Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: VCD Help - No Automatic DRLs (14 Audi S7)
    Verified VCDS User InfiniteReality's Avatar
    Nov 2018
    Please set Byte 3 Bit 4 in your Unit 09 central electrics. In addition the Bit that Uwe mentioned for turning on/off DLR in the MMI Menu to assure it is on.
    If this does not help, try unsetting Byte 2 Bit 5 in addition
    You solved it! It was byte 2 bit 5, now they work as intended and I also re-enabled the option to turn them on/off in the MMI. Many, many thanks!
    2014 Audi S7
  2. Likes Uwe liked this post
  3. #12
    Sep 2018
    Just for reference, another way that I believe you could disable them is by removing the DRL function from the DRL lamps. Research light configuration or light functions for more information. This an interesting post too, albeit in German.
  4. #13
    Quote Originally Posted by PuJuM View Post
    I don't think that's applicable because an S7 is no MQB.
