You can create an adaptation- and meas. values map of every control unit using the Applications-->Controller Channel Map feature...
... And be prepared for that scan to take some time. Best to use a battery charger, or let the engine idle while doing that type of scan.Or Debug 2 in settings menu and doing autoscan.
Great, thanks.You can create an adaptation- and meas. values map of every control unit using the Applications-->Controller Channel Map feature...
Great, thanks.
It looks like I manually need to enter each controller address (01 -> FF), which shouldn't be an issue, but it also asks for "Login or security access code". I presume the code is only required for modules that are protected (but let me know if you believe otherwise).
Thanks.
Did this work?
