Results 1 to 10 of 18
Thread: 2009 Jetta 2.5: 01044 - Control Module Incorrectly Coded
    Mar 2014
    Brighton, MI
    Getting the code since we bought the car. All stock AFAIK.
    Is the code thrown because of some shoddy work (change a module) of the previous owner? Which module is incorrectly coded?
    Any suggestions how to troubleshoot?
    Code comes right back after erasing.
       Component: J533  Gateway   H07 0062
       Revision:   H07 01    Serial number: 100508F2001357
       Coding: ED807F060002021002
       VCID: 3560AC335C4FC7E235-8060
                        Mileage: 181793 km
                        Time: 00:36:49
    Full scan:
    Friday,23,November,2018,15:53:55:03761
    VCDS Version: 18.9.0.1 (x64)
    VIN: 3VWJM71KX9M004386   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
    VIN: 3VWJM71KX9M004386   Mileage: 203180km-126250miles
    65-Tire Pressure -- Status: Not registered 0011
    Address 01: Engine (CBT)       Labels: 07K-906-055-CBT.clb
       Part No SW: 07K 906 055 P    HW: 07K 906 055 M
       Component: 2,5l R5/4V      G   9205
       Revision: G6H01---    Serial number: VWX7Z0H524L1DD
       Coding: 0000075
       Shop #: WSC 02615 444 84571
       VCID: 3B74BA0B7A6B1192C3-806E
    012408 - Throttle Control
                   P3078 - 000 - Airflow at Idle too Low
                        Mileage: 198530 km
                        Time: 02:03:30
                        RPM: 1354 /min
                        Load: 21.2 %
                        Speed: 50.0 km/h
                        Temperature: 83.0C
                        Temperature: 42.0C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 13.843 V
    008577 - Performance Malfunction in Cooling System
                   P2181 - 000 -  - MIL ON
                        Fault Status: 11100000
                        Mileage: 202870 km
                        Time: 01:21:25
                        RPM: 2809 /min
                        Load: 65.9 %
                        Speed: 133.0 km/h
                        Temperature: 73.0C
                        Temperature: 6.0C
                        Voltage: 14.224 V
       Part No SW: 09G 927 750 JE    HW: 09G 927 750 JE
       Component: AQ 250 6F           1377
       Revision: 00H76000    Serial number:
       Coding: 0000840
       VCID: 7DF0741324FFDFA2BD-8028
       Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
       Revision: 00H45001
       Coding: 113B400D492200FE880E02EC921F00413000
       Shop #: WSC 53635 001 1048576
       VCID: 7EF2731FE9F9C4BAA4-802A
       Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       VCID: 7CF679173FE5D6AA8A-8028
       Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
       Revision: 00H54000    Serial number: 00000000974569
       Coding: 14058E234004150007140000001400000008730B5C000120000000000000
       VCID: 6FEC5E5B7E93BD323F-803A
       Component: Wischer 240608 021  0501
       Coding: 00038805
       Shop #: WSC 00066
       Revision: 05034000    Serial number: 003B6M05NU2G
       Coding: 0013889
       VCID: 6CD649574F85462A1A-8038
       Subsystem 2 - Serial number: 6332MSME42150D0D9
       Subsystem 3 - Serial number: 6342MSME3B63617EN
       Subsystem 4 - Serial number: 6351HSME1627202D0
       Subsystem 5 - Serial number: 6361HSME163D13588
       Subsystem 6 - Serial number: 63727SME157D43351
       Subsystem 7 - Serial number: 63827SME160E2C7AD
       Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
       Coding: 0010021
       VCID: 030402EB421BA952CB-8056
       Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
       Component: KOMBIINSTRUMENT 3HL 1222
       Revision: V0003000    Serial number: VWX7Z0H524L1DD
       Coding: 0023203
       Shop #: WSC 07807 444 69274
       VCID: 3C76B9177F6516AACA-8068
                        Mileage: 181793 km
                        Time: 00:36:49
       Component: IMMO            3HL 1222
       Shop #: WSC 53734 001 1048576
       Revision: 72009005    Serial number: 00000537288617
       Coding: 0001205
       Part No: 1K0 909 144 C
       Revision: 00H15000
       VCID: 2A5A8F4F85F1981AA8-807E
       Coding: 13900F880186083F0904058FB0880F0488DCA0
       VCID: 040601F74715AE6AF2-8050
       Revision: 72009005    Serial number: 00000024888619
       Coding: 0001204
       VCID: 70EE5D2763ADA2CA26-8024
    Address 56: Radio        Labels: 1K0-035-161.lbl
       Part No SW: 1K0 035 161 D    HW: 1K0 035 161 D
       Component: Radio DE2       017 0021
       Revision: 00017000    Serial number: VWZ4Z7H6354944
       Coding: 0040401
       VCID: 204E6D67F3CD524AF6-8074
       Part No SW: 1K0 959 703 Q    HW: 1K0 959 795 J
       Component: J388   TUER-SG HL   1120
       Revision: 12006001    Serial number: 00000003188927
       Coding: 0001168
       VCID: 3E72B31F697904BAE4-806A
       Coding: 0100101
                        Reset counter: 63
                        Mileage: 190060 km
                        Time: 19:49:50
       Part No SW: 1K0 959 704 Q    HW: 1K0 959 794 J
       Component: J389   TUER-SG HR   1120
       Revision: 12006001    Serial number: 00000003194149
       Coding: 0001168
       VCID: 3F8CCE1B6E730DB2EF-806A
    End-------------------------(Elapsed Time: 01:53)--------------------------
    The car is not stock, it & is FOD with TPMS being disabled & unlawfully...........
