Using different tcm
timmburu
Pirate
Walking the Plank
Kenya
LP/IP
My transmission is 5hp(5speed) forward.im using an all wheel coded tcm.have received no fault codes both on tcm and ecm..
My question is should i be worried doing so?
hmeco_
C?ID=260276
Try making a full Auto-Scan and post a unmodified version of it here. There can be more issues than to the eye.
timmburu
Pirate
Walking the Plank
Kenya
LP/IP
There is no error in both tcu and ecm..only error i have is abs module..right abs short to ground and plus..
Tcm soft coding-00001-programmed for 4wheel
Ecm soft coding-04051-programmed for for 2wheel
Gearbox-is 2wheel
The car moves with no issues.no limp mode.no error.my question is using the 4wheel 5speed tcm on a 2wheel 5speed gearbox..is it a problem i should worry?
I tried coding the tcm to 00013..but it refused..how do i go about it?
hmeco_
C?ID=260276
show them in a full auto-scan, as full as it says, full non edited with header and the whole 9-yard :) like i said above, there can be more that meets the eye
timmburu
Pirate
Walking the Plank
Kenya
LP/IP
I will do that on monday vehicle is in the garage but first i will post pics of the errors i had before i recoded ecm..pics are not that quality but you can make it out..
timmburu
Pirate
Walking the Plank
Kenya
LP/IP
timmburu
Pirate
Walking the Plank
Kenya
LP/IP
how do i post pics?
PetrolDave
Westbury, UK
C?ID=1423
how do i post pics?
This site doesn't allow attaching images, so you upload the pics to a picture hosting service such as imgur, then link to them using the Insert Image tag.
timmburu
Pirate
Walking the Plank
Kenya
LP/IP
timmburu
Pirate
Walking the Plank
Kenya
LP/IP
timmburu
Pirate
Walking the Plank
Kenya
LP/IP
Owner of garage :-(..how much is one?
timmburu
Pirate
Walking the Plank
Kenya
LP/IP
Apologies..it was for the garage owner..im in kenya how do i get one
Fredrick Awuor
Kenya
C?ID=309834
Mburu...kindly check me out at shimo LA tewa road,industrial area.....I have a legit interface, will help you get one from Rosstech....0733516570.....and will scan for you over a cup of coffee
