Results 1 to 10 of 19
Thread: MK7 GTI instrument lights
    Aug 2018
    New to the community. Is there a way to adjust the instrument panel lights using the VCDS? I would like to disable the sensor that dims the lights automatically AND find a way to turn the lights off using the dashboard switch. I often drive very dark roads, and the instrument panel lights are way too bright even at the lowest setting.
    Oct 2017
    Northwest UK
    Please could you provide an autoscan. There should be an option through your infotainment unit, I have it to dim my lights.
  3. Likes Uwe liked this post
    Unverified
    Aug 2018
    Argentina
    DESDE EL MULTIMEDIA PODES CONFIGURAR LA LUZ DEL TABLERO COMO QUIERAS
    Quote Originally Posted by topitoaudiocar View Post
    The language of this forum is English, please post only in English.
  6. Likes hmeco_, Uwe liked this post
    Aug 2018
    At this point I've made two changes; I can operate windows with key fob I have turned off ASR
    Saturday,24,November,2018,16:02:57:16860
    VCDS Version: 18.9.0.2
    Dealer/Shop Name: gordons garage
    VIN: 3VW5T7AU7HM020081   License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 15 16 17 19 42 44 52 5F 75 A9
    VIN: 3VW5T7AU7HM020081   Mileage: 27526km-17103miles
    A9-Struct. Borne Sound -- Status: Malfunction 0010
    Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 L    HW: 06K 907 425 B
       Revision: --H13---
       Coding: 091900122424002F0000
       Shop #: WSC 00066 790 00065
       ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
       ROD: EV_ECM20TFS0205G0906259L_VW37.rod
       VCID: 3776E12A8E0C58F224-8062
    Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
       Part No SW: 5Q0 614 517 AF    HW: 5Q0 614 517 AF
       Component: ESC           H62 0398
       Revision: 00000000    Serial number: 52316000000366
       Coding: 01FA6BA13422096C4077020881C42980D62C90024081943400430050C00603
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
       ROD: EV_Brake1UDSContiMK100ESP_035.rod
       VCID: 75EA2B22D480EAE2F6-8020
    16401 - Tire Pressure Warning
              C102D 00 [008] -  -
                        Reset counter: 173
                        Mileage: 27411 km
                        Date: 2018.11.23
                        Time: 12:58:01
       Part No SW: 5GM 907 426 C    HW: 5GM 907 426 C
       Component: AC Manuell    H03 1601
       Revision: 00001K03
       Coding: 00020004200100000000000000000002
       ASAM Dataset: EV_ACManueBHBVW37X 004132
       ROD: EV_ACManueBHBVW37X_004_VW37.rod
       VCID: 489492D6F3F2270A5D-801C
       Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
       Revision: --------    Serial number: 865815081600UC
       Coding: 000008464041804969E44000001407201000000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 7AF0381EFD9E859A9B-802E
       Component: WWS    160911  043 0581
       Serial number:         160922094616
       Serial number: 003GCR05FX0P
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 479691EAFEEC287254-8012
       Occupant Detection:
       Serial number: IBH000000000005RI78P
       Coding: 30305A
       Subsystem 2 - Part No SW: -----------    HW: 480 002 507 16
       Serial number: 35700000000D04D00D1G
       Subsystem 3 - Part No SW: -----------    HW: 480 002 507 16
       Serial number: 3580000000081105BC1C
       Subsystem 4 - Part No SW: -----------    HW: 480 402 907 16
       Serial number: 3510002B7209506341DT
       Subsystem 5 - Part No SW: -----------    HW: 480 402 907 16
       Serial number: 35200029B209506092BX
       Subsystem 6 - Part No SW: -----------    HW: 480 400 708 16
       Serial number: 3550002C5215E1C570F8
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 708 16
       Serial number: 3560002C7215E1C46183
       Part No SW: 5Q0 953 521 K    HW: 5Q0 953 569 A
       Revision: FF034034    Serial number: 20160817400493
       Coding: 0400
       Shop #: WSC 66564 385 16448
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3A70F81EBD1E459ADB-806E
