Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Retrofit aux heater on A3 8v, HVAC module does not accept coding
    Jan 2016
    Hi guys,
    i am retrofitting a petrol auxilary heater to my 2015 a3 8v E-tron.
    I know which codings are needed, but the Auto HVAC (Module 08) will not accept the coding that the aux heater is present (byte 6 bit 0 on)
    I get Error 31: Request out of range.
    I presume that it needs the security access code first?
    Does anyone here know the correct security access code for this module?
    I cant find it anywhere on this forum or on the web.
    Thanks in advance!
    Sep 2015
    Are you installing OEM heater to your car? Just wondering, since I have a retrofitted non-OEM auxiliary heater in my A3 8V and HVAC does not have that bit enabled and everything is working nicely.
  3. Likes downtime liked this post
    May 2017
    Does your HVAC module support aux heater? If it doesn’t the result is usually that.
    Or the other option what Mika mentioned. Then naturally it won’t code as it is not visible to HVAC.
  5. Likes Uwe, Ronc liked this post
  6. #4
    Jan 2016
    yes, this heater is original from an A3 8V Etron.
    I found this coding on a forum. Seems logical that the heater needs to communicatie with the climate control.
    I think the HVAC should be able to support the aux heater, because the petrol heater is an original option to the E-tron, (which has electric preheating as a standard)
    May 2017
    Can you provide a full autoscan please.
    If this is anything like Golf GTE or Passat GTE the aux heater only works as a pre-heater, it does not work during drive which would explain why you can’t code it to HVAC.
    Also the HVAC units that support aux heater for sure, have a aux heater button on it.
    But my guess here is that the odd decision by VAG to not allow fuel heater during drive is the main reason.
    I think why there’s a coding option in HVAC is that you could start the webasto from the panel as well. The control/wakeup command for the HVAC is coming from the webasto control unit.
  8. Likes Uwe liked this post
  9. #6
    Apr 2018
    ITALY
    +1, on my regular Golf I had to replace the HVAC panel to have the Webasto button. when I tried coding the Webasto with the "normal" HVAC panel, I would get an error.
  10. Likes Uwe liked this post
  11. #7
    Jan 2016
    Here is my scan.
    Do i understand correctly that VW has a real key (button) on the dash for starting the parking heater? Audi has only control through the MMI.
    I dont know if the coding in module 8 is necessary. It is present in VCDS.
    Fact is that i cant get the heater to work. It keeps saying "no basic setting".
    I have fuel to the heater and the fuel and waterpump work correct with the output functions.
    "Heater operation for production" runs for a few seconds and i hear the circulation pump. Then it stops and the "no basic setting" error doesnt go away.
    I have exactly the same situation as "darkchina811" reported mid september. Only i cant get the error out.
    That is why i thought that it might be caused by the coding in module 8.
    Monday,26,November,2018,22:04:19:31113
    VCDS Version: 18.9.0.2 (x64)
    VIN: WAUZZZ8V7GA092145   License Plate:
    Mileage: 30355km-18861mi   Repair Order:
    Chassis Type: 8V-AU37 (5QE)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 23 2B 42 44 51 52 55
              5F 75 8C A5 BB BC C6
    VIN: WAUZZZ8V7GA092145   Mileage: 30355km-18861miles
    C6-Batt. Chrg. -- Status: Malfunction 0010
    Address 01: Engine (J623-CUKB)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 023 AF    HW: 04E 907 309 F
       Component: 1.4l TFSI hy  H22 2660
       Revision: X3H22---
       Coding: 021D0012636401083000
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM14TFS01104E906023AF 005006
       ROD: EV_ECM14TFS_005.rod
       VCID: 64CD51DB6F22366A51-8030
       Part No SW: 0DD 300 045 K    HW: 0DD 927 770 B
       Component: GSG DQ400E    H31 1121
       Revision: 00031033    Serial number: TFK01510290350
       Shop #: WSC 00099 780 00200
       ASAM Dataset: EV_TCMDQ400021 001001
       ROD: EV_TCMDQ400021_VW37.rod
       VCID: 2F67EEF77664C5327C-807A
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
       Part No SW: 5Q0 907 379 AK    HW: 5Q0 907 379 H
       Component: ESC           H31 0809
