Results 1 to 10 of 14
Thread: Volkswagen Passat CC 2009 2.0L ABS coding Faults following a new key coding
    Nov 2018
    Hope you can help me with this Passat, the vehicle history to date:-
    Standard vehicle no mods Right hand drive
    Vehicle working fine previous days/weeks
    Locksmith due next day to supply and code new spare key
    It was a cold morning the battery was discharged. car was started with a jump pack and road tested fine before key coding
    A new key coded the alarm sounded and five lights on dash abs eps hand brake comfort / sport
    new battery fitted
    I have searched the forum and coded the abs unit. The codes before this read are stored in a pdf the faults below are after the coding of the abs unit
    Andy Taylor
    Wednesday,07,November,2018,16:10:07:38326
    VCDS Version: 18.9.0.2
    VIN: WVWZZZ3CZ9E530832   License Plate: MARK
    Mileage: 104680km-65045mi   Repair Order:
    Chassis Type: 3C-VW46 (3C0)
    Scan: 01 03 08 09 10 14 15 16 17 19 25 42 44 46 4F 52 53 56 62 72
    VIN: WVWZZZ3CZ9E530832   Mileage: 104680km-65045miles
    Address 01: Engine (CAW)       Labels:. 06J-906-026-CAW.clb
       Part No SW: 06J 906 026 D    HW: 06J 906 026 D
       Component: MED17.5             2424
       Revision: A7H06---    Serial number: VWZCZ000000000
       Coding: 0404000318070060
       Shop #: WSC 05314 000 00000
       VCID: 2B5F45E68A90861250-807E
                   U1017 - 000 -  - Intermittent
                        Fault Frequency: 18
                        Mileage: 104543 km
                        Date: 2013.03.22
                        Time: 19:59:25
                        Temperature: 54.0°C
                        Temperature: 26.0°C
                        Absolute Pres.: 980.0 mbar
                        Voltage: 12.319 V
                        Mileage: 104543 km
                        Date: 2013.03.22
                        Time: 19:59:25
                        Temperature: 54.0°C
                        Temperature: 26.0°C
                        Voltage: 12.319 V
                   U1017 - 000 -  - MIL ON
                        Fault Status: 11100000
                        Mileage: 104543 km
                        Date: 2013.03.22
                        Time: 19:59:30
                        Temperature: 54.0°C
                        Temperature: 26.0°C
                        Voltage: 12.319 V
    001393 - Brake Switch (F)
                   P0571 - 000 - Implausible Signal - MIL ON
                        Temperature: -40.0°C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 0.000 V
    Readiness: 0000 0001
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
       Component: J104    C4 440 V2   0011
       Revision: --025---    Serial number: 00000786190962
       Coding: 0002412
       Shop #: WSC 05311 000 00000
                        Reset counter: 229
                        Hex Value: 0x0000
                        Voltage: 0.00 V
                        Bin. Bits: 00011111
                        Count: 227
                        Hex Value: 0x0000
                        Reset counter: 229
                        Hex Value: 0x0000
                        Voltage: 0.00 V
                        Bin. Bits: 00011111
                        Count: 149
                        Hex Value: 0x0000
    00810 - Sensor 1/2 for Brake Pressure
                        Reset counter: 229
       Part No SW: 5K0 907 044 AJ    HW: 5K0 907 044 AJ
       Component: Climatronic   130 0303
       Coding: 0000000000
       ASAM Dataset: EV_Climatronic A01001
       VCID: 73EF9D86DA209ED2D8-8026
       Revision: 00H54000    Serial number: 00000008888321
       Coding: E1840F8B00041A0047970F00170000000008FF475C40017C170000000000
       Shop #: WSC 05124 000 08193
       VCID: 336F5D8652A0DED218-8066
       Subsystem 1 - Part No: 3C8 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer 170908 022  0602
       Coding: 00046997
       Shop #: WSC 05124
       Component: RLS     061008 054  0402
       Coding: 00209133
       Shop #: WSC 05124
       Part No SW: 3C8 919 475     HW: 3C8 919 475
       Component: PARKHILFE 8K  H07 0007
       Revision: --------    Serial number: 97540827303145
