Results 1 to 10 of 12
Thread: Golf 7 DQ250 to DQ500
    Oct 2018
    Romania
    Hello guys! I have the same problem on my 2015 VW Golf 7R after performing a DSG swap from DQ250 to DQ500.
    I have the following ABS error code, among others: 8299 - Databus U1121 00 [009] - Missing Message [FCAN: Anhaenger_01_alt veraltet bit is set].
    The big problem is that after the swap, the gearbox engages and drives away at around 1600 rpms. In any gear, it only engages above 1600 rpm, and below 1600 rpms it is slipping the clutches excessively causing premature clutch damage and wearing them out.
    I hope that this could be the problem and I would be able to address it with your help, so any info would be more than welcome and I thank you for it in advance!
    Also, please excuse me if I make some mistakes as I am a VCDS and forum newbie and don't even know how to correctly post the scan log code, but I indicated it in the below post. Thank you!
    Oct 2018
    Romania
    Tuesday,13,November,2018,22:03:58:34744
    VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
    VIN:    License Plate:
    Mileage: 14870km-9239mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 47 52
              55 5F A5 A9
    VIN:    Mileage: 14870km-9239miles
    Address 01: Engine (J623-CJXC)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 F    HW: 06K 907 425 B
       Revision: --H13---
       Coding: 091D00122466050B3004
       ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
       ROD: EV_ECM20TFS0205G0906259F.rod
       VCID: 313C1C4961A1210F21B-8064
    Readiness: 0010 0001
       Part No SW: 0DL 300 012 H    HW: 0GC 927 711 G
       Component: GSG DQ500     H06 2110
       Revision: 00H06V07
       ROD: EV_TCMDQ500021.rod
       VCID: 2E060735709F3EF73C9-807A
       Revision: 00000000    Serial number: 62155000001290
       Coding: 01FA6BA15420296D077E070541CA6980D62A94E0E08296F7184250F8C288
       Shop #: WSC 42948 002 104857
       VCID: 7AAEFB65FC572257D01-802E
    8299 - Databus
                        Reset counter: 83
                        Mileage: 14870 km
                        Date: 2018.11.13
                        Time: 21:44:31
       Revision: 00021000    Serial number: 0376565716
       Coding: 030C0C
       VCID: 3A2E3B65BCD7E257901-806E
       Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
       Revision: 00001K08
       Coding: 00020014200100011105000000101002
       VCID: 6A8ECB258CF792D7201-803E
       Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
       Serial number: 01061523000747
       Coding: 00111E46C24122F30BA44080B10407281800000000000000000000000000
       Shop #: WSC 12345 123 61029
       ROD: EV_BCMBOSCH_015.rod
       VCID: 094C94A9A9B139CFC9B-805C
       Component: WWS    150715  043 0551
       Serial number:         150811163729
       Component: RLHS  037 0059
       Serial number: S4Y15M08D27H14M52S33
       Coding: 90A8DD
       Component: Sensor, DWA  006 0326
       Serial number: 000000000ZY151880WNS
       Serial number: 00000000000033180258
       Sun Roof:
       Component: J245 PS73.403  H03 0004
       Serial number: 0000FST000GEHQ100000
       Coding: 181801
       Revision: --------    Serial number: 39331523901073
       Coding: 0071155011
       VCID: 43D04681CB1DA39FC37-8016
       Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
       Component: ACC Bosch MQB H05 0400
       Serial number: 21071503212754
       Coding: 001C1700FE0739
       ASAM Dataset: EV_ACCMRRBoschVW372 001016
       Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
       Component: DAEMPFUNGS-SG H16 0120
       Serial number: 31071541350413
       ROD: EV_DRCONTITEMIC_VW37.rod
       VCID: 372822518FC5FF3F6FF-8062
       Serial number: 003F6R10FXX4
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 41DC4C89D101B18FD1B-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 001 008 15
       Serial number: 357670000005A2C4F41
       Subsystem 2 - Part No SW: -----------    HW: 480 001 008 15
       Serial number: 358670000001E138B51U
       Subsystem 3 - Part No SW: -----------    HW: 480 402 108 15
       Serial number: 35165029B1CF1D32E25O
       Subsystem 4 - Part No SW: -----------    HW: 480 401 108 15
       Serial number: 3526502B51D1B624D29F
       Subsystem 5 - Part No SW: -----------    HW: 480 401 808 15
       Serial number: 3556502AB1CB0C0350DI
       Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0110
       Revision: --------    Serial number: 20081504221429