       Revision: 00000000    Serial number: 63185000000608
       Coding: 12F140A23829326E0378060441C82948021C4CC0608294F5F8A150788608
       ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
       ROD: EV_Brake1UDSContiMK100OMG_001.rod
       VCID: 050B6C5F8458AF62E6-8050
    32832 - Switch for Electric Parking Brake
              C100C 07 [032] - Mechanical Failure
       Revision: 00021000    Serial number: 0386830410
       Coding: 030C0C
       VCID: 3A71CFA3BD26109ADB-806E
       Part No SW: 8V0 820 043 G    HW: 8V0 820 043 G
       Component: AC Automat    H05 0040
       Revision: 20010000    Serial number: 00000000785477
       Coding: 0300000000000000000000000000100001000000
       ASAM Dataset: EV_AirCondiFrontRDWAU37X 001015
       ROD: EV_AirCondiFrontRDWAU37X.rod
       VCID: 3669DB93893EF4FA3F-8062
       Subsystem 1 - Part No SW: 12E 963 231 F    HW: 12E 963 231 F
       Component: J848 HV-PTC  H09 0206
       Serial number: LM153223003807000433
       Component: AQ_Hum_Sensor  H01 0003
       Serial number: 3B1987D7000000000001
       Subsystem 3 - Part No SW: 12E 820 803 E    HW: 12E 820 803 E
       Component: J842 eKK  H02 0005
    459030 - Invalid Data Received From Electric A/C Compressor
              U046C 00 [040] - -
                        Mileage: 29634 km
                        Date: 2018.10.21
                        Time: 18:58:27
                        Unlearning counter according OBD-OBD Parameter: 29
                        Compressor shut-off requirement: Shut-off from Engine Control Module (ECM) via CAN
                        Compressor status: global-A/C compressor release status: transmitted
                        Compressor status: global-A/C compressor: target speed: 0 /min
                        Compressor status: global-A/C compressor: actual speed: Measured value not available
                        Compressor status: global-A/C compressor: function status: Air conditioner compressor off
                        Compressor status: global-A/C compressor error indicator: not active
                        Compressor status: global-A/C compressor: veh. elec. syst. volt.: OK
                        Compressor status: global-A/C compressor: inverter temperature: Measured value not available
       Part No SW: 5Q0 937 084 AR    HW: 5Q0 937 084 AM
       Component: BCM MQBAB M+  H24 0175
       Serial number: 01061532000615
       Coding: 04051D46C2D106FD438C5004B11407A80C1E000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 0815656BB34AB20A9D-805C
       Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 150808  042 0580
       Serial number:         151102160601
       Coding: 0A47F7
       Serial number: 60971829
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
       Serial number: 02 09 2015  00001415
       Component: Sensor, DWA  005 0312
       Serial number: 000000000ZY112370VBD
       Serial number: 00000000000058693429
       Part No SW: 5Q0 919 298 K    HW: 5Q0 919 298
       Component: PARKHILFE PLA H12 0054
       Revision: --------    Serial number: 39491530000173
       Coding: 1030060011
       ASAM Dataset: EV_EPHVA2CAU3700000 003021
       ROD: EV_EPHVA2CAU3700000_003.rod
       VCID: 4797A657FED47D7254-8012
    Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
       Part No SW: 5Q0 907 567 P    HW: 5Q0 907 567 P
       Component: ACC3          H10 0100
       Serial number: 25111503032432
       Coding: 003E1701FE0309
       ASAM Dataset: EV_ACCBoschMQB 001024
       ROD: EV_ACCBoschMQB_AU37.rod
       VCID: 4895A56BF3CA720A5D-801C
       Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
       Component: AirbagVW20    010 0870
       Serial number: 003MFR01HXTI
       Coding: 98FCC0000C2000009C5400CA004800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 50A58D0B0B9ABACA05-8004
       Subsystem 1 - Part No SW: -----------    HW: 480 002 011 15
       Serial number: 357000000005BC21C71N
       Subsystem 2 - Part No SW: -----------    HW: 480 002 011 15
       Serial number: 35800000000C9C21C71T
       Subsystem 3 - Part No SW: -----------    HW: 480 401 711 15
       Serial number: 35100029B1DBD61560DE
       Subsystem 4 - Part No SW: -----------    HW: 480 401 711 15
       Serial number: 3520002AD1DBD6124213
       Subsystem 5 - Part No SW: -----------    HW: 480 400 611 15
       Serial number: 3550002AB1D25F01E135
