Hello guys i need for your experience at Phaeton
Wednesday,14,November,2018,16:18:25:44995
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4436.4
Mileage: 276220km-171635mi Repair Order:
Chassis Type: 3D - VW Phaeton (2002 > 2006)
Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 27 28 29 2E
34 36 37 38 39 46 47 55 56 57 65 66 68 69 71 75 76 77
Mileage: 276220km-171635miles
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 09L 927 760 E HW: GS1 904 1
Component: AG6 09L 3.0l V6TDI 1901
Coding: 0000101
VCID: 392C240A55436EFF99B-5160
18265 - Load Signal
P1857 - 000 - Error Message from ECU
Fault Status: 01110000
Reset counter: 40
Mileage: 276226 km
(no units): 30.0
(no units): 25.0
Temperature: 26.0°C
T.B. Angle: 0.0°
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU - Intermittent
Fault Status: 00110000
Reset counter: 40
Mileage: 276226 km
18269 - Throttle Position Sensor (G79)
P1861 - 000 - Error Message from ECU - Intermittent
Reset counter: 40
Mileage: 276226 km
Address 03: ABS Brakes Labels: 3D0-614-517.lbl
Part No: 3D0 614 517 AK
Component: ESP 5.7 allrad H33 0047
Coding: 0008356
Shop #: WSC 01065 000 00000
VCID: 6B80CE426F9F0C6F5B7-51F2
18263 - Powertrain Data Bus
P1855 - 000 - Software Version Monitoring
18265 - Load Signal
013 - Check DTC Memory
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 135 S HW: 5WK 470 21
Component: Kessy 6700
Revision: 67005514 Serial number: VWZ3Z0E1370678
Coding: 0004328
VCID: 3534283A795B8A9F7D3-5160
Component: ELV XXXX
8 Faults Found:
02241 - Engine Control Module; Immobilizer Data not Adapted
01312 - Powertrain Data Bus
00087 - Terminal 30 for Starting Relevant Consumers
Address 06: Seat Mem. Pass Labels: 3D0-959-759.lbl
Part No: 3D0 959 759 C
Component: Sitzmemory D1 BF 1720
Coding: 0000003
VCID: 36362F36645D8187749-5160
01884 - Massage Button (E337)
Address 07: Control Head Labels: 3D0-035-00x-07.lbl
Part No: 3D0 035 007 P
Component: ZAB COCKPIT 0253
Coding: 0400525
VCID: 2616FF76B4FDF107C49-5160
No Faults Found
Address 08: Auto HVAC Labels: 3D0-907-040.lbl
Part No: 3D0 907 040 J
Component: Climatronic D1 2031
VCID: 2514F87AC9FBFA1FCD3-5160
010 - Open or Short to Plus
00033 - Left Front Air Outlet Button (E301)
Address 09: Cent. Elect. Labels: 3D0-937-049-V1.clb
Part No: 3D0 937 049 H
Component: STG.Bordnetz 5101
Coding: 0000003
VCID: 2F381A529B07B04F37F-5160
Address 13: Auto Dist. Reg Labels: Redir Fail!
Part No: 3D0 907 567 H
Component: AC101 V6D 6HP194 09 0338
Coding: 0001441
VCID: 313C1C2A8D33A6BF21B-5160
6 Faults Found:
51577 - Unknown Error Code
Unknown - 012 -
Count: 12849
00272 - Function Disabled due to Electromagnetic Interference
012 - Electrical Fault in Circuit - MIL ON
Count: 31
00472 - Control Module for Brake Boost (J539)
02085 - Incorrect Control Module Installed
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 E
Component: 0J Airbag 8.4E+ H10 0935
Coding: 0012362
Address 16: Steering wheel Labels: 3D0-953-549.lbl
Part No: 3D0 953 549 D
Component: Lenksäulenmodul 3401
Coding: 0000022
VCID: 2E0607569C0DB9473C9-5160
Address 17: Instruments Labels: 3D0-920-xxx-17.lbl
Part No: 3D0 920 882 N
Component: KOMBIINSTRUMENT RB8 0521
Coding: 0007111
VCID: 323E132688359DA7581-5160
Address 18: Aux. Heat Labels: None
Part No: 3D0 815 005 AA
Component: Standheizung 2426
VCID: 5CE29D9EBA317BD7A2D-5160
01406 - No Flame
00664 - Fuel gauge
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70BAD92E46B9EFB76E5-5160
Address 23: Brake Booster Labels: None
Part No: 3D0 907 563 B
Component: BREMSBOOSTER 4010
VCID: 2708F272B3F7E80FFFF-5160
6 Faults Found:
00151 - Plausibility Auto Distance Regulation (ADR) System
008 - Implausible Signal - Intermittent - MIL ON
Address 34: Level Control Labels: 3D0-907-553-V2.clb
Part No: 3D0 907 553 C
Component: LUFTFDR.-CDC- 3C3V0 1122
Coding: 0005521
7 Faults Found:
01769 - Sensor for Vehicle Leveling; Front Right (G289)
