Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: 2013 VW Golf GTi -- TOO RICH P0172
    Sep 2014
    Guatemala
    Exclamation 2013 VW Golf GTi -- TOO RICH P0172
    hi guys,
    I am going crazy here, got this car and checked everything as it throws the system too rich fault
    * found cat converter completely obstructed, removed it (it is now catless, that is not an issue in our country as it was cheaper than buying a new cat)
    * had a P2237, so changed primary 02 sensor to latest part number
    * checked PCV, perfect condition
    * checked timing everything is good
    * checked for leaks on boost side, pressure tested everything all good
    * removed and checked HPFP for any symptom
    * changed injectors as it was having misfires while idle
    * compression test on all 4 cylinders all show 145 psi
    * leak down test 98% hold
    * spark plugs porcelain white and external part dark black
    so right now it continues to throw the P0172 when you are driving for a long period and lift gas pedal on a downhill, 1 big explosion comes out of the exhaust.
    measuring blocks (lambda control moves from around -8% to +9%
    https://imgur.com/a/jVNrC3X
    block 032 I have seen idle channel start at 0% and raise up to -24% at some ocasions.
    Monday,12,November,2018,11:06:18:22246
    VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WVWZZZ1KZDW095264   License Plate:
    Chassis Type: 1K-VW36 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 4C 52 55 56 77
    VIN: WVWZZZ1KZDW095264   Mileage: 73220km-45496miles
    2E-Media Player 3 -- Status: Not registered 0001
    Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
       Part No SW: 5K0 907 115 A    HW: 1K0 907 115 AA
       Component: 2.0l R4/4V TFSI     0040
       Revision: AAH18---    Serial number:
       Coding: 040300101C070060
       Shop #: WSC 00642 210 45725
       VCID: 2809FB468EF67527F65-807C
    000370 - Fuel Trim; Bank 1
                   P0172 - 000 - System Too Rich
                        Mileage: 73220 km
                        Date: 2013.04.04
                        Time: 01:24:42
                        RPM: 858 /min
                        Load: 22.0 %
                        Temperature: 100.0°C
                        Temperature: 53.0°C
                        Absolute Pres.: 850.0 mbar
                        Voltage: 13.843 V
    Readiness: 0110 0001
       Part No SW: 02E 300 058 P    HW: 02E 927 770 AL
       Component: GSG DSG AG6     512 3514
       Revision: 05551213    Serial number: 00001208151501
       VCID: 270BF87A83E87A5FFFF-8072
       Revision: 00H31001
       Coding: 143B600D092B80FF280D06EA901D0141350D50
       VCID: 7DA7FA123DF4008FF53-8028
       Part No SW: 5K0 907 044 GK    HW: 5K0 907 044 GK
       Component: Climatronic   H19 1313
       Revision: 00001004
       Coding: 0010004002
       VCID: 7AADF10E2C5A37B7D01-802E
       Part No SW: 1K0 937 086 R    HW: 1K0 937 086 R
       Component: BCM PQ35  M   111 0709
       Revision: AC111709
       Coding: 40180A3BE825F300408800C0340089EC4FD54088737D8D20E48400240040
       VCID: 3FDB401A7778D29FA7F-806A
       Component: Wischer 06091  26  0512
       Coding: 009F95
       Component: RLS 140912 05  54  0403
       Coding: 0630AD
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 13
                        Mileage: 66616 km
                        Date: 2018.04.13
                        Time: 11:08:35
                        Voltage: 12.30 V
                            Term 50 Off
    01259 - Fuel Pump Relay (J17)
                        Fault Status: 00101001
                        Reset counter: 226
                        Mileage: 73209 km
                        Date: 2013.03.31
                        Time: 08:00:08
                            Term 15 Off
                        Voltage: 12.35 V
                            Term 50 Off
    Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
       Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0025
       Revision: --------    Serial number: 56231203401265
       Coding: 348103
       ASAM Dataset: EV_EPHVA2C000000000 002008
       ROD: EV_EPHVA2C000000000.rod
       VCID: 44D14FF61E1EB147FAD-8010
    12658720 - Databus
              [Steuergerät für elektrische Park-/Handbremse-J540 - mEPB_1 - kein Signal/keine Kommunikation]
                        Reset counter: 13
                        Mileage: 66616 km
                        Date: 2018.04.13
                        Time: 11:08:35
       Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
       Serial number: 003G5RANTBE9
       Coding: 00003957
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 313F1622B1AC34EF21B-8064
       Serial number: 3572MSME1D5A5274ZZZ/
       Serial number: 3582MSME37616074ZZZS