       Coding: 100001
       VCID: 71E3978EA83CACC22A-8024
       Part No SW: 3C0 907 376     HW: 3C0 907 376
       Component: DAEMPFUNGS-SG H07 0069
       Revision: 00000000    Serial number: 29090802190001
       Coding: 010180
       VCID: 66C9F4D291F27B7A4F-8032
    03264 - Functionalty Shut Off
                000 -  -  - Intermittent
                        Fault Frequency: 11
                        Reset counter: 254
                        Mileage: 104543 km
                        Date: 2013.03.22
                        Time: 00:59:33
                        Error Code: 9
                        Bin. Bits: 00000000
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 212
                        Mileage: 104543 km
                        Date: 2013.03.22
                        Time: 00:59:33
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 229
                        Mileage: 104543 km
                        Date: 2013.03.22
                        Time: 00:59:33
                        Bin. Bits: 00000000 00001110
    03262 - Comfort Restriction
                        Fault Frequency: 37
                        Reset counter: 229
                        Mileage: 104543 km
                        Date: 2013.03.22
                        Time: 04:48:56
                        Error Code: 2
                        Bin. Bits: 00000000
       Part No SW: 5N0 959 655 A    HW: 5N0 959 655 A
       Component: J234__301 VW10 HI   1815
       Revision: 19013000    Serial number: 0039DPKL3ZLL
       Coding: 0012337
       VCID: 3B7F75A67AF01692C0-806E
       Subsystem 1 - Serial number: 6333FTS655882598
       Subsystem 2 - Serial number: 6343FTS606522568
       Subsystem 3 - Serial number: 6353ETS6PL44VVNR
       Subsystem 4 - Serial number: 6363ETS60BA7VVNR
    Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
       Part No SW: 3C0 953 549 AJ    HW: 3C0 953 549 AJ
       Component: J0527               0025
       Revision: 00030000    Serial number: 3C5953507BN
       Coding: 0000501
       Shop #: WSC 05311 000 08193
       VCID: 74ED9E9A172E99EAC1-8020
       Subsystem 1 - Part No: 3C8 959 537   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAP   H2˙ 0021
       Coding: 00000226
       Part No SW: 3C8 920 970     HW: 3C8 920 970
       Component: KOMBI         H19 0023
       Coding: 440F00
       Shop #: WSC 05314 115 00000
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
       VCID: 69D3FFEE88EC540262-803C
       Part No SW: 3C0 907 530 J    HW: 3C0 907 951
       Component: J533__Gateway   H13 0152
       Revision:   H13       Serial number: 2900R089138336
       Coding: F9A87F06000203009003
       VCID: 2855BAEA9B66AD0ABD-807C
       Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
       Component:    IMMO         042 0383
       Revision: 00042000    Serial number: VWZCZ000000000
       VCID: 39736FAE70CC2482D2-806C
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
       Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
       Component: J386  TUER-SG FT    1534
       Revision: 71009005    Serial number: 00000750488825
       Coding: 0000693
       VCID: 4085024A1316754A95-8014
                        Fault Status: 00100101
                        Reset counter: 254
       Part No: 1K0 909 144 C
       Component: EPS_ZFLS Kl. 205    2301
       Revision: 00H15000
       VCID: 2A5140E2856A9F1AAB-807E
       Component:    KSG PQ46 ELV 042 0472
       Coding: 01910A0001860E763604941570085FCE107C01
    Address 4F: Centr. Electr. II (J533_)       Labels:. 1K0-907-532.clb
       Part No SW: 1K0 907 532     HW: 3C0 907 951
       Revision: --------    Serial number: 2900R089138336
       Coding: 01030100
       Subsystem 1 - Part No SW: 6R0 959 591     HW: 6R0 959 591
       Component: J245  H04 0052
       Serial number: 837500024040
       Coding: 000006
       Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
       Component: J387  TUER-SG BT    1534
       Revision: 71009005    Serial number: 00000063988822
       Coding: 0000692
       VCID: 4183074E181C7C429A-8014
       Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
       Component: J540 EPB3  VW-10498 0003
       Revision:   009       Serial number: 00000000149356
