Results 1 to 5 of 5
Thread: DTCs that dont turn on mil
    Verified VCDS User victor35ma's Avatar
    Nov 2014
    Los Angeles CA.
    hi every one at ross tech how are you today? got a 2012 Audi SC Q7, question:
    every time this Q7 Come to shop for a 5000 miles service the engine module comes with those dtcs stored in the ecm 01. but MIL wont turn on ever. what is causing this dtc to trigger?
    Tuesday,13,November,2018,09:56:02:23194
    VIN: WA1LGAFE1CD006852   License Plate: 8FAK007
    Mileage: 105010km-65250mi   Repair Order: 41180
    Chassis Type: FE-AU56 (4F0)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 47 4C 4F 52 55 56 5F
              62 6C 6D 6F 72 76
    VIN: WA1LGAFE1CD006852   Mileage: 105010km-65250miles
    4C-Tire Pressure II -- Status: Malfunction 0010
    Address 01: Engine (CJW)       Labels:. 06E-907-551-CAJ.clb
       Part No SW: 4L0 910 551 J    HW: 4L0 907 551 A
       Component: 3.0l V6 TFSI        0040
       Revision: --H08---    Serial number:
       Coding: 0121000A290F0128
       Shop #: WSC 39881 001 1048576
       VCID: 2F2EF412BE47D6327C-807A
    6 Faults Found:
    012410 - Air Intake System
                   P307A - 000 - Flow too Low - Intermittent
                        Mileage: 103936 km
                        Date: 2018.10.30
                        Time: 11:04:12
                        RPM: 672 /min
                        Absolute Pres.: 452.2 mbar
                        Absolute Pres.: 446.9 mbar
                        Load: 5.1 %
                        Ign. Timing: 2.3 °BTDC
                        (no units): 55.76
    000104 - MAP/MAF <-> Throttle Position Correlation
                   P0068 - 000 -  - Intermittent
                        Mileage: 103936 km
                        Date: 2018.10.30
                        Time: 11:04:12
                        RPM: 672 /min
                        Load: 5.1 %
                        (no units): 55.76
    009523 - Ignition Switch; Run/Start Position Circuit
                   P2533 - 000 - Open or Short to Ground - Intermittent
                        Fault Status: 00100001
                        Mileage: 104518 km
                        Mass Air / Rev.: 0.0 mg/str
                        Temperature: 52.5°C
                        Bin. Bits: 00000000
                        Voltage: 10.00 V
    005386 - Engine Off Timer Performance
                   P150A - 000 -  - Intermittent
                        Mileage: 104518 km
                        Temperature: 52.5°C
                        Bin. Bits: 00000000
                        Voltage: 10.71 V
                   U1017 - 000 -  - Intermittent
                        Mileage: 104518 km
                        Date: 2018.11.07
                        Time: 11:15:21
                        RPM: 1376 /min
                        Mass Air / Rev.: 179.9 mg/str
                        Temperature: 46.5°C
                        Bin. Bits: 00000010
                        Load: 18.8 %
                   P0087 - 000 - Too Low - Intermittent
                        Mileage: 104991 km
                        Date: 2018.11.11
                        Time: 05:41:33
                        RPM: 1728 /min
                        Mass Air / Rev.: 730.3 mg/str
                        Temperature: 108.0°C
                        (no units): 7.85
                        Pressure: 5.6 bar
                        Pressure: 4.9 bar
       Part No SW: 0C8 927 750 N    HW: 0C8 927 750 N
       Component: AL1000 AISIN  001 2088
       Coding: 001378
       Shop #: WSC 45732 002 1048576
       ROD: EV_TCMAL991031_002.rod
       VCID: 373ECC728E171EF224-8062
       Revision: 00H02001
       Coding: 0099409
       Shop #: WSC 31414 790 00001
       VCID: 3424FB7E5761F5EA01-8060
                000 -  -  - Intermittent
                        Reset counter: 143
                        Mileage: 104518 km
                        Count: 128
                        Count: 9029
                        Count: 297
                        Count: 37888
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
       Component: FBSAUDIC6 ELV   H07 0200
       Revision: 00H07000    Serial number: 10603501944755
       Coding: 0000131
       VCID: 2502163AECBB9C6286-8070
       Subsystem 1 - Part No: 4F0 910 132 J
       Subsystem 2 - Part No: 4F0 910 220 A
       Component: FBSAUDIC6 IDG   H01 0054
    00955 - Key 1
                002 - Lower Limit Exceeded
                        Fault Status: 01110010
                        Reset counter: 0
       Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AH
       Revision: 00---026    Serial number: 00000030225458
       Coding: 0008C026
       VCID: 2502163A2CBB9C6286-8070
                        Reset counter: 142
                        Mileage: 104518 km
                        Date: 2018.11.07
                        Time: 10:20:54
                        Voltage: 10.80 V
       Part No SW: 4F0 910 279 AH    HW: 4F0 907 279 D
       Component: ILM Fahrer      H31 0400
       Coding: 0039123
       VCID: 6FAE34127EC796323C-803A
       Component: Wischer AU716   H18 0110
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
                        Reset counter: 142
                        Mileage: 104516 km
                        Date: 2018.11.07
                        Time: 10:25:00
       Component: 73 AIRBAG AUDI8RH43 0230
       Revision: 07H43000    Serial number: 0038QD09Z0GO
       Coding: 0014131
       VCID: 2B16E0028A5FAA1250-807E
       Subsystem 1 - Part No: 4L0 959 339 C
       Component: BF-Gewichtsens. H05 0040
       Subsystem 2 - Serial number: 6332QSME14695748J
       Subsystem 3 - Serial number: 6342QSME5F6A166C.
