Help abs coding passat cc 2012
code
New Member
Sweden
C?ID=30208 (NRRT)
hi
can some one help me with abs coding, fault code on vacuum sensor but car do not have this sensor !!:banghead:
thanks
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 18 19 25 42 44 46 47 4C 4F
          52 53 55 56 61 62 69 6C 72 77
VIN: WVWZZZ3CZCE705874   Mileage: 126990km-78907miles
Address 01: Engine (J623-CFGB)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 997 018 A    HW: 03L 907 309 AE
   Component: R4 2.0l TDI   H25 9981
   Revision: 41H25---    Serial number: 00000000000000
   Coding: 001D001A047401080000
   Shop #: WSC 40519 222 00000
   ASAM Dataset: EV_ECM20TDI01103L997018A 003002
   ROD: EV_ECM20TDI01103L906018NC.rod
   VCID: 326FE27A657734DA13-8066
   Part No SW: 02E 300 057 N    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3113
   Revision: 05551213    Serial number: 00001201211926
   Shop #: WSC 05311 000 00000
   VCID: 24431422E783AA6A91-8070
   Part No SW: 3AA 614 109 AJ    HW: 3AA 614 109 AJ
   Component: J104   C2 450M VE3E 0023
   Revision: --H07---    Serial number: 00000005256398
   Coding: 0122300
   Shop #: WSC 33312 002 104856
   VCID: 75E519661C9963E2F6-8020
03366 - Vacuuum Sensor
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 62
                    Mileage: 126992 km
                    Date: 2013.04.12
                    Time: 14:04:28
                    Hex Value: 0x0200
                    Bin. Bits: 00000000 00000001
                    Voltage: 12.75 V
                    Bin. Bits: 00011111
                    Count: 137
                    Hex Value: 0x0000
02757 - Learning Tire Pressures
                    Reset counter: 62
                    Mileage: 126992 km
                    Date: 2013.04.12
                    Time: 14:04:29
                    Hex Value: 0x0200
                    Voltage: 13.00 V
                    Bin. Bits: 00011111
                    Count: 194
                    Hex Value: 0x0000
   Part No SW: 3AA 907 044 E    HW: 3AA 907 044 E
   Component: Climatronic   H03 0101
   Revision: 00001K01
   Coding: 0010004809
   Shop #: WSC 00015 115 00000
   Part No SW: 3AA 937 087 J    HW: 3AA 937 087 J
   Component: BCM PQ47 H++  421 0465
   Revision: BD421001
   Coding: 000C000000000000008C0080B40009642355000865202520E484C72400C1
   VCID: 418DBDB6D8D19F429A-8014
   Subsystem 1 - Part No SW: 3C8 955 119 F    HW: 3C8 955 119 F  Labels: 1KX-955-119.CLB
   Component: WWS464 191211  010 0604
   Serial number: 191211
   Coding: 00B795
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0024
   Serial number: Y12M01D30h15m19s27S1
   Coding: 0280DD
Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
   Part No SW: 3AE 919 475 B    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0016
   Revision: --------    Serial number: 28261203202504
   Coding: 318104
   ASAM Dataset: EV_EPHVA18VW47X0000 001005
   ROD: EV_EPHVA18VW47X0000.rod
   VCID: 3E77C64AA12FE0BAE7-806A
Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
   Part No SW: 3AA 907 567 A    HW: 3AA 907 567
   Component: AC201  RDW A    036 0170
   Revision: 00036000    Serial number: 00000000531586
   Coding: 0010000
   VCID: 387BD0524B0BDE8A2D-806C
   Revision: 00000000    Serial number: 25011203980002
   Coding: 030180
   Shop #: WSC 05314 000 00000
   VCID: 2759032E56B54172B4-8072
   Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
   Component: J234__702 VW10 HI   2118
   Revision: 24017000    Serial number: 003L7P1W61V+
   Coding: 0012338
   VCID: 7CF30C423FB332AA89-8028
   Subsystem 1 - Serial number: 6332MTS617890032
   Subsystem 2 - Serial number: 6342MTS620330032
   Subsystem 3 - Serial number: 6351HTS6CFC30AKR
   Subsystem 4 - Serial number: 6361HTS6D8F30AKR
   Part No SW: 3C5 953 501 BM    HW: 5K0 953 569 T
   Revision: FF010040    Serial number: 20120122301714
   Coding: 2982A70001
   VCID: 71ED2D76A0F14FC22A-8024
   Coding: E20000
   Part No SW: 3C8 920 880 L    HW: 3C8 920 880 L
   Component: KOMBI         H04 0408
   Coding: 140F01
   Shop #: WSC 05314 115 00000
   VCID: 3565D966941923E236-8060
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 A
   Component: Standheizer     043 4730
   Revision: 00043000    Serial number: 09022127000000