       Coding: 0010000
                        Fault Status: 11111101
                        Reset counter: 229
                        Mileage: 104543 km
                        Date: 2013.03.22
                        Time: 01:00:14
                        Voltage: 13.30 V
                        Count: 71
                        Hex Value: 0x1240
                        Hex Value: 0x0001
                        Hex Value: 0x0101
       Part No SW: 3C8 035 195     HW: 3C8 035 195
       Component: Radio RCD510  036 0130
       Revision: 00000001    Serial number: VWZ1Z3H3361405
       Coding: 0500040004
       VCID: 65CBF3DE6CF4706246-8030
       Part No SW: 3C8 959 703 B    HW: 1K0 959 795 Q
       Component: J388   TUER-SG HL   0309
       Revision: 43004101    Serial number: 00000000624119
       Coding: 0000144
       VCID: 3163578EA8BCECC26A-8064
       Part No SW: 3C8 959 704 B    HW: 1K0 959 794 Q
       Component: J388   TUER-SG HR   0309
       Revision: 43004101    Serial number: 00000000604052
       Coding: 0000144
       VCID: 32615882ADBAD7DA13-8066
    End-------------------------(Elapsed Time: 03:46)--------------------------
    Gateway Installation List:  3C0 907 530 J
  2. Likes Dana liked this post
  3. #2
    United States
    I'm not extremely confident the Engine/Trans configuration of the 03-ABS coding is correct however the RHD version of that coding is: 0003436
    If you don't receive any additional suggestions please try that. 17-Instruments and 19-CAN GW appear to be correctly coded for RHD and GB.
    Best,
    Dana
    0D6C | 0003436
    096C | 0002412
    Vehicle Identification No. WVWZZZ3CZ9E530832
    Model Passat CC PACC
    Date of production 14.10.2008
    Year 2009
    Sales type 3572L2
    Engine Code CAWB
    Transmission Code KNU
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PE Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation units/platform components 0DJ Vehicle class differentiation -350-
    Emission standard 0GG Emission standard EU4
    Trailer hitch 1D0 without trailer towing
    airbag 4UE driver and front passanger airbags
    Aktivkohlebehälter / Ottopartikelfilter 1E1 Activated carbon canister
    Tray areas package QE2 Storage compartment
    Aerials 8ZH Antenna for AM/FM reception, "diversity"
    Exterior mirror setting 6XN Exterior mirrors, power-adjustable/ separately heated
    Left exterior mirror 5SJ Left exterior mirror, convex
    Right exterior mirror 5RV Right exterior mirror, aspherical
    Drive type 1X0 Front-wheel drive
    "Multimedia"video/DVD/notebook connection 9WL Jack for external audio source
    Equipment levels A8F Sports equipment
    Brake type in rear 1KU Disc brakes in rear
    batteries J0L Battery 340 A (70 Ah)
    Brake type, front 1LH Disc brakes in front
    Beverage holders 4M6 Beverage holders
    Battery/alternator capacity NY2 Increased battery capacity
    Component part sets with country-specific design requirements B0N Component parts set, complying with vehicle type for Great Britain, various parts
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AT Electronic stability control (ESC)
    Owner's manuals 0VF Information kit in English
    Operating voltage 9Z0 Operating voltage 12 V
    Heated washer nozzles 9T0 Without heated washer nozzles
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A0 Without CD changer/CD player
    "Charism" 2H1 "drive select"
    Chrome package QJ3 Chrome package (version 2)
    General operating permit, alterations C01 Operating permit, alteration
    Roof rails/roof load rack 3S0 Without roof rails/roof load rack
    Roof insert/convertible top 3FG Glass roof
    Suspension system in rear 1JP Rear shock absorption
    Suspension system in front G61 Shock absorption in front
    Load-through hatch/ski bag 3X2 Load-through hatch
    Insert for the filling up of unleaded fuel/fuel type 2G1 Insert for the filling up of unleaded fuel
    Installation differentiation for components 0EN Installation differentiation for transmission MQ 350 -- vehicle components --
    Theft protection system 7AL Anti-theft alarm system, interior monitoring, backup horn and towing protection
    Inserts 5MD Decorative aluminum inserts