       Serial number: 3512QSME74221B13ZZZM
       Serial number: 3522QSME66471730ZZZQ
       Part No SW: 5K0 953 507 AF    HW: 5K0 953 549 A
       Revision: --------    Serial number:  90440LIF000HS
       Coding: 189A040000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 74B1DF360E3E41C78AD-8020
       Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H30 0032
       Serial number: 0068085
       Coding: 830000
       Part No SW: 5K6 920 873     HW: 5K6 920 873
       Coding: 170E01
       VCID: 73B3DC2A0B3046FF937-8026
    9453074 - Fuel Level Sensor 1
              B103E 1B [008] - Resistance Too High
                        Reset counter: 226
       Part No SW: 7N0 907 530 AB    HW: 7N0 907 530 AB
       Component: J533  Gateway H47 1633
       Revision:   H47       Serial number: 030912F1001490
       Coding: 350000
       Shop #: WSC 12345 528 03869
       VCID: 70B9D3267AA67DE76E5-8024
                        Mileage: 66616 km
                        Date: 2018.04.13
                        Time: 11:08:36
       VCID: 6A8DC14E5CFA8737201-803E
       Revision: A1001003    Serial number: 7660899436
       VCID: 290FFE4299FC4C2FE9B-807C
       Part No SW: 5K0 959 701 C    HW: 5K0 959 701 C
       Component: Tuer-SG         009 2117
       Coding: 0004150
       VCID: 323D192EB82A0FF7581-8066
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 74     3305
       Revision: 00H22000
       VCID: 372B283A5348EADF6FF-8062
       Part No SW: 5K0 959 702 J    HW: 5K0 959 702 J
       Component: Tuer-SG         009 2103
       Coding: 0004406
       VCID: 3A2D310E605AF7B7901-806E
       Coding: 1442908
       VCID: 34311F36423E01C74AD-8060
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000022
       Coding: 00000022
       Part No SW: 5K0 035 190 B    HW: 5K0 035 190 B
       Component: Radio RCD510  005 0236
       Revision: 00000001    Serial number: VWZ1Z3M7282520
       Coding: 05000410040005
       VCID: 2411EF76FEDE9147DAD-8070
    03138 - Input AUX IN
                        Reset counter: 13
                        Mileage: 66616 km
                        Date: 2018.04.13
                        Time: 11:08:52
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Revision: 1B001001    Serial number: 00007663415370
       Coding: 0A00000000010100
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 3A2D310E6CDAF7B7901-806E
    End----------(Elapsed Time: 01:08, VBatt start/end: 13.6V/13.6V)-----------
    May 2016
    Sama13, cat was smoke so an ongoing issue, Is this car chipped????
    Also what his the condition of the oil.????
    Back fire?. Not sure intake or exhaust. Back fire normally timing or lean burn, take a pick.
    Also what is the condition of intake, filter, (intake runners if applicable). Noted lambda going from almost 10% lean and rich, right on the edge of out of bounds both ways.
    You stated new injectors, are any of them posting inordinate times compared to each other?
    You stated PCV is good, not sure what that means, your call.
    LARIMORE
    Sep 2014
    Guatemala
    hi Larry,
    I answer on order:
    1. Yes ongoing issue, this car was bought second hand by the guy I am working with trying to solve the issue, but it seems previous guy had removed stock downpipe and let it get wet with rain so it messed up.
    2. Car is reflashed, eys.
    3. New oil Motul 8100 X-Clean, it consumed 2 liters in around 5,000 kms
    4. Backfire from the exhaust when going downhill without fuel pedal pressed.
    5. Stock intake, new air filter, cleaned runners 4,000 kms ago. removed tube from intercooler to throttle to check and all is good (known to have an issue)
    6. haven't checked injector times as I don't know how can you explain so I can check it, bought latest version.
    7. blocked pcv to check if it made any difference and it didn't, checked with the normal way that we learned a while ago of checking idle when warm engine, if there is another way please explain.
    Quote Originally Posted by Larry Manton View Post
    LARIMORE
    hi guys,
    Hey Sam........
    Do you you have legacy scans you could post & what codes you had?
    Is the car FOD modified?
    Sep 2014
    Guatemala
    Hey Sam........
    Sir Jack, you got me off guard, what do you mean with Legacy scan?
    VCDS auto-scans when you first started and all the original fault codes or was it only this one fault code?
  7. #7
    Sep 2014
    Guatemala
    Is car modified for programming?
    What specific part number for the forward OXS was installed, because didn't this require a firmware revision to be used & also I dont see an SVM code for that ECU you have?
  9. #9
    Sep 2014
    Guatemala
    Yes I am trying to return it to stock.
  10. #10
    Yes do that and verify the aforementioned on OXS sensor!