       Part No SW: 5G1 920 856 B    HW: 5G1 920 856 B
       Component: KOMBI         344 8311
       Coding: 0BBD0902A180CF0502086A001000000000000000
       VCID: 2D5AC3427C50E2224E-8078
    16777020 - Function Restricted due to Interrupted Communications
              U1110 00 [008] - -
                        Fault Frequency: 37
                        Reset counter: 173
                        Mileage: 24540 km
                        Date: 2018.09.19
                        Time: 08:06:33
       Part No SW: 5Q0 907 530 AL    HW: 5Q0 907 530 L
       Component: GW MQB Mid    211 2265
       Revision: --------    Serial number: 01081610802632
       Coding: 0101000830085900FB000028080F00000001050000000000000000000000
       Shop #: WSC 00066 790 07026
       ROD: EV_GatewConti_013_VW37.rod
       VCID: 7BFE3D1AF2A4BC9280-802E
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H11 0103
       Serial number: 29160001590330066341
       Coding: 30FFFF
       Serial number: 1709160605014Q
       Coding: 003E03200000020000000000
       VCID: 438E85FACAD4045288-8016
       Serial number: 00000000000013790956
       Coding: 011000
       Coding: 8102
       ROD: EV_SteerAssisMQB_013.rod
       Serial number: 250916060504FV
       VCID: 428080FED5CE0D5A83-8016
       Serial number: 00000000000004289512
       Coding: 091000
       Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
       Component: MU-S-S-US     710 0751
       Coding: 02730000FF00000051220001001808009F0203D40120010002
       ROD: EV_MUStd4CDELP_VW26.rod
       Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
       Component: ABT_Std-2  H53 1031
       Serial number: VWZ8Z9SJW011LN
              B11CF 53 [009] - Deactivated
                        Reset counter: 197
                        Mileage: 24540 km
                        Date: 2018.09.19
                        Time: 06:40:10
                        Voltage terminal 30: 14.0 V
                        SDARS_tuner_status_2-Audio Signal: Available
                        SDARS_tuner_status_2-Antenna current: 140 mA
                        SDARS_tuner_status_2-Reception quality: optimum_signal
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
       Component: OCULowMQBUS   007 0568
       ROD: EV_OCULowMQB.rod
       Serial number: 160726200317
       VCID: 6BDE0D5A82C42C1210-803E
    0006 - Actuator for Structural Accoustics
              P193A 00 [009] - Open Circuit
                        Reset counter: 138
                        Mileage: 21608 km
                        Date: 2018.07.25
                        Time: 15:10:17
    End-------------------------(Elapsed Time: 03:24)--------------------------
    Got the OP verified; moving this to tweaks.
    I suspect the answer is yes, there's a whole lot of Adaptation Channels for "dimming_characteristic_curve_adjustment" in that cluster, but to be honest, I've never messed with any of them.
    I'm going to suggest you post an Adaptation Channel Map from your instrument cluster so people can see what's in there now.
  10. #8
    Aug 2018
    Unable to generate Channel Map.
    Following directions you provided: Select Applications; Controller Channel Map; Controller Address = 17 (assuming this is where to find the map for instrument lights); check Measuring Blocks and Pre-label File; click GO.
    A new window opens for about two seconds, but as soon as the words 'Gereat 00065' appear in the 'extra' field, that window closes and I'm looking at the controller address window again. I've tried this several times. Don't know what to do next.
  11. #9
    Quote Originally Posted by jgordon View Post
    Adaptations, not Measuring Blocks.
    .CSV would also be the preferred output for this.
  12. #10
    Oct 2018
    Not sure if this helps you 100%, but here is a write-up made by DV52 about changing the dashboard lights and the dimming curve, this could help set you on the right track: https://www.dropbox.com/s/84ipeea9wq...ion_1.pdf?dl=0
  13. Likes Uwe liked this post
