Jetta ABS Module Coding (MK60EC1)
TDiSteve
C?ID=325367
So my abs module died on me and I replaced it with a new one. I don’t have the old coding and I was wondering if someone could help piece one together for me. Searched around on forums and none of the coding worked for me. Always gave an error 31 message. Any help would be much appreciated thank you
2009 Jetta 2.5 5-speed Manual Transmission
Monday,26,November,2018,12:59:10:14607
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
VIN: 3VWJM71K59M050806   License Plate:
Mileage: 198610km-123410mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWJM71K59M050806   Mileage: 198610km-123410miles
Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 Q    HW: 07K 906 055 M
   Component: 2,5l R5/4V      G   9970
   Revision: G6H02---    Serial number: VWX7Z0H824710W
   Coding: 0000071
   Shop #: WSC 03235 444 11290
   VCID: 3C21C9C46A68371782D-8068
000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
               P0030 - 000 - Malfunction / Open Circuit - MIL ON
                    Fault Status: 11100000
                    Mileage: 198527 km
                    Time: 22:00:19
                    RPM: 670 /min
                    Load: 22.0 %
                    Temperature: 88.0°C
                    Temperature: 36.0°C
                    Absolute Pres.: 960.0 mbar
                    Voltage: 13.462 V
000305 - Oxygen (Lambda) Sensor B1 S1
               P0131 - 000 - Signal too Low
                    Mileage: 198529 km
                    Time: 22:04:47
                    RPM: 1735 /min
                    Load: 16.5 %
                    Speed: 53.0 km/h
                    Temperature: 76.0°C
                    Temperature: 36.0°C
                    Voltage: 13.843 V
000818 - Knock Sensor 2 (G66)
               P0332 - 000 - Signal too Low - Intermittent
                    Mileage: 198548 km
                    Time: 15:30:42
                    RPM: 2439 /min
                    Load: 16.9 %
                    Speed: 93.0 km/h
                    Temperature: 59.0°C
                    Temperature: 11.0°C
                    Voltage: 14.224 V
008577 - Performance Malfunction in Cooling System
               P2181 - 000 -  - MIL ON
                    Mileage: 198564 km
                    Time: 17:09:22
                    RPM: 2400 /min
                    Load: 68.6 %
                    Speed: 21.0 km/h
                    Temperature: 66.0°C
                    Temperature: 23.0°C
                    Voltage: 13.843 V
Readiness: 0010 0101
   Component: ESP MK60EC1   H45 0109
   Revision: 00H45001
   Shop #: WSC 57429 001 1048576
   VCID: 00597D344A0093F79E5-8054
6 Faults Found:
03306 - Coding Not Valid
            000 -  -  - Intermittent
                    Reset counter: 11
                    Mileage: 198611 km
                    Count: 3
                    Count: 2
                    Count: 12288
                    Count: 4161
                    Count: 42496
                    Count: 65280
                    Fault Status: 01100101
                    Reset counter: 11
                    Mileage: 198527 km
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 279
                    Count: 48896
                    Reset counter: 11
                    Mileage: 198527 km
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 295
                    Count: 48896
                    Reset counter: 11
                    Mileage: 198527 km
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 270
                    Count: 48896
                    Reset counter: 10
                    Mileage: 198527 km
                    Count: 7
                    Count: 2
                    Count: 12800
                    Count: 195
                    Count: 48896
                    Reset counter: 11
                    Mileage: 198527 km
                    Count: 7
                    Count: 2
                    Count: 12800
                    Count: 320
                    Count: 48896
Please post a complete Auto-Scan. The one you posted above has everything after the ABS missing.
