Volkswagen Passat CC 2009 2.0L ABS coding Faults following a new key coding
ataylor92
C?ID=156813
Hope you can help me with this Passat, the vehicle history to date:-
Standard vehicle no mods Right hand drive
Vehicle working fine previous days/weeks
Locksmith due next day to supply and code new spare key
It was a cold morning the battery was discharged. car was started with a jump pack and road tested fine before key coding
A new key coded the alarm sounded and five lights on dash abs eps hand brake comfort / sport
new battery fitted
I have searched the forum and coded the abs unit. The codes before this read are stored in a pdf the faults below are after the coding of the abs unit
Andy Taylor
Wednesday,07,November,2018,16:10:07:38326
VCDS Version: 18.9.0.2
VIN: WVWZZZ3CZ9E530832   License Plate: MARK
Mileage: 104680km-65045mi   Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 10 14 15 16 17 19 25 42 44 46 4F 52 53 56 62 72
VIN: WVWZZZ3CZ9E530832   Mileage: 104680km-65045miles
Address 01: Engine (CAW)       Labels:. 06J-906-026-CAW.clb
   Part No SW: 06J 906 026 D    HW: 06J 906 026 D
   Component: MED17.5             2424
   Revision: A7H06---    Serial number: VWZCZ000000000
   Coding: 0404000318070060
   Shop #: WSC 05314 000 00000
   VCID: 2B5F45E68A90861250-807E
               U1017 - 000 -  - Intermittent
                    Fault Frequency: 18
                    Mileage: 104543 km
                    Date: 2013.03.22
                    Time: 19:59:25
                    Temperature: 54.0°C
                    Temperature: 26.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 12.319 V
                    Mileage: 104543 km
                    Date: 2013.03.22
                    Time: 19:59:25
                    Temperature: 54.0°C
                    Temperature: 26.0°C
                    Voltage: 12.319 V
               U1017 - 000 -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 104543 km
                    Date: 2013.03.22
                    Time: 19:59:30
                    Temperature: 54.0°C
                    Temperature: 26.0°C
                    Voltage: 12.319 V
001393 - Brake Switch (F)
               P0571 - 000 - Implausible Signal - MIL ON
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
Readiness: 0000 0001
Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
   Component: J104    C4 440 V2   0011
   Revision: --025---    Serial number: 00000786190962
   Coding: 0002412
   Shop #: WSC 05311 000 00000
                    Reset counter: 229
                    Hex Value: 0x0000
                    Voltage: 0.00 V
                    Bin. Bits: 00011111
                    Count: 227
                    Hex Value: 0x0000
                    Reset counter: 229
                    Hex Value: 0x0000
                    Voltage: 0.00 V
                    Bin. Bits: 00011111
                    Count: 149
                    Hex Value: 0x0000
00810 - Sensor 1/2 for Brake Pressure
                    Reset counter: 229
   Part No SW: 5K0 907 044 AJ    HW: 5K0 907 044 AJ
   Component: Climatronic   130 0303
   Coding: 0000000000
   ASAM Dataset: EV_Climatronic A01001
   VCID: 73EF9D86DA209ED2D8-8026
   Revision: 00H54000    Serial number: 00000008888321
   Coding: E1840F8B00041A0047970F00170000000008FF475C40017C170000000000
   Shop #: WSC 05124 000 08193
   VCID: 336F5D8652A0DED218-8066
   Subsystem 1 - Part No: 3C8 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 170908 022  0602
   Coding: 00046997
   Shop #: WSC 05124
   Component: RLS     061008 054  0402
   Coding: 00209133
   Shop #: WSC 05124
   Part No SW: 3C8 919 475     HW: 3C8 919 475
   Component: PARKHILFE 8K  H07 0007
   Revision: --------    Serial number: 97540827303145
   Coding: 100001
   VCID: 71E3978EA83CACC22A-8024
   Part No SW: 3C0 907 376     HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0069
   Revision: 00000000    Serial number: 29090802190001
   Coding: 010180
   VCID: 66C9F4D291F27B7A4F-8032
03264 - Functionalty Shut Off
            000 -  -  - Intermittent
                    Fault Frequency: 11
                    Reset counter: 254
                    Mileage: 104543 km
                    Date: 2013.03.22
                    Time: 00:59:33
                    Error Code: 9
                    Bin. Bits: 00000000
