Results 1 to 4 of 4
Thread: Coding Help - VW Tiguan Phase II - 2016
    Nov 2018
    Tunisia
    Exclamation Coding Help - VW Tiguan Phase II - 2016
    Dear All,
    I just bought a new VCDS device and i'm new on coding
    I made a scan for the car and i got many errors can you advise, please
    I installed a new Bluetooth module in the car
    Please check the error below
    Wednesday,14,November,2018,00:08:02:23561
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
    VCDS Version 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WVGCG2AX0GW000308   License Plate:
    Mileage: 70590km-43862mi   Repair Order:
    Chassis Type: AX-VW36 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 4C 52 53 56 61
              62 6C 72 77
    VIN: WVGCG2AX0GW000308   Mileage: 70590km-43862miles
    77-Telephone -- Status: Malfunction 1010
       Part No SW: 5N0 920 883 D    HW: 5N0 920 883 D
       Component: KOMBI         H03 0705
       Coding: 611F01
       VCID: 353722BFB5C4B63F7D3-8061
    13654544 - Databus
              [Steuergerät für Telefon keine Kommunikation]
                        Reset counter: 213
                        Mileage: 70462 km
                        Date: 2018.11.11
                        Time: 17:31:33
       Part No SW: 7N0 907 530 AQ    HW: 7N0 907 530 AL
       Component: J533  Gateway H58 1653
       Revision:   H58       Serial number: 140315F1001212
       Coding: 356002
       Shop #: WSC 12345 123 61029
       VCID: 7F5B0097C7F8BC6FE7F-802B
    01304 - Radio
                        Fault Status: 00110100
                        Reset counter: 213
                        Mileage: 70462 km
                        Date: 2018.11.11
                        Time: 17:31:54
                        Reset counter: 213
                        Mileage: 70462 km
                        Date: 2018.11.11
                        Time: 17:31:32
                000 -  -  - Intermittent
                        Mileage: 70462 km
                        Date: 2018.11.11
                        Time: 17:19:40
       Revision: A1001003    Serial number: 7670229784
       Coding: 010100
       VCID: 2B0304C76300F0CF1B7-807F
    01304 - Radio
                        Reset counter: 213
       Part No SW: 5K0 035 190 A    HW: 5K0 035 190 A
       Component: Radio RCD510  053 0213
       Revision: 00000001    Serial number: VWZ1Z3R0981594
       Coding: 0100040004000C
       VCID: 2313ECE70BD0388FA37-8077
                        Reset counter: 213
                        Mileage: 70462 km
                        Date: 2018.11.11
                        Time: 17:31:31
    00856 - Radio Antenna
                        Fault Status: 00101011
                        Reset counter: 213
                        Mileage: 70462 km
                        Date: 2018.11.11
                        Time: 17:19:54
                        Reset counter: 213
                        Mileage: 70462 km
                        Date: 2018.11.11
                        Time: 17:19:54
    Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
       Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
       Component: Telefon       H09 6900
       Revision: 00009000    Serial number: 00000A09759372
       Coding: 412120
       Shop #: WSC 00078 790 00187
       VCID: 2A0D01C36CFAE9C7E01-807F
    03426 - Left Audio Channel
                        Reset counter: 213
                        Mileage: 70462 km
                        Date: 2018.11.11
                        Time: 17:43:23
    03427 - Right Audio Channel
                        Reset counter: 213
                        Mileage: 70462 km
                        Date: 2018.11.11
                        Time: 17:43:22
    01304 - Radio
                        Reset counter: 213
                        Mileage: 70462 km
                        Date: 2018.11.11
                        Time: 17:43:25
    End----------(Elapsed Time: 01:30, VBatt start/end: 12.2V/12.2V)-----------
    Thank you & Regards
    Mootez
    HQ
    So um... what happened to that Auto-Scan? No engine... how does this car move? Please do not edit down the Auto-Scan, you need to post the FULL Auto-Scan. What little is there.... lots of "Intermittent" codes. Clear them out, take the car for a short test drive and then run another Auto-Scan and post the results.
