Supply Voltage for Vehicle Ride Height Sensor
Skodillac
C?ID=344787
I got this “Error: bend lighting (AFS)” alert in a dashboard and the malfunction light is on. Auto-scan shows this kind of fault code "5275409 - Supply Voltage for Vehicle Ride Height Sensor", but it doesn't tell where the fault exactly is. There is two height sensors and the control unit. I didn't find that fault code description. How it looks, what could be the cause? Does this fault code have description somewhere? Thank you in advance! The car is Skoda Octavia 2014.
C107F 11 [137] - Short to Ground
Reset counter: 150
Mileage: 106504 km
Date: 2018.03.30
Time: 20:47:42
Let me see.............?
JPPSG!
Skodillac
C?ID=344787
Auto-scan
Fresh Auto-scan from this day
Tuesday,20,November,2018,16:44:14:61571
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
VIN: TMBJC7NE7E01XXXXX   License Plate:
Mileage: 124983km-77660mi   Repair Order:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 2B 42 44 52 55 5F 69
          6D
VIN: TMBJC7NE7E0145326   Mileage: 124983km-77660miles
Address 01: Engine (J623-CHPA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 G    HW: 04E 907 309 A
   Component: 1,4l R4 TSI   H08 5761
   Revision: WAH08---
   Coding: 01250032243401081000
   Shop #: WSC 73430 031 00121
   ASAM Dataset: EV_ECM14TFS01104E906016G 002008
   ROD: EV_ECM14TFS01104E906016G.rod
   VCID: 2615F5CE78680507C49-8072
Readiness: 0110 0001
   Part No SW: 0CW 300 047 E    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5260
   Revision: 00043014    Serial number: CU501312145860
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 3D273AA28DFEA6DFB53-8068
   Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
   Component: EMB8 EHCB     H31 0356
   Revision: 00000000    Serial number: 635430000004D0
   Coding: 1C076A9124241171007A060241C9243856248800608224F0F0210070C002
   Shop #: WSC 73430 031 00063
   VCID: 4BC3647AC34A186F3B7-801E
   Revision: 00021000    Serial number: 0323194413
   Coding: 030C0C
   Shop #: WSC 73430 790 00121
   VCID: 3A2D31BE9CD091E7901-806E
   Part No SW: 5E0 907 044 F    HW: 5E0 907 044 F
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 02010004000100011005000000100000
   ROD: EV_ACClimaBHBVW37X_003_SK37.rod
   VCID: 2809FBF6727C1377F65-807C
   Part No SW: 5Q0 937 086 Q    HW: 5Q0 937 086 Q
   Component: BCM PQ37BOSCH 026 0095
   Revision: --------    Serial number: 86581912130058
   Coding: 0C031B46424722FB4FE44004001C17080800000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
   ROD: EV_BCMBOSCH_012.rod
   VCID: 48C95B76D23CF377165-801C
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 131216  041 0570
   Serial number:         131218160704
   Coding: 065DDD
   Component: RLFS  024 0042
   Serial number: Y13M12D27H22M35S07S9
   Coding: 02805D
   Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H09 0033
   Revision: --------    Serial number: 60831400701984
   Coding: 0001050111
   ASAM Dataset: EV_EPHVA14AU3700000 002018
   VCID: 38292BB6A2DC83F7665-806C
   Part No SW: 5Q0 907 572 B    HW: 5Q0 907 572 B
   Component: ACC Bosch MQB H04 0200
   Serial number: 05121376510343
   Coding: 00001800FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001014
   VCID: 3635258EA8C87587749-8062
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 Airbag VW20   012 01890189
   Revision: --------    Serial number: 003P4PS4QPGR
   ROD: N/A
   VCID: 7F5B00AAC77274CFE7F-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 001 112 13
   Serial number: 3576U000000FFC947E0+
   Subsystem 2 - Part No SW: -----------    HW: 454 001 012 13
   Serial number: 3586U000000389246E0C
   Subsystem 3 - Part No: -----------
   Component: SideSensor_Dr
   Part No SW: 5Q0 953 507 EE    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 05011404401650
   Coding: 1410
   ROD: EV_SMLSKLOMQB_012_AU37.rod
   VCID: 7DA7FAA2CD7E66DFF53-8028
   Part No SW: 5E0 920 871 B    HW: 5E0 920 871 B
   Component: KOMBI         333 2210
   Coding: 07A40A182980000801882A01000000
   VCID: 270BF8CA7F621C0FFFF-8072
   Revision: --------    Serial number: 0001450417
   Coding: 030100342F085700EF00024A1C0F00010001050000000000000000000000
   ROD: EV_GatewLear_010.rod
   VCID: 3FDB40AA87F2B4CFA7F-806A
   Subsystem 2 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
   Serial number: 000000000A0510191213
   Serial number: 5445082103
Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
   Part No SW: 5G0 857 511 D    HW: 5G0 857 511
   Component: FLA           H04 0002
   Revision: AA001001
   Coding: 02018F6B76765D525220343E01
   VCID: 2B0304FA638A386F1B7-807E
   Revision: 00000000    Serial number: 13000265357005
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311F86BEB467974AD-8060
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000085446217
   Coding: 00150920D000040000001100
   VCID: 44D14F46EE14D717FAD-8010
   Serial number: 00000000000001428178
   Coding: 010200
   Coding: 0103
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DF4652F106C23FD1B-8014
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000087611829
   Coding: 00150120D000040000001100