    Scuff plates 7M0 Plastic scuff plates in door apertures
    Park distance control 7X2 Park distance control in front and rear
    Electric interface for external use UF0 Without electric interface
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    fire extinguisher 6A0 without fire extinguisher
    Pedestrian protection VL1 Extended pedestrian protection measures
    Headlight activation 8K8 Low beam assistant with "Coming Home" function
    Parking brake UH2 Parking brake
    Alternators 8GU Alternator 140 A
    Transmission types/gearshift mechanisms 0G4 Cable gearshift
    Weight category rear axle 0YD Weight range 4 installation control only, no requirement forecast
    Weight category front axle L23 Suspension range 23 installation control only, no requirement forecast
    Base engine TQ2 4-cyl. petrol engine 2.0 l assembly 06J.B
    Tie down straps/net/pocket 6M0 Without tie down straps/net/pocket
    cruise control system 8T0 Without cruise control system (CCS)
    Garage door opener VC0 without Garage door opener
    Transmission specifications G0K 6-speed manual transmission
    Cruise control system and speed limiter 6Y9 without cruise control system
    Brackets 3P1 Bracket for first aid kit and warning triangle
    Rear seats 3NN Rear bench seat, not split, split backrest, folding
    Heating and air-conditioning system 9AK Climatronic with impact pressure control, CFC-free
    Headlamps 8BK Twin headlamps for driving on the left, with integrated high beam
    Customized installation FC0 Without individual installation
    Interior light in footwell 6T0 Without interior light in footwell
    Instrument clusters U5B Instrument insert, mph speedometer Great Britain
    Breakaway interior rearview mirror 4L6 Breakaway interior rearview mirror, auto-dimming
    headphone connection, rear 8MA no headphone connection in rear
    Body style K8C Coupe
    Luggage compartment floor covering 6SE Flat needle-punched trunk floor covering
    Cassette and CD storage unit 4W0 without cassette / CD tray
    Electronic map cooling system QS0 Without electronic map cooling system
    Child seats QA0 without child seat
    Climatic zones 0Y1 Standard climatic zones
    Compass/road sign display QR0 Without compass/road sign display/ dynamic road sign display
    Seat ventilation/massage seat 4D0 Without seat ventilation/massage seat
    headrest for seat, rear 3Q1 headrest for seat, rear
    Fuel quantity for initial filling 1Z2 Increase in initial standard fuel filling
    Fuel systems 1A2 Fuel system for SI engine with direct injection (FSI)
    Body measures 5C0 Without special body measures
    Radiator grille 6KJ Radiator grille with chrome-plated strip
    Rear license plate bracket 6P1 Rear license plate carrier (ECE)
    Front license plate bracket 6W1 Front license plate carrier (large)
    Paint preservative/transit coating 5K0 Without surface protection, with additional transit coating
    Paint coating FB0 standard paint coating
    Rear cargo area 3GA Without luggage compartment floor
    Country codes FE0 Without country code (no DVD player in vehicle)
    Steering system arrangement L0R Right-hand drive
    Reading lamp 8S7 2 reading lights in front
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Backrest release 3H0 Without backrest release for front seats
    Load edge protection 2P1 Plastic loading edge protection
    Lumbar support 7P8 Electrically adjustable lumbar support for right front seat
    steering wheels 2PP Leather-wrapped multi-function steering wheel
    Speaker installation 8RM 8 speakers (passive)
    Headlight range control 8Q1 Headlight range control
    Center armrest 6E3 Front center armrest
    Multi-function display/trip computer 9Q5 Multi-function display with control
    center console 3D5 center console
    Engine cooling 8Z5 not hot country
    Engine specifications D2L 4-cylinder petrol engine 2.0 L/147 KW (16 V) Turbo FSI, homogeneous Basic engine is: T59/T61/TQ2/TU2/TD6/TN6
    Left vanity mirror 4SU Vanity mirror, left, illuminated
    Right vanity mirror 4TU Vanity mirror, right, illuminated
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TD Rear fog light for driving on the left