       Subsystem 4 - Serial number: 6352QSME1D6A406EV
       Subsystem 5 - Serial number: 6362QSME626A125EO
       Subsystem 6 - Serial number: 63734SME62690F7EH
       Subsystem 7 - Serial number: 63834SME62692454/
       Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
       Component: J0527               0830
       Revision: 00H08000    Serial number: 90026113380284
       Coding: 0002042
       VCID: 281C1F0E9BA9810ABD-807C
       Component: E0221           H03 0030
       Part No SW: 4L0 920 984 T    HW: 4L0 920 984 T
       Component: KOMBIINSTR.   H22 0411
       Revision: 00200000    Serial number: LP3514P1D
       Coding: 8BD663040100CF05020205
       VCID: 44C4ABBEC7C1456AB1-8010
       Part No SW: 4F0 907 468 R    HW: 4F0 907 468 F
       Component: GW-BEM 4CAN-M H06 0057
       Revision: LB500035    Serial number: 3500L12105000B
       Coding: 00C303
       VCID: 3E30D956A92D2FBAE7-806A
       Component: J367-BDM  H07 0125
       Serial number: 00000000002790287140
                        Reset counter: 142
                        Mileage: 104518 km
                        Date: 2018.11.07
                        Time: 09:43:45
                        Bin. Bits:    10111
                        Voltage: 11.00 V
                        Count: 7
       Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
       Component: MEM-FS        H08 0064
       Revision: AA000000    Serial number: 00000021217680
       Coding: 00581300000011110000
       VCID: 3228FD666D75FBDA13-8066
       Component: TSG FA        H12 0362
       Revision:             Serial number: 0000021008276
       Coding: 011F07205E40440004
       VCID: 48DCBF8EFBE9610A5D-801C
    01705 - Selection Switch for Mirror-Adjust (E48)
                        Reset counter: 125
       Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
       Component: Komfortgeraet   H11 0120
       Revision: 0120 ---    Serial number: 01613377210000
       Coding: 3569693
       VCID: 383CCF4E4B09118A2D-806C
       Part No SW: 4L0 035 223 H    HW: 4L0 035 223 G
       Component: BOSE G3 Q7    H03 0130
       Revision: CH003000    Serial number: 00000000019769
       Coding: 030000
       VCID: 271E1C3256B78E72B4-8072
       Part No SW: 4F0 910 274 B    HW: 4F0 907 274
       Component: J793  RKA+      H04 0110
       Revision: 00000519    Serial number: 00005190148508
       Coding: 0693965
       VCID: 23060822E28F6252E8-8076
                        Fault Status: 00101101
                        Reset counter: 143
                        Mileage: 104518 km
                        Date: 2018.11.07
                        Time: 10:20:09
                        Hex Value: 0x0000
                        Hex Value: 0x0000
                        Hex Value: 0x0001
                        Voltage: 10.60 V
                        Temperature: 24.0°C
                        (no units): 0.0
                        Reset counter: 143
                        Mileage: 104518 km
                        Date: 2018.11.07
                        Time: 10:20:09
                        Hex Value: 0x0000
                        Hex Value: 0x0000
                        Hex Value: 0x0001
                        Voltage: 10.60 V
                        Temperature: 24.0°C
                        (no units): 0.0
       Component: ILM Beifahrer   H16 0100
       Revision:             Serial number: 00000000104897
       Coding: 0012001
       VCID: 5EF079D6896D0FBA87-800A
       Component: TSG BF        H12 0362
       Revision:             Serial number: 0000021004857
       VCID: 47DEBCB2F6F76E7254-8012
       Component: ****LWR12**** H02 0012
       Serial number: 120119-0001-045
       Coding: 1147A71010020000
       ROD: EV_HeadlRegulBasic.rod
       VCID: 42C8ADA6D5D54B5A83-8016
       Part No SW: 4G0 035 082 C    HW: 4G0 035 082
       Component: Radio U SIRIU H53 0101
       Revision: AB001007    Serial number: 236A.0C7506964
       Coding: 020007010000000000
       VCID: 200C072E3399794AF5-8074
       Part No SW: 4L2 035 746 B    HW: 4L2 035 746
       Component: H-BNT-NA      H42 0422
       Revision: --------    Serial number: 097AO0C7510105
       Coding: 180200060004E1EF41000345EF632003140000000100000000
       VCID: 2D12EE1A744BA4224E-8078
       Component: NAR 2011  0505
       Component: DU7 High  H41 0104
       Serial number: A130A60CS092575
       Subsystem 3 - Part No SW: 4L0 919 614 B    HW: 4L0 919 614 B
       Component: E0380 Bedient  H01 0060
       Serial number: 00000001971368
       Component: CD-Database  3371
       Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
       Component: TSG HL        H11 0362
       Revision:             Serial number: 0000020675786
       Coding: 010E07204040230004
       VCID: 46C0B1B6F1FD777AAF-8012
