Friday,23,November,2018,20:32:59:42397
VIN: WAUW2AFC3EN014896 License Plate:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 28 34 36 3B 3C 42 44 46
47 52 53 55 56 5F 62 6C 6D 72 8F 90 A9 BA
VIN: WAUW2AFC3EN014896 Mileage: 83353km-51793miles
BA-Motor Mounts -- Status: Malfunction 0010
Address 01: Engine (------CEUC) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 906 014 E HW: 4H0 906 014
Component: 4.0l V8TFSI / H62 0001
Revision: NCH62---
Coding: 1A2500326526000E1000
Shop #: WSC 00477 128 28888
ASAM Dataset: EV_ECM40TFS0114G0906014E 001001
ROD: EV_ECM40TFS0114G0906014E.rod
VCID: 2411EF687E51A6F7DAD-8070
Part No SW: 4G9 927 156 C HW: 0B5 927 156 J
Component: 0B5 40TFSINAR H02 0002
Revision: --H02---
Shop #: WSC 02391 785 00200
ROD: EV_TCMDL501021.rod
VCID: 3537222CC5CB2F7F7D3-8060
Part No SW: 4G0 907 379 L HW: 4G0 907 379 L
Component: ESP PREMIUM H09 0450
Coding: 65B65703A66DEAC05B00
VCID: 3A2D3110ECD5C007901-806E
Part No SW: 4H0 907 064 CR HW: 4H0 907 064 CR
Component: BCM2 2.0 H33 0433
Coding: 0D8A2046000000000000
VCID: 7BA3F414A3EF390FCB7-802E
Serial number: 2313000100991012
Part No SW: 4G0 820 043 AE HW: 4G0 820 043 AE
Component: KLIMA 4 ZONEN H13 0087
Serial number: 11061300040334
Coding: 688320B849
ASAM Dataset: EV_AirCondiComfoUDS 002040
VCID: 629DA97024C5E8C7E81-8036
Part No SW: 4H0 907 063 CG HW: 4H0 907 063
Component: BCM1 2.0 H12 0130
Revision: 11012002 Serial number: 00000001735237
Coding: 02003000163C8FE0E90080C7A0003928CF9CD208A2080221800008406000
VCID: 6FBBD044E79755AF77F-803A
Component: WWS57X 130525 H36 0080
Serial number: 130530044910
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 21390271
Coding: 02006E
Subsystem 3 - Part No SW: 4G0 941 531 D HW: 4G0 941 531 D
Component: E1 - LDS H07 0044
Serial number: 04 06 2013 00000805
Component: USHL4.2 H30 0030
Serial number: 0000002274555R679402
Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA105523000003747305
Coding: 020300
Serial number: 17398FA6000000000001
03188 - Bulb for Side Marker Light; Front Left
Fault Status: 01101100
Reset counter: 191
Mileage: 82885 km
Date: 2018.11.16
Time: 17:17:00
Revision: 11001001 Serial number: 61061315800067
Coding: A8C109
VCID: 71BFD63CF123435F61B-8024
Part No SW: 4G0 959 655 A HW: 4G0 959 655 A
Component: Airbag10.43 H33 0033
Revision: -------- Serial number: 003D800347UP
Coding: 303145313131303030314A55304C34473853
VCID: 33331C34CBBF314F537-8066
Serial number: 6940000Y130000USKM0S
Serial number: 3575HRB4065217O06056
Serial number: 3585HRB401C50GEOCHU$
Serial number: 3515JRB401050IBUO12
Serial number: 3525JRB400O50HQCK0NV
Serial number: 3554VRB401050J2CE9CZ
Serial number: 3564VRB400A50J2EGI7A
Revision: -------- Serial number: 90372MEV000WT
Coding: 000434
VCID: 38292B18D259D217665-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Serial number: 10 04 2013 D0198714
Part No SW: 4G8 920 985 F HW: 4G8 920 985 F
Component: TBenUsa Nv H80 0618
Revision: 30460230 Serial number: 658040613596025
Coding: 03EF01079B43D705020300
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K.rod
Part No SW: 4G0 907 468 AC HW: 4G0 907 468 AC
Component: J533--Gateway H12 0037
Revision: -------- Serial number: 00000000972367
Coding: 00E1034800
ASAM Dataset: EV_GatewPkoUDS 001018
Serial number: 5080930603
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 A HW: 4H0 907 163 A
Component: 4 Wheel Drive H16 0013
Serial number: 000406130001306
ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
VCID: 270BF8640F674DEFFFF-8072
Part No SW: 4G0 919 158 K HW: 4G0 919 158 K
Component: KLIMA FOND H07 0087
Serial number: 08061300040624
Coding: 20
ASAM Dataset: EV_ClimaContrUnitRearUDS 002019
VCID: 372B2824DFC7DD6F6FF-8062
Part No SW: 4G0 907 553 F HW: 4G0 907 553 F
Coding: 008000
ROD: EV_AirSuspe_VW51.rod
VCID: 2E050D40209D1CA73C9-807A
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000063632485
Coding: 00581B0000002001000001010101102030303232203232
VCID: 77ABE8249FC71D6FAFF-8022
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H02 0056
Revision: -------- Serial number: EJ1BPA7E00GF25
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
Part No SW: 4G0 907 566 J HW: 4G0 907 566
Component: J769 SWA MasterH04 0060
Revision: 00H04000 Serial number: 6PZ 010 287-08
