New battery drains, sometimes lasts for days. have to clear codes to allow jumpstart
Kevin Mann
Canada
C?ID=325784
Chassis Type: 4L0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 36 37 42 46 47 4F
          52 53 55 56 61 62 67 6C 72 76 77
   Mileage: 98170km-61000miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Malfunction 0010
0F-Digital Radio -- Status: Not registered 0001
15-Airbags -- Status: Cannot be reached 1100
1E-Media Player 2 -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 1010
53-Parking Brake -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
67-Voice Control -- Status: Malfunction 0010
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
   Part No SW: 4F0 910 852 A    HW: 4F0 905 852 C
   Component: FBSAUDIC6 ELVSG H01 0030
   Revision: 31050601    Serial number: 10601200590330
   Coding: 0000007
   Shop #: WSC 02323 785 00200
   VCID: 241111D4C2DA4387DAD-8070
   Subsystem 1 - Part No: 4F0 910 131 L
   Component: FBSAUDIC6 KSG   H27 0080
6 Faults Found:
                    Fault Frequency: 17
                    Reset counter: 144
                    Mileage: 98175 km
                    Date: 2018.10.24
                    Time: 14:12:56
00190 - Driver's Door Handle Touch Sensor (G415)
                    Fault Status: 00111011
                    Reset counter: 144
                    Mileage: 98175 km
                    Date: 2018.10.24
                    Time: 14:26:57
00288 - Steering Column Lock Actuator (N360)
            014 - Defective
                    Fault Status: 01111110
                    Reset counter: 104
                    Mileage: 98175 km
                    Date: 2018.10.24
                    Time: 17:10:53
                    Reset counter: 144
00532 - Supply Voltage B+
                    Reset counter: 144
                    Mileage: 98174 km
                    Date: 2006.05.10
                    Time: 14:34:55
                    Reset counter: 144
                    Mileage: 98174 km
                    Date: 2006.05.10
                    Time: 14:33:58
   Part No SW: 4F0 910 732 R    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4610
   Revision: 00000000    Serial number: 361KK067510404
   Coding: 0000003
   Shop #: WSC 02335 785 00200
   VCID: 323DE78C882EDD37581-8066
   Subsystem 2 - Serial number: 00000000593110
   Subsystem 3 - Serial number: 0123.11.060000000100010873ÿ
   Subsystem 4 - Serial number: 010873ÿ
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Reset counter: 104
                    Mileage: 98174 km
                    Date: 2006.05.10
                    Time: 12:00:47
                    Reset counter: 144
                    Mileage: 98174 km
                    Date: 2006.05.10
                    Time: 14:36:55
   Part No SW: 4F0 910 043 A    HW: 4F1 820 043 AG
   Component: KLIMABETAETIGUNGH30 0020
   Revision: 00000052    Serial number: 00000000331514
   Coding: 0532520
   Shop #: WSC 02325 785 00200
   VCID: 1C612934FAAA7B4762D-8048
   Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
   Coding: 0113114
   VCID: 3039ED848622EF272E5-8064
   Subsystem 1 - Component: Fehler Lin-Slave 01
   Subsystem 2 - Component: Fehler Lin-Slave 02
                    Reset counter: 144
00456 - Control Module for Access and Start Control (J518)
                    Reset counter: 144
                    Mileage: 98172 km
                    Date: 2018.10.24
                    Time: 17:30:00
                    Reset counter: 144
                    Mileage: 98172 km
                    Date: 2006.05.10
                    Time: 14:24:00
                    Reset counter: 144
                    Mileage: 98172 km
                    Date: 2006.05.10
                    Time: 14:28:00
Address 0E: Media Player 1 (R199)       Labels:. 4E0-035-785.lbl
   Part No SW: 4E0 035 785 F    HW: 4E0 035 785
   Component: SG ext.Player H09 0850
   Revision: 00000000
   Shop #: WSC 131071 1023 08191
   VCID: 2B03FAE8A3048CFF1B7-807E
                    Reset counter: 0
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 K    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0140
   Revision: 00000000    Serial number: AUZ4Z7G0198985
   Coding: 0000100
   VCID: 2F3BEEF89B1CF0DF37F-807A
Address 15: Airbags
Address 16: Steering wheel
   Part No SW: 4F0 910 930 C    HW: 4F0 920 931 T
   Component: KOMBIINSTR. M73 H19 0120
   Revision: 00000000    Serial number: 5HN53GGC6
   Coding: 2113368
   Shop #: WSC 45359 002 1048576