    Jef
  3. Likes Uwe, Fredrick Awuor liked this post
    Nov 2018
    Tunisia
    Please find the below full scan as requested
    I just installed the BT 9W2 both from aliexpress
    Monday,19,November,2018,23:27:29:23561
    VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
    Mileage: 71000km-44117mi   Repair Order:
              62 6C 72 77
    VIN: WVGCG2AX0GW000308   Mileage: 71000km-44117miles
    Address 01: Engine (J623-CTHA)       Labels:. 03C-907-309-V1.clb
       Part No SW: 03C 906 026 BC    HW: 03C 907 309 M
       Component: 1.4l R4 TSI   H02 7742
       Revision: LKH02---    Serial number: 00000000000000
       Coding: 001D0032000401000000
       ASAM Dataset: EV_ECM14TSI01103C906026BC 001005
       ROD: EV_ECM14TSI01103C906026BC.rod
       VCID: 629DA9E354CA7187E81-8036
       Part No SW: 02E 300 063 D    HW: 02E 927 770 AL
       Component: GSG DSG AG6     531 4301
       Revision: 05653104    Serial number: 00001501302058
       VCID: 176BC837C388642F4FF-8042
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 BN    HW: 5N0 614 109 BN
       Component: J104   C6 450M VDC4 0021
       Revision: --H07---    Serial number: 00000008762753
       Coding: 0054349
       VCID: 78A9EB8BEED68B57A65-802C
       Part No SW: 7N0 907 426 CM    HW: 7N0 907 426 CM
       Component: AC Manuell    H20 0707
       Revision: 00001002
       Coding: 0010002003
       VCID: 015F866FB18CCA9F91B-8054
       Part No SW: 5K0 937 086 Q    HW: 5K0 937 086 Q
       Component: BCM PQ35 M    122 0174
       Revision: BC122001
       Coding: 60180A3B80251AC4408800C0340081644F51AA88436D89606480C7000041
       VCID: 42DD4963F48A1187C81-8016
       Subsystem 1 - Part No SW: 5N1 955 119 B    HW: 5N1 955 119 B  Labels: 1KX-955-119.CLB
       Component: WWS316 200215  24  0664
       Coding: 009795
       Component: RLS 180315 05  54  0403
       Coding: 02304D
    Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
       Part No SW: 5N0 919 475 D    HW: 1Q0 919 475
       Component: PARKHILFE 4K  H03 0045
       Revision: --------    Serial number: 32991507102722
       Coding: 308102
       ASAM Dataset: EV_EPHVA14VW3680000 001005
       ROD: EV_EPHVA14VW3680000.rod
       VCID: 3A2D31839CDA5947901-806E
       Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
       Component: J234__20J VW10 HI   2518
       Revision: 28020000    Serial number: 003L7P56WUSS
       Coding: 0012362
       VCID: 7CA1F79BDAEEA777C2D-8028
       Subsystem 1 - Serial number: 6332MTS660930615
       Subsystem 2 - Serial number: 6342MTS616590625
       Subsystem 3 - Serial number: 6351HTS6CVO9GDKJ
       Subsystem 4 - Serial number: 6361HTS61MN9GDKR
       Part No SW: 5K0 953 501 CP    HW: 5K0 953 569 AK
       Component: LENKS.MODUL   016 0162
       Revision: FF010042    Serial number: 20150311100401
       Coding: 1982040000
       VCID: 7AADF183DC5A9947D01-802E
       Component: E221__MFL-TAS  H31 0037
       Serial number: 0759900
       Coding: 820000
       Coding: 611F01
       VCID: 353722BFB5C4B63F7D3-8060
       Coding: 356002
       VCID: 7F5B0097C7F8BC6FE7F-802A
       Component: IMMO          H03 0705
       VCID: 6A8DC1C3ACFA29C7201-803E
       Coding: 010100
       VCID: 2B0304C76300F0CF1B7-807E
       Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
       Component: TUER-SG FT    002 0503
       Revision: 13110009    Serial number: 0009535622
       Coding: 0204B4
       VCID: 38292B8BA2D64B57665-806C
       Slave Driver:
       Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  009 1504
       Serial number: 00000009269441
       Coding: 000490
       Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
       Component: J500__APA-BS KL.285 1401
       Revision: 1BH04841    Serial number: 00150680456901
       Coding: 0000258
       VCID: 41DF466FFD8C0A9FD1B-8014
       Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
       Component: TUER-SG BT    002 0503
       Revision: 15110009    Serial number: 0009544886
       Coding: 0204B4
       VCID: 392F2E8F99DC525F99B-806C
       Slave Passenger:
       Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  009 1504
       Serial number: 00000009262069
       Coding: 000490
       Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
       Component: J540 EPB4  VW-63206 0012
       Revision:   H19       Serial number: 00000000589216
       Coding: 0026167
       VCID: 38292B8BAE564B57665-806C
       VCID: 2313ECE70BD0388FA37-8076
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AL
       Component: Batt.regelung H58 1653
       Coding: 032F7864
       VCID: 71BFD6AF81ACDA1F61B-8024
       Component: J367-BDM  H07 0180
       Serial number: 32064G55491491641583
       Part No SW: 5N0 907 441 A    HW: 5N0 907 441 A
       Revision: 00H13000    Serial number: 525PA8-JA31097
       Coding: 0020010
       Shop #: WSC 01324 011 00200
       VCID: 2D070ADF5114FEFF053-8078
       Coding: 402110
       VCID: 2A0D01C36CFAE9C7E01-807E
    01526 - Emergency Call Button (E276)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 196
                        Mileage: 70934 km
                        Date: 2018.11.18
                        Time: 09:36:11
    End----------(Elapsed Time: 01:29, VBatt start/end: 12.3V/12.3V)-----------
    Nov 2018
    Tunisia
    Dear Jef i just made new test as requested
    Please can you assist to help me on BT coding
    THank you
    Mootez