   VCID: 43D34C5AEB1AD02FC37-8016
   Serial number: 00000000000001461396
   Coding: 190200
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 03CA02003F000000
   Shop #: WSC 73430 790 00063
   Coding: 3E0000
   Coding: 3E0000
                    Reset counter: 192
                    Mileage: 124944 km
                    Date: 2018.11.19
                    Time: 00:28:05
Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-STD1.clb
   Part No SW: 5E0 035 840 A    HW: 5E0 035 840 A
   Component: MU-S--ER      040 0435
   Serial number: S3E01101140622
   Coding: 03730200FF00000011110001000800002F0000840100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 1F1BE02A2732D4CF87F-804A
   Subsystem 1 - Part No SW: 5E0 919 605 B    HW: 5E0 919 605 B
   Component: ABT_Std_Plus  H50 0022
   Serial number: SKZ8Z9NK600NPH
   Part No SW: 5Q0 907 383     HW: 5Q0 907 383
   Component: Anhaenger     H11 0030
   Revision: 6A001003    Serial number: 00000322177119
   Coding: 0100000200000000
   ASAM Dataset: EV_TrailFunctDemouHella 001001
   ROD: EV_TrailFunctDemouHella.rod
   VCID: 74B1DF86FE3427978AD-8020
   Part No SW: 5E0 959 107     HW: 5E0 959 107
   Component: HDSG-Modul    H01 0744
   Revision: 42001001    Serial number: 344300403
   Coding: 1233074003
   ASAM Dataset: EV_HDSGSk462 301136
   ROD: EV_HDSGSk462_SK37.rod
   VCID: 698FBEF2A9F6EA7F29B-803C
End----(Elapsed Time: 02:47, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Short to Ground
Check ride sensor wiring and sensor for FOD corrosion contamination, at plug & in addition to fuses for the ride height, by using RTFB and WD.
Thank you for your auto-scan and oh Welcome to the Collective!
Skodillac
C?ID=344787
Things that I have done so far
Thank you!
Things that I have done so far:
Checked and cleared connectors with compressed air and CRC oil
Checked, changed ( just in case) and oiled fuses.
Measured the reference voltage from sensors connectors ( something like 4,6V, ingnition on and engine off)
Did auto-scan when both sensors and connectors were loose
Checked sensors for physical damage
Took the car battery negative connector loose for 15 mins.
The malfunction light and fault still persist.
Here is the auto-scan with loose sensors. That is not what expected, but like this it was.
Looking forward for new ideas to try!
Sunday,18,November,2018,17:02:15:61571
VIN: TMBJC7NE7E0xxxxxx   License Plate:
Mileage: 124677km-77470mi   Repair Order:
          6D
VIN: TMBJC7NE7E0xxxxxx   Mileage: 124677km-77470miles
   Revision: WAH08---
   Coding: 030C0C
1058315 - Antenna for Keyless Entry System; Interior Antenna 2
          B1174 13 [008] - Open Circuit
                    Reset counter: 212
                    Mileage: 124249 km
                    Date: 2018.11.11
                    Time: 12:05:47
   Revision: 00001K06
          B10CD 00 [009] -  -
                    Reset counter: 186
                    Mileage: 123253 km
                    Date: 2018.11.04
                    Time: 20:01:48
                    Voltage terminal 30: 10.9 V
   Coding: 065DDD
   Coding: 02805D
   Coding: 0001050111
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 221
                    Mileage: 124605 km
                    Date: 2018.11.16
                    Time: 09:19:49
                    Control Module temperature: 12 °C
                    Voltage terminal 15: 11.9 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
   Component: Airbag VW20   012 0189
   ROD: EV_AirbaVW20TS6VW48X.rod
   Subsystem 3 - Part No SW: -----------    HW: 454 801 112 13
   Serial number: 3516R20F49E020000002
   Subsystem 4 - Part No SW: -----------    HW: 454 800 612 13
   Serial number: 3526RAD2E8802000000E
   Subsystem 5 - Part No SW: -----------    HW: 454 802 810 13
   Serial number: 3556VD788BA01000000M
   Coding: 1410
131602 - Power Steering Control Module
          U101D 00 [008] - No Communication
          [Timeout Knoten 0x12 / 44 - Steuergerät für Lenkhilfe]
                    Reset counter: 226
                    Mileage: 123654 km
                    Date: 2018.11.06
                    Time: 08:52:30
                    Terminal 15: OFF
   Revision: AA001001
   Coding: 010200
   Coding: 0103
   Coding: 190200
   Coding: 3E0000
   Coding: 3E0000
                    Reset counter: 184
                    Mileage: 123528 km
                    Date: 2018.11.05
                    Time: 23:40:09
5256721 - Rear Left Ride-Height Sensor
          C1036 11 [008] - Short to Ground
                    Reset counter: 224
   Coding: 1233074003
End----(Elapsed Time: 01:36, VBatt start/end: 11.2V/11.2V. VIgn 11.2V)-----
myounus
Northwest UK
C?ID=321059
If you've checked the wiring / connections and it's showing continuity then it's possibly the sensor itself that's been subjected to FOD.
Skodillac
C?ID=344787
When I took the rear sensor out separately, the front sensor and measure data began to work again. The Broken rear sensor disturbed also the front one. So it was the rear level-sensor, I changed it to a reuse part (from Seat Leon) and everything works again like new. Thanks for the tips!