   Coding: 0031032
   VCID: 3361E77E526D3DD218-8066
01410 - Heater Over-Temp
                    Reset counter: 56
                        After-Run
                    Temperature: 148.0°C
                    Temperature: -48.0°C
                    Voltage: 12.00 V
01411 - Temperature Sensor (G18)
                    Fault Status: 00100111
                    Reset counter: 96
                    Mileage: 126605 km
                    Date: 2013.04.10
                    Time: 19:14:43
                        Malfunction
                    Temperature: 205.0°C
                    Voltage: 12.07 V
02251 - Heater Unit Locked
                    Reset counter: 56
   Part No SW: 7N0 907 530 Q    HW: 1K0 907 951
   Component: J533  Gateway H41 1623
   Revision:   H41       Serial number: 210112F1000603
   Coding: 469006
   VCID: 3E77C64AA92FE0BAE7-806A
   Part No SW: 3AA 959 799 A    HW: 3AA 959 799 A
   Component:    IMMO         083 0400
   Revision: 00083000    Serial number: VWZCZ000000000
   VCID: 4687AEAA31FFB87AAF-8012
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0537
   Revision: 12110009    Serial number: 0004266846
   Coding: 0200FF
   Shop #: WSC 05311 115 00000
   VCID: 6DD53106BCC9AB220E-8038
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0501
   Serial number: 00000002696479
   Coding: 010098
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.299 1002
   Revision: 1AH03734    Serial number: 00120240277801
   Coding: 0000258
   Shop #: WSC 80093 222 69422
   VCID: 3C73CC427F33F2AAC9-8068
Address 46: Central Conv.        Labels:. 3C0-959-799-46.clb
   Component: 09 KESSY PQ47   083 0341
   Coding: 01900A0001C60E763604941572004FCE7058011324379C
   Subsystem 4 - Part No: 3AA 962 243
   Component: GEB.F.Heckoef       0719
   Part No SW: 5K0 035 456 C    HW: 5K0 035 456 C
   Component: KonzernAmp 8K H07 0202
   Revision: --------    Serial number: EAA086A0004804
   ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
   ROD: EV_AudioVerst8KanalBNO2.rod
   VCID: 2A5FFA1A4DA77C1AAB-807E
   Component: EZE_2         H41 1623
   Coding: 00000008
   VCID: 6FE92B0EBEC559323C-803A
   Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
   Component: Analoguhr  005 0003
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0537
   Revision: 14110009    Serial number: 0004259388
   Coding: 0200FE
   ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
   VCID: 6ED7360AB1CF503A37-803A
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0501
   Serial number: 00000002680273
   Coding: 010098
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000642965
   Coding: 0022167
   VCID: 3565D9665C1923E236-8060
   Component: AFS-ECU       H04 0111
   Coding: 07B200000B000200
   VCID: 3779D36E8E15D1F224-8062
   Subsystem 1 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0007
   Coding: 350000
   Subsystem 2 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0007
   Coding: 350000
   Part No SW: 3C8 035 190 C    HW: 3C8 035 190 C
   Component: Radio RCD510  051 0207
   Revision: 00000001    Serial number: VWZ1Z3M2013826
   Coding: 0501000001000F
   VCID: 2341173E228DAD52E8-8076
   Component: Batt.regelung H41 1623
   Coding: 030F185A
   VCID: 71ED2D76A8F14FC22A-8024
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900720206
Address 69: Trailer (J345)       Labels:. 7N0-907-383.clb
   Part No SW: 7N0 907 383     HW: 7N0 907 383
   Component: Anhaenger     H09 0101
   Revision: 3I001002    Serial number: 00008130004637
   Coding: 0106040000000000
   VCID: 73E1277ED2ED7DD2D8-8026
   Part No SW: 3C8 907 441 A    HW: 3C8 907 441 A
   Component: J772__Rearview      0140
   Revision: 00H10000    Serial number: 525PA8-J211271
   Coding: 0030008
   VCID: 285B00129BAB4E0ABD-807C
   Part No SW: 5K0 035 730 D    HW: 5K0 035 730 D
   Component: TELEFON       H12 2902
   Revision: 1B001001    Serial number: 00007661766949
   Coding: 0A01000000010101
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 26470E2A59BF587A8F-8072
No fault code found
PetrolDave
Westbury, UK
C?ID=1423
Please repost the Auto-Scan without editing it.
code
New Member
Sweden
C?ID=30208 (NRRT)
ok i got it :popcorn:
The OP is OK. But he should Get Verified. It looks like he's in Category 2...