       Coding: 0C10
       ROD: EV_SMLSKLOMQB_VW37.rod
       Part No SW: 5G1 920 790 A    HW: 5G1 920 790 A
       Component: KOMBI         407 3193
       Coding: 07AD7818FF8C00080186FB0B5400000000000000
       Shop #: WSC 54321 123 12345
       VCID: 290CF429497159CFE9B-807C
       Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1224
       Revision: --------    Serial number: 0003844395
       Coding: 030100043F085900FB00027A9C0F00010001050000000000000000000000
       VCID: 75B4E859D5494D2FBD3-8020
       Component: E221__MFL-DC1  H10 0040
       Serial number: 29150001593150105333
       Coding: 2DFFFF
       Serial number: 1911797503
       Serial number: HA1-00025.06.15
       Coding: 0001
       VCID: 46D65F95F82F96B7E49-8012
       Revision: 00000000    Serial number: 15000182341004
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3432155D9EB314274AD-8060
       Component: HRE_Master    H11 0071
       Serial number: 0377252543
       Coding: 02011103
       ROD: EV_HREntryHella_VW37.rod
       VCID: 3C223D7DB6E3DC6782D-8068
       Lane Change Assistant 2:
       Component: HRE_Slave  H11 0071
       Serial number: 0376464997
       Coding: 020111
       Serial number: 180815BHI12473
       Coding: 003F1220D000040000001000
       Shop #: WSC 05570 003 1048576
       Serial number: 00000000000006855727
       Coding: 110000
       Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
       Component: EPS_MQB_ZFLS  505 5063
       Coding: 9103
       VCID: 392C2469B9D1E94F99B-806C
    Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
       Part No SW: 5Q0 035 456     HW: 5Q0 035 456
       Component: MIB2_lite_amp H20 0110
       Revision: 00000001    Serial number: VWZ8Z1FBA00QPJX
       Coding: 12000000008AAA8A000000000000
       ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
       ROD: EV_AMPMst11CGen2ALPI.rod
       VCID: 6D84C039BD1985EF453-8038
    0572 - Loudspeaker 2 in Double-Subwoofer
              B130D 11 [009] - Short to Ground
                        Reset counter: 81
                        Mileage: 14835 km
                        Date: 2018.11.12
                        Time: 19:50:08
                        Voltage terminal 30: 12.3 V
    0565 - Loudspeaker 1 in Double-Subwoofer
              B130C 13 [008] - Open Circuit
                        Reset counter: 123
                        Mileage: 14835 km
                        Date: 2018.11.12
                        Time: 19:50:10
       Serial number: 220715BGM02003
       Coding: 003F1020DE00040000801000
       VCID: 42DE4385D407AA97C81-8016
       Serial number: 00000000000007133700
       Coding: 090000
       Coding: 02A202104F010200
       VCID: 40DA498DDA0BB887DE5-8014
       Subsystem 1 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
       Coding: 900000
       Subsystem 2 - Part No SW: 3D0 941 329 D    HW: 3D0 941 329 D  Labels: 3D0-941-329.CLB
       Coding: 900000
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
       Part No SW: 3G0 035 043 B    HW: 3G0 035 043
       Component: MU-H-N-EU     H42 0317
       Serial number: A599G0F7535717
       Coding: 027300010000000051110002000808031F0107F401200100DF
       VCID: 1B60DEE1132DBB5F6B7-804E
       Component: ABT_High  H62 0031
       Serial number: VWZ8Z9RU302XA3
       Subsystem 2 - Part No SW: V03 959 800 QR    HW: -----------
       Component: ECE 2017/2018  --- 0161
       Component: Gracenote2  --- 1011
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
       Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
       Component: MQB_MFK       H06 0060
       Serial number: 10000409245
       Coding: 0101020001020308000400010100000100
       ROD: EV_MFKBoschAU370.rod
    1123601 - predictive route data
              B1630 02 [008] - Signal Failure
                        Reset counter: 121
                        Mileage: 14838 km
                        Date: 2018.11.12
                        Time: 20:15:56
                        Control Module temperature: 48 °C
                        Outside air temperature: 10.5 °C
                        Vehicle speed: 48.32 km/h
                        Voltage terminal 15: 14.1 V
                        Terminal 15 on: 518.8 s
       Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
       Serial number: 150722200614
       VCID: 2F381A31779537FF37F-807A
    End----------(Elapsed Time: 02:11, VBatt start/end: 14.5V/14.4V)-----------
    Jun 2014
    Poland
    Did you ever compare ratio gear between them ?