    Front fog lamp/additional headlamp 8WD Integrated front fog light
    Hubcaps 1NL Trims for alloy wheels
    Wheels C9T Alloy wheels 8J x 18
    Radios 8AI Radio "RCD510 MP3"
    Smoker's/non-smoker's package 9JA Non smoker version
    Tire pressure monitoring system 7K6 Tire pressure monitoring system
    tire H03 Tires 235/40 R18 95W (polymer coating)
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G3 Alloy spare wheel with original equipment tires
    Restraint systems, front 3QT 3-point seat belts in front, with tensioner and height adjustment
    PHK Air-conditioning package
    PJ5 "Interlagos" painted in Sterling Silver 4 alloy wheels 8J x 18 tires 235/40 R18
    PN8 Decorative inserts "Brushed Aluminum"
    RHC
    Side airbag 4X3 Side airbag in front, with curtain airbag
    Gearshift knob/handle 6Q2 Gearshift knob/handle in leather
    Special labels/plates 0SS Labels in English and French
    Tail lamp assemblies 8SA Rear combination lamp, standard design
    Locking mechanism for boot lid/cover rear 4E2 Tailgate/trunk lid release from inside (electrically)
    Front seat, left 3TG Sports comfort seat in front, left
    Front seat, right 3SG Sports comfort seat, front, right
    Seat belt check 9P1 Seat belt reminder, electric contact in buckle
    Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE label
    seat covers N2N Seat trim covers in woven fabric
    Seat adjustment 3L3 Manual height adjustment for front seats
    seat heater 4A0 without seat heater
    Side lights 7R3 Side turn signal lights (white)
    Audio-response system/voice control QH0 without voice control
    Lane change assist/lane keeping system 7Y0 no lane change assistant
    Side and rear windows 4KF heat protective glass for door, side and rear windows, darkened from b-pillar
    Protective side molding 4B4 Protective side molding
    Sunroof roller blind for rear/side windows 3Y2 Power-operated roll-up sunshade for rear window
    power outlet 7B3 12-volt outlet(s)
    Bumper 2JC Comfort bumpers
    Headlamp washer system 8X0 Without headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N3 intermittent windscreen wiper with rain sensor
    Special approval measures 3M0 Without special measures
    Nameplate set 0NB Nameplate set in basic version
    Special alarm systems 9A0 Without taxi alarm system
    Mass damper for steering wheels 1Q0 steering wheel without balance weight
    Door and lid locking system 4K3 Central locking w/ radio remote control, interior controls and SAFELOCK
    Type approval countries/countries with special requirements B09 Type approval country GB/Northern Ireland
    Carrier frequency for remote control 5D1 Carrier frequency 433.92 to 434.42 Mhz
    Partition 3CA without partition
    Transit coating NT0 Transit coating (type 1)
    Door and side trim panels 3LC Door and side trim panel in foam film and woven fabric
    TV reception/digital radio reception QV0 without TV/digital radio reception
    Assembly parts for engine (drive bearing) 1VG Assembly part for 4-cyl. engine
    Identification plates 1EX Special identification plate for EU
    Delivery equipment 2A0 Without delivery equipment
    First aid kit / warning triangle 1T2 warning triangle
    Two-way radio installation preparation 9D0 without prepared for two way radio system
    Preparation for rotating beacon/siren combination 9F0 Without preparation for rotating beacon/siren combination
    Telephone / telematics 9W0 Without car phone preparation/ installation
    Additional warning lights 9TC Additional retro-reflectors (door area)
    LongLife Service Regime QG1 LongLife Service Regime
    Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
    Windshield Glass 4GF Windshield in heat-insulating glass
    Second battery/battery installation 8FA without 2nd battery
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Front and rear floor mats
    Decorative trims 4ZB Bright decorative trims
    Additional child seat anchors 3B4 Child seat anchors for child seat system ISOFIX
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
  4. Likes Uwe, Jack@European_Parts liked this post
  5. #3
    Nov 2016
    Do you not have a previous auto scan to compare to?