TDiSteve
C?ID=325367
My bad, wasn’t sure if the rest was needed or not. Here it is
   Coding: 0000071
                    Mileage: 198527 km
                    Time: 22:00:19
                    RPM: 670 /min
                    Load: 22.0 %
                    Temperature: 88.0°C
                    Temperature: 36.0°C
                    Voltage: 13.462 V
                    Mileage: 198529 km
                    Time: 22:04:47
                    RPM: 1735 /min
                    Load: 16.5 %
                    Speed: 53.0 km/h
                    Temperature: 76.0°C
                    Temperature: 36.0°C
                    Voltage: 13.843 V
                    Mileage: 198548 km
                    Time: 15:30:42
                    RPM: 2439 /min
                    Load: 16.9 %
                    Speed: 93.0 km/h
                    Temperature: 59.0°C
                    Temperature: 11.0°C
                    Voltage: 14.224 V
                    Mileage: 198564 km
                    Time: 17:09:22
                    RPM: 2400 /min
                    Load: 68.6 %
                    Speed: 21.0 km/h
                    Temperature: 66.0°C
                    Temperature: 23.0°C
                    Voltage: 13.843 V
   Revision: 00H45001
6 Faults Found:
                    Reset counter: 11
                    Mileage: 198611 km
                    Count: 3
                    Count: 2
                    Count: 12288
                    Count: 4161
                    Count: 42496
                    Count: 65280
                    Reset counter: 11
                    Mileage: 198527 km
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 279
                    Count: 48896
                    Reset counter: 11
                    Mileage: 198527 km
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 295
                    Count: 48896
                    Reset counter: 11
                    Mileage: 198527 km
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 270
                    Count: 48896
                    Reset counter: 10
                    Mileage: 198527 km
                    Count: 7
                    Count: 2
                    Count: 12800
                    Count: 195
                    Count: 48896
                    Reset counter: 11
                    Mileage: 198527 km
                    Count: 7
                    Count: 2
                    Count: 12800
                    Count: 320
                    Count: 48896
   Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
   Component: Climatic PQ35   142 1111
   Revision: 00142031    Serial number: 00000000000000
   VCID: 7CA109C42AE8F717C2D-8028
   Revision: 00H54000    Serial number: 00000001026106
   Coding: 04058E234004150007140000001400000008730B5C000120000000000000
   Shop #: WSC 00066 123 12345
   VCID: 323DE7FCB82CF167581-8066
   Component: Wischer 130908 021  0501
   Coding: 00038805
   Shop #: WSC 00066
   Revision: 05034000    Serial number: 003B6M06SGDJ
   Coding: 0013889
   VCID: 6C8139845A88679752D-8038
   Subsystem 2 - Serial number: 6332MSME3D452C1FQ
   Subsystem 3 - Serial number: 6342MSME3D723911B
   Subsystem 4 - Serial number: 6351HSME18020922Y
   Subsystem 5 - Serial number: 6361HSME177F686AS
   Subsystem 6 - Serial number: 63727SME17241E12Z
   Subsystem 7 - Serial number: 63827SME17246713Z
   Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
   Coding: 0000021
   VCID: 03537238571688EF837-8056
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
00885 - Ignition Switch (D) Terminal 50
   Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
   Component: KOMBIINSTRUMENT 3HL 1222
   Revision: V0003000    Serial number: VWX7Z0H824710W
   Coding: 0022203
   Component: J533  Gateway   H07 0062
   Revision:   H07 01    Serial number: 270708F1000780
   Coding: E9807F070002021002
   VCID: 3537DCE04942E65F7D3-8060
                    Mileage: 198527 km
                    Time: 21:56:52
   Component: IMMO            3HL 1222
   Revision: 72009005    Serial number: 00000303988830
   Coding: 0001205
   VCID: 6FBB2E886B9E9C8F77F-803A
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 69     2301
   Revision: 00H15000
   VCID: 2A0DFF9C90FCB9A7E01-807E
   Coding: 13900F880186003F0904058FB0880F0488DC80
   VCID: 0451712452188FD7BAD-8050
   Revision: 72009005    Serial number: 08071906163804
   Coding: 0001204
   VCID: 70B92DF476A083776E5-8024
                    Fault Status: 00101100
                    Fault Frequency: 139
                    Reset counter: 51
                    Mileage: 198527 km
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 D    HW: 1K0 035 161 D
   Component: Radio DE2       018 0021
   Revision: 00018000    Serial number: VWZ4Z7H6379134
   Coding: 0040401
   VCID: 20191DB4E6C073F7BE5-8074
   Revision: 12006001    Serial number: 00000003453941
   Coding: 0001168
   VCID: 76B51BEC14C4AD47B49-8022
                    Fault Frequency: 12
                    Reset counter: 51
                    Mileage: 198523 km
                    Reset counter: 11
                    Mileage: 198523 km
   Coding: 0100101
                    Fault Status: 01110100
                    Mileage: 198527 km
                    Time: 21:58:18
   Revision: 12006001    Serial number: 00000003413762
   Coding: 0001168
   VCID: 77AB16E813CED44FAFF-8022
End----(Elapsed Time: 01:20, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
I do not have a lot of confidence in this, but try:
143B600D092700FA280306E4901F0042B100
PLEASE WAIT COMPILING DATA !
