Results 1 to 9 of 9
Thread: Retrofit rear camera A6 2017 MMI?
    Oct 2016
    Norway
    I need some help with this project.
    Cannot find a complete kit anywhere because this is a FL and doesn't use the same camera module.
    Is CP going to be a problem retrofitting this? (if it's possible)
    Thank you in advance for any help
    Feb 2016
    Czech Republic
    Use aftermarket rear camera...
    I have both on Audi A6 4G - original and cheap China camera - and China have much more better picture.
    I used RoadPassion (is now only on Alibaba) interface with dynamic guidelines from Ali and also camera from Ali. The camera you will buy have not to have static lines !!! Best is with CCD chip Sony.
    Now I have AreaView and cannot swap original camera for China ones , because it have different optical so Area View can be splitted :-(
    Oct 2016
    Norway
    Super, thank you for the tip 👍
    Oct 2016
    Norway
    Cannot find a way to code 5f.
    Tried byte 7 bit 1 and byte 6 bit 2. Only getting wrong coding fault.
    6c and gateway is without fault.
    Oct 2016
    Norway
    Saturday,08,December,2018,04:50:41:07409
    VCDS Version: 18.9.0.2
    VIN: WAUZZZ4G9HN063358   License Plate: ALLROAD
    Mileage: 12556km-7801mi   Repair Order:
    Chassis Type: 4G-AU57 (4G8)
    Scan: 01 02 03 05 08 09 13 15 16 17 18 19 20 22 28 34 36 3B 3C 42
              44 46 52 53 55 5F 62 69 6C 6D 72 85 8B 8E 8F 90 A9 AC C0
    VIN: WAUZZZ4G9HN063358   Mileage: 12556km-7801miles
    17-Instruments -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CVUA)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 589 F    HW: 4G0 907 589 B
       Component: 3.0BTD EDC17  H23 0001
       Revision: 54H23---
       Coding: 322A403A25760B030000
       ASAM Dataset: EV_ECM30BTD0114G0907589F 001001
       ROD: EV_ECM30BTD0114G0907589F.rod
       VCID: 3779D3088E5175F224-8062
       Part No SW: 4G0 927 158 BC    HW: 0BK 927 156 AM
       Component: 0BK 30RTDIRdW H22 1003
       Revision: --H22---
       Coding: 000001
       VCID: 70EB2814ABBFE2CA25-8024
       Coding: 49B7DE4D92ED7BB2BB00
       ROD: EV_ESP9BOSCHAU57X.rod
       VCID: 418DBDD0D0953B429A-8014
       Part No SW: 4H0 907 064 HP    HW: 4H0 907 064 HP
       Component: BCM2 2.0      H61 0825
       Coding: 05A96F0E000000000000
       VCID: 7EF7062CE9EB84BAA7-802A
       Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
       Serial number: 18101600041716
       Coding: 369211782D0000
       VCID: 63C157586A494952A8-8036
    Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
       Part No SW: 4H0 907 063 GH    HW: 4H0 907 063 AH
       Component: BCM1 2.0      H20 0368
       Revision: 15020001    Serial number: 00001495856201
       Coding: 0105C01440349FE2E90140C7A0001800CF9C67082E08020180000894E10117020040002D030000
       VCID: 74E32404D7A7DEEAC1-8020
       Component: WWS57X 160903  H38 0080
       Serial number:         160914092411
       Coding: 0045F7
       Serial number: 62365055
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
       Component: E1 - LDS  H07 0044
       Serial number: 21 10 2016  00000479
       Subsystem 4 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA125469000025976063
       Coding: 020300
       Subsystem 5 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H01 0005
       Serial number: D5C8025800PAG0MUFU03
       Part No SW: 4G0 907 561 B    HW: 4G0 907 561
       Component: ACC3          H21 0055
       Coding: 7F04010202
       ASAM Dataset: EV_AdaptCruisContrAU57X 002015
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: 295D057048E5D302A2-807C
       Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
       Component: Airbag10.43   H82 0086
       Revision: --------    Serial number: 003P100BLR79
       Coding: 30333130313730323630554A304C34473053
       VCID: 3B71CF38B2795192C0-806E
       Serial number: 3575HRB405L46U745O7K
       Serial number: 3585HRB405P46HMS19AZ
       Serial number: 3515JRB4014577K0M99U
       Serial number: 3525JRB4014577K0D97K
       Serial number: 3554VRB400A57EUID0U2
       Serial number: 3564VRB400A57EUIG0O0
