Hope you can help me with this Passat, the vehicle history to date:-
Standard vehicle no mods Right hand drive
Vehicle working fine previous days/weeks
Locksmith due next day to supply and code new spare key
It was a cold morning the battery was discharged. car was started with a jump pack and road tested fine before key coding
A new key coded the alarm sounded and five lights on dash abs eps hand brake comfort / sport
new battery fitted
I have searched the forum and coded the abs unit. The codes before this read are stored in a pdf the faults below are after the coding of the abs unit
Thanks
Andy Taylor
new battery fitted
Thanks
Andy Taylor
Wednesday,07,November,2018,16:10:07:38326
VCDS Version: 18.9.0.2
VIN: WVWZZZ3CZ9E530832 License Plate: MARK
Mileage: 104680km-65045mi Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 10 14 15 16 17 19 25 42 44 46 4F 52 53 56 62 72
VIN: WVWZZZ3CZ9E530832 Mileage: 104680km-65045miles
Address 01: Engine (CAW) Labels:. 06J-906-026-CAW.clb
Part No SW: 06J 906 026 D HW: 06J 906 026 D
Component: MED17.5 2424
Revision: A7H06--- Serial number: VWZCZ000000000
Coding: 0404000318070060
Shop #: WSC 05314 000 00000
VCID: 2B5F45E68A90861250-807E
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 000 - - Intermittent
Fault Frequency: 18
Mileage: 104543 km
Date: 2013.03.22
Time: 19:59:25
Load: 0.0 %
Temperature: 54.0°C
Temperature: 26.0°C
Absolute Pres.: 980.0 mbar
Voltage: 12.319 V
Mileage: 104543 km
Date: 2013.03.22
Time: 19:59:25
Load: 0.0 %
Temperature: 54.0°C
Temperature: 26.0°C
Voltage: 12.319 V
U1017 - 000 - - MIL ON
Fault Status: 11100000
Mileage: 104543 km
Date: 2013.03.22
Time: 19:59:30
Load: 0.0 %
Temperature: 54.0°C
Temperature: 26.0°C
Voltage: 12.319 V
001393 - Brake Switch (F)
P0571 - 000 - Implausible Signal - MIL ON
Load: 0.0 %
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0000 0001
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 P HW: 3C0 614 109 P
Component: J104 C4 440 V2 0011
Revision: --025--- Serial number: 00000786190962
Coding: 0002412
Shop #: WSC 05311 000 00000
Reset counter: 229
Hex Value: 0x0000
Voltage: 0.00 V
Bin. Bits: 00011111
Count: 227
Hex Value: 0x0000
Reset counter: 229
Hex Value: 0x0000
Voltage: 0.00 V
Bin. Bits: 00011111
Count: 149
Hex Value: 0x0000
Reset counter: 229
Part No SW: 5K0 907 044 AJ HW: 5K0 907 044 AJ
Component: Climatronic 130 0303
Coding: 0000000000
ASAM Dataset: EV_Climatronic A01001
VCID: 73EF9D86DA209ED2D8-8026
Revision: 00H54000 Serial number: 00000008888321
Coding: E1840F8B00041A0047970F00170000000008FF475C40017C170000000000
Shop #: WSC 05124 000 08193
VCID: 336F5D8652A0DED218-8066
Subsystem 1 - Part No: 3C8 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 170908 022 0602
Coding: 00046997
Shop #: WSC 05124
Component: RLS 061008 054 0402
Coding: 00209133
Shop #: WSC 05124
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 3C8 919 475 HW: 3C8 919 475
Component: PARKHILFE 8K H07 0007
Revision: -------- Serial number: 97540827303145
Coding: 100001
VCID: 71E3978EA83CACC22A-8024
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0069
Revision: 00000000 Serial number: 29090802190001
Coding: 010180
VCID: 66C9F4D291F27B7A4F-8032
03264 - Functionalty Shut Off
Fault Frequency: 11
Reset counter: 254
Mileage: 104543 km
Date: 2013.03.22
Time: 00:59:33
Error Code: 9
Bin. Bits: 00000000
00776 - Level Control System Sensor; Left Front (G78)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 212