Vehicle Identification No.3VWJM71K59M050806
ModelJetta
JEM
Date of production21.09.2008
Year2009
Sales type1K2ES1
Engine CodeCBTA
Transmission CodeKPF
Part No SW: 07K 906 055 Q HW: 07K 906 055 M <<<<<<<<<<<<<<< Correct part #!
Component: 2,5l R5/4V G 9970 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Firmware update needed 9971 or higher!
Coding: 0000071
Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< According to etka/Link not correct part & researching suspect FOD!
Correct part numbers are ( 1K0-907-379 or 375 AD also alternate 1K0-907-375 AH/AN or 379AH AN WITH ESP! )
Coding: 144B000C092700FA281300E4901F00000000 VIN STRIP!
Coding: 143B600D092700FA280306E4901F0042B100 UWE
OP would you like to roll dice with coding attempts assuming all risk and responsibility or install correct part numbers as aforementioned in legacy or as superseded?
SCANS OF NET
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PCWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation units/platform components0HMVehicle class differentiation -1KM- Build status corresponds to production in Mexico
tail pipe0P1Rear side exhaust tailpipe
drive-off assistanceUG0Without hill start assist/hill descent control/comfort driving assist
Emission standard7GBEmission standard ULEV 2
Trailer hitch1D0without trailer towing
airbag4UMDriver's and front passenger air bag, NAR with front passenger air bag deactivation (2-stage) - SMART airbag with automatic deactivation
Aktivkohlebehälter / Ottopartikelfilter1E4Activated carbon canister (ORVR) and siphoning device for fueling
Aerials8ZMAntenna
Exterior mirror setting6XNExterior mirrors, power-adjustable/ separately heated
Left exterior mirror5SHLeft exterior mirror, flat (US)
Right exterior mirror5RRRight exterior mirror, convex (US)
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WLJack for external audio source
Equipment levelsA8VUS equipment with deleted option
Brake type in rear1KEDisc brakes in rear
batteriesJ0NBattery 330 A (61 Ah)
Brake type, front1ZPDisc brakes in front (Geomet D)
Components with special surface6FFExterior mirror housing and various attachments colour coded to vehicle
Battery/alternator capacityNY0Standard battery/alternator capacity
Component part sets with country-specific design requirementsB0DAssembly kit, USA corresponding vehicle version (not California), various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ATElectronic stability control (ESC)
Owner's manuals0VMInformation kit in American English
Operating voltage9Z0Operating voltage 12 V
brake wear indicator9U1brake wear indicator
Heated washer nozzles9T1Heated washer nozzles in front
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
"Charism"2H0Without "drive select"
Chrome packageQJ0Without aluminum/chrome work package
General operating permit, alterationsC13Operating permit, alteration
Roof rails/roof load rack3S0Without roof rails/roof load rack
Roof insert/convertible top3FAroof without cut out
Suspension system in rear1JARear shock absorption, basic design 1
Suspension system in frontG46Shock absorption in front
Load-through hatch/ski bag3X0without load through system
Insert for the filling up of unleaded fuel/fuel type2G7Filler neck module 1 with insert
Installation differentiation for components0EJInstallation differentiation for transmission MQ 250 -- vehicle components --
Theft protection system7AGElectronic immobilizer with anti-theft alarm system (for USA)
Inserts5MADecorative inserts
Scuff plates7M5Without impact protection film for door sill
Park distance control7X0Without park distance control
Electric interface for external useUF0Without electric interface
Manufacturing sequence differentiation0FLMexico manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL0Standard pedestrian protection measures
Pedal clusterVF0Standard pedal cluster
Headlight activation8K4Separate daytime running lights NAR
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Weight category rear axle0YFWeight range 6 installation control only, no requirement forecast
Weight category front axleL07Suspension range 07 installation control only, no requirement forecast
Base engineT8K5-cylinder SI engine 2.5 l unit 07K.1
Luggage netting/pocket on backrest(s)4U5Luggage pockets on backrest
Luggage compartment cover3U0Without luggage compartment cover
cruise control system8T2Electronic cruise control system (CCS)
Garage door openerVC0without Garage door opener
Luggage compartment trim5A7Comfort luggage compartment trim with service lid/snap-on cover
