Hi all,
Firstly I would like to apologise for the shortness of my post, I have spent the best part of an hour writing a post only for it to be deleted as I was timed out of the site! doh!!
The short version is that I have recently purchased an Audi A5 2.7 tdi January 2008 registration which has UDS protocol.
It seems as though VCDS will not allow me to adapt the new G450 sensor. I have tried turning the ignition on for 5 seconds and off for 40 seconds x5, this hasn't worked either.
Please can someone give me some advice or set me in the correct direction.
I am more than happy to provide extra detail on how I got to my current situation regarding the faults on the vehicle, however this could be totally irrelevant to resolving the issue so I think probably better for me to answer with info that may help, also I had written a lot of it in the previous post which timed out ( teach me to press copy before posting in the future )
One point to note is that when I have attempted to clear the codes, 5188 & 5189 do not clear. All of the other codes remain clear until the car is running again, therefore I do not know if these codes are caused by the fact that the car is not getting the correct readings from a G450 sensor.
This has been a bit of a long winded saga and I am happy to provide in depth detail if that's what is required to get it resolved. Ive looked at various tried and tested methods found searching internet forums but have not got any further.
I did actually completely unplug the G450 sensor and see what the readings were in this circumstance, it didn't make much if any difference to the values being displayed in VCDS for the particulate filter. I still have the old one which part of me thinks might not even be faulty as the readings I am getting from the new sensor are the same as the old one ( this could be due to the fact its not adapted or that there is nothing wrong with either sensor at all ).
Apologise this post is a bit all over the place, my previous attempt wasn't so bad, however I'm trying to post this whilst serving customers in my chipshop
Please if someone can explain to me how to adapt the G450 considering that it doesn't look as though I can do it the tradional way through VCDS, I have also considered the possiblitly that I am over looking the other engine error codes as I am treating them as biproducts of the DPF codes.
I hope that all makes sense, written in a bit of a rush, VCDS values and error codes below.
Tuesday,13,November,2018,16:38:42:40320
VCDS Version: 18.9.0.2 HEX-V2 CB: 0.4436.4
VIN: WAUZZZ8T48A026264 License Plate: €€
Chassis Type: 8T-AU48 (8T0)
Scan: 01 02 03 05 07 08 09 0E 10 15 16 17 19 1E 37 42 46 47 52 53
55 56 77
Address 01: Engine (J623-CAMA) Labels:| 059-907-401-V1.clb
Part No SW: 8K1 907 401 D HW: 8K0 907 401
Component: 2.7TDI EDC17 H01 0009
Revision: --H01---
Coding: 0114002C02070020
Shop #: WSC 00590 210 81363
ASAM Dataset: EV_ECM27TDI8K1907401D A01010
ROD: EV_ECM27TDI8K1907401D.rod
VCID: 2D07F57DBD98E66F053-8078
5188 - Diesel Particulate Filter (Bank 1)
P242F 00 [167] - Restricted/Clogged
Mileage: 220221 km
Date: 2018.11.13
Time: 17:30:54
Coolant temperature: 39 °C
Intake air temperature: 23 °C
Voltage terminal 30: 12.140 V
Crankshaft speed (RPM): 0.0 /min
Vehicle speed: 0.00 km/h
Field regeneration status-Bits 0-7: 00000000
Field regeneration status-Bits 0-7: 00010000
Field regeneration status-Bits 0-7: 10000000
Particle filter: difference pressure: 3 hPa
Exh t Adap TP Flt Us: -270.0 °C
Exhaust gas vol.flow particulate filter: 0.0 m³/h
Particle filter: kilometers since last regeneration: 0 m
7900 - Right Engine Mount Solenoid Valve (N145)
P1577 00 [036] - Open Circuit