Coding: 0000003
VCID: 36352520D44D2467749-8062
Subsystem 1 - Part No: 4G0 907 568 J
Component: J770 SWA Slave H04 0060
Subsystem 2 - Serial number: 6PZ 010 287-28
Subsystem 3 - Serial number: 5F10.06.1300H04000AMS14276ÿ
Subsystem 4 - Serial number: S14276ÿ
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0507
Coding: 011F5F025E00628002000412
VCID: 45D752EC95ABBFFFED3-8010
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0002548860
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323D193034A53847581-8066
Revision: 00002001 Serial number: 0309116636
Coding: 0126063A20FAF08580B00A8002030D000000000000000000000000000000
Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000156075
Subsystem 3 - Part No SW: 4G8 959 591 HW: 7P0 959 591 C
Component: J245 PS40.039 H01 0008
Serial number: WOO2239025/
Coding: 101F00
Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00003564458
Subsystem 5 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H11 0029
Serial number: WA106023000003815278
Subsystem 6 - Part No SW: 3AA 962 243 B HW: 3AA 962 243 B
Component: GEB.F.Heckoef H16 0810
Serial number: 93025326
Part No SW: 4G1 035 223 A HW: 4G1 035 223 A
Component: BOSE-G3C7-ANC H02 0540
Revision: CJ002700 Serial number: 00000000007520
Coding: 030000
VCID: 1C61D78846A19E3762D-8048
03405 - Bass Loudspeaker
Fault Status: 00111011
Fault Frequency: 81
Reset counter: 254
Part No SW: 4G8 959 792 H HW: 4G8 959 792 F
Component: TSG BF H04 0507
Coding: 011F5F025E00628002000402
VCID: 44D14FE89E9186F7FAD-8010
Part No SW: 4H0 907 801 G HW: 4H0 907 801 A
Component: EPB-4 H03 0014
Revision: -------- Serial number: 00000000715951
ROD: EV_ParkiBrake_VW51.rod
VCID: 2C01074816816EB712D-8078
Address 55: Headlight Range (J431) Labels:| 4H4-907-357-V1.clb
Part No SW: 4H4 907 357 C HW: 4H4 907 357 A
Component: ....AFS13.... H01 0020
Serial number: 130608-0004-003
Coding: 12236F33701AA600
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste_AU21.rod
H01 0031
Coding: 3A0000
H01 0031
Coding: 3A0000
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Revision: AB001007 Serial number: 156F$0D7811537
Coding: 020007010000000001
VCID: 2411EF687ED1A6F7DAD-8070
02983 - Connection between Impedance Converter 1 and Window Antenna
Fault Status: 01101011
Reset counter: 191
Mileage: 82885 km
Date: 2018.11.16
Time: 17:09:35
Voltage: 12.20 V
Part No SW: 4G0 035 746 E HW: 4G0 035 746 E
Component: H-BNT-NA H40 0735
Revision: -------- Serial number: 194F50D7535388
Coding: 0A0200040303F1EF55128F1E00000003100001000000000000
VCID: 290FFE5C19F37B9FE9B-807C
Subsystem 1 - Part No: 8R0 060 884 BD
Component: NAR 2013/2014 0802
Subsystem 2 - Part No SW: 4G0 919 605 C HW: 4G0 919 605 C
Component: DU8 C7 SV H43 0021
Serial number: AUZ8ZDDD001YP46
Subsystem 3 - Part No SW: 4G1 919 612 Q HW: 4G1 919 612 Q
Serial number: 90349MF1000K2
Component: CD-Database 5298
Part No SW: 4G8 959 795 H HW: 4G8 959 795 F
Component: TSG HL H03 0507
Coding: 010F1F024000628002000002
VCID: 47CB58E4AFA7ADEF1FF-8012
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Revision: --H07--- Serial number: 525 PA8J35G998
Coding: 1080013
VCID: 2615F56004ED54E7C49-8072
Part No SW: 4G8 959 107 R HW: 4G8 959 107 G
Component: HDSG-Modul H13 0043
Revision: 12013001 Serial number: 151300166
Coding: 0A3305C102
ASAM Dataset: EV_HDSGAu573 001022
ROD: EV_HDSGAu571.rod
VCID: 44D14FE89E1186F7FAD-8010
Component: TSG HR H03 0507
Component: RGS-VL H13 0080
Coding: 0006E008031F0300070308014244CA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 313F163C31A3035F21B-8064
Component: RGS-VR H13 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
Part No SW: 4G0 907 159 B HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0010
Serial number: 130322200029
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 HW: 4H0 907 145
Component: AEM - LEAR H05 0006
Revision: 00001001 Serial number: 97804002048304
ASAM Dataset: EV_AEMLearAU64X 002014
ROD: EV_AEMLearAU64X_AU57.rod
VCID: 6695B560C8ED94E7049-8032
1294 - Actuator 1 for Drivetrain Mounts
C1131 07 [009] - Mechanical Failure
Reset counter: 191
Mileage: 82885 km
Date: 2018.11.16
Time: 17:09:30
End----------(Elapsed Time: 02:43, VBatt start/end: 12.3V/12.3V)-----------