Transmission specificationsG0C5-speed manual transmission
Brackets3P0Without bracket for first aid kit and warning triangle
handle for hand brake lever6PAHand brake lever handle in plastic
Rear spoiler5J0Without rear spoiler
Rear window wiper and washer system8M0Without rear window wiper and washer system
Rear seats3NNRear bench seat, not split, split backrest, folding
Heating and air-conditioning system9APClimatic air-conditioning system (semi-automatic)
Headlamps8ESTwin headlamps for driving on the right, with integrated high beam (US design)
Customized installationFC0Without individual installation
Interior light in footwell6T1Interior light in footwell
Instrument clustersU5CInstrument cluster, mph speedometer - USA -
Breakaway interior rearview mirror4L2Breakaway interior rearview mirror, dimming
Sticker (customized or special edition)0KAWithout decals and emblems
Body styleK8BNotchback
Cassette and CD storage unit4W0without cassette / CD tray
coolbox1W2Glove compartment cooling system
child safety4H3Manual child lock
Electronic map cooling systemQS0Without electronic map cooling system
Child seatsQA0without child seat
Climatic zones0Y3Cold zones
Compass/road sign displayQR0Without compass/road sign display/ dynamic road sign display
headrest for seat, rear3Q6Three rear head restraints
Head restraints3J1Hight-adjustable head restraints for front seats
Fuel tank treatment2LCFuel tank with special material treatment (coextrusion)
Fuel quantity for initial filling1Z0Initial standard fuel filling
Fuel systems1A1Fuel system for fuel-injected SI engine, injection system without fuel return
Body measures5C1Body measures for increased safety requirements
Child seat anchors in front3G0Without child seat anchora in front (ISOFIX)
Rear license plate bracket6P2License plate bracket, rear (NAR)
Front license plate bracket6W3License plate bracket front (small, NAR)
Paint preservative/transit coating5K5Transport protection film with additional transport protection measures
Paint coatingFB0standard paint coating
Rear cargo area3GAWithout luggage compartment floor
Steering system arrangementL0LLeft-hand drive
Reading lamp8S4Two reading lights front, two rear
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H0Without backrest release for front seats
Air duct, front areaVK1Air duct, type 1
Load edge protection2P1Plastic loading edge protection
Lumbar support7P4Manually adjustable lumbar support in front seats
steering wheels1MESteering wheel
Speaker installation8RM8 speakers (passive)
Headlight range control8Q0without beam length regulator
Center armrest6E3Front center armrest
Marten repellerUM0Without marten repeller
Multi-function display/trip computer9Q0Without multi-function display/ trip computer
Engine cooling8Z6Hot country
Engine specificationsD775-cylinder SI engine 2.5 l/125 kW (20V) (R-5) base engine is T8K
Left vanity mirror4SHLeft vanity mirror illuminated with cover and special mirror imprint (NAR), extractable
Right vanity mirror4TQVanity mirror, right, illuminated, with cover and special mirror imprint (NAR)
Navigation device7Q0without navigation system
rear fog lamp8TAwitout rear fog lamp
Front fog lamp/additional headlamp8WAWithout fog lights
Upgrading measuresGP0Vehicles w/o special upgrade measures
Rear of platform module base4P1Rear floor panel module, type 2
Platform group class7PAPlatform group class 1
Hubcaps1NLTrims for alloy wheels
WheelsCJ8Alloy wheels 6.5J x 16
Radios8UFRadio with CD drive (double DIN)
Smoker's/non-smoker's package9JFNon-smoking package (NAR)
Tire pressure monitoring system7K4Tire pressure monitoring system 315 MHz High
tireH4BAll-season tires 205/55 R16 H (NAR)
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G4Space-saving spare wheel
Restraint systems, front4QQ3-point seat belts in front with pretensioner and height adjustment, US label
PJLAlloy wheels 162 Mugello package
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q1Gearshift knob/handle in plastic
Special labels/plates0SSLabels in English and French
Locking mechanism for boot lid/cover rear4E2Tailgate/trunk lid release from inside (electrically)
Front seat, left3TFFront left comfort seat
Front seat, right3SFComfort seat, front right
Nameplates for sales nameQD3Lettering for sales name
Seat belt check9P7Visual and acoustic seat belt reminder, electric contact in buckle
Outer rear seat belts3ZD3-point seat belts, outer rear with US label
Center rear seat belts3C83-point seat belt, center rear with US label