Mileage: 220221 km
Date: 2018.11.13
Time: 17:35:48
Engine speed: 1102.50 /min
Normed load value: 31.8 %
Coolant temperature: 38 °C
Intake air temperature: 22 °C
Voltage terminal 30: 11.620 V
Crankshaft speed (RPM): 1102.5 /min
Engine mount 1: 0.00 %
Engine mount 2: 0.00 %
Transmission mount 1: 0.00 %
Transmission mount 2: 0.00 %
Vehicle voltage terminal 30: 11620 mV
5253 - Exhaust Pressure Sensor 1 (G450)
P0473 00 [036] - Signal too High
Mileage: 220221 km
Date: 2018.11.13
Time: 17:32:08
Particle filter: difference pressure: 900 hPa
Exhaust gas temp.after pre-catalyst: 40.9 °C
Exh t Sens TP Flt Us: -270.0 °C
4984 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 00 [101] - Electrical Fault
Mileage: 220221 km
Date: 2018.11.13
Time: 17:38:01
Coolant temperature: 40 °C
Intake air temperature: 19 °C
Voltage terminal 30: 12.500 V
Vehicle voltage terminal 30: 12480 mV
Coolant temperature: 40.4 °C
Glow status-Bits 0-7: 00000000
Glow status-Bits 0-7: 00110000
Glw Plg r LVS Ps: 14.30 %
Intake air temperature: 19.2 °C
5189 - Particulate Trap Bank 1
P2002 00 [039] - Efficiency Below Threshold
Mileage: 220221 km
Date: 2018.11.13
Time: 17:30:54
Address 02: Auto Trans
Part No SW: 8K0 907 379 K HW: 8K0 907 379 K
Component: ESP8 front H03 0180
Coding: 1A0500
Shop #: WSC 06325 000 00000
VCID: 41DFB9CD1180120FD1B-8014
Part No SW: 8K0 907 289 C HW: 8K0 907 289 C
Component: BCM2.01 H38 0253
Revision: 00003002
Coding: 011000
VCID: 392FD12D79504ACF99B-806C
Subsystem 1 - Part No SW: 8K0 959 754 D HW: 8K0 959 754 D
Component: FBSAUDIB8 IDG H71 0083
Serial number: 0514000110349019
Subsystem 2 - Part No SW: 8K0 905 852 C HW: 8K0 905 852 C
Component: ELVAUDIB8 H35 0039
Serial number: 0207000002929007
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 E HW: 4E0 035 729
Component: Interfacebox H43 4690
Revision: 00000000 Serial number: 329LR077530034
Coding: 0005002
VCID: 3B23CB257F6C78DF8B7-806E
Subsystem 1 - Part No: 8T0 919 609
Component: E0380 BedienteilH08 0100
Subsystem 2 - Serial number: 00000000032905
Subsystem 3 - Serial number: 0107.12.070000000100010130ÿ
Subsystem 4 - Serial number: 010130ÿ
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 N HW: 8T2 820 043 N
Component: KLIMA 3 ZONEN H05 0120
Revision: D1000000 Serial number: 0110.12.070017
Coding: 36060000
VCID: 3D27C53D6D7876EFB53-8068
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H21 0253
Revision: 05021001 Serial number: 00000000064970
Coding: 260050910014AF010009000300005D5D001D438800010141000000
VCID: 3039EC09AA2A8B872E5-8064
Subsystem 1 - Part No SW: 8T2 955 119 C HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 101207 H11 0040
Serial number: SWFBIE 0000164
Coding: 00FD11
Component: RLS H04 0002
Serial number: 10030633
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Serial number: 00000000003011070006
Part No SW: 8T2 035 110 B HW: 8T2 035 110 A
Component: MP3-Changer H42 0380
Revision: 00042003 Serial number: AUZ5ZBG4533109
VCID: 2A0DFE6180F6F157E01-807E
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 B HW: 8K0 919 475
Component: PARKHILFE 4K H06 0010
Revision: 11001001 Serial number: 75330735105231
Coding: 000101
VCID: 3829D429425A53C7665-806C
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD12AZHM
Coding: 30323433363030303030554A305238543053
VCID: 3C21C83976E27FE782D-8068
Serial number: 6334MSME343403572
Serial number: 6344MSME3433613C9
Serial number: 6352QSME4A463D69W
Serial number: 6362QSME476E292DZ
Serial number: 63732SME49732529/
Serial number: 63832SME49733F211
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [136] - Resistance Too High
Mileage: 220221 km
Date: 2018.11.13
Time: 17:38:25
