Results 1 to 10 of 16
Thread: Greetings 2018 basic transmission settings
    New User
    Nov 2018
    Hello can any experts on here shed a light on the proper procedure to do a basic transmission settings. Should engine be on or off etc. Is it as simple as holding the brake on in park with engine on at the right temps and hitting Go and let it do it’s stuff.
    Part No SW: 0CW 300 042 D HW: 0AM 927 769 E
    Component: GSG DQ200G2_M H05 1601
    Revision: 00005008 Serial number: CU501802195086
    Shop #: WSC 73430 031 00063
    ROD: EV_TCMDQ200021_VW31.rod
    VCID: 377D7C148E5C89F224-8062
    Verified VCDS User hmeco_'s Avatar
    Nov 2018
    In order to be able to help you, please post a full and unmodified auto-scan in code brackets.
    If you don´t know how to do so, here is a How-to-post-auto-scan-guide
    - hMeco
    Best Regards
    Hamzalija "hMeco" Meco
    >>> HOW-TO-POST-AUTO-SCANS <<<<<
  3. Likes Jdobbins liked this post
    New User
    Nov 2018
    Thursday,01,November,2018,21:02:21:04365
    VCDS Version: 18.9.0.2 (x64)
    VIN: TMBBP7NE6J03xxxxx   License Plate:
    Mileage: 25399km-15782mi   Repair Order:
    Chassis Type: NE-SK37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 47 52 5F 6C
    VIN: TMBBP7NE6J03xxxxx   Mileage: 25399km-15782miles
    Address 01: Engine (J623-CHZD)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04C 906 026 BH    HW: 04C 907 309 AE
       Component: R3 1.0l TFS   H26 4038
       Revision: W1H26---
       Coding: 01250032236419081000
       ASAM Dataset: EV_ECM10TFS01104C906026BH 002003
       ROD: EV_ECM10TFS01104C906026BH.rod
       VCID: 68DFEF689362D60A7D-803C
       CAN Converter 01:
       Part No SW: 5Q0 614 517 CR    HW: 5Q0 614 517 AD
       Component: ESC           H25 0523
       Revision: 00000000    Serial number: 60698000001032
       Coding: 24078A912420216D407F060960C5242451248402600624723621F070C002430B00000012121212B835351919323200
       ROD: EV_Brake1UDSContiMK100IPB_037_SK37.rod
       VCID: 0305D8C48A041552C8-8056
       Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
       Component: VWKESSYMQB    021 0803
       Revision: 00021000    Serial number: 0473395930
       Coding: 032C0C
       Shop #: WSC 73430 790 00063
       ASAM Dataset: EV_KessyHellaMQBAB 002020
       VCID: 3C776338B77AAAAAC9-8068
       Part No SW: 5E0 907 044 AQ    HW: 5E0 907 044 AQ
       Component: Climatronic   H04 2002
       Revision: 00001K00
       Coding: 01110004000110011005004800101022
       ASAM Dataset: EV_ACClimaBHBVW37X 006147
       VCID: 74E78B18DFAA22EAC1-8020
       Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
       Component: BCM MQBAB M+  H36 0253
       Serial number: 01001806100580
       ROD: EV_BCMBOSCH_018.rod
       VCID: 081FCFE8B322360A9D-805C
       Subsystem 1 - Part No SW: 5E2 955 119 A    HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 180131  051 0916
       Serial number: 887253F0401803100811
       Coding: 164DDD
       Component: RLHS  047 0105
       Serial number: S9Y18M03D09H06M09S19
       Coding: 04805D
       Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
       Serial number: 000000000ZY17245295V
       Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
       Serial number: 00002856223980182586
       Sun Roof:
       Subsystem 5 - Part No SW: 6R0 959 591 D    HW: 6R0 959 591 D
       Component: J245 PS72.405  H04 0005
       Serial number: 0000FST001YLBKF00000
       Coding: 981803
    204546 - Remote key 2
                        Reset counter: 189
                        Mileage: 18138 km
                        Date: 2018.09.24
                        Time: 14:01:55
    262936 - Sensor for anti-theft alarm system
              B1330 29 [008] - Signal Implausible
                        Reset counter: 16
                        Mileage: 21270 km
                        Date: 2018.10.10
                        Time: 18:34:22
       Serial number: 000308418018058
       Coding: 0471151051
       VCID: 4B9530E4E2D41D1270-801E
       Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
       Component: ACC BOSCH MQB H10 0654
       Coding: 3300600141FFC728949C810520400600000000000000000000
       ASAM Dataset: EV_ACCBOSCHVW416 002006
       VCID: 3E736930A166B8BAE7-806A
       Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
