2011 Amarok Fault Codes
uglyduckling81
Australia
C?ID=340375
It looks like I have Sensor 3 of EGT faulty but it's also showing fuel pressure sensor errors. I reset the faults and after a few engine restarts they are showing again.
Anyone able to help with what might be causing these errors
Engine (J623-CDCA)
4911 - Exhaust Gas Temperature Sensor; B1 S3
          P242A 00 [175] - Malfunction
                    Mileage: 94362 km
                    Date: 2018.11.25
                    Time: 16:23:50
                    Engine speed: 985.50 /min
                    Normed load value: 22.4 %
                    Coolant temperature: 31 °C
                    Intake air temperature: 32 °C
                    Voltage terminal 30: 11.760 V
                    Exh.gas temp.sen 1: 65.0 °C
                    Exh.gas temp.sen 2: -0.0 °C
                    Exh.gas temp.sen 3: 1000.0 °C
                    Exh.gas temp.sen 4: 40.9 °C
                    Shut-off timer: last engine shut-off time: 8306 s
5231 - Fuel Rail/System Pressure
          P0087 00 [032] - Too Low
5171 - Boost Pressure Regulation
          P0299 00 [096] - Control Range Not Reached
5257 - Exhaust Gas Temperature Sensor; B1 S3
                    Mileage: 94362 km
                    Time: 00:00:00
                    Voltage terminal 30: 12.280 V
                    Exh.gas temp.sen 1: 35.1 °C
                    Exh.gas temp.sen 4: 33.2 °C
                    Shut-off timer: last engine shut-off time: 32834 s
Welcome to our forum.
We much prefer a complete Auto-Scan here rather than just a snippet that shows your fault codes and doesn't even show the ECU details.
uglyduckling81
Australia
C?ID=340375
Tuesday,27,November,2018,09:16:57:19789
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
VIN: *******   License Plate: *******
Mileage: 94360km-58632mi   Repair Order:
Chassis Type: 2H-VN81 (6N0)
Scan: 01 03 08 09 15 17 19 22 25 32 56
VIN: *******  Mileage: 94360km-58632miles
Address 01: Engine (J623-CDCA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 FA    HW: 03L 907 309 K
   Component: R4 2,0L EDC   H34 9745
   Revision: 26H34---    Serial number: 00000000000000
   Coding: 01194012232600080000
   Shop #: WSC 40084 959 88113
   ASAM Dataset: EV_ECM20BTD01103L906019FA 002005
   ROD: EV_ECM20BTD_002_VN81.rod
   VCID: 6FBB2F69C719D8AF77F-803A
                    Mileage: 94362 km
                    Date: 2018.11.25
                    Time: 16:23:50
                    Mileage: 94362 km
                    Time: 00:00:00
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (-----)       Labels: 2H0-907-37x-ESP.clb
   Part No SW: 2H0 907 379 F    HW: 2H0 907 379 D
   Component: ESP MK25A XT  H43 0104
   Revision: 00H43001
   Coding: C07324B69196039E24A389A8AF5510
   Shop #: WSC 00000 059 49152
   VCID: 3333E319EB31BC4F537-8066
02053 - Control Module for Transfer Case (J646)
                    Reset counter: 223
                    Mileage: 90235 km
                    Count: 32896
                    Count: 4353
                    Count: 8269
                    Count: 1022
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 2H0 907 040 B    HW: 2H0 907 040 B
   Component: ClimatronicT5 H11 0202
   Coding: 0000001002
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 20191C554A4737D7BE5-8074
   Part No SW: 6R7 937 087 B    HW: 6R7 937 087 B
   Component: PQ25 BCM      H10 0015
   Revision: -1------    Serial number: 1002307800
   Coding: 3C0002380C01000000300000240A04C40080412E600200003000
   Shop #: WSC 00000 059 00000
   VCID: 43D3B3D9BB910CCFC37-8016
   Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 3321
   Coding: 110000
   Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 3321
   Coding: 110000
   Subsystem 3 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3321
   Coding: 100000
   Subsystem 4 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3321
   Coding: 100000
   Part No SW: 2H0 959 655 B    HW: 2H0 959 655 B
   Component: VW10Airbag00H H06 0013
   Revision: --------    Serial number: 003HN000BRKF
   Coding: 000000000000000000000000000000003048
   Shop #: WSC 07456 790 50316
   VCID: 3333E319EBB1BC4F537-8066
   Serial number: 3495RRB405F6ORG8BHIM
   Serial number: 3505RRB40696OBGCIG5X
   Serial number: 3555YRB404R6SFPQL974
   Serial number: 3565YRB40676QGG089K.