seat coversN3LCircular-knit velour seat covers
Seat adjustment3PTManual height adjustment for front seats
seat heater4A3seat heating for front seats separat controlable
Safety head restraint system3K0w/o safety head restraint system
Side lights7R4Side marker lamps and turn signal repeaters (turn signals with white lens)
Horns8Y1Two-tone horn
Side and rear windows4KCSide and rear windows in heat-insulating glass
Protective side molding4B0with no protective side strip
Sunroof roller blind for rear/side windows3Y0without roller blind
Supertone system and tone sequence control9J0Without supertone system and tone sequence control
power outlet7B212 volt socket in luggage compartment
Bumper2JCComfort bumpers
Rear stabilizer0BGRear stabilizer
Front stabilizer bar0AGFront stabilizer bar
Drawers under front seatsQN0Without drawers under front seats
Heavy-duty/sports version2UAStandard design
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N4Windshield wiper intermittent control with potentiometer (four speeds)
Special approval measures3M0Without special measures
Nameplate set0NVNameplate set "2.5"
Special alarm systems9A0Without taxi alarm system
Door storage compartments in front3YRDoor pockets with insert mats
Mass damper for steering wheels1Q0steering wheel without balance weight
Door and lid locking system4K0Central locking w/ radio remote control and interior controls
Type approval countries/countries with special requirementsB34Legal requirements USA
Carrier frequency for remote control5D2Carrier frequency 315 MHz
Partition3CAwithout partition
Door and side trim panels4AFDoor and side trim panel in foam film and woven fabric
doors0A24 doors
TV reception/digital radio receptionQV0without TV/digital radio reception
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EBwithout identification plate
Delivery equipment2A8Delivery equipment, water border
First aid kit / warning triangle1T0Without first-aid material, without warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Preparation for rotating beacon/siren combination9F0Without preparation for rotating beacon/siren combination
Telephone / telematics9W0Without car phone preparation/ installation
Additional warning lights9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG0without service interval extension
Heat accumulator system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield Glass4GFWindshield in heat-insulating glass
Washer fluid level indicator8W1Washer fluid level indicator
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFront and rear floor mats
Additional body panels, side6EAWithout additional side body covers (stone guard)
Additional child seat anchors3B7Child seat anchors as per Canadian requirements a. ISOFIX child seat system
Auxiliary heating system9M0Without auxiliary heater/parking heater
TDiSteve
C?ID=325367
Will try later today once I’m off the old 9-5, thank you.
D-Dub
US 2014 GTI Drivers Edition/DSG
C?ID=272151
kind of off topic, but how are you able to determine when a controller needs an update?
Component: 2,5l R5/4V G 9970 << Firmware update needed 9971 or higher!
is this etka or some other system providing this?
and when something gets indicated as needing a newer firmware, is this a dealer and/or authorized shop only procedure?
who provides the firmware, VW directly? how, through erwin?
I understand that vcds does not do controller firmware updates, are there other recommend tools available for the layman to use?
what are the costs involved in attempting to get a controller updated, are they generally considered part of a recall or other service bulletin?
Would someone just drive into the dealer service center and tell them they want any/all controller modules updated?
Yup........
RTFB Lots of reading......
https://www.nastf.org/i4a/pages/index.cfm?pageid=1
https://literature.vw.com/calibration_lookup.asp
https://erwin.vw.com/erwin/showHome.do
https://erwin.vw.com/erwin/showSearch.do
https://erwin.vw.com/erwin/showCheckRequirements.do
An approved pass-thru device to comport with the specification, ERWIN NASTF or OEM VAS interface edic with ODIS subscriptions!
D-Dub
C?ID=272151
some good links and info thank you, but what it boils down to it's for non-shade-tree technicians use only.
All I guess depends on the size of the shade tree you work under and budget but yeah can get costly even for a small business private repair station.
Fredrick Awuor
Kenya
C?ID=309834
Hello Jack....any link for ROW Volkswagens.... Thanks
