Saturday,10,November,2018,09:25:23:49958
VCDS Version: 18.2.1.2 (x64)
Mileage: 61970km-38506mi Repair Order:
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 4C 52 53 56 62 72
77
Mileage: 61970km-38506miles
2E-Media Player 3 -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 06J 997 029 N HW: 06J 907 309 A
Component: MED17.5.2 TFSI 2 1518
Revision: P3H07--- Serial number:
Coding: 0423010A19070160
Shop #: WSC 06921 002 1048576
VCID: 42A5AF281D4CF75471-8016
U1017 - 000 -
Mileage: 60619 km
Date: 2018.10.07
Time: 06:55:44
Temperature: 38.0°C
Temperature: 35.0°C
Absolute Pres.: 840.0 mbar
Voltage: 11.938 V
U1017 - 000 - - MIL ON
Fault Status: 11100000
Mileage: 60619 km
Date: 2018.10.07
Time: 06:55:55
Temperature: 38.0°C
Temperature: 35.0°C
Voltage: 11.938 V
008817 - Oxygen (Lambda) Sensor Signal B1 S2
P2271 - 000 - too Rich - Intermittent
Fault Frequency: 12
Mileage: 60629 km
Date: 2018.10.08
Time: 04:06:20
RPM: 1865 /min
Load: 67.0 %
Speed: 58.0 km/h
Temperature: 97.0°C
Temperature: 36.0°C
Absolute Pres.: 810.0 mbar
Voltage: 13.843 V
000314 - Oxygen (Lambda) Sensor B1 S2
P013A - 000 - Response too Slow Rich to Lean - Intermittent
Mileage: 61495 km
Date: 2018.10.30
Time: 03:05:45
RPM: 1428 /min
Load: 9.4 %
Speed: 76.0 km/h
Temperature: 94.0°C
Temperature: 45.0°C
Absolute Pres.: 790.0 mbar
Voltage: 13.716 V
Part No SW: 09G 927 750 LR HW: 09G 927 750 LR
Component: AQ 250 6F 1971
Revision: 00H90000 Serial number:
Coding: 0000840
VCID: 0C3941106F8871244B-8058
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 AP HW: 5N0 614 109 AP
Component: J104 C6 450M VD82 0005
Revision: --H07--- Serial number: 00000005445558
Coding: 0005158
VCID: 79D708C4301A748C60-802C
6 Faults Found:
Fault Frequency: 227
Reset counter: 130
Mileage: 60619 km
Date: 2018.10.07
Time: 06:56:54
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 11.75 V
Bin. Bits: 00000010
Count: 191
Hex Value: 0x0000
01164 - ESP Operation
Reset counter: 166
Mileage: 60643 km
Date: 2018.10.08
Time: 07:02:57
Speed: 15.0 km/h
Hex Value: 0x0000
Voltage: 14.00 V
Bin. Bits: 00000010
Count: 239
Hex Value: 0x0000
Reset counter: 166
Mileage: 60643 km
Date: 2018.10.08
Time: 07:02:57
Reset counter: 166
Mileage: 60643 km
Date: 2018.10.08
Time: 07:02:57
Reset counter: 166
Mileage: 60643 km
Date: 2018.10.08
Time: 07:02:57
00810 - Sensor 1/2 for Brake Pressure
Reset counter: 166
Mileage: 60643 km
Date: 2018.10.08
Time: 07:02:57
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0404
Revision: 00001018
Coding: 0000001002
VCID: 002165209BC0254427-8054
13701504 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 130
Mileage: 58408 km
Date: 2018.02.25
Time: 03:26:34
13701520 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 130
Mileage: 58408 km
Date: 2018.02.25
Time: 03:26:34
13701536 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 130
Mileage: 58408 km
Date: 2018.02.25
Time: 03:26:34
Part No SW: 5K0 937 084 J HW: 5K0 937 084 J
Component: BCM PQ35 B 021 0064
Revision: BG021001
Coding: 6F180A1B80232EC4008800C11000044448010086524D8D60648000000040
VCID: 3957C8C4B09AB48C20-806C
Subsystem 1 - Part No SW: 5N1 955 119 HW: Labels: 1KX-955-119.CLB
Component: Wischer 10031 013 0203
Serial number: N1955119 °203!
