- Joined
- Nov 5, 2018
- Messages
- 47
- Reaction score
- 7
- Location
- Europe - Hungary
- VCDS Serial number
- C?ID=338434
I have two control module in my car which is red in autoscan.
BB-Door Rear Drv -- Status: Not registered 0001
BC-Door Rear Pass -- Status: Not registered 0001
I cannot open these.
What is the solution to reach these?
Friday,16,November,2018,16:52:34:64377
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
VCDS Version 18.9.0.2 (x64) HEX-V2 CB: 0.4436.4
VIN: TMBAR7NEXK0036742 License Plate: PYK234
Mileage: 3724km-2313mi Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F BB BC
VIN: TMBAR7NEXK0036742 Mileage: 3724km-2313miles
Address 01: Engine (J623-DADA) Labels:. 04E-907-309-V1.clb
Part No SW: 05E 906 018 AL HW: 05E 907 309
Component: R4 1.5l TFS H22 6084
Revision: 81H22000
Coding: 011900322324190800000000000000000000000000000000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM15TFS01105E906018AL 003002
ROD: EV_ECM15TFS01105E906018AL.rod
VCID: 6FBBD0C76712BBEF77F-803B
Address 03: ABS Brakes (J104) Labels:* None
Part No SW: 5Q0 614 517 DF HW: 5Q0 614 517 AF
Component: ESC H62 0974
Revision: 00000000 Serial number: 62278000000267
Coding: 24076A9124232172407E060460C5242456248402600624722023F070C009430B00000012121212B835351919323200
Shop #: WSC 73430 031 12345
ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009
ROD: EV_Brake1UDSContiMK100ESP_037_SK37.rod
VCID: 78A9EB9B125CFC57A65-802D
Part No SW: 5E0 907 044 AP HW: 5E0 907 044 AP
Component: Climatronic H04 2002
Revision: 00001K00
Coding: 01010004000110011005004800101022
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_ACClimaBHBVW37X 006147
VCID: 73B3DCB70B3A9F0F937-8027
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 DA HW: 5Q0 937 084 CD
Component: BCM MQBAB B H38 0273
Serial number: 00001823902159
Shop #: WSC 73430 790 12345
ASAM Dataset: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 7AADF1932C50EE47D01-802F
Subsystem 1 - Part No SW: 5E1 955 119 A HW: 5E1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 180811 051 0916
Serial number: 887353F0401822300929
Coding: 1F4DFD
Subsystem 2 - Part No SW: 8U0 955 559 HW: 8U0 955 559 Labels: 8U0-955-559.CLB
Component: G355_FeuchteS H07 0002
Serial number: 72290246
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5QA 919 283 C HW: 5QA 919 283
Component: PDC 4 KanalH07 0050
Serial number: 000308419618240
Coding: 0601050001
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_EPHVA14AU3700000 009037
ROD: EV_EPHVA14AU3700000.rod
VCID: 4ACD61533C30BEC7001-801F
Part No SW: 3Q0 959 655 BH HW: 3Q0 959 655 BH
Component: Airbag VW21 006 0712
Revision: -------- Serial number: 003W4PHN028S
Shop #: WSC 73430 790 00000
ROD: EV_AirbaVW21TS6VW48X_VW37.rod
VCID: 0557926F55AE91BFAD3-8051
Subsystem 1 - Part No SW: ----------- HW: 454 001 308 18
Serial number: 3570000000090C38B03I
Subsystem 2 - Part No SW: ----------- HW: 454 001 608 18
Serial number: 35800000000F1358313C
Subsystem 3 - Part No SW: ----------- HW: 454 801 908 18
Component: SideSensor_Dr 301 0148
Serial number: 35100AD22EF15000000S
Subsystem 4 - Part No SW: ----------- HW: 454 802 108 18
Component: SideSensor_Pr 301 0148
Serial number: 352005545B6150000009
Subsystem 5 - Part No SW: ----------- HW: 454 800 408 18
Component: FrontSensor_D 304 0149
Serial number: 3550095843915000000E
Part No SW: 5Q0 953 507 GD HW: 5Q0 953 549 F
Revision: -------- Serial number: 30081820241335
Coding: 1400
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 7EA5FD833078C267EC9-802B
Part No SW: 5E0 920 740 F HW: 5E0 920 740 F
Component: KOMBI 212 2501
Coding: 07AD02002180000801083A001001000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009066
VCID: 2615F5E38868BAA7C49-8073
Part No SW: 3Q0 907 530 Q HW: 3Q0 907 530 C
Component: GW MQB High 439 4344
Revision: -------- Serial number: 0008379434
Coding: 030100047F085700EB000248080F00010001070000000000000000000000
ASAM Dataset: EV_GatewNF 013044
ROD: EV_GatewNF_VW37.rod
VCID: 3D273A8F7DFE197FB53-8069
Subsystem 2 - Part No SW: 3V0 919 719 E HW: 3V0 919 719 E
Component: E221__MFL-PR6 H02 0160
Serial number: 000000000D2174290818
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 75886002001809012D3D
Part No SW: 5Q4 959 593 F HW: 5Q4 959 593 F
Component: TSG FS 006 0246
Serial number: 0000336807160
Coding: 00110120D000020000001100
VCID: 48C95B5B223C4CD7165-801D
Subsystem 1 - Part No SW: 5Q0 959 811 E HW: 5Q0 959 811 E Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000023505338
Coding: 010200
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 5Q0 910 143 C HW: 5Q0 910 143
Component: MQB_VWBS_GEN2 212 2211
Serial number: 856026 00
Coding: 0100001000400010
ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
ROD: EV_SteerAssisVWBSMQBGen2_SK37.rod
VCID: 2B0304D7938A87CF1B7-807F
Part No SW: 5Q4 959 592 F HW: 5Q4 959 592 F
Component: TSG BFS 006 0246
Serial number: 0000341102239
VCID: 47CB58672F2243AF1FF-8013
Subsystem 1 - Part No SW: 5Q0 959 812 E HW: 5Q0 959 812 E Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000023517010
Coding: 190200
Address 5F: Information Electr. (J794) Labels:| 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 840 C HW: 5Q0 035 840 C
Component: MU-S--ER H41 0472
Serial number: SKZAZ2U0789211
Coding: 03730100FF00000041110001000002002F0208C40120050003
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: 2D070ACFAD9E89FF053-8079
Subsystem 1 - Part No SW: 5E0 919 605 N HW: 5E0 919 605 N
Component: ABT_Std-2 H52 8130
Serial number: SKZ6ZHV2471660
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End----------(Elapsed Time: 01:21, VBatt start/end: 12.2V/12.2V)-----------