    9445397 - Key switch for deactivation of passenger-side airbag
              B1020 15 [137] - Open or Short to Plus
                        Mileage: 12556 km
                        Date: 2018.12.07
                        Time: 00:31:32
    9446677 - Redundant signal path for airbag shut-off; passenger side
              B1025 15 [137] - Open or Short to Plus
                        Mileage: 12556 km
                        Date: 2018.12.07
                        Time: 00:31:31
       Component: Lenks.Modul   H05 0005
       Revision: --------    Serial number: 90372PJC000E1
       Coding: 0004FD
       VCID: 387BD0348B4F7A8A2D-806C
       Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
       Serial number: 14 06 2016  C0025886
       Part No SW: 4G9 920 951 L    HW: 4G9 920 951 L
       Component: TDieRdwAccNv  H14 0225
       Revision: 13001303    Serial number: 658171016596009
       Coding: 138625089F550008010600
       ASAM Dataset: EV_RBD4K 004060
       ROD: EV_RBD4K.rod
       VCID: 3A7FCA3CBD43689ADB-806E
    Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
       Part No SW: 4H0 265 105 J    HW: 4H0 265 105 J
       Component: Standheizung  H26 0270
       Revision: 77007007    Serial number: 20160101034157
       Coding: 5D3F01
       VCID: 295D057040E5D302A2-807C
       Part No SW: 4G8 907 468 H    HW: 4G8 907 468
       Component: J533--Gateway H15 0096
       Revision: --------    Serial number: 00000002410892
       Coding: C0CD078118
       VCID: 3D75C120AC6D5FA2FE-8068
       Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
       Serial number: 9435731604
       Voltage stabilizer:
       Serial number: 16082200000000000062
       Part No SW: 4H0 857 511     HW: 4H0 857 511
       Component: FLA           H04 0021
       Revision: AA001002
       VCID: 67D943489671257274-8032
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H19 0200
       Serial number: 001410160001015
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
       VCID: 285B007453EFEA0ABD-807C
       Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
       Component: KLIMA FOND    H08 0113
       Serial number: 19101600041572
       Coding: 21
       Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
       Component: LUFE-DAEMPFER H19 0783
       Coding: 008003
       ASAM Dataset: EV_AirSuspe 003025
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2F69EB687601BD327C-807A
       Revision: AA000000    Serial number: 00000223371353
       VCID: 77F91308C6D1B5F2E4-8022
       Component: SARA 6D red   H04 0056
       Revision: --------    Serial number: EJ1BPA7E02F4TM
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
       Component: SWA Master    H08 0070
       Serial number: 0419525758
       Coding: 040321
       VCID: 397DD530B8456382D2-806C
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
       Component: SWA Slave  H08 0070
       Serial number: 0419793356
       Coding: 040321
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0511
       Coding: 011F16015E00628002080013
       VCID: 4585A9C0CCBD1762A6-8010
       Component: RCevo         H54 0202
       Revision: 00000001    Serial number: 0000354032
       Coding: 101001010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106.rod
       Revision: 00002001    Serial number: 0420222852
       Coding: 013A0E20A0B93095C32009842E010F470000000000000000000000000000
       Subsystem 1 - Part No: 4G0 951 177 B
       Component: Sensor, DWA  005 0002
       Subsystem 3 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS20.403  H03 0004
       Serial number: 0000FST0018EGZ200000
       Coding: 901F00
       Subsystem 4 - Part No SW: 4G0 947 135 K    HW: 4G0 947 135
       Serial number: 0000000AP00025865396
       Subsystem 5 - Part No SW: 4G9 959 591 A    HW: 8V3 959 591 A
       Component: J394 PS20.403  H03 0004
       Serial number: 0000FST0018EO3E00000
       Coding: 801F00
       Coding: 011F16015E00628002080002
       VCID: 4687AECCF1BB1C7AAF-8012
       Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
       Component: EPB-4         H01 0018
       Revision: --------    Serial number: 00000001964238
