Results 1 to 10 of 11
Thread: '04 Golf MK5, Several malfunctions. Windows, brake light switch, modules...etc.
    Oct 2014
    Norway
    I'm checking my grandmother's Golf MK 5.
    There are several problems that I know about:
    1. Front wipers don't work. Ordered new motor.
    2. Windows are not able to open/close. Don't know why..
    3. Brake light is not working. Is it possible to test the sensor?
    But it seems to be more problems as well according to VAGCOM.
    It seems to be a problem with the comunication to several modules, what is the best way to troubleshoot?
    I'm very thankfull for all help!
    BR Jorn
    Tuesday,11,November,2014,21:09:42:15915
    VCDS Version: 14.10.0.0 (x64)
    Data version: 20141022
    VIN: WVWZZZ1KZ4W118524   License Plate:
    Mileage: 106710km-66306mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZ4W118524   Mileage: 106710km-66306miles
    Address 01: Engine        Labels: 036-906-032-AXP.lbl
       Part No SW: 036 906 032 AG    HW: xxxxxxxxxxx
       Component: BOSCH ME7.5.10      5612
       Revision: 00000000    Serial number: VWZ7Z0D9456574
       Coding: 0000071
       Shop #: WSC 01392 785 00200
       VCID: 55A1AA8EFC3F7D896CD-8000
    Readiness: 1110 0101
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
       Part No: 1K0 907 379 N
       Component: ASR FRONT MK70      0103
       Coding: 0017025
       VCID: 3D71122E644F85C944D-8068
       Part No: 1K0 820 047 CC
       Component: Climatic PQ35   080 0201
       VCID: 67DD90465653FF19CE1-8032
    Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
       Part No SW: 1K0 937 049 K    HW: 1K0 937 049 K*
       Component: Bordnetz-SG 1.0 H30 0701
       Revision: 00030000    Serial number: 00000000560429
       Coding: 088F8F0600041800001400001400000000
       VCID: 377D00064673AF999E1-8062
       Subsystem 1 - Component: Fehler Lin-Slave 01
    02071 - Local Databus
    00918 - Terminal 31
    00576 - Terminal 15
       Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
       Component: 0L AIRBAG VW8   022 0500
       Revision: 04022000    Serial number: 0033FD0A219D
       Coding: 0012364
       Shop #: WSC 01371 785 00200
       VCID: 2A5B297285C1027111F-807F
       Subsystem 1 - Serial number: 6332MSME7C644402
       Subsystem 2 - Serial number: 6342MSME01744402
       Subsystem 3 - Serial number: 6351HSME10176901
       Subsystem 4 - Serial number: 6361HSME514C7201
       Part No SW: 1K0 953 549     HW: 1K0 953 549
       Component: Lenksäulenmodul 012 0030
       VCID: 6FEDF8667EA32759861-803A
       Part No: 1K0 920 850 P
       Component: KOMBIINSTRUMENT VDD 3556
       Coding: 0005101
       Shop #: WSC 00011 888 96745
       VCID: 3467370A57054481BB3-8061
       Coding: 0005101
    Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
       Part No SW: 1K0 907 530 C    HW: 1K0 907 951
       Component: Gateway         H08 0080
       Revision: 08          Serial number: 26001042280058
       Coding: 3D3F0340070002
       VCID: 275DD04696D33F190E1-8072
       Component: IMMO                3556
       Shop #: WSC 00220 218 16467
       Part No: 1K1 909 144 F
       Component: EPS_ZFLS Kl.0       1301
       VCID: 2E532562B9296E51CD7-807B
    Address 46: Central Conv.
    Address 52: Door Elect, Pass.
    Address 56: Radio
    Address 62: Door, Rear Left
    Address 72: Door, Rear Right
    End-------------------------(Elapsed Time: 01:51)--------------------------
    Bad Convenience CAN bus?
    Oct 2014
    Norway
    Hi Uwe,
    Do you have some further information, I'm not that experienced..
    BR Jorn
    Tartu, Estonia
    Can bus, like a internet in car, but with many networks and one can gateway(router) to handle traffic.. Ie convience can, drivetrain ie.... .
    Seem like some module or wire is broken so traffic cannot occur on one network.
  5. Likes Dana liked this post
    Oct 2014
    Norway
    I have some basic knowledge regarding bus communication.
    What I need are some hints for how to troubleshoot.
    Is there a place where I can find info regardring CAN BUS and how to trouble shoot, diagrams etc.
    Appreciate your help so far!
    BR Jorn
    Your car has several CAN bus networks in it. One for the powertrain, one for the convenience systems, once for infotainment, etc. The Gateway acts as a router between them.
    Oct 2014
    Norway
    I understand.
    How should I start to troubleshoot?
    Check cable connections etc?
    I have tried to find electrical diagrams for Golf MK5, so far without any luck.
    BR Jorn
  9. #8
    You can get wiring diagrams and other related documentation here:
    http://www.erwin-portal.com/
  10. Likes Dana liked this post
  11. #9
    Oct 2014
    Norway
    Thank you for the link!
    I have investigated even more, and it seems that problem is a visit of......a cable eating mouse!!
    I shall replace and do some soldering of cables, and hopefully I have fixed most of the problems..
    BR Jorn
  12. Likes Uwe, Dana liked this post
  13. #10
    Sometimes I think VWAG puts rodent-attracting pheromones in their wiring harnesses.
  14. Likes Dana liked this post