       Component: Airbag VW21   006 0703
       Revision: --------    Serial number: 003W4P40ZE4Z
       Coding: 98CCC000000000005C5400CC008800000065
       ROD: EV_AirbaVW21TS6VW48X_VW37.rod
       VCID: 0501C6DC84302B62E6-8050
       Subsystem 1 - Part No SW: -----------    HW: 454 002 502 18
       Serial number: 35700000000FB09D6D2+
       Subsystem 2 - Part No SW: -----------    HW: 454 002 302 18
       Serial number: 35800000000450887D2K
       Subsystem 3 - Part No SW: -----------    HW: 454 802 402 18
       Serial number: 35100EF32BC13000000R
       Subsystem 4 - Part No SW: -----------    HW: 454 802 002 18
       Serial number: 3520024DDBB13000000P
       Subsystem 5 - Part No SW: -----------    HW: 454 801 902 18
       Serial number: 355008CD58313000000N
       Part No SW: 5Q0 953 507 JB    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 02031804400638
       Coding: 6410
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 7F0D5434E6EC71B2AC-802A
       Part No SW: 5E0 920 950 F    HW: 5E0 920 950 F
       Component: KOMBI         303 0310
       Coding: 27AD02182580860001887A011001000000000000
       VCID: 2959AA6C48E82F02A2-807C
    16777018 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
                        Reset counter: 17
                        Mileage: 23912 km
                        Date: 2018.10.25
                        Time: 10:14:30
    16777020 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
                        Reset counter: 17
                        Mileage: 23912 km
                        Date: 2018.10.25
                        Time: 10:14:35
    16777022 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
                        Reset counter: 17
                        Mileage: 23912 km
                        Date: 2018.10.25
                        Time: 10:14:30
       Component: GW MQB High   436 4326
       Revision: --------    Serial number: 0007518863
       Coding: 030100047F085700EB0002581C0F00010001070000000000000000000000
       Shop #: WSC 73430 790 00000
       ASAM Dataset: EV_GatewNF 013044
       ROD: EV_GatewNF_VW37.rod
       VCID: 387F7F288342868A2D-806C
       Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
       Component: E221__MFL-PR6  H02 0160
       Serial number: 000000000A2191070318
       Serial number: 75886000001803110BC4
       Revision: 00000000    Serial number: 18000058674007
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 34674B189F2A62EA01-8060
       Serial number: 0000308203087
       Coding: 00110020DC01040000001100
       VCID: 479D0CD4FEBCF97254-8012
       Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
       Component: FOND_FHSG_DRV  006 0007
       Serial number: 00000000000019590172
       Coding: 1D0200
       Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
       Component: EPS_MQB_ZFLS  131 1081
       Coding: 01170000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 73E58804DAA425D2D8-8026
       Part No SW: 81A 035 223     HW: 81A 035 223
       Component: MIB2_amp_P_SK H10 0410
       Revision: 00000001    Serial number: SKZ8Z1HJE041G3T
       Coding: 0373010000AA002AAA0000000000
       ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001001
       ROD: EV_AMPMst16C4Gen2ALPI.rod
       VCID: 59B9DAAC58087F82F2-800C
       Serial number: 0000307850848
       VCID: 468301D0F9B6E07AAF-8012
       Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
       Component: FOND_FHSG_PSG  006 0007
       Serial number: 00000000000019833307
       Coding: 050200
    Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
       Part No SW: 5Q0 035 874 C    HW: 5Q0 035 874 C
       Component: MU-S-ND-ER    H41 0471
       Serial number: SKZAZ2U0475647
       Coding: 037301010000000041111202008800002F0208E601200500CF
       ROD: EV_MUStd4CTSAT_VW36.rod
       Subsystem 1 - Part No SW: 5E0 919 605 M    HW: 5E0 919 605 M
       Component: ABT_Std-2_Nav  H50 8130
       Serial number: SKZ6ZHT2113199
       Subsystem 2 - Part No SW: 5L0 051 236 AD    HW: -----------
       Component: ECE1 2018  --- 0915
    6669 - Optical Data Bus for Digital Sound System
              U10CC 00 [008] - Intermittent Disruption
                        Reset counter: 28
                        Mileage: 25034 km