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 212
                    Mileage: 104543 km
                    Date: 2013.03.22
                    Time: 00:59:33
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 229
                    Mileage: 104543 km
                    Date: 2013.03.22
                    Time: 00:59:33
                    Bin. Bits: 00000000 00001110
03262 - Comfort Restriction
                    Fault Frequency: 37
                    Reset counter: 229
                    Mileage: 104543 km
                    Date: 2013.03.22
                    Time: 04:48:56
                    Error Code: 2
                    Bin. Bits: 00000000
   Part No SW: 5N0 959 655 A    HW: 5N0 959 655 A
   Component: J234__301 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPKL3ZLL
   Coding: 0012337
   VCID: 3B7F75A67AF01692C0-806E
   Subsystem 1 - Serial number: 6333FTS655882598
   Subsystem 2 - Serial number: 6343FTS606522568
   Subsystem 3 - Serial number: 6353ETS6PL44VVNR
   Subsystem 4 - Serial number: 6363ETS60BA7VVNR
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
   Component: J0527               0025
   Revision: 00030000    Serial number: 3C5953507BN
   Coding: 0000501
   Shop #: WSC 05311 000 08193
   VCID: 74ED9E9A172E99EAC1-8020
   Subsystem 1 - Part No: 3C8 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP   H2ÿ 0021
   Coding: 00000226
   Part No SW: 3C8 920 970     HW: 3C8 920 970
   Component: KOMBI         H19 0023
   Coding: 440F00
   Shop #: WSC 05314 115 00000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
   VCID: 69D3FFEE88EC540262-803C
   Part No SW: 3C0 907 530 J    HW: 3C0 907 951
   Component: J533__Gateway   H13 0152
   Revision:   H13       Serial number: 2900R089138336
   Coding: F9A87F06000203009003
   VCID: 2855BAEA9B66AD0ABD-807C
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   Revision: 00042000    Serial number: VWZCZ000000000
   VCID: 39736FAE70CC2482D2-806C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
   Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1534
   Revision: 71009005    Serial number: 00000750488825
   Coding: 0000693
   VCID: 4085024A1316754A95-8014
                    Fault Status: 00100101
                    Reset counter: 254
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 205    2301
   Revision: 00H15000
   VCID: 2A5140E2856A9F1AAB-807E
   Component:    KSG PQ46 ELV 042 0472
   Coding: 01910A0001860E763604941570085FCE107C01
Address 4F: Centr. Electr. II (J533_)       Labels:. 1K0-907-532.clb
   Part No SW: 1K0 907 532     HW: 3C0 907 951
   Revision: --------    Serial number: 2900R089138336
   Coding: 01030100
   Subsystem 1 - Part No SW: 6R0 959 591     HW: 6R0 959 591
   Component: J245  H04 0052
   Serial number: 837500024040
   Coding: 000006
   Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1534
   Revision: 71009005    Serial number: 00000063988822
   Coding: 0000692
   VCID: 4183074E181C7C429A-8014
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   009       Serial number: 00000000149356
   Coding: 0010000
                    Fault Status: 11111101
                    Reset counter: 229
                    Mileage: 104543 km
                    Date: 2013.03.22
                    Time: 01:00:14
                    Voltage: 13.30 V
                    Count: 71
                    Hex Value: 0x1240
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  036 0130
   Revision: 00000001    Serial number: VWZ1Z3H3361405
   Coding: 0500040004
   VCID: 65CBF3DE6CF4706246-8030
   Part No SW: 3C8 959 703 B    HW: 1K0 959 795 Q
   Component: J388   TUER-SG HL   0309
   Revision: 43004101    Serial number: 00000000624119
   Coding: 0000144
   VCID: 3163578EA8BCECC26A-8064
   Part No SW: 3C8 959 704 B    HW: 1K0 959 794 Q
   Component: J388   TUER-SG HR   0309
   Revision: 43004101    Serial number: 00000000604052
   Coding: 0000144
   VCID: 32615882ADBAD7DA13-8066
End-------------------------(Elapsed Time: 03:46)--------------------------
Gateway Installation List:  3C0 907 530 J
Dana
Western PA, USA
I'm not extremely confident the Engine/Trans configuration of the 03-ABS coding is correct however the RHD version of that coding is: 0003436
If you don't receive any additional suggestions please try that. 17-Instruments and 19-CAN GW appear to be correctly coded for RHD and GB.