Mileage: 104543 km
Date: 2013.03.22
Time: 00:59:33
01316 - ABS Control Module
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 229
Mileage: 104543 km
Date: 2013.03.22
Time: 00:59:33
Bin. Bits: 00000000 00001110
03262 - Comfort Restriction
Fault Frequency: 37
Reset counter: 229
Mileage: 104543 km
Date: 2013.03.22
Time: 04:48:56
Error Code: 2
Bin. Bits: 00000000
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__301 VW10 HI 1815
Revision: 19013000 Serial number: 0039DPKL3ZLL
Coding: 0012337
VCID: 3B7F75A67AF01692C0-806E
Subsystem 1 - Serial number: 6333FTS655882598
Subsystem 2 - Serial number: 6343FTS606522568
Subsystem 3 - Serial number: 6353ETS6PL44VVNR
Subsystem 4 - Serial number: 6363ETS60BA7VVNR
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AJ HW: 3C0 953 549 AJ
Component: J0527 0025
Revision: 00030000 Serial number: 3C5953507BN
Coding: 0000501
Shop #: WSC 05311 000 08193
VCID: 74ED9E9A172E99EAC1-8020
Subsystem 1 - Part No: 3C8 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H2ÿ 0021
Coding: 00000226
Part No SW: 3C8 920 970 HW: 3C8 920 970
Component: KOMBI H19 0023
Coding: 440F00
Shop #: WSC 05314 115 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
VCID: 69D3FFEE88EC540262-803C
Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 J HW: 3C0 907 951
Component: J533__Gateway H13 0152
Revision: H13 Serial number: 2900R089138336
Coding: F9A87F06000203009003
VCID: 2855BAEA9B66AD0ABD-807C
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
VCID: 39736FAE70CC2482D2-806C
Component: ELV 027 0380
3C0905861G ELV 027 0380
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1534
Revision: 71009005 Serial number: 00000750488825
Coding: 0000693
VCID: 4085024A1316754A95-8014
Fault Status: 00100101
Reset counter: 254
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 205 2301
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2A5140E2856A9F1AAB-807E
Component: KSG PQ46 ELV 042 0472
Coding: 01910A0001860E763604941570085FCE107C01
Component: Neigungssensor 004 0611
Address 4F: Centr. Electr. II (J533_) Labels:. 1K0-907-532.clb
Part No SW: 1K0 907 532 HW: 3C0 907 951
Revision: -------- Serial number: 2900R089138336
Coding: 01030100
Subsystem 1 - Part No SW: 6R0 959 591 HW: 6R0 959 591
Component: J245 H04 0052
Serial number: 837500024040
Coding: 000006
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1534
Revision: 71009005 Serial number: 00000063988822
Coding: 0000692
VCID: 4183074E181C7C429A-8014
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 009 Serial number: 00000000149356
Coding: 0010000
Fault Status: 11111101
Reset counter: 229
Mileage: 104543 km
Date: 2013.03.22
Time: 01:00:14
Voltage: 13.30 V
Count: 71
Hex Value: 0x1240
Hex Value: 0x0001
Hex Value: 0x0101
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 HW: 3C8 035 195
Component: Radio RCD510 036 0130
Revision: 00000001 Serial number: VWZ1Z3H3361405
Coding: 0500040004
VCID: 65CBF3DE6CF4706246-8030
Part No SW: 3C8 959 703 B HW: 1K0 959 795 Q
Component: J388 TUER-SG HL 0309
Revision: 43004101 Serial number: 00000000624119
Coding: 0000144
VCID: 3163578EA8BCECC26A-8064
Part No SW: 3C8 959 704 B HW: 1K0 959 794 Q
Component: J388 TUER-SG HR 0309
Revision: 43004101 Serial number: 00000000604052
Coding: 0000144
VCID: 32615882ADBAD7DA13-8066
End-------------------------(Elapsed Time: 03:46)--------------------------
Gateway Installation List: 3C0 907 530 J