   Part No SW: 2H0 920 863     HW: 2H0 920 863
   Component: KOMBI         H17 0206
   Coding: 170A00
   VCID: 66954A4DE8E319E7049-8032
   Part No SW: 6N0 909 901     HW: 6R7 937 087 B
   Component: GW-K-CAN TP20 0015
   Revision: -1------
   Coding: 742300
   VCID: 70B92C15DAA7C7576E5-8024
   Part No SW: 2H0 927 755 B    HW: 2H0 927 755 B
   Component: SG offroad VTG      0153
   Revision: 00H06000    Serial number: T1IRB06709VZ99
   Coding: 0000013
   VCID: 2F3BEF690B1998AF37F-807A
   Component: IMMO          H17 0206
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
   VCID: 6A8D3E7DFCFB3D87201-803E
Address 32: Differential Locks (J647)       Labels:* 2H0-927-771.clb
   Part No SW: 2H0 927 771     HW: 2H0 927 771
   Component: Quersperre    H04 0014
   Revision: 11001001    Serial number: 4DG 12.08.10 00
   ASAM Dataset: EV_QuersUDSAAMVN817 A01005
   ROD: EV_QuersUDSAAMVN817.rod
   VCID: 6B833B79F301248F5B7-803E
Address 56: Radio
End----------(Elapsed Time: 00:58, VBatt start/end: 14.3V/14.2V)-----------
Tuesday,27,November,2018,09:20:48:19789
VIN: *** License Plate: *
VIN: ****   Mileage: 94360km-58632miles
   Revision: 00H43001
   Coding: 0000001002
   Coding: 110000
   Coding: 110000
   Coding: 100000
   Coding: 100000
   Coding: 170A00
   Revision: -1------
   Coding: 742300
   Coding: 0000013
Address 56: Radio
End----------(Elapsed Time: 01:00, VBatt start/end: 14.2V/14.2V)-----------
Tuesday,27,November,2018,11:13:29:19789
VIN: *****  License Plate: ****
          P242A 00 [167] - Malfunction
                    Mileage: 94365 km
                    Date: 2018.11.27
                    Time: 09:25:03
                    Coolant temperature: 62 °C
                    Intake air temperature: 35 °C
                    Voltage terminal 30: 12.860 V
                    Exh.gas temp.sen 1: 126.7 °C
                    Exh.gas temp.sen 4: 87.7 °C
                    Shut-off timer: last engine shut-off time: 14 s
          P242A 00 [039] - Malfunction
                    Mileage: 94365 km
                    Date: 2018.11.27
                    Time: 09:25:03
                    Intake air temperature: 34 °C
                    Voltage terminal 30: 12.880 V
                    Exh.gas temp.sen 1: 129.0 °C
                    Shut-off timer: last engine shut-off time: 9 s
   Revision: 00H43001
   Coding: 0000001002
   Coding: 110000
   Coding: 110000
   Coding: 100000
   Coding: 100000
   Coding: 170A00
   Revision: -1------
   Coding: 742300
   Coding: 0000013
Address 56: Radio
End----------(Elapsed Time: 00:58, VBatt start/end: 14.2V/14.1V)-----------
I would focus on the EGT sensor fault. The other faults are both flagged "Intermittent - Not Confirmed", which makes the far less worrisome.
uglyduckling81
Australia
C?ID=340375
I will.
The truck also threw a faulty catalytic converter today as well after I posted. Hopefully it's all related to a bad sensor. Try it first then see what is happening.