Best,
Dana
0D6C | 0003436
096C | 0002412
Vehicle Identification No.WVWZZZ3CZ9E530832
ModelPassat CC PACC
Date of production14.10.2008
Year2009
Sales type3572L2
Engine CodeCAWB
Transmission CodeKNU
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PEWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation units/platform components0DJVehicle class differentiation -350-
Emission standard0GGEmission standard EU4
Trailer hitch1D0without trailer towing
airbag4UEdriver and front passanger airbags
Aktivkohlebehälter / Ottopartikelfilter1E1Activated carbon canister
Tray areas packageQE2Storage compartment
Aerials8ZHAntenna for AM/FM reception, "diversity"
Exterior mirror setting6XNExterior mirrors, power-adjustable/ separately heated
Left exterior mirror5SJLeft exterior mirror, convex
Right exterior mirror5RVRight exterior mirror, aspherical
Drive type1X0Front-wheel drive
"Multimedia"video/DVD/notebook connection9WLJack for external audio source
Equipment levelsA8FSports equipment
Brake type in rear1KUDisc brakes in rear
batteriesJ0LBattery 340 A (70 Ah)
Brake type, front1LHDisc brakes in front
Beverage holders4M6Beverage holders
Battery/alternator capacityNY2Increased battery capacity
Component part sets with country-specific design requirementsB0NComponent parts set, complying with vehicle type for Great Britain, various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ATElectronic stability control (ESC)
Owner's manuals0VFInformation kit in English
Operating voltage9Z0Operating voltage 12 V
Heated washer nozzles9T0Without heated washer nozzles
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
"Charism"2H1"drive select"
Chrome packageQJ3Chrome package (version 2)
General operating permit, alterationsC01Operating permit, alteration
Roof rails/roof load rack3S0Without roof rails/roof load rack
Roof insert/convertible top3FGGlass roof
Suspension system in rear1JPRear shock absorption
Suspension system in frontG61Shock absorption in front
Load-through hatch/ski bag3X2Load-through hatch
Insert for the filling up of unleaded fuel/fuel type2G1Insert for the filling up of unleaded fuel
Installation differentiation for components0ENInstallation differentiation for transmission MQ 350 -- vehicle components --
Theft protection system7ALAnti-theft alarm system, interior monitoring, backup horn and towing protection
Inserts5MDDecorative aluminum inserts
Scuff plates7M0Plastic scuff plates in door apertures
Park distance control7X2Park distance control in front and rear
Electric interface for external useUF0Without electric interface
Manufacturing sequence differentiation0FAStandard manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
fire extinguisher6A0without fire extinguisher
Pedestrian protectionVL1Extended pedestrian protection measures
Headlight activation8K8Low beam assistant with "Coming Home" function
Parking brakeUH2Parking brake
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Transmission types/gearshift mechanisms0G4Cable gearshift
Weight category rear axle0YDWeight range 4 installation control only, no requirement forecast
Weight category front axleL23Suspension range 23 installation control only, no requirement forecast
Base engineTQ24-cyl. petrol engine 2.0 l assembly 06J.B
Tie down straps/net/pocket6M0Without tie down straps/net/pocket
cruise control system8T0Without cruise control system (CCS)
Garage door openerVC0without Garage door opener
Transmission specificationsG0K6-speed manual transmission
Cruise control system and speed limiter6Y9without cruise control system
Brackets3P1Bracket for first aid kit and warning triangle
Rear seats3NNRear bench seat, not split, split backrest, folding
Heating and air-conditioning system9AKClimatronic with impact pressure control, CFC-free
Headlamps8BKTwin headlamps for driving on the left, with integrated high beam
Customized installationFC0Without individual installation
Interior light in footwell6T0Without interior light in footwell
Instrument clustersU5BInstrument insert, mph speedometer Great Britain
Breakaway interior rearview mirror4L6Breakaway interior rearview mirror, auto-dimming
headphone connection, rear8MAno headphone connection in rear
Body styleK8CCoupe
