There is nothing added later in my car, all of them are factory equipment, I only went to 19 can gateway 03 output test section, I chose the lowest component component protection option in the options, the test started and airbag defective error output, I stopped the test, switched on and off the ignition, but restarted, " Airbag not working "I see the warning.
active error appears in 15 airbag blocks, I delete errors but come again, shouldn't I do this test? What is the purpose of this test? I did wonder, but as a result my car airbags did not work. . ((