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 402 810 15
       Serial number: 2280002A11D3F972217%
       Subsystem 7 - Part No SW: -----------    HW: 480 402 710 15
       Serial number: 2290002C71D3F972C17I
       Subsystem 8 - Part No SW: -----------    HW: 480 002 710 15
       Serial number: I0M0000000055A7D7618
       Subsystem 9 - Part No SW: -----------    HW: 480 002 710 15
       Serial number: I0N0000000057A7D761B
       Part No SW: 8V0 953 521 GK    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0120
       Revision: --------    Serial number: 31101508491449
       Coding: EC18
       ASAM Dataset: EV_SMLSKLOMQB 020001
       VCID: 0913606FA840CB0282-805C
       Part No SW: 8V0 920 872 K    HW: 8V0 920 872 K
       Component: KOMBI         H03 6423
       Coding: 078D0C186F9400080D83EE121200000000000000
       Shop #: WSC 55783 001 104857
       VCID: 458BAC5FC4D86F62A6-8010
       Part No SW: 5Q0 963 272 D    HW: 5Q0 963 272 D
       Component: STH-MQB       006 0070
       Coding: 22D4
       ASAM Dataset: EV_AuxilParkiHeateWOS 002016
       VCID: 3777D6978E340DF224-8062
    0376 - No Basic Setting
              B2010 00 [009] -  -
                        Reset counter: 175
                        Mileage: 30355 km
                        Date: 2018.11.26
                        Time: 21:54:37
                        Operating condition of parking heater: OFF
                        71
                        Coolant temperature of parking heater: 11 °C
                        Coolant temperature: 9 °C
                        Engine running status: not recognized
                        Fuel level: 22 l
                        Heater output: 0 W
    Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
       Part No SW: 5QE 907 530 E    HW: 5QE 907 530 A
       Component: GW MQB EV     312 3245
       Revision: --------    Serial number: 09111510520191
       Coding: 0201001726F200005B001218580000000001010100010000000000000000
       ASAM Dataset: EV_GatewEVConti 013020
       ROD: EV_GatewEVConti_013_VW37.rod
       Subsystem 1 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
       Serial number: 16 11 2015  F0043938
       Subsystem 2 - Part No SW: 5QE 915 181     HW: 5QE 915 181
       Serial number: 3627298203
    Address 23: Brake Booster (J539)       Labels:* None
       Part No SW: 5QE 909 059 D    HW: 5QE 909 059 B
       Component: EBKV          H14 0182
       Serial number:   085430011005
       Coding: 03720100331900030002050500
       ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
       ROD: EV_BrakeBoostBoschMQBOMG_003.rod
       VCID: 4FA78E7716A4A5321C-801A
       Brake Assistance Sub:
       Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
       Component: VX70BrakeAssi  H04 0152
       Serial number: 05802861241115232654
    222976 - Brake Booster; Brake Pedal Travel Excessive
              C1214 00 [032] -  -
                        Mileage: 28312 km
                        Date: 2018.08.20
                        Time: 16:49:00
       Revision: 00000000    Serial number: 15000251699007
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 346DE19B9F42E6EA01-8060
       Serial number: 300915BIT21884
       Coding: 001C9F204000040000001003
       Shop #: WSC 06385 790 00021
       VCID: 438FB247CAEC515288-8016
       Component: EPS_MQB_ZFLS  125 1063
       Coding: D302
       VCID: 448DB15BCFE2566AB1-8010
    Address 51: Electric Drive (J841)       Labels: None
       Part No SW: 5G0 907 080 D    HW: 5G0 907 080 D
       Component: VW370P3815010 H06 4492
       Revision: 00H06000
       Coding: C0020000000000000000
       ASAM Dataset: EV_DMCM09550115G0907080D 001018
       ROD: EV_DMCM09550115G0907080D.rod
       VCID: 285505EB538A920ABD-807C
       Serial number: 081015BJ718517
       Coding: 001C97204000040000001003
       Shop #: WSC 55783 001 1048576
       VCID: 4281B743D5F6585A83-8016
       Coding: 011A00002B230200
       ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
       VCID: 3F87BEB7A60435B2EC-806A
       Coding: E00100
       Coding: E00100
       Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H01 7050
       Coding: E00100
       Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H01 7050
       Coding: E00100
    Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-HGH1.clb
       Part No SW: 8V0 035 035 F    HW: 8V0 035 035 B
