Results 1 to 10 of 10
Thread: 1998 A6 2.5tdi won't rev beyond 3000rpm
    Pirate
    Nov 2018
    Hi Guys,
    So far I've replaced the air filter, MAF sensor, fuel filter and MAP sensor.
    Apart from starting better the problem is still there.
    I have the full version of VCDS but no experience of using it.
    Could someone please advise me which channels to log etc to identify the cause.
    Thanks for any advice
    Andy
    Verified VCDS User hmeco_'s Avatar
    Nov 2018
    when you open your VCDS and its registered, on first window there is a auto-scan function, hit it!
    once its complete save it and paste the unmodified content in code brackets, if you donīt know how to do so, please read this guide here: How-to-post-an-Auto-Scan
    once auto-scan is posted it is a lot easier to track down what issues you have stored in your car, and there fore easier to solve them.
    - hmeco
    Best Regards
    Hamzalija "hMeco" Meco
    >>> HOW-TO-POST-AUTO-SCANS <<<<<
  3. Likes Eric, Uwe, NZDubNurd liked this post
    Pirate
    Nov 2018
    Will do, scanned for fault codes and 00575 showed up.
    Still there after replacing MAP sensor.
    Nov 2017
    Latvia
    Pirate
    Nov 2018
    Thanks for the link but I had read the description.
    Problem is how do I test components that would cause the error.
    Just off out to do a full scan as requested so will post the results soon.
    Pirate
    Nov 2018
    Full scan as requested.
    Removed.  Data from a clone/pirated copy of VCDS is not welcome here.
    Getting help on this forum requires the use of a legitimate VCDS system.
    http://www.ross-tech.com/distributors.php#uk
    Let us know via PM if/when you get one so we can adjust your forum status.
  9. #8
    Pirate
    Nov 2018
    What are you talking about I bought this on amazon.co.uk
  10. #9
    Then I suggest you file a complaint and return it to them. Let Trading Standards know too.
  11. Likes PetrolDave liked this post
  12. #10
    Quote Originally Posted by Wooks View Post
    Uwe is the owner of Ross-Tech which develops VCDS, so if he says you have a pirate copy then you have pirate copy - no ifs, no buts, no maybes
  13. Likes Fredrick Awuor liked this post