    Component: 2,5l R5/4V G 9205 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Update programming needed!
    Concerned about the gateway code but not the TPMS code that caused someone to play dirt ball tricks in the installation list, Cheesy again Kraft?
  3. Likes jyoung8607, Fredrick Awuor liked this post
    19-CAN Gateway -- Status: Malfunction 0010 <<<<<<<<<<<<<<<<<<<<<<< Here!
    65-Tire Pressure -- Status: Not registered 0011<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Here!
    More importantly here!
    https://www.nhtsa.gov/laws-regulations?page=9
    https://www.law.cornell.edu/cfr/text/49/part-578
  5. Likes jyoung8607, Fredrick Awuor liked this post
  6. #4
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by KraftwerkTurbo View Post
    The CAN gateway is complaining because there's a module present in the car that it's not configured to recognize. It looks like the previous owner made an attempt to de-equip TPMS from the car, most likely because...
    They didn't want to buy sensors. Connect to module 19, go to Installation List, check address 65 Tire Pressure, save it. With that done, the fault in 19 should go away. Then sort out your TPMS sensors so you have properly working TPMS.
    Silence gives consent.
  7. Likes KraftwerkTurbo, Uwe, Fredrick Awuor liked this post
  8. #5
    Mar 2014
    Brighton, MI
    Where in my question did I talk about concerned?
    Also thanks for the (non requested) legal advise (not applicable).
    The TPMS code is self-explanatory to me. Didn't know that someone tried to code out the TPMS module.
    But some helpful poster provided the useful information already.
  9. #6
    I prefer the city under the city in "Demolition Man" the movie Jason & which isn't afraid to express nor hide ones feelings in order to convey the gravity of the situation, end result is OP if working on system should know his own liability and two the collective was deemed not to have the ability to check their own air PSI or was it because the technology has been on aircraft/aerospace and critical components for decades proving the ability to save lives and no reason since cost so low now that it be implemented?
    Then again what does it matter kids tomorrow wont check TP and will get in an "Uber" car etc. & so they can stay plugged into the social media, which is far more important to control them?
    Anyone want a rat burger?
    I'm in.......
    My point exactly.............
    I just asked questions and pointed you to possible helpful information, I never gave advice to be clear!
  10. Likes jyoung8607, Fredrick Awuor liked this post
  11. #7
    Cincinnati, OH
    Jack, I would never in a million years ask you to hide your feelings. I love having the Jack Experience on this forum.
  12. #8
    I am very sensitive to ones feelings and I do break the OP's and the collectives balls, but most of all it is out of my duty as a friend with term of endearment!
    I don't want to see anyone here getting in trouble for doing stupid illegal shit and not knowing the scope of the pit they are a step away from falling in.
    OP think about what I have asked.........
  13. Likes jyoung8607, Fredrick Awuor liked this post
  14. #9
    He certainly does make it more, uhm, colorful, doesn't he?
  15. Likes Jack@European_Parts, jyoung8607 liked this post
  16. #10
    Mar 2014
    Brighton, MI
    2009 Jetta - CAN Gateway - Control Module Incorrectly Coded - 01044
    Bought car, no changes or modifications AFAIK.
    The 01044 code keeps coming up.
    Is there a 'can gateway module'?
    I checked the settings, but they seemed to make sense.
    Sunday,27,January,2019,13:19:32:03761
    VCDS Version: 18.9.1.0 (x64)
    VIN: 3VWJM71KX9M004386   Mileage: 205450km-127660miles
       Coding: 0000075
       VCID: 3B74BA0B7A6B1192C8-806E
    Readiness: 0010 0101
       Coding: 0000840
       VCID: 7DF0741324FFDFA2B6-8028
       Revision: 00H45001
       VCID: 7EF2731FE9F9C4BAAF-802A
       VCID: 7CF679173FE5D6AA81-8028
       VCID: 6FEC5E5B7E93BD3234-803A
       Coding: 00038805
       Shop #: WSC 00066
       Coding: 0013889
       VCID: 6CD649574F85462A11-8038
       Coding: 0010021
       VCID: 030402EB421BA952C0-8056
       Coding: 0023203
       VCID: 3C76B9177F6516AAC1-8068
       VCID: 3560AC335C4FC7E23E-8060
                        Fault Frequency: 14
                        Mileage: 205455 km
                        Time: 23:48:40
       Coding: 0001205
       Revision: 00H15000
       VCID: 2A5A8F4F85F1981AA3-807E
       VCID: 040601F74715AE6AF9-8050
       Coding: 0001204
       VCID: 70EE5D2763ADA2CA2D-8024
       Coding: 0040401
       VCID: 204E6D67F3CD524AFD-8074
       Coding: 0001168
       VCID: 3E72B31F697904BAEF-806A
       Coding: 0100101
                        Fault Status: 01110100
                        Mileage: 205455 km
                        Time: 23:49:01
       Coding: 0001168
       VCID: 3F8CCE1B6E730DB2E4-806A
    End-------------------------(Elapsed Time: 01:54)--------------------------