       Component: MU-H-LN-EU    H45 0401
       Serial number: A301K0F7558834
       Coding: 01739301FF0A000021110001000A02102F00010501000100DE
       ROD: EV_MUHig6C3HBAS_AU37.rod
       Subsystem 1 - Part No SW: V03 959 800 QA    HW: -----------
       Component: ECE 2016  --- 0134
       Component: DU High  H49 0014
       Serial number: AUZ8Z9FY204FFZ
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 L    HW: 8V0 919 614 L
       Component: ControlUnit_H  H81 0816
       Serial number: C1000005101500030112
       Component: Gracenote  --- 1010
    7171 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 175
                        Mileage: 30355 km
                        Date: 2018.11.26
                        Time: 21:55:46
                        Voltage terminal 30: 13.3 V
                        BAP-BAP_Function_ID: 02
       Part No SW: 5QE 035 284 C    HW: 5QE 035 284 C
       Component: OCULowMQBEU   012 0715
       Coding: 0173930110809A0100F800000000
       ROD: EV_OCULowMQB.rod
    Address 8C: Hybrid Battery (J840)       Labels: None
       Part No SW: 5Q0 915 182 C    HW: 5Q0 915 182 C
       Component: BECM          H05 0752
       Serial number: T7250045
       Coding: 00000000
       ASAM Dataset: EV_BECM09620115Q0915182 006037
       ROD: EV_BECM09620115Q0915182.rod
       VCID: 336FE2879A4CE1D218-8066
       Battery Junction Box:
       Subsystem 1 - Part No SW: 5Q0 915 250 D    HW: 5Q0 915 250 D
       Component: BJB  H27 0240
       Cell module: control module 1:
       Subsystem 2 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D1  H14 0472
       Serial number: V013C1590320064
       Cell module: control module 2:
       Subsystem 3 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D2  H14 0472
       Serial number: V013C1590320075
       Cell module: control module 3:
       Subsystem 4 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D3  H14 0472
       Serial number: V013C1590330432
       Cell module: control module 4:
       Subsystem 5 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D4  H14 0472
       Serial number: V013C1590330161
       Cell module: control module 5:
       Subsystem 6 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D5  H14 0472
       Serial number: V013C1590330431
       Cell module: control module 6:
       Subsystem 7 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D6  H14 0472
       Serial number: V013C1590330162
       Cell module: control module 7:
       Subsystem 8 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D7  H14 0472
       Serial number: V013C1590330164
       Cell module: control module 8:
       Subsystem 9 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D8  H14 0472
       Serial number: V013C1590330429
    26717 - Battery Charger Input
              P0D80 00 [032] - Open Circuit
                        Mileage: 28312 km
                        Date: 2018.08.20
                        Time: 13:08:57
                        Pack Voltage: 387.6 V
                        Pack Current: -0.00 A
                        Isolation Resistance: 5080 kOhm
                        Maxumum charge current limit: 3 A
                        Maximum discharge current limit: 330.0 A
                        Contactor Voltage: 0 V
                        OBD unlearned counter: 31
                        Crash status: 00
                        Pilot Line Status: 00
                        Fuse Status: 00
                        (Minus) Contactor Status: 00
                        (Plus) Contactor Status: 00
                        Terminal 15 status: 00
                        Max Cell Temperature: 24 °C
                        Min Cell Temperature: 24 °C
                        Air inlet temperature: 24 °C
                        Air outlet temperature: 24 °C
                        LV Battery Voltage: 12.1 V
                        Min.cell voltage: 4.038 V
                        Max.cell Voltage: 4.042 V
                        Max.cell SOC: 94 %
                        Min.cell SOC: 94 %
                        Hybrid Battery Pack Remaining Life: 94.9 %
                        Max Charge Pack Current(10s duration): 0 A
                        Max Discharge Pack Current(10s duration): 0.0 A
                        Max Pack Voltage(10s duration): 386 V
                        Min Pack Voltage(10s duration): 386 V