Luggage compartment floor covering6SEFlat needle-punched trunk floor covering
Cassette and CD storage unit4W0without cassette / CD tray
Electronic map cooling systemQS0Without electronic map cooling system
Child seatsQA0without child seat
Climatic zones0Y1Standard climatic zones
Compass/road sign displayQR0Without compass/road sign display/ dynamic road sign display
Seat ventilation/massage seat4D0Without seat ventilation/massage seat
headrest for seat, rear3Q1headrest for seat, rear
Fuel quantity for initial filling1Z2Increase in initial standard fuel filling
Fuel systems1A2Fuel system for SI engine with direct injection (FSI)
Body measures5C0Without special body measures
Radiator grille6KJRadiator grille with chrome-plated strip
Rear license plate bracket6P1Rear license plate carrier (ECE)
Front license plate bracket6W1Front license plate carrier (large)
Paint preservative/transit coating5K0Without surface protection, with additional transit coating
Paint coatingFB0standard paint coating
Rear cargo area3GAWithout luggage compartment floor
Country codesFE0Without country code (no DVD player in vehicle)
Steering system arrangementL0RRight-hand drive
Reading lamp8S72 reading lights in front
steering1N3Speed-related variable steering assist (Servotronic)
Backrest release3H0Without backrest release for front seats
Load edge protection2P1Plastic loading edge protection
Lumbar support7P8Electrically adjustable lumbar support for right front seat
steering wheels2PPLeather-wrapped multi-function steering wheel
Speaker installation8RM8 speakers (passive)
Headlight range control8Q1Headlight range control
Center armrest6E3Front center armrest
Multi-function display/trip computer9Q5Multi-function display with control
center console3D5center console
Engine cooling8Z5not hot country
Engine specificationsD2L4-cylinder petrol engine 2.0 L/147 KW (16 V) Turbo FSI, homogeneous Basic engine is: T59/T61/TQ2/TU2/TD6/TN6
Left vanity mirror4SUVanity mirror, left, illuminated
Right vanity mirror4TUVanity mirror, right, illuminated
Navigation device7Q0without navigation system
rear fog lamp8TDRear fog light for driving on the left
Front fog lamp/additional headlamp8WDIntegrated front fog light
Hubcaps1NLTrims for alloy wheels
WheelsC9TAlloy wheels 8J x 18
Radios8AIRadio "RCD510 MP3"
Smoker's/non-smoker's package9JANon smoker version
Tire pressure monitoring system7K6Tire pressure monitoring system
tireH03Tires 235/40 R18 95W (polymer coating)
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G3Alloy spare wheel with original equipment tires
Restraint systems, front3QT3-point seat belts in front, with tensioner and height adjustment
PHKAir-conditioning package
PJ5"Interlagos" painted in Sterling Silver 4 alloy wheels 8J x 18 tires 235/40 R18
PN8Decorative inserts "Brushed Aluminum"
RHC
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q2Gearshift knob/handle in leather
Special labels/plates0SSLabels in English and French
Tail lamp assemblies8SARear combination lamp, standard design
Locking mechanism for boot lid/cover rear4E2Tailgate/trunk lid release from inside (electrically)
Front seat, left3TGSports comfort seat in front, left
Front seat, right3SGSports comfort seat, front, right
Seat belt check9P1Seat belt reminder, electric contact in buckle
Outer rear seat belts3ZB3-point seat belts, outer rear with ECE label
seat coversN2NSeat trim covers in woven fabric
Seat adjustment3L3Manual height adjustment for front seats
seat heater4A0without seat heater
Side lights7R3Side turn signal lights (white)
Audio-response system/voice controlQH0without voice control
Lane change assist/lane keeping system7Y0no lane change assistant
Side and rear windows4KFheat protective glass for door, side and rear windows, darkened from b-pillar
Protective side molding4B4Protective side molding
Sunroof roller blind for rear/side windows3Y2Power-operated roll-up sunshade for rear window
power outlet7B312-volt outlet(s)
Bumper2JCComfort bumpers
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N3intermittent windscreen wiper with rain sensor
Special approval measures3M0Without special measures
Nameplate set0NBNameplate set in basic version
Special alarm systems9A0Without taxi alarm system
Mass damper for steering wheels1Q0steering wheel without balance weight
