- Joined
- May 24, 2018
- Messages
- 43
- Reaction score
- 12
- Location
- Czech Republic
- VCDS Serial number
- C?ID=337474
Hello, after 5F unit change (VW dealer) I got the mistake, see in my full scan. I went through all 4 EX BUS that have to be active, all right.
Any idea, what kind of mistake I have?
Thank you!
Lukas
Thank you!
Lukas
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 3C 42 44 52 55 5F
69 6C A5 CA CF
VIN: WVWZZZ3CZFP4xxxxx Mileage: 170826km-106146miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 ET HW: 04L 907 309 R
Component: R4 2.0l TDI X21 1990
Revision: B5X21---
Coding: 011D001A04741D083000
Shop #: WSC 10000 444 00002
ASAM Dataset: EV_ECM20TDI01104L906026ET 002002
ROD: EV_ECM20TDI01104L906026FL.rod
VCID: 005870D10A84FE679E5-8054
Part No SW: 0D9 300 041 A HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4801
Revision: 05853104 Serial number: TFK01411260629
Shop #: WSC 00028 028 00024
ROD: EV_TCMDQ250021.rod
VCID: 16743689780060D7549-8042
Part No SW: 3Q0 907 379 H HW: 3Q0 907 379 H
Component: ESC H34 0906
Revision: 00000000 Serial number: 42904000000356
Coding: 0FEC6A8F34200B730779060641C849F0562CD0E0608292F11862F078CAA9
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034001
VCID: 3FDAB32D37FA419FA7F-806A
Part No SW: 3Q0 959 435 HW: 3Q0 959 435
Component: VWKESSYMQB 023 0522
Revision: 00023000 Serial number: 0355060936
Coding: 000F0F0703
ASAM Dataset: EV_KessyHellaMQBAB 004027
VCID: 77AA1B0D5F4AB9DFAFF-8022
Part No SW: 5G0 907 044 CQ HW: 5G0 907 044 CQ
Component: Climatronic H04 1801
Revision: 00001K10
Coding: 12020124604101012115505001101802
Shop #: WSC 07790 995 07790
ROD: EV_ACClimaBHBVW37X_006_VW48.rod
VCID: 78A818315254B6A7A65-802C
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 086 BD HW: 5Q0 937 086 BD
Component: BCM PQ37BOSCH 028 0146
Revision: -------- Serial number: 86580112141660
Coding: 00971E46C2410AFF4BE44004001C07081C80000000000000000000000000
ROD: EV_BCMBOSCH_014.rod
VCID: 7DA609257D76938FF53-8028
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 141124 042 0607
Serial number: 141201070426
Coding: 0F4DFD
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y14M12D11H14M52S31
Coding: 06A8DD
Light switch:
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 17 10 2014 00001092
Sun Roof:
Part No SW: 5Q0 919 294 H HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0053
Revision: -------- Serial number: 39391433501067
Coding: 0071257111
ROD: EV_EPHVA18AU3700000_002_VW48.rod
VCID: 40D8B0D14A043E67DE5-8014
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 C HW: 3Q0 907 572 A
Component: ACC BOSCH MQB H04 0195
Coding: B21F7F7915FFFF28949C807D
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3536D10505C68BCF7D3-8060
Part No SW: 3Q0 959 655 AE HW: 3Q0 959 655 AE
Component: Airbag VW20 012 0195
Revision: -------- Serial number: 003R1PP7RFCD
Coding: 98FCC0C0008000005C5400CC000800000065
Shop #: WSC 00028 028 00012
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 015E75D5018EF76F91B-8054
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 105 1032
Serial number: 3G1857705E0328O00083
Coding: 80000A
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 105 1032
Serial number: 3G1857706E0328O00396
Coding: 80000A
Subsystem 3 - Part No SW: ----------- HW: 454 000 112 14
Serial number: 3576U0000001B4691210
Subsystem 4 - Part No SW: ----------- HW: 454 000 112 14
Serial number: 3586U000000FA391C11I
Subsystem 5 - Part No SW: ----------- HW: 454 800 312 14
Component: SideSensor_Dr 111 0148
Serial number: 3516R73374B05000000$
Subsystem 6 - Part No SW: ----------- HW: 454 800 312 14
Component: SideSensor_Pr 111 0148
Serial number: 3526R5F224B050000001
Subsystem 7 - Part No SW: ----------- HW: 454 800 112 14
Component: FrontSensor_D 114 0149
Serial number: 3556V14FC3F05000000J
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 3Q0 953 521 R HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20141127500777
Coding: 0C10
ROD: EV_SMLSVALEOMQB.rod
Part No SW: 3G0 920 751 HW: 3G0 920 751
Component: KOMBI 308 4311
Coding: 0BF512186F8C000808887E2B5002000800000000
VCID: 629C5A59E4C84C77E81-8036
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 C HW: 5Q0 963 272 C