Component: Lenks.Modul H10 0012
Revision: -------- Serial number: 90315GLG0004V
Coding: 000012
Component: E221 - MFL H02 0003
Address 17: Instruments
Part No SW: 8T0 907 468 F HW: 8T0 907 468 F
Component: GW-BEM 4CAN-M H07 0084
Revision: EB002032 Serial number: 3200E07B24804E
Coding: 000003
Shop #: WSC 00583 210 66199
VCID: 44D1B0D90E920727FAD-8010
Subsystem 1 - Part No SW: 8K0 915 181 HW: 8K0 915 181
Component: J367-BDM H06 0150
Serial number: 1700124C041207
Address 1E: Media Player 2 (R192) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H15 0700
Revision: 00000000
VCID: 270B07559FE4CC3FFFF-8072
Part No SW: 4E0 910 887 T HW: 4E0 919 887 M
Component: MNS ECE H50 1030
Revision: 00000000 Serial number: 333LJ077531003
VCID: 3E25C2316C7E6DF7AC9-806A
Part No SW: 8K0 959 793 A HW: 8K0 959 793 A
Component: TSG FA H09 0149
Revision: Serial number: €q
Coding: 0110022240012201
VCID: 3E25C231607E6DF7AC9-806A
Revision: 00003002 Serial number: 0107846448
Coding: 011B068200390400002000
Component: DWA-Sensor H02 0030
Component: LIN BACKUP HO H03 1301
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASM.clb
Part No SW: 8T0 035 223 P HW: 8T0 035 223 A
Component: DSP STD H07 0250
Revision: S2400000
Coding: 010101
VCID: 3B23CB25736C78DF8B7-806E
Part No SW: 8K0 959 792 A HW: 8K0 959 792 A
Component: TSG BF H09 0149
Revision: Serial number: Yq
Reset counter: 93
Mileage: 220221 km
Date: 2018.11.13
Time: 13:34:07
Part No SW: 8K0 907 801 C HW: 8K0 907 801 C
Component: EPB Audi B8 H03 0040
Revision: 00000003 Serial number: 00000000038529
VCID: 2F3BEF75B714947F37F-807A
Part No: 8K0 907 357 A
Shop #: WSC 06324 000 00000
VCID: 3333E305573CB09F537-8066
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Revision: 00000000 Serial number: 336L1077529864
VCID: 2E05F271BC1E9D773C9-807A
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 C HW: 4F1 862 335
Component: BTA H10 0960
Revision: 00H10000 Serial number: 00000007552889
Coding: 0010021
VCID: 24111059E2D22727DAD-8070
End----------(Elapsed Time: 02:11, VBatt start/end: 12.2V/12.1V)-----------
Tuesday,13,November,2018,16:43:08:40320
Address 01: Engine (8K1 907 401 D)
16:43:00
IDE00427 Particle filter: difference pressure 20 hPa
IDE00428 Particle filter: offset for differential press. 2 hPa
IDE00431-ENG57549 Particle filter: field regeneration lock status-Bits 0-7 00000000
IDE00432 Particle filter: time since last regeneration 79180 s
IDE00433 Particle filter: oil ash volume 0.28 l
IDE00434 Particle filter: soot mass calculated 39.03 g
IDE00435 Particle filter: soot mass measured 37.43 g
IDE00436 Particle filter: kilometers since last regeneration 594740 m
16:43:27
IDE00432 Particle filter: time since last regeneration 79198 s
IDE00434 Particle filter: soot mass calculated 39.04 g
IDE00435 Particle filter: soot mass measured 37.15 g
uesday,13,November,2018,16:51:20:40320
VIN: WAUZZZ8T48A026264 License Plate: RUN
16:51:10
IDE00424-ENG57549 Service regeneration: cancel conditions-Bits 0-7 11111101
IDE00432 Particle filter: time since last regeneration 79446 s
IDE00434 Particle filter: soot mass calculated 39.05 g
IDE00435 Particle filter: soot mass measured 36.04 g
IDE01407 Particle filter: fuel consumption since last regeneration 61.76 l
16:53:15
IDE00427 Particle filter: difference pressure 21 hPa
IDE00432 Particle filter: time since last regeneration 79561 s
IDE00434 Particle filter: soot mass calculated 39.06 g
IDE00435 Particle filter: soot mass measured 35.08 g
IDE01407 Particle filter: fuel consumption since last regeneration 61.79 l
16:53:17
IDE00432 Particle filter: time since last regeneration 79564 s
IDE00435 Particle filter: soot mass measured 35.01 g
Address 01: DTCs cleared
