I'm Tom living in Cambridge (UK) with a nice 2016 SEAT Ibiza 1,2 FR TSI (6J) being rebuilt after a front end small bump, but big enough to set off the dash and steering wheel airbags. Replaced airbags, headlamps, bumper and radiator. No damage to suspension or steering.
G85 Steering Angle Basic Settings lost is coming up. So I first re-learned steering end stops by starting engine, left lock for 10sec then right lock for 10sec, back to centre, it beeped. Then tried to calibrate to zero: Basic Settings (04) select steering zero calibration, said Completed, but error remains. I can't find much info about steering angle setting for the Ibiza, am I doing it right?
Sunday,25,November,2018,14:22:32:31648
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4436.4
VIN: VSSZZZ6JZHR067881 License Plate:
Chassis Type: 6J-SE26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: VSSZZZ6JZHR067881 Mileage: 29034km-18040miles
Address 01: Engine (J623-CJZC) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 LH HW: 04E 907 309 AF
Component: R4 1.2l TFS H23 3855
Revision: R4H23---
Coding: 01110012232410080000
Shop #: WSC 00049 770 00221
ASAM Dataset: EV_ECM12TFS01104E906027LH 001001
ROD: EV_ECM12TFS01104E906027BB.rod
VCID: 75B7E2BAF5468CAFBD3-8020
CAN Converter 01:
17158 - Databus
U1123 00 [047] - Received Error Message
Mileage: 29032 km
Date: 2018.09.22
Time: 00:23:01
Engine speed: 948.00 /min
Normed load value: 21.2 %
Coolant temperature: 102 °C
Intake air temperature: 16 °C
Voltage terminal 30: 14.324 V
Mass flow through throttle valve: 8.0 kg/h
Median injection timing: 0.586 ms
A/C compressor: load current: act. value: 136.50 A
U0428 00 [047] - -
Mileage: 29032 km
Date: 2018.09.22
Time: 00:23:01
Engine speed: 944.50 /min
Voltage terminal 30: 14.277 V
selected gear-Bits 0-7: 0
Readiness: 0110 0001
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 R HW: 6R0 907 379 BA
Component: ESP9.0i H04 0006
Serial number: 08503024161020
Coding: 13DD287D492933C7091C00710052C81492CC90000005C9098F00
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
VCID: 3E253D9680F00FF7AC9-806A
0625 - Display for Tire Pressure Monitoring
Fault Frequency: 12
Reset counter: 178
Mileage: 29032 km
Date: 2018.09.22
Time: 00:14:40
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [137] - -
[Scl_LWI_Lenkradwinkel_Error]
Reset counter: 176
Mileage: 29032 km
Date: 2018.09.22
Time: 00:14:40
1149 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [137] - -
[Scl_LWI_SensorNotCalibrated]
Reset counter: 176
Mileage: 29032 km
Date: 2018.09.22
Time: 00:14:40
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6P0 820 045 H HW: 6P0 820 045 H
Component: AC Manuell H01 0204
Serial number: 1610131B-0041
Coding: 000000000100100000
Shop #: WSC 00049 770 00143
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 313F16AA41AEE08F21B-8064
262914 - Refrigerant Pressure
B10AB F0 [013] - Too Low
Reset counter: 176
Mileage: 29032 km
Date: 2018.09.22
Time: 00:15:49
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 D HW: 6C0 937 089
Component: BCM PQ26 Hi4R H10 0094
Serial number: 006308225406
Coding: 0B00084040130A7B0BA44000B12703000000690057010000000000000000
ASAM Dataset: EV_BCMA0 006002
ROD: EV_BCMA0_006_SE26.rod
Subsystem 1 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 042 0105
Serial number: S7Y16M10D19H04M32S54
Coding: 00194D
Drivers Door Control Module:
Subsystem 2 - Part No SW: 6R0 959 802 EC HW: 6R0 959 802 EC Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 0630
Serial number: KU0KU007101662814545
Coding: 0000B5
Subsystem 3 - Part No SW: 6R0 959 801 EB HW: 6R0 959 801 EB Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 0630
Serial number: KU0KU014101662885303
Coding: 1000A5
Subsystem 4 - Part No SW: 6C0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY162580XDG
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number: 00000000000067570235
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 J HW: 6C0 959 655 J
Component: VW20Airbag004 002 0380
Revision: -------- Serial number: 003TH0002DAV
Coding: 88C0C000000000005C0000CA008800000000
Shop #: WSC 00049 770 00113
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 3A2D31869CD823D7901-806E
Subsystem 1 - Part No SW: ----------- HW: 410 272 910 16
Component: SideSensor_Df 15B 0148
Serial number: 3495R000E29D4C86B200
Subsystem 2 - Part No SW: ----------- HW: 410 273 010 16
Component: SideSensor_Pf 15B 0148
Serial number: 3505R000229D6CE5E27/
U1101 00 [137] - Active
[ATP Wrong IKA]
Mileage: 29032 km
Date: 2018.09.22
Time: 00:15:02
Part No SW: 6P0 920 940 B HW: 6P0 920 940 B
Component: KOMBI 202 2310
Coding: 272409002180260001086A001000000000000000
ROD: EV_DashBoardVDDMQBAB_SE26.rod
VCID: 303913AE4AA4E9872E5-8064
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 A HW: 6C0 937 089
Component: GW MQB A0 H10 0094
Revision: -------- Serial number: 006308225406
Coding: 010100082008560070000000000000000001000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_VW26.rod
VCID: 2615F5F67860B737C49-8072
Subsystem 1 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000A0304210116
Coding: 002000
U1101 00 [009] - Active
Reset counter: 178
Mileage: 29034 km
Date: 2018.10.12
Time: 02:56:48
Supply voltage: Terminal 30: 14.4 V
Terminal 15: On
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C2 909 144 AJ HW: 6C2 909 144 D
Component: EPS_TRW_ALow 323 3242
Serial number: CGAR0314
Coding: 000300
ASAM Dataset: EV_SteerAssisUDSTRW 016134
ROD: EV_SteerAssisUDSTRW.rod
VCID: 71BFD6AA812EA08F61B-8024
1094656 - Steering angle sensor
Reset counter: 178
Mileage: 29034 km
Date: 2018.10.11
Time: 01:02:14
Address 5F: Information Electr. (J794) Labels:| 5F0-035-MIB-STD2.clb
Part No SW: 5QA 035 858 A HW: 5QA 035 858 A
Component: MU-S-ND-ER H30 0359
Serial number: SEZAZ2S0190019
Coding: 04520001960A000011111101008808002F0201C60120010046
ASAM Dataset: EV_MUStd6C1TSAT 001015
ROD: EV_MUStd6C1TSAT_SE26.rod
VCID: 45D7527AE5265C2FED3-8010
Subsystem 1 - Part No SW: 5F0 919 604 A HW: 5F0 919 604 A
Component: ABTm_Std2_Nav H44 1031
Serial number: SEZ8Z9SLM02FZA
End----------(Elapsed Time: 00:55, VBatt start/end: 14.5V/14.4V)-----------
