Monday,26,November,2018,16:03:42:38326
VCDS Version: 18.9.0.2
VIN: WVWZZZ3CZGE046109 License Plate:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F
VIN: WVWZZZ3CZGE046109 Mileage: 82067km-50994miles
Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 ET HW: 04L 907 309 R
Component: R4 2,0L EDC H21 1343
Revision: B5H21---
Coding: 011D001203651D083000
Shop #: WSC 05311 115 00315
ASAM Dataset: EV_ECM20TDI01104L906026ET 002001
ROD: EV_ECM20TDI01104L906026FL.rod
VCID: 0005C24A9B96B54AD5-8054
Part No SW: 0D9 300 041 A HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4801
Revision: 06253104 Serial number: TFK01506181464
Shop #: WSC 05311 115 00075
ROD: EV_TCMDQ250021.rod
VCID: 16298412E9122BFA1F-8042
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 61995000000792
Coding: 0FEC928F34240B720778060041CC49F0492CD0E0608292F11862F078C202
Shop #: WSC 00015 115 00001
VCID: 7AF1B0A2FD4AEF9A9B-802E
Part No SW: 3Q0 959 435 B HW: 3Q0 959 435 B
Component: VWKESSYMQB 026 0709
Revision: 00026000 Serial number: 0374452187
Coding: 000F0F0703
ASAM Dataset: EV_KessyHellaMQBAB 004032
VCID: 39736FAEB8CC2482D2-806C
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 AF HW: 5G0 907 426 AF
Component: AC Manuell H03 1202
Revision: 00001K06
Coding: 12120104202100001000400000000002
ASAM Dataset: EV_ACManueBHBVW37X 003129
ROD: EV_ACManueBHBVW37X_003_VW37.rod
VCID: 6FE791F6B608BA323C-803A
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 086 AH HW: 5Q0 937 086 AH
Revision: -------- Serial number: 86581307152723
Coding: 03011842C2C1027F0FA44094B10407281880000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
Subsystem 1 - Part No SW: 3G2 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150625 043 0607
Serial number: 150628105738
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S5Y15M07D03H05M37S25
Coding: 90A8DD
Light switch:
Subsystem 3 - Part No SW: 3G0 941 633 HW: 3G0 941 633
Component: E1 - LDS MQB H01 0032
Serial number: 03 05 2015 00000196
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 006 0326
Serial number: 000000000ZY15167410L
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000062910872
Part No SW: 5Q0 919 294 L HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0056
Revision: -------- Serial number: 39331519608569
Coding: 0071051811
ROD: EV_EPHVA18AU3700000_002_VW48.rod
VCID: 448D0E5ACF0E696AB1-8010
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0192
Coding: 3200678251FFC428949C804D
ASAM Dataset: EV_ACCBOSCHVW48X 001008
ROD: EV_ACCBOSCHVW48X.rod
VCID: 346D5E9A9FAED9EA01-8060
Part No SW: 3Q0 959 655 BA HW: 3Q0 959 655 BA
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003SSPE3LMFU
Coding: 98FCC0C0000000005C5400CC008800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7EF9BCB2E162C3BAA7-802A
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1032
Serial number: 3G2857705E0196P00604
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 3G2857706E0194P00828
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 001 207 15
Serial number: 3576U0000007B1647517
Subsystem 4 - Part No SW: ----------- HW: 454 001 207 15
Serial number: 3586U000000D5364751A
Subsystem 5 - Part No SW: ----------- HW: 454 801 007 15
Component: SideSensor_Dr 301 0148
Serial number: 3516REC20A3070000004
Subsystem 6 - Part No SW: ----------- HW: 454 801 207 15
Component: SideSensor_Pr 301 0148
Serial number: 3526R34E45E070000008
Subsystem 7 - Part No SW: ----------- HW: 454 800 507 15
Component: FrontSensor_D 304 0149
Serial number: 3556V6AA165070000009
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 3Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150721500954
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 3D7B7BBEACE418A2FE-8068
Part No SW: 3G0 920 941 A HW: 3G0 920 941 A
Component: KOMBI 201 6421
Coding: 27A409182780260001886B011000000000000000
VCID: 244DAEDA2F4E496A91-8070
1048578 - No Basic Setting
B2010 00 [009] - -
Reset counter: 21
Mileage: 82060 km
Date: 2018.11.26
Time: 14:41:24
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 M
Component: GW MQB High 212 2227
Revision: -------- Serial number: 09071510801465
Coding: 030300045F087300FB00005C1C0F00010001070000000000000000000000
ROD: EV_GatewConti_013_VW48.rod
VCID: 75EBA39ED45480E2F6-8020
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0040
Serial number: 29150001420920095281
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 0559857103
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0031
Serial number: 15000066707006
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71E3978EA03CACC22A-8024
Component: TSG FS 020 0041
Serial number: 070715BG700627
Coding: 00350A20D001028000001000
VCID: 438F0D46CA006E5288-8016
Subsystem 1 - Part No SW: 5Q4 959 811 E HW: 5Q4 959 811 E Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001824912
Coding: 0D0000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Coding: 8103
Shop #: WSC 00015 115 00315
Component: TSG BFS 020 0041
Serial number: 090715BG817348
Coding: 00350020D001028000001000
VCID: 42810842D51A675A83-8016
Subsystem 1 - Part No SW: 5Q4 959 812 E HW: 5Q4 959 812 E Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001833049
Coding: 050000
Part No SW: 3Q0 035 874 A HW: 3Q0 035 874 A
Component: MU-S-ND-ER 820 0629
Coding: 02840201FF00000051111101008808001F0100C601200100CF
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 3065528A6BB6E5CA65-8064
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H43 4064
Serial number: VWZ6Z9R1961694
Subsystem 2 - Part No SW: 3G0 919 866 H HW: -----------
Component: ECE 2015/16 --- 0430
End-------------------------(Elapsed Time: 06:20)--------------------------