Door and lid locking system4K3Central locking w/ radio remote control, interior controls and SAFELOCK
Type approval countries/countries with special requirementsB09Type approval country GB/Northern Ireland
Carrier frequency for remote control5D1Carrier frequency 433.92 to 434.42 Mhz
Partition3CAwithout partition
Transit coatingNT0Transit coating (type 1)
Door and side trim panels3LCDoor and side trim panel in foam film and woven fabric
TV reception/digital radio receptionQV0without TV/digital radio reception
Assembly parts for engine (drive bearing)1VGAssembly part for 4-cyl. engine
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EXSpecial identification plate for EU
Delivery equipment2A0Without delivery equipment
First aid kit / warning triangle1T2warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Preparation for rotating beacon/siren combination9F0Without preparation for rotating beacon/siren combination
Telephone / telematics9W0Without car phone preparation/ installation
Additional warning lights9TCAdditional retro-reflectors (door area)
LongLife Service RegimeQG1LongLife Service Regime
Heat accumulator system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield Glass4GFWindshield in heat-insulating glass
Second battery/battery installation8FAwithout 2nd battery
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFront and rear floor mats
Decorative trims4ZBBright decorative trims
Additional child seat anchors3B4Child seat anchors for child seat system ISOFIX
Auxiliary heating system9M0Without auxiliary heater/parking heater
rhinopower
C?ID=58979
Do you not have a previous auto scan to compare to?
Dana
Western PA, USA
I don't believe they do. This is a shop (i.e. that's a customer's car rather than a personal vehicle) and I believe it was a first time customer so they don't have historical scans.
My concern is based on the fact that we don't have a single (good baseline) scan from a Passat or CC with the ABS module coded to 0002412 -or- 0003436. That's probably because all of our 2009 CAWB engine code scans are from FWD automatic 09G transmissions rather than FWD 6-speed manuals. Hopefully someone can correct me if HEX 6C doesn't = 2009: 2.0l TFSI CAWB [PR-TQ2] & 6-Speed Manual [PR-G0K+0EN].
Edit, after further review I am reasonably confident the coding suggestion in post #2 is correct.
ataylor92
C?ID=156813
2009 Passat cc Manual Gearbox With Auto Hold Hand Brake
The coding from DANA worked for all control units except the auto hold parking brake, I have changed the code to 0000057 but we still have a flashing parking brake light in the instrument cluster. the only other faults are in the suspension system (14) 03262 comfort restriction and 00776 level control system sensor.
Friday,16,November,2018,09:45:38:38326
Mileage: 104820km-65132mi   Repair Order:
VIN: WVWZZZ3CZ9E530832   Mileage: 104820km-65132miles
   Coding: 0003436
   Coding: 0000000000
   Coding: 00046997
   Shop #: WSC 05124
   Coding: 00209133
   Shop #: WSC 05124
   Coding: 100001
   Coding: 010180
                    Fault Frequency: 19
                    Reset counter: 245
                    Mileage: 104764 km
                    Date: 2013.04.06
                    Time: 01:07:29
                    Error Code: 2
                    Bin. Bits: 00000000
                    Reset counter: 242
                    Mileage: 104764 km
                    Date: 2013.04.06
                    Time: 01:07:29
   Coding: 0012337
   Coding: 0000501
   Coding: 00000226
   Coding: 440F00
   Coding: 0000693
   Component: EPS_ZFLS Kl. 206    2301
   Revision: 00H15000
   Coding: 01030100
   Coding: 000006
   Coding: 0000692
   Coding: 0000057
   Coding: 0500040004
   Coding: 0000144
   Coding: 0000144
End-------------------------(Elapsed Time: 03:47)--------------------------
Hope you can Help
Andy Taylor
Jef
HQ
So what is up with this? Locate the T4va connector for the G78, any visual issues with the wiring harness that you can see? Unplug T4va connector, terminals clean and shiny? On the T4va connector, /1 + /3 should be a 5V reference signal with ignition on. /2 is data back to the Electronics Damping Control Module (J250), T47a/26. /4 is empty.