                        Max.cell Voltage(10s duration): 4.043 V
                        Min.cell Voltage(10s duration): 4.038 V
                        Accelerator Pedal Position D: 14.1 %
                        Calculated LOAD Value: 0.0 %
                        Engine coolant temperature: 23 °C
                        Engine RPM: 0.00 /min
                        Vehicle Speed Sensor: 0 km/h
                        Ambient Air Temperature: 215 °C
                        Hybrid Battery Pack Remaining Life: 94.90 %
                        control module system voltage: 12.100 V
                        absolute load: 0.0 %
                        Time After Engine Start: 0 s
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
       Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
       Component: MQB_MFK       H06 0060
       Serial number: 10000464374
       Coding: 0101010001010303000500000100000100
       ROD: EV_MFKBoschAU370.rod
       VCID: 3C7DC9BBB7122EAAC9-8068
       Serial number: 271015BJP11072
       Coding: 000C97204000040000001002
       Serial number: 271015BJP11047
    Address C6: Batt. Chrg. (J1050)       Labels:* None
       Part No SW: 5QE 915 682 AA    HW: 5QE 915 682 AA
       Component: OBC KOSTAL    H61 3017
       Revision: --------    Serial number: 1411150KD001PA
       Coding: 115068203000
       ASAM Dataset: EV_OBCSinglPhaseKLOVW3709 004001
       ROD: EV_OBCSinglPhaseKLOVW3709_004.rod
       VCID: 0C1D597BA732DE2AB9-8058
    2097152 - Battery Management
              P33EB 00 [008] - Read Event Memory
                        Reset counter: 204
                        Mileage: 29634 km
                        Date: 2018.10.21
                        Time: 18:58:23
    2097696 - Charging Socket A for AC Connection
              P31C7 00 [008] - Open Circuit
                        Fault Frequency: 12
                        Reset counter: 210
                        Mileage: 22858 km
                        Date: 2018.04.30
                        Time: 09:13:03
    End-------------------------(Elapsed Time: 05:54)--------------------------
  12. #8
    May 2017
    Yes, VW, Seat and Skoda all have a separate button on HVAC panel for immediate aux heater activation. I thought Audi had that too and only the timer settings are controlled via MMI?
    Am I correct that you don't have anything visible in the MMI regarding Aux heater at the moment? Have you gone through the respective adaptation channels in 5F and activated them? These :
    ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
    Do you have a remote control fob for the fuel heater? How are you trying to perform the basic settings? Have you modified the aux heater adaptation channels in any way?
    But again, I still expect the e-tron to be the same as VW GTE plugin hybrid models. In that case, the fuel heater is only a parking heater. So you'll have timer settings in the MMI but no immediate activation. Also fuel heater operation is blocked during drive, it does not produce extra heat during the time car is in active drive mode. This is really stupid restriction in my opinion, I just can't understand why they've made such a decision.
  13. #9
    Apr 2018
    ITALY
    are you sure the fuel line is full and primed? disconnect it at the heater and start the metering pump with output test for at least 60 seconds. of course use a glass container under the hose lol.
    then reconnect and try the operation for production again. the heater should start and clear the basic settings.
    this is how (I think) I did it, since there is little documentation my installation was full of trial and error. I don't remember everything exactly sorry
  14. Likes Ronc liked this post
  15. #10
    Jan 2016
    I primed the fuel line and checked that fuel came out at the heater.
    But still no success.
    operation for production runs for about 3 seconds and then stops. (not running). Sometimes it shows N/A very short before it stops.
    Glow plug and flame monitor runs only for a fraction of a second.
    Combustion blower, circulation pump and metering pump work as expected.
    Supply pump does not run and gives error on the heater controller. Is this the pump in the tank of the car?
    I had the remote connected and calibrated before, but now that doesnt work anymore either.
    Dont really know what to do anymore, except try the same again tomorrow.