Coding: 009795
01259 - Fuel Pump Relay (J17)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 135
Mileage: 58437 km
Date: 2018.04.06
Time: 00:00:12
Term 15 Off
Voltage: 10.30 V
Reset counter: 131
Mileage: 58408 km
Date: 2018.02.25
Time: 03:26:41
Voltage: 13.00 V
Reset counter: 131
Mileage: 58408 km
Date: 2018.02.25
Time: 03:26:41
Voltage: 13.00 V
Reset counter: 131
Mileage: 58408 km
Date: 2018.02.25
Time: 03:26:41
Voltage: 13.00 V
02092 - Enabling Heated Seat
Reset counter: 130
Mileage: 58408 km
Date: 2018.02.25
Time: 03:26:41
Voltage: 13.55 V
Part No SW: 5N0 959 655 S HW: 5N0 959 655 S
Component: J234__ VW10 HI 2118
Revision: 27020000 Serial number: 003L6P1B180X
Coding: 0000000
VCID: 4DBF8C14D412382C9C-8018
Subsystem 1 - Part No: 5N0 959 339 B
Subsystem 2 - Serial number: 00000000004GNA
Subsystem 3 - Serial number: 0013.01.120000300000660098ÿ†63
Subsystem 4 - Serial number: 660098ÿ†6332MTS641910602 ÿ†63
Subsystem 5 - Serial number: 10602 ÿ†6342MTS623670592 ÿ†63
Subsystem 6 - Serial number: 70592 ÿ†6351HTS6R36L0AKJ ÿ†63
Subsystem 7 - Serial number: L0AKJ ÿ†6361HTS6EMOHMAKJ ÿ†63
Subsystem 8 - Serial number: HMAKJ ÿ†63727TS6KQUL0AKR ÿ†63
Subsystem 9 - Serial number: L0AKR ÿ†63827TS6G0EK0AKR ÿ
Subsystem 10 - Serial number: K0AKR ÿ
Part No SW: 5K0 953 501 AQ HW: 5K0 953 569 F
Revision: FF010040 Serial number: 20120312300805
Coding: 5980140000
VCID: 79D708C4F81A748C60-802C
Part No SW: 5N0 920 972 E HW: 5N0 920 972 E
Component: KOMBI H04 0617
Coding: 211F01
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 354FC4F4948250ECC4-8060
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 260212F2002169
Coding: 356002
VCID: 3A55D7C8B59CBF9429-806E
Reset counter: 131
Mileage: 58408 km
Date: 2018.02.25
Time: 03:26:51
Reset counter: 131
Mileage: 58408 km
Date: 2018.02.25
Time: 03:26:51
Reset counter: 131
Mileage: 58408 km
Date: 2018.02.25
Time: 03:26:51
03272 - Control Module for Audio Interface
Reset counter: 131
Mileage: 58408 km
Date: 2018.02.25
Time: 03:26:55
Component: IMMO H04 0617
VCID: 6AF527888DBCCF1499-803E
9456681 - Key
B104C 29 [008] - Implausible Signal
Mileage: 58437 km
Date: 2018.04.06
Time: 00:10:57
Address 2E: Media Player 3
Part No SW: 5N0 959 701 B HW: 5N0 959 701 B
Component: Tuer-SG 008 2005
Coding: 0001205
VCID: 3449F9F057F849E4F3-8060
Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
Component: J500__APA-BS KL.285 1002
Revision: 1AH03836 Serial number: 00120610077001
Coding: 0000258
Shop #: WSC 01324 020 00200
VCID: 3C59D1D07FA881A43B-8068
Address 52: Door Elect, Pass.
Part No SW: 3AA 907 801 J HW: 3AA 907 801 J
Component: J540 EPB4 VW-63206 0012
Revision: H19 Serial number: 00000000193956
Coding: 0010000
VCID: 3851CDC04B90AD84DF-806C
8 Faults Found:
Fault Status: 01110000
Reset counter: 130
Voltage: 8.60 V
Count: 98
Hex Value: 0x0150
Hex Value: 0x0082
Hex Value: 0x4040
Reset counter: 130
Voltage: 8.80 V
Count: 41
Hex Value: 0x0150
Hex Value: 0x0082
Hex Value: 0x4040
Fault Status: 01110101
Reset counter: 130
Voltage: 9.30 V
Count: 99
Hex Value: 0x1150
Hex Value: 0x0082
Hex Value: 0x4040
02432 - Supply Voltage for Left Parking Brake Motor (V282)
Reset counter: 130
Mileage: 60056 km
Date: 2018.09.15
Time: 19:32:33
Voltage: 12.10 V
Count: 29
Hex Value: 0x1240
Hex Value: 0x0001
Hex Value: 0x0101
013 - Check DTC Memory
Fault Status: 01111101
Fault Frequency: 49
Reset counter: 47
Mileage: 58593 km
Date: 2018.07.16
Time: 00:00:18
Voltage: 11.60 V
Count: 69
Hex Value: 0x1250
Hex Value: 0x0001
Hex Value: 0x0101
02433 - Supply Voltage for Right Parking Brake Motor (V283)
Reset counter: 130
Mileage: 60056 km
Date: 2018.09.15
Time: 19:32:34
Voltage: 12.10 V
Count: 30
Hex Value: 0x1250
Hex Value: 0x0001
Hex Value: 0x0101
02435 - Supply Voltage for Control Module for Right Channel
Fault Status: 00101001
Fault Frequency: 63
Reset counter: 164
Mileage: 60162 km
Date: 2018.09.16
Time: 05:56:08
Voltage: 12.00 V
Count: 16
Hex Value: 0x1240
Hex Value: 0x0001
Hex Value: 0x0101
02434 - Supply Voltage for Control Module for Left Channel
Reset counter: 138
Mileage: 61496 km
Date: 2018.10.30
Time: 03:14:26
Voltage: 10.50 V
Count: 15
Hex Value: 0x12D0
Hex Value: 0x0001
Hex Value: 0x0101
Part No SW: 5N0 035 164 D HW: 5N0 035 164 D
Component: LOW NAR Tig H02 0004
Revision: -----03S Serial number: VWZ4Z6M3305400
Coding: 0100040004000C
VCID: 2A75E788453C0F1459-807E
Reset counter: 130
Mileage: 58408 km
Date: 2018.02.25
Time: 03:27:01
Address 62: Door, Rear Left
Address 72: Door, Rear Right
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661552059
Coding: 0A10040000010100
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 27731EBC5E2E327C46-8072
End-------------------------(Elapsed Time: 01:41)--------------------------