                        Date: 2018.10.31
                        Time: 15:09:35
                        Voltage terminal 30: 12.8 V
                        Temperature of MOST transceiver-max.value: -50 °C
                        Temperature of MOST transceiver-min.value: -50 °C
                        Temperature of MOST transceiver-Current: 29 °C
    6678 - Digital sound System control module
              U106A 00 [008] - No Communication
                        Fault Frequency: 31
                        Reset counter: 30
                        Mileage: 15139 km
                        Date: 2018.09.04
                        Time: 18:24:38
                        Voltage terminal 30: 12.7 V
              U11B8 00 [008] - No Communications
                        Reset counter: 29
                        Mileage: 21328 km
                        Date: 2018.10.11
                        Time: 10:30:28
                        Voltage terminal 30: 14.7 V
                        Interface for external media: status-Status: Open circuit
       Coding: 0473010122002017000040
       ROD: EV_CamSysRVRVCPANAMQBAB_006_SK37.rod
       VCID: 39797A2CB8489F82D2-806C
    End-------------------------(Elapsed Time: 05:04)--------------------------
    Nov 2018
    Regarding your auto transmission, have you tried this Wiki-How-To-Automatic_Transmission_Basic_Settings
    Also while you are at it, i would recommend you to register you´r VCDS with the forum here, so you can post in the Verified members area. Here is a How-to-get-verified
    - hMeco
    Best Regards
    Jul 2014
    Tallinn, Estonia
    Car has only 25000km on it and already needs basic settings on the DSG? Is something already wrong with it?
  7. Likes PetrolDave, Uwe liked this post
    New User
    Nov 2018
    Hi. It’s a taxi and a mistake was made in drive where a driver placed his left foot on brake
    And reved the engine thinking like a manual with the clutch depressed the clutches would
    be disengaged it then made a clanking clunking noise which I believe would be the same
    as the clanking clunking Heard in the basic transmission settings. The car drives fine it’s just
    A wee whirring noise on down changeing especially on rough ground and speed humps. I think
    a recalibration would sort it.
    New User
    Nov 2018
    Months later it would appear that my fault finding skills in modern cars should be left to the experts. I don’t think there was anything wrong with this DSG. I have came to the conclusion that the modules in modern cars should not be touched at all, unless faulty and diagnosis required. It Seems to me that the slightest code change from factory can introduce all sorts of nasty side effects like vibrations, spinning noises and shuddering taking off in D2
    I found my log in vcds that notified me off all the changes I had done. I reversed the lot and as if by magic the car started driving very robustly again. No more issues as mentioned above. a simple needle sweep or enabling fan speed display in auto mode etc, in my experience, seems to cause severe annoyances. Doesn’t stop the car driving but you will feel the difference. Only my opinion doing 100 miles plus a day.
    Feel free to discuss
  10. #8
    Quote Originally Posted by Jdobbins View Post
    Scratching my head how enabling needle sweep would have such effects, and I'm not sure what you mean by "enabling fan speed display in auto mode".
    It would certainly be interesting to do and undo those changes one-by-one to find out exactly which one has undesirable side effects.
  11. #9
    New User
    Nov 2018
    Enabling fan (blower) speed display in AUTO mode
    Controller 08 - HVAC
    07 - Coding
    Byte 11 Bit 6 - Blower Status Display in Auto-Mode active - enable
  12. #10
    New User
    Nov 2018
    Car was spinning and vibrating again. Changed that coding back along with needle sweep as I had missed those ones restoring to factory and car drove great for the rest of my shift.
    Next shift it returned.
    Going to retire and stop trying to diagnose this car as it defies logic and is making a clown out of me.
    Car is going in to dealers in next few days. See if they can sort it.
    Will report back with their findings.
  13. Likes Uwe liked this post