00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
01598 - Drive Battery Voltage
01049 - Supply Voltage Term 50
01400 - Suspension Level Control
Address 36: Seat Mem. Drvr Labels: 3D0-959-760.lbl
Part No: 3D0 959 760 C
Component: Sitzmemory D1 F 1720
Coding: 0000004
No Faults Found
Address 37: Navigation Labels: 3D0-919-887.lbl
Part No: 3D0 919 887 E
Component: NAVIGATION 0188
Coding: 0400000
00384 - Optical Databus
Address 38: Roof Electronics Labels: 3D0-907-135.lbl
Part No: 3D0 907 135 B
Component: Dachmodul 0605
Coding: 0000027
VCID: 221EE366D8D50D27A81-5160
00926 - Terminal 30
00216 - Signal EC-mirror Fade Out
Address 46: Central Conv. Labels: 3D0-959-933.lbl
Part No: 3D0 959 933 F
Component: HSG 0101
Coding: 0000040
Shop #: WSC 50792 143 66245
VCID: 33301622772F94AF537-4B1E
Subsystem 1 - Part No: 3D1 959 701 H
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 3D1 959 702 H
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 3D0 959 703 G
Subsystem 4 - Part No: 3D0 959 704 G
Subsystem 5 - Part No: 3D0 909 610 D
Component: 3N HDSG 2430
23 Faults Found:
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
01308 - Control Module for Roof Electronics (J528)
01517 - Control Module for Trailer/Towing Sensor (J345)
00927 - Terminal 30 (Right)
01516 - Terminal 30; Left
00926 - Terminal 30
00576 - Terminal 15
01503 - Bulb for 3rd Brake Light (M25)
00106 - Signal Central Locking SAVE/LOCK Passenger Side
00318 - Supply Voltage for Rear Lid Control Module
Address 47: Sound System Labels: 7Lx-035-4xx-47.lbl
Part No: 3D0 035 466 A
Component: 12K-AUDIOVERST 0118
VCID: 201AE96ED6D91F37BE5-5160
00421 - Rear Left DSP Midrange Speaker (R105)
Address 68: Wiper Electr. Labels: 3Dx-955-1xx-V1.clb
Part No: 3D1 955 119 A
Component: Front Wiper 2005
00155 - Driver-Passenger Side Control Module Communication
Address 71: Battery Charger Labels:
VCID: 55F488BADD1BAA9F9D3-5160
11 Faults Found:
00084 - Electrical System Battery Switch-Over Relay (J549)
00085 - Starter Battery Switch-Over Relay (J580)
00086 - Parallel Battery Connection Relay (J581)
00089 - Wire Monitoring for Terminal 30 Starter Battery
007 - Short to Ground
00576 - Terminal 15
00093 - Terminal 15 for Starting Relevant Consumers
00000 - End of output
Address 76: Park Assist Labels: None
Part No: 3D0 919 283 D
Component: 01 Einparkhilfe 0907
VCID: 2B000E42AF1FCC6F1B7-5160
Address 77: Telephone Labels: None
Part No: 3W0 035 729 C
Component: Telefon 0241
VCID: 372822326357788F6FF-5160
End----(Elapsed Time: 08:26, VBatt start/end: 14.1V/13.2V. VIgn 0.0V)------
Reason: CODE tags
NostraJackAss
Is 0x01 or 0x05 under water because engine is off line.............but kessy saw it for not being adapted
Check fuses!
Certified Master Trained NY/BAR/BAD 7076062/ASE/SAE/NASTF Legal Factory Authorized/Licensed
GeKo/FaZit # 403738
www.FixMyEuro.com <<<<<CLICK HERE! or
vwemporium@aol.com ( JPPSG & Unverified members need not PM me & Please don't email or call facility for free tech support...use the forum )
Post Thanks / Like - 2 Likes
FoRT
Originally Posted by
Baholli
I know a guy who knows a guy.
Looks a lot like you've unhooked a bunch of stuff on the front end of the car.
There's no 01 at all in the scan, while...
... it was apparently up and running somewhat at the time.
So... yeah. You've been doing things to this car. Exactly what are those things?
I'm getting a sense you have an ECU installed that is not the factory ECU.
Silence gives consent.
Post Thanks / Like - 3 Likes
NostraJackAss
GeKo/FaZit # 403738
I remove seat and i find some water and i clean,i controll all fuse and all fuse is ok .But problem is car can't start starter .Have any idea other
Can't start... do you mean it cranks over but doesn't fire? Or it just doesn't crank over?
Jef
Post Thanks / Like - 1 Likes
Hello Jef car doesn't crank over
can be problem brake boost g201 ?what you think for this have any answer