   VCID: 231312C8C7D444BFA37-8076
   Part No SW: 4L0 910 468     HW: 4L0 907 468
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0900B06A308058
   Coding: F5D1DE77707206
   Shop #: WSC 02334 785 00200
   VCID: 6C8139F46A8A4BC752D-8038
                    Reset counter: 104
                    Mileage: 98175 km
                    Date: 2018.10.24
                    Time: 17:05:59
                    Fault Frequency: 27
                    Reset counter: 144
                    Mileage: 98175 km
                    Date: 2018.10.24
                    Time: 14:12:56
                    Fault Status: 00101011
                    Reset counter: 144
                    Mileage: 98175 km
                    Date: 2018.10.24
                    Time: 14:30:39
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 E    HW: 4E0 035 110 A
   Component: MP3-Changer     H44 0390
   Revision: 00044000    Serial number: AUZ5ZBF3117101
   VCID: 1A6D2F2CF09E0577701-804E
                    Reset counter: 144
                    Mileage: 98174 km
                    Date: 2006.05.10
                    Time: 14:38:55
   Coding: 0082954
   VCID: 619F58C09D4816AFF1B-8034
                    Reset counter: 144
                    Mileage: 98172 km
                    Date: 2006.05.10
                    Time: 14:36:33
   Part No SW: 4E0 910 888 M    HW: 4E0 919 887 L
   Component: MNS US          H48 1100
   Revision: 00000000    Serial number: 381KV067514328
   VCID: 3829D5A46E523767665-806C
Address 46: Central Conv.
   Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
   Component: DSP-High C6     H10 0240
   Revision: PROD_01     Serial number: 00000000004285
   Coding: 0000026
   VCID: 25170CD0C9E0BA8FCD3-8070
00419 - Left Front DSP Midrange Speaker (R103)
                    Fault Frequency: 31
                    Reset counter: 144
                    Mileage: 98175 km
                    Date: 2018.10.24
                    Time: 14:31:42
                    Fault Frequency: 28
                    Reset counter: 144
                    Mileage: 98175 km
                    Date: 2018.10.24
                    Time: 14:34:43
   Part No SW: 4F0 910 280     HW: 4F0 907 280 B
   Revision:             Serial number: 00000000059043
   Coding: 0012014
   VCID: 5EE5633CAC362957CC9-800A
                    Reset counter: 144
                    Mileage: 98172 km
                    Date: 2018.10.24
                    Time: 17:30:00
                    Voltage: 11.600 V
                    Temperature: 77.0°C
                    Reset counter: 144
                    Mileage: 98172 km
                    Date: 2018.10.24
                    Time: 17:35:00
                    Voltage: 11.600 V
                    Temperature: 77.0°C
Address 52: Door Elect, Pass.
Address 53: Parking Brake
Address 55: Headlight Range
   Part No SW: 4E0 910 541 T    HW: 4F0 035 541 H
   Revision: 00000000    Serial number: 394K1067709259
   VCID: 313FE8808D28E62F21B-8064
                    Reset counter: 144
                    Mileage: 98174 km
                    Date: 2006.05.10
                    Time: 14:38:47
   Revision: 00000000    Serial number: 00000000152229
   Shop #: WSC 02457 002 1048576
   Component: von MLA  1234567890
   Coding: 34463039313531303544204D4C4131323334353637383930
02272 - Quiescent Current Stage 1
            000 -  -  - Intermittent
                    Fault Frequency: 15
                    Date: 2018.10.19
                    Time: 04:20:37
                    Fault Frequency: 12
                    Mileage: 97912 km
                    Date: 2018.10.19
                    Time: 05:26:51
                    Reset counter: 144
                    Mileage: 98175 km
                    Date: 2018.10.24
                    Time: 17:30:23
02276 - Quiescent Current Stage 5
                    Fault Frequency: 7
                    Mileage: 98175 km
                    Date: 2018.10.24
                    Time: 17:35:16
                    Mileage: 98174 km
                    Date: 2006.05.10
                    Time: 14:29:20
Address 62: Door, Rear Left
   Component: SDS 3501 US     H45 0630
   Revision: 00000000    Serial number: 00000611180090
   Shop #: WSC 12336 024 394758
   VCID: 3431E194723AD3074AD-8060
                    Reset counter: 144
                    Mileage: 98174 km
                    Date: 2006.05.10
                    Time: 14:35:45
Address 6C: Back-up Cam.
