- Joined
- Apr 28, 2014
- Messages
- 52
- Reaction score
- 31
- Location
- New Zealand
- VCDS Serial number
- C?ID=213797
Hi All,
trying to help out another workshop here, they've swapped an ABS unit to another car and back again without logging the coding for it. See log for details. Can anyone help on what the coding may be? TIA
Wednesday,28,November,2018,09:22:47:55685
VCDS Version: 18.9.0.2 (x64)
VIN: WVWZZZ1KZ9W146215 License Plate: YELLOW
Mileage: 78670km-48883mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZ9W146215 Mileage: 78670km-48883miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 T HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: VWX7Z0H83NI870
Coding: 040300431C070160
VCID: 377D39A7469401F224-8062
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
Fault Status: 00110010
Mileage: 77216 km
Time: 19:12:08
RPM: 759 /min
Load: 21.6 %
Temperature: 75.0°C
Temperature: 35.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.970 V
012555 - Low Pressure Fuel regulation
P310B - 002 - Fuel Pressure Outside Specification - Intermittent
Mileage: 78471 km
Time: 22:30:53
RPM: 753 /min
Load: 17.2 %
Temperature: 75.0°C
Temperature: 28.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.970 V
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0000 0100
Part No SW: 02E 300 052 C HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1950
Revision: 04843012 Serial number: 00000809130684
Shop #: WSC 78350 981 90755
VCID: 1427AE2B37A20AEA61-8040
Part No SW: 1K0 907 379 AE HW: 1K0 907 379 AE
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Shop #: WSC 24207 210 01865
VCID: 75E1F3AFDC18B3E2F6-8020
03306 - Coding Not Valid
Reset counter: 189
Mileage: 78671 km
Count: 3
Count: 14
Count: 12800
Count: 4161
Count: 43008
Count: 3584
Reset counter: 189
Count: 3
Count: 12
Count: 4608
Count: 195
Count: 43264
Count: 3584
Part No SW: 1K0 907 044 DE HW: 1K0 907 044 DE
Component: ClimatronicPQ35 130 1213
Revision: 00130023 Serial number: 00000000000000
VCID: 6DD1DBCF74487B220E-8038
Revision: 00H54000 Serial number: 00000008941665
Coding: E78F8F2700041500471400001400000000097F075C000100000000000000
VCID: 33650DB752ECEDD218-8066
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 230908 021 0501
Coding: 00038805
Shop #: WSC 01357
Component: RLS 271008 054 0402
Coding: 00733357
Shop #: WSC 01357
Reset counter: 225
Mileage: 78503 km
Voltage: 9.10 V
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 15 AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0C6AP0
Coding: 0012597
VCID: 6CD7D6CB4F52722A19-8038
Subsystem 1 - Serial number: 6332MSME42106A3C9
Subsystem 2 - Serial number: 6342MSME4144781DE
Subsystem 3 - Serial number: 6352QSME7F22326FT
Subsystem 4 - Serial number: 6362QSME140C2528C
Part No SW: 1K0 953 549 BS HW: 1K0 953 549 BS
Component: J0527 057 0101
Coding: 0012142
VCID: 04079E6B47C29A6AF1-8050
Component: E0221 002 0010
Part No SW: 1K6 920 864 HW: 1K6 920 864
Component: KOMBIINSTRUMENT VDD 1214
Revision: V0002000 Serial number: VWX7Z0H83NI870
Coding: 0007503
Shop #: WSC 18613 002 1048576
VCID: 6FEDC1C77E4489323C-803A
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K08A070F30
Coding: ED817F060002020003
VCID: 356133AF5C98F3E236-8060
Reset counter: 189
Mileage: 77213 km
Time: 00:01:18
01304 - Radio
Reset counter: 129
Mileage: 77213 km
Time: 00:01:23
Component: IMMO VDD 1214
Shop #: WSC 71310 981 90785
Part No SW: 1K0 959 701 N HW: 1K0 959 701 N
Component: Tuer-SG 006 1220
Coding: 0000694
VCID: 39793F9F70801782D2-806C
01706 - Switch for Mirror-Adjust (E43)
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 74 2301
Revision: 00H15000
Shop #: WSC 01324 785 00200
VCID: 2A5B10D38526AC1AAB-807E
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 809002005103087F2D0484056008DF03E0FCA0
VCID: 71E9C7BF68709FC22A-8024
Part No SW: 1K0 959 702 N HW: 1K0 959 702 N
Coding: 0000950
VCID: 3A7B209375861C9ADB-806E
00097 - Front Passengers Central Locking (Safe) Motor (V162)
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74E7CEAB1762AAEAC1-8020
Address 56: Radio
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1302
Coding: 0000144
Shop #: WSC 01357 011 1012552
VCID: 387F3A9B4B8A0E8A2D-806C
00098 - Rear Left Central Locking (Safe) Motor (V163)
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
End-------------------------(Elapsed Time: 01:48)--------------------------