Component: STH-MQB 006 0069
Coding: 9309
VCID: 3634D60918C080D7749-8062
Subsystem 1 - Part No SW: 5Q0 963 513 HW: 5Q0 963 513
Component: R149 T91-LIN 003 0301
Serial number: 00000000000001027933
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 29111410800846
Coding: 0B0300344F017300EF00025E1C0F00010001070000000000000000000000
ROD: EV_GatewConti_011_VW48.rod
VCID: 72BC2A193428DCF7981-8026
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0040
Serial number: 27140003062100094494
Coding: 2DFFFF
Subsystem 3 - Part No SW: 3Q0 915 181 A HW: 3Q0 915 181 A
Component: J367-BDMHella H04 8050
Serial number: 7498745203
Power Converter DC AC:
Subsystem 4 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: WECHSELRICHTE H54 0033
Serial number: 0015860
Analog clock:
Subsystem 5 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 111 1004
Serial number: 0212201400010310
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0031
Serial number: 14000249651010
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71BE2515312EE7EF61B-8024
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 E HW: 3Q0 907 566
Component: MRR1Rear H16 0510
Revision: --------
Coding: 16C000
VCID: 3A2CC2392CD864B7901-806E
Part No SW: 5Q4 959 593 D HW: 5Q4 959 593 B
Component: TSG FS 009 0016
Serial number: 0000127482581
Coding: 00370B205800028000001000
VCID: 46D4A6C968201057E49-8012
Subsystem 1 - Part No SW: 5Q4 959 812 E HW: 5Q4 959 812 E Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000000535055
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 K HW: 5Q0 909 143 E
Component: MQB_PP_APA 203 2033
Revision: 00000000 Serial number: 0000092408
Coding: 01000011005000
ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
ROD: EV_SteerAssisVWBSMQBA_008.rod
VCID: 3B22C73D23E25DBF8B7-806E
Part No SW: 5Q4 959 592 C HW: 5Q4 959 592 B
Component: TSG BFS 009 0015
Serial number: 0000128541534
Coding: 003501205C00028000801100
VCID: 44D0BCC15E1C2247FAD-8010
Subsystem 1 - Part No SW: 5Q4 959 811 E HW: 5Q4 959 811 E Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000000555770
Coding: 090000
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0110
Coding: 039A00004F210200
ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
Subsystem 1 - Part No SW: 7PP 941 572 A HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 0001
Coding: E02400
Subsystem 2 - Part No SW: 7PP 941 572 A HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 0001
Coding: E02400
Subsystem 3 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0003
Coding: E02400
Subsystem 4 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0003
Coding: E02400
Part No SW: 3Q0 035 874 B HW: 3Q0 035 874 B
Component: MU-S-ND-ER 840 0761
Coding: 02840201FF0000005141110100880A001F0504C4012001008F
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 313EE515F1AEA7EF21B-8064
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZHT3233946
Subsystem 2 - Part No SW: 5NA 919 866 HW: -----------
Component: ECE1 2018/19 --- 1030
1552 - Expanded Bus Activity Active
U1104 00 [009] - -
Reset counter: 115
Mileage: 170826 km
Date: 2018.11.11
Time: 18:42:08
Voltage terminal 30: 12.2 V
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 D HW: 5Q0 907 383 D
Component: Anhaenger H14 0137
Revision: 8A001001 Serial number: 0354678309
Coding: 0100000202000000
VCID: 3828D83112D476A7665-806C
Address 6C: Back-up Cam. (J123) Labels:* None
Part No SW: 5Q0 907 556 HW: 5Q0 907 556
Component: TopView H11 0327
Serial number: C854706JG000070
Coding: 01840201E30F200000204414
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 003011
ROD: EV_CamSysRVAV2ARCE2MQBAB_003_VW37.rod
VCID: 76B416095840C0D7B49-8022
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 653 E HW: 3Q0 980 653
Component: MQB_B_MFK H08 0121
Serial number: 26111411P10378
Coding: 01040802050004010022235F814EA5009B00A2200140
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 B HW: 4M0 907 594
Component: SAD_STG_1 009 0002
Coding: 208040748202
ASAM Dataset: EV_SunRoofCONTIAU736 004008
ROD: EV_SunRoofCONTIAU736_004.rod
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 E HW: 3Q0 907 590
Revision: --------
Coding: 16C000
VCID: 372ADB0D1FCA79DF6FF-8062