Address 72: Door, Rear Right
   Part No SW: 4F0 910 283 F    HW: 4F0 919 283 F
   Revision: 00H09000    Serial number: 06220631905651
   Coding: 0021206
   VCID: 270B06D8B3ECA89FFFF-8072
                    Reset counter: 40
                    Mileage: 98175 km
                    Date: 2018.10.24
                    Time: 17:30:23
   Component: Handyvorb2      H16 1130
   Revision: 00000000    Serial number: 00000007555921
   Coding: 0010900
   VCID: 280905E4BEF2A7E7F65-807C
End----(Elapsed Time: 01:41, VBatt start/end: 11.7V/11.7V. VIgn 0.0V)------
RyMar
South Africa
C?ID=133909
Do you have clamp tester or multimeter to test for current draw at battery? Close and lock all doors (alarm) and wait at least 2min for all systems to go into `sleep` mode and check draw.
siLc
Tallinn, Estonia
C?ID=330192
In addition to this, also close the hood latch because it's usually monitored by the factory alarm.
And you might want to post an autoscan with the ignition turned on - a lot is missing in the scan without it.
Kevin Mann
Canada
C?ID=325784
Yes it is a new battery, but not OEM.
I will read JPPSG and follow all the steps.
I was suspecting either a relay or the ignition switch as it only happens intermittently.
After getting my car cleaned prior to all the problems, I seen water all around the push start button surface thinking it may be shorting causing the problem.
There was a code saying ignition switch shorted or open.
I removed it but didn't see any moisture on the component.
Just learning to navigate the forum, finding some good info here!
Kevin Mann
Canada
C?ID=325784
I spoke with the dealer and they mentioned coding.
I have an A6, I may need to go with an OEM battery to have the info the coding requires.
Kevin Mann
Canada
C?ID=325784
I have the battery fully charged, will clear the fault codes and run a new scan either tonight or tomorrow and repost.
Thanks for the link
Kevin Mann
Canada
C?ID=325784
I did use a clamp on and it took a couple minutes as the loads dropped off, took a couple minutes for the trunk light to go out and was then down to 0.02 amps once it went to sleep.
RyMar
South Africa
C?ID=133909
My understanding if the battery is not coded you will loose battery life? Not battery drain.
PetrolDave
Westbury, UK
C?ID=1423
You do not need an OEM battery to be able to code the battery management, if the battery type and rating are the same then all you need to change is the serial number - which can be done with VCDS.
That's my understanding too.
It's sounds more like some module is continuously draining current instead of turning off.
RyMar
South Africa
C?ID=133909
There is not a aftermarket `tracking` type system fitted? In the past a found a couple of these systems will come alive at some stage and the current draw will increase. It usually happens when the back up battery of that system starts failing.
................................:banghead:
Kevin Mann
Canada
C?ID=325784
Thanks! After a second call to Audi the service guy said the same thing. The battery info has now been updated with VCDS
It is pointing to a something not turning off occasionally and draining the battery.
Looking like the ignition start stop button could be suspect due to water found all around it after going through a drive through cleaning shop.
$110 CAD for a new push button, but more testing to isolate the issue first :)
Kevin Mann
Canada
C?ID=325784
No after market stuff on the car, but good info thanks.
Larry Manton
C?ID=112505
Does the evap on these cars come on at some time during sleep, know some of them come alive at odd times, just asking?, don't know on VW, everyone plays the game a little different.
LARIMORE
PetrolDave
Westbury, UK
C?ID=1423
Pass on that one...
A current clamp over the battery cable might be a good idea to see what the idle current when the car is locked drops to?
Kevin Mann
Canada
C?ID=325784
Update
Updated the battery coding with new battery specs.
Load tested the battery and it is good.
A 12 hour parasitic draw test was at .05 amps.
Updated the control modules to latest factory specs.
Cleared all fault codes and drove the car multiple times with no faults returning.
Did an autoscan last night and have posted the scan below.
So far so good, the car has been starting with no voltage issues.