  6. #4
    United States
    Quote Originally Posted by rhinopower View Post
    I don't believe they do. This is a shop (i.e. that's a customer's car rather than a personal vehicle) and I believe it was a first time customer so they don't have historical scans.
    My concern is based on the fact that we don't have a single (good baseline) scan from a Passat or CC with the ABS module coded to 0002412 -or- 0003436. That's probably because all of our 2009 CAWB engine code scans are from FWD automatic 09G transmissions rather than FWD 6-speed manuals. Hopefully someone can correct me if HEX 6C doesn't = 2009: 2.0l TFSI CAWB [PR-TQ2] & 6-Speed Manual [PR-G0K+0EN].
    Edit, after further review I am reasonably confident the coding suggestion in post #2 is correct.
    Nov 2018
    2009 Passat cc Manual Gearbox With Auto Hold Hand Brake
    The coding from DANA worked for all control units except the auto hold parking brake, I have changed the code to 0000057 but we still have a flashing parking brake light in the instrument cluster. the only other faults are in the suspension system (14) 03262 comfort restriction and 00776 level control system sensor.
    Friday,16,November,2018,09:45:38:38326
    Mileage: 104820km-65132mi   Repair Order:
    VIN: WVWZZZ3CZ9E530832   Mileage: 104820km-65132miles
       Coding: 0003436
       Coding: 0000000000
       Coding: 00046997
       Shop #: WSC 05124
       Coding: 00209133
       Shop #: WSC 05124
       Coding: 100001
       Coding: 010180
                        Fault Frequency: 19
                        Reset counter: 245
                        Mileage: 104764 km
                        Date: 2013.04.06
                        Time: 01:07:29
                        Error Code: 2
                        Bin. Bits: 00000000
                        Reset counter: 242
                        Mileage: 104764 km
                        Date: 2013.04.06
                        Time: 01:07:29
       Coding: 0012337
       Coding: 0000501
       Coding: 00000226
       Coding: 440F00
       Coding: 0000693
       Component: EPS_ZFLS Kl. 206    2301
       Revision: 00H15000
       Coding: 01030100
       Coding: 000006
       Coding: 0000692
       Coding: 0000057
       Coding: 0500040004
       Coding: 0000144
       Coding: 0000144
    End-------------------------(Elapsed Time: 03:47)--------------------------
    Hope you can Help
    Andy Taylor
    HQ
    So what is up with this? Locate the T4va connector for the G78, any visual issues with the wiring harness that you can see? Unplug T4va connector, terminals clean and shiny? On the T4va connector, /1 + /3 should be a 5V reference signal with ignition on. /2 is data back to the Electronics Damping Control Module (J250), T47a/26. /4 is empty.
    If the electrical paths for the G78 sensor are to factory design, replace said sensor.
    Jef
  9. Likes Dana, Jack@European_Parts liked this post
  10. #7
    United States
    In reply to the email we received, the car has RR-Code UH2 Parking brake so the coding of 0000057 = Parking Brake with Auto-Hold (Rest of World / PR-UH2) in the 53-Parking brake module looks good to me.
    I agree with Jef regarding the electrical G78 DTC in 14-Susp. Elect. Resolving that problem may allow you to clear the one related to Comfort Restriction.
  11. Likes Jack@European_Parts liked this post
  12. #8
    Davey and Goliath agree!
  13. #9
    Nov 2018
    hello
    Thanks for all your help to date.
    The wiring and circuit values for the left front sensor are good, I will fit the new part when it arrives, do we think this will cure the flashing parking brake light.
    Andy T
  14. #10
    HQ
    I suspect it will, but won't know for sure until you give us an update.
    Jef