If the electrical paths for the G78 sensor are to factory design, replace said sensor.
Dana
Western PA, USA
In reply to the email we received, the car has RR-Code UH2 Parking brake so the coding of 0000057 = Parking Brake with Auto-Hold (Rest of World / PR-UH2) in the 53-Parking brake module looks good to me.
I agree with Jef regarding the electrical G78 DTC in 14-Susp. Elect. Resolving that problem may allow you to clear the one related to Comfort Restriction.
Davey and Goliath agree!
ataylor92
C?ID=156813
hello
Thanks for all your help to date.
The wiring and circuit values for the left front sensor are good, I will fit the new part when it arrives, do we think this will cure the flashing parking brake light.
Andy T
Jef
HQ
I suspect it will, but won't know for sure until you give us an update. :confused:
ataylor92
C?ID=156813
2009 Passat cc 6 speed manual gearbox with auto hold hand brake
We have fitted a new sensor to left front suspension this has resolved all fault code, unfortunately we still have a flashing / blinking yellow parking brake light in the instrument cluster, the only help I give is the auto hold button doesn't light up but does activate in vcds
Andy Taylor
Friday,23,November,2018,13:21:46:38326
VIN: WVWZZZ3CZ9E530832   Mileage: 104990km-65237miles
   Coding: 0003436
   Coding: 0000000000
   Coding: 00046997
   Shop #: WSC 05124
   Coding: 00209133
   Shop #: WSC 05124
   Coding: 100001
   Coding: 010180
   Coding: 0012337
   Coding: 0000501
   Coding: 00000226
   Coding: 440F00
   Coding: 0000693
   Revision: 00H15000
   Coding: 01030100
   Coding: 000006
   Coding: 0000692
   Coding: 0000057
   Coding: 0500040004
   Coding: 0000144
   Coding: 0000144
End-------------------------(Elapsed Time: 03:41)--------------------------
Scratching head, wondering how this is possible when you have no fault codes anywhere.
Drive the car some. Set/Release the EPB a few times. Let's see if we can get some fault codes to set and give us a clue?
ataylor92
C?ID=156813
The car has been road tested for several days, the parking brake light is still flashing and the auto hold doesn't work and will not stay activated VCDS unless you hold the switch down.
we have one fault in the central conv 00955 key 1. On the day the faults occurred the battery was discharged the vehicle was started with a battery boost pack and a locksmith was coding a new key.
Andy T
Wednesday,28,November,2018,10:41:40:38326
VIN: WVWZZZ3CZ9E530832   Mileage: 105060km-65281miles
   Coding: 0003436
   Coding: 0000000000
   Coding: 00046997
   Shop #: WSC 05124
   Coding: 00209133
   Shop #: WSC 05124
   Coding: 100001
   Coding: 010180
   Coding: 0012337
   Coding: 0000501
   Coding: 00000226
   Coding: 440F00
   Coding: 0000693
   Revision: 00H15000
00955 - Key 1
                    Fault Frequency: 30
                    Reset counter: 49
   Coding: 01030100
   Coding: 000006
   Coding: 0000692
   Coding: 0000057
   Coding: 0500040004
   Coding: 0000144
   Coding: 0000144
End-------------------------(Elapsed Time: 03:50)--------------------------
Jef
HQ
http://wiki.ross-tech.com/wiki/index.php/VW_Tiguan_(5N)_Parking_Brake
  • Start engine, let idle.
  • Set and then release parking brake.
  • Connect to EPB with VCDS.
  • Do Basic Settings 007 to open EPB mech. Wait 20 seconds after motors stop, then back out of Basic Settings.
  • Do Basic Settings 006 to close EPB mech. Wait 20 seconds after motors stop, then back out of Basic Settings.
  • Do Basic Settings 010 to perform Function Test. Wait 20 seconds after motors stop, then back out of Basic Settings.
  • Exit out of EPB module.
  • Lock car up with remote.
  • Do 3 laps around car, clockwise, look for door dings.
  • Disarm alarm, start car.
Please provide feedback.