    ECU have proper software for proper gear box , with proper ratio on each gear
    people move gearbox 5 to gearbox 6 , and then ECU freaking out
    Simple reason is - ECU not understand new speed according to "load" and RPM
    Check if any this same ECU exist with 7 DSG, and compare SW / coding
    Oct 2018
    Romania
    Quote Originally Posted by Spacewalker View Post
    Hello! I will ask a friend of mine who has DQ500 with Golf 7 engine to check the coding and compare it to mine.
    Check coding on Engine and Gearbox?
    Thank you!
    But any idea where does that error come from? With the trailer obsolete bit set?
    Jun 2014
    Poland
    ECu SOFTWARE and after proper SW - coding
    gearbox always have one software , and can not be change as far as I know
    Oct 2018
    Romania
    Will compare the codings with the ones that my friend has on his Golf 7R DQ500 and start from there.
    Yes, you can change gearbox software. I had upgraded software on my DQ250 and will go down the same route of updated software on the DQ500. Also, you have a counter somewhere in the Gearbox module on VCDS which shows how many successful write attempts have been performed and how many in total.
    Back to the topic, still nobody does not have a clue about the error message that I am encountering with the Databus trailer obsolete?
  9. #8
    Oct 2018
    Romania
    update on the topic: got rid of the above indicated error message regarding the Databus trailer obsolete message.
    ABS - Adaptations - Vehicle and trailer stabilization - and disable it.
    Then went into Basic settings on the Gearbox and reset everything I was able to find, and completed by doing the basic setting of transmission program in the end. Now the car engages at the same high rpms - 1500-1600 RPMs - but engages without clutch slippage.
    However, it still engages at very high rpms! Tomorrow will redo the gearbox settings and road settings via ODIS - hopefully - and will come back to let you know more about the status. But for now, it is a step in the right direction.
  10. Likes Uwe, jyoung8607 liked this post
  11. #9
    Oct 2018
    Romania
    Hello everybody and Happy New Year!
    Let's revive this topic a little with some status updates, and ask for your help, maybe you are able to help me, please!
    So, the car is driving fine. No problems. Did around 4000 kms after the swap to DQ500. Almost all is well.
    Currently running on standard RS3 software.
    Only complaints that I have are:
    - drive selector - the toggle for Eco, Comfort, Normal, Race and Individual does not work anymore (or at least the engine / gearbox setting does not work anymore) when the gearbox selector is in P (park) or N (neutral). It only works when the selector is in D (drive) or S (sport).
    - despite driving in ECO mode or Normal mode, the gearbox disengages the selected gear when you take off your foot from the accelerator pedal, and re-engages when you hit the gas pedal again. This is standard ECO mode driving procedure. But it should not be performing it when the car is in Drive, but it does.
    Any opinions?
    Does anybody know where are the driving modes stored in VCDS?
    I clearly have something wrongly coded....
    Any opinions or advice would be more than welcome.
    Thank you!
  12. #10
    Apr 2018
    ITALY
    Driving Profile Selection is handled by the Gateway (module 19) and it's a FeC/SWaP feature, nothing you can do with VCDS, need ODIS with online account. trust me I learned it the hard way when I upgraded my Gateway.
    anyway, if that was the case you should have an error logged. maybe DPS is messed up because of errors somewhere else.
    can you post a current autoscan? erase all DTCs first so we see what stays.
  13. Likes Uwe, Jack@European_Parts liked this post