 Chassis Type: 4F (4L0)
VIN: WAUDV74F67N090226   Mileage: 98390km-61136miles
Address 01: Engine        Labels:. 079-907-560-BVJ.clb
   Part No SW: 4F1 910 560 A    HW: 4F1 907 560
   Component: 4.2l V8/4V          0030
   Revision: 74H03---    Serial number:
   Coding: 01050009190F0120
   Shop #: WSC 91445 999 90288
   VCID: 211F18C0DDC856AFB1B-8074
008568 - Bank 1; System Too Rich off Idle
               P2178 - 002 -  - Intermittent
                    Mileage: 98264 km
                    Date: 2018.12.02
                    Time: 12:31:22
                    RPM: 2143 /min
                    Load: 16.9 %
                    Speed: 112.0 km/h
                    Temperature: 96.0°C
                    Temperature: 12.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 14.605 V
   Part No SW: 4F2 910 156 H    HW: 09L 927 156 C
   Component: AG6 09L 4,2lFSI USA 0030
   Revision: --H01---    Serial number:        4259877
   VCID: 2A0DFFECA0FE95F7E01-807E
   Part No SW: 4F0 910 517 AD    HW: 4F0 614 517 AA
   Component: ESP8 quattro    H01 0070
   Coding: 0020840
   VCID: 66954BDC74667197049-8032
   Coding: 0000007
   Coding: 0000003
   Coding: 0532520
   Coding: 0113114
   Subsystem 1 - Part No: 4F1 910 113 C  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0210
   Coding: 00064784
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
   Revision: 00000000
   Coding: 020000
   Shop #: WSC 20132 003 1048576
   Coding: 0000100
   Part No SW: 4F0 910 655 F    HW: 4F0 959 655 A
   Component: 64 AIRBAG AUDI8RH29 0300
   Revision: 14H29000    Serial number: 00359D0BES41
   Coding: 0013876
   Subsystem 1 - Serial number: 6332CSME15251E2C3
   Subsystem 2 - Serial number: 6342CSME146D46466
   Subsystem 3 - Serial number: 6352QSME1A443A51F
   Subsystem 4 - Serial number: 6362QSME1829517BM
   Subsystem 5 - Serial number: 63734SME190D38271
   Subsystem 6 - Serial number: 63834SME183A3707+
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 C
   Revision: 00H03000    Serial number: 90025063110042
   Coding: 0012241
   Component: E0221           H07 0090
   Coding: 2113368
   Coding: F5D1DE77707A06
   Shop #: WSC 20345 003 1048576
   Coding: 0082954
02261 - Data Medium
                    Fault Status: 00101110
                    Reset counter: 155
                    Mileage: 98344 km
                    Date: 2018.12.03
                    Time: 22:27:45
                    Hex Value: 0x5C05
                    Hex Value: 0xADE1
                    Hex Value: 0x0D00
                    Hex Value: 0x55A4
   Component: TSG FA          H12 0120
   Revision: 00000000    Serial number: )!
   Coding: 0051947
   Shop #: WSC 02327 785 00200
   VCID: 2C01F9F4AA0A8BC712D-8078
   Component: Komfortgeraet   H22 0170
   Revision: 01700022    Serial number: 01024986060000
   Coding: 4619293
   VCID: 2E05F3FC9C16F9D73C9-807A
   Coding: 0000026
02457 - Loudspeaker in Hat Shelf (R150)
                    Reset counter: 151
   Coding: 0012014
   Component: TSG BF          H12 0120
   Revision: 00000000    Serial number: !
   Coding: 0051947
   Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
   Component: EPB  CDEC0080   H04 0080
   Revision: --H04---
   Coding: 0007022
   Shop #: WSC 02324 785 00200
   VCID: 20191DC4D6C25FA7BE5-8074
   Coding: 0000016
   VCID: 290F00E0A5F89EEFE9B-807C
   Subsystem 1 - Part No: 4F0 941 329 B
   Component: AFS-Modul links H02 0020
   Subsystem 2 - Part No: 4F0 941 329 B
   Component: AFS-Modul rechtsH02 0020
   Component: von BA2  1234567891
   Coding: 344630393135313035442042413231323334353637383931
   Coding: 0051754
   Part No SW: 4F0 910 441     HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J69207Q
   Coding: 1000304
   VCID: 5DE76430A130324FD53-8008
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Coding: 0051754
   Coding: 0021206
   Coding: 0010900
End----------(Elapsed Time: 02:25, VBatt start/end: 14.2V/14.5V)-----------