       Part No SW: 4L0 910 441 C    HW: 8T0 907 441 D
       Component: J772__Rearview      0130
       Revision: --H06---    Serial number: 525PA8-J21411K
       Coding: 1021101
       VCID: 2600113691BD977A8F-8072
       Part No SW: 4L0 910 945     HW: 4L0 827 851 E
       Component: ValeoHeckdeckel H57 0500
       Revision: --H57001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       VCID: 6C94231E4FD16D2A19-8038
       Subsystem 3 - Serial number: RD23.01.12--H57001001A0055ÿ
       Subsystem 4 - Serial number: 1A0055ÿ
       Component: ILM HINTEN 2    H08 0080
       Revision: AAH08080    Serial number: 123636098-----
       Coding: 0003595
       Component: J_245_EE16_SKB10H12 0220
       Component: J_394_EE16_SKB10H12 0220
       Component: J_392_EE16_SKB10H12 0220
       Component: TSG HR        H11 0362
       Revision:             Serial number: 0000020675623
       Part No SW: 4L0 910 283 C    HW: 4L0 919 283 C
       Component: Parkhilfe 8-Kan H03 0500
       Revision: 00H03000    Serial number: 37331201601386
       Coding: 0221266
       VCID: 2A18E50685A5B31AAB-807E
                        Reset counter: 142
                        Reset counter: 142
    End----(Elapsed Time: 02:03, VBatt start/end: 11.9V/12.0V. VIgn 12.0V)-----
    I am new to VCDS but... I will master it.
    In order to trigger a MIL, a fault has to be pretty severe, or for less sever ones, occur during more than one successive driving cycle. Some DTCs that VAG doesn't judge to have an effect on emissions will never trigger a MIL.
    The ones in that ECU are all flagged "Intermittent", meaning the fault condition that set the code was not present (or could not be detected) at the time the scan was performed, or during the most recent drive cycle. They also all have a faull frequency of just 1 or 2..
    For laughs, have you checked of any of them show up generic OBD-II Mode 7 (Pending DTCs)?
  3. Likes jyoung8607 liked this post
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by victor35ma View Post
    Many (most?) faults have to happen twice, on back-to-back drive cycles, in order for the MIL to come on. They also have to be emissions-relevant, and while most faults are, there are some that aren't. The dates and frequencies in the freeze-frame data indicate the problems aren't happening very often, only once or twice in the last month. If the vehicle is driven daily, it's very possible the MIL won't illuminate, by design.
    A good question. Which of these fault(s) do you think are recurring between service visits?
    From what you posted, all the freeze-frames that have voltage values show system voltage quite low, as low as 10.0 volts. That's low enough to cause lots of spurious errors and faults, particularly while cranking a decent-sized diesel engine. It's possible you have an ECM power relay/supply or ignition switch issue, but even if that were true, you can't really diagnose that properly without healthy voltage levels. I'd check the battery and charging system performance before troubleshooting further.
    This vehicle was built in February 2012, so it's approaching seven years old. If it's still got its factory battery, I'd consider replacing it regardless of load test results, preferably with a quality AGM battery.
    Silence gives consent.
  5. Likes Uwe, Eric, Jack@European_Parts, PetrolDave liked this post
  6. #4
    dtcs that dont turn on mil
    Strange isn't it?
    6 Faults Found:
    Mileage: 103936 km
    Date: 2018.10.30
    Time: 11:04:12
    RPM: 672 /min
    Load: 5.1 %
    (no units): 55.76
    Agreed it could in gas engine or diesel....... Not a TDI
    All while not illuminating for a P0562 OBD-II: System Voltage Low Diagnostic Trouble Code (DTC): P0562?
    Indeed Interesting.........?
    The VAS side of the scan must give the dealership incite to sell work that an independent couldn't with an OBD2 generic scanner, not the case here with VCDS!
    HQ
    Thanks for posting the full Auto-Scan!
    Vehicle Identification No. WA1LGAFE1CD006852
    Model Audi Q7 qu. 3.0
    AQ7
    Date of production 02.02.2012
    Year 2012
    Sales type 4LB5KA
    Engine Code CJWE
    Transmission Code MHN
    Clean throttle body then perform TBA.
    http://wiki.ross-tech.com/wiki/index.php/P307A/012410
    http://wiki.ross-tech.com/wiki/index...2/P0068/000104
    If ignition off B+ is lost to ECM, this code will set. Check power and ground inputs to ECM first. A quick glance here... fuse S17 goes to T94/64 0.5mm rt/vi wire... Is /64 loosing power or voltage drop under load? This looks like a job for a 180 Load Pro (not a sponsor).
    In the CAN Gateway:
    Anything we need to know here? Charging system to factory design? Battery correctly coded?
    Jef