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 326FE21C653390DA13-8066
       Coding: 04FA02102A630200
       VCID: 3463E4049F279EEA01-8060
       Coding: E01E00
       Coding: E01E00
       Part No SW: 4G1 035 020 F    HW: 4G1 035 020 D
       Component: MU-H-ND-EU    051 0670
       Serial number: A735J0G7501286
       Coding: 017542010000000013111102000A00002F000AE5F17001009F
       VCID: 1C332CA417B736AA29-8048
       Subsystem 1 - Part No SW: V03 959 801 FB    HW: -----------
       Component: ECE 2016/2017  --- 0153
       Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
       Serial number: AUZ8Z9GY806EPG
       Multimedia Operating Unit:
       Serial number: 90349PJD0005P
       Component: Gracenote2---  --- 1013
       Coding: 010F14004000628002080002
       VCID: 499DA5F0E0A5F30242-801C
    Address 69: Trailer (J345)       Labels:| 4H0-907-383-V2.clb
       Part No SW: 4G8 907 383 B    HW: 4G8 907 383 B
       Component: Anhaenger     H20 0160
       Revision: 7B001003    Serial number: 0419325132
       Coding: 0100000202000000
       VCID: 3361E7189A2999D218-8066
    Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
       Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
       Component: D4-PA RVC Mid H07 0050
       Coding: 027502010201000300
       Shop #: WSC 79104 790 00000
       ASAM Dataset: EV_CamSysRearPANAAU914 002002
       ROD: EV_CamSysRearPANAAU914_VW51.rod
       Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
       Component: HDSG-Modul    H05 0152
       Revision: 14005001    Serial number: 287600108
       Coding: 093205C031
       ROD: EV_HDSGAu571.rod
       VCID: 3667DE0C895B8CFA3F-8062
    0004 - No Basic Setting
              B2010 00 [137] -  -
                        Reset counter: 60
                        Mileage: 12556 km
                        Date: 2018.12.07
                        Time: 02:25:25
                        Voltage terminal 30: 11.93 V
       Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
       Component: DPC-SG        H27 0081
       Coding: EA060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2C53FC644717C62A59-8078
       Part No SW: 4G0 907 541 B    HW: 4G0 907 541
       Coding: 7F04010202
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
       ROD: EV_AdaptCruisContr2AU57X_002.rod
       VCID: 275903485EF1E572B4-8072
       Part No SW: 4H0 907 107 H    HW: 4H0 907 107
       Component: BV-SG         H34 0090
       Serial number: 005002452010167
       Coding: 04C0BB1E1111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
    0049 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Reset counter: 60
                        Mileage: 12556 km
                        Date: 2018.12.07
                        Time: 02:15:07
                        Outside air temperature: 13.5 °C
                        Voltage terminal 15: 12.0 V
                        Control Module temperature: 21.0 °C
       Component: RGS-VL        H16 0080
       Coding: 0066E608031F0376070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 316DED106035ABC26A-8064
       Component: RGS-VR        H16 0080
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       Part No SW: 4G0 907 159 D    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0007
       Serial number: 160925200495
       VCID: 2E57F66C710BB43A77-807A
       Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0013
       Revision: 00000000    Serial number: 162560084
       ROD: EV_RDCMA00100_008.rod
    Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
       Part No SW: 4G0 907 160 E    HW: 4G0 907 160 B
       Component: SAS-GEN 2 AGA H09 0011
       Serial number: 160908200473
    End-------------------------(Elapsed Time: 06:50)--------------------------
    Oct 2016
    Norway
    Is byte 19 bit 4 worth a try?
  7. #7
    Sure, if you are talking about [5F].
    That is for Rearcamera Low (RVC).
  8. Likes Uwe liked this post
  9. #8
    Oct 2016
    Norway
    Byte 19 bit 4 was the solution
  10. Likes Uwe liked this post
  11. #9
    Verified VCDS User A I S's Avatar
    Feb 2019
    S.London Kent
    Did that work . 19 and 4
