Shop #: WSC 01383 790 50316
       ASAM Dataset: VW_RNS310 A02005
       ROD: EV_VWRNS310UDS.rod
       VCID: 997AB4FC98116482B1-80CC
       Part No SW: 3C0 959 701 C    HW: 3C0 959 793 A
       Component: TUER-SG FT    002 0307
       Revision: 12101005    Serial number: 0001703062
       Coding: 0010B6
       ASAM Dataset: EV_DCU42BroseDriveSide A03004
       ROD: EV_DCU42BroseDriveSide_VW36.rod
       VCID: A81C8138D37BCD0A3E-80FC
       Slave Driver:
       Subsystem 1 - Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  006 1401
       Serial number: 00000005397568
       Coding: 000090
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 70     3001
       Revision: 00H17000
       VCID: B12A6C5C28A18CC2E9-80E4
       Part No SW: 3C0 959 702 C    HW: 3C0 959 792 A
       Component: TUER-SG BT    002 0307
       Revision: 14101005    Serial number: 0001712156
       Coding: 0011B6
       ASAM Dataset: EV_DCU52BrosePasseSide A03004
       ROD: EV_DCU52BrosePasseSide_VW36.rod
       VCID: A91A843CC871F40221-80FC
       Slave Passenger:
       Subsystem 1 - Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  006 1401
       Serial number: 00000005373095
       Coding: 000090
       Part No SW: 7P6 035 730 B    HW: 7P6 035 730 B
       Component: TELEFON       H05 0440
       Revision: 1B001001    Serial number: 00007668680859
       Coding: 0A01000000010101
       ASAM Dataset: UHVNA A01007
       ROD: UHVNA.rod
       VCID: B12A6C5CE0A18CC2E9-80E4
    End----------(Elapsed Time: 01:14, VBatt start/end: 14.1V/14.0V)-----------
  2. Likes Uwe liked this post
  3. #2
    New User
    Nov 2018
    Lithuania
    In my country there is a saying: prepare the horse sleigh in the summer, and the carriage in the winter. So I still haven't found an answer yet and have been driving throughout all the winter without it. Is there any way to find out which condition that bite indicates? Any thoughts are welcome
